Honda Accord Tires and Wheels
Honda dealer says replacement tires must be the Micheliin designed specially for the 2003 Honda Accord V-6 or handling will suffer.
Sounds strange. Those tires are $265 ea. I need 4 and invite comments/suggestions re a less exspensive solution. Many thanks!
Try any of the following:
www.tirerack.com
www.discounttire.com
I have never heard of Honda making weights! I have always gone to a tire store, picked out tires based on my needs and the ratings of the tires (traction, temperature, wear, etc.) and will continue to do so!
That doesn't mean that the weight used by a tire shop aren't just as good.
Personally, I like the stick on weights and have them applied to the inside only for a neater appearance.
Contrary to what mama always told me, neatness doesn't always count. If you have a smooth rolling Accord at any speed with balancing weights only applied to the inside area of the wheels, then pat yourself on the shoulder and accept my sincere "Attaboy" for being one lucky son of a gun. Due to inevitable manufacturing inconsistencies with belt positioning irregularities, and unpredictable flow of gooey casing and tread compounding during molding, tires often end up needing to be balanced in two planes.
But on vehicles such as my Passat, that's the only way to balance them. Weights cannot be applied to the outside of the alloys.
Also go over Tire Rack and put your tire size and speed rating to see what tire come up. Then go to a local tire shop and purchase the tires. Most tire shops can give you a feel if it is ok to go to an H rated tire. I imagine the ride will be a bit softer. You may not be able to tell the difference since H rated tires a pretty firm. I would go with H rated. But talk to your local tire shop.
Yokohoma Avid rated well. Tires do not need to be Michelin.
The Yokahama Avid's sound fine except for their poor performance in snow which is an important consideration in the NE.
I did mention the H but was told--again by dealer one-- that only the same tire would suffice.
I will continue trying, because I do need to replace the OEs.
Thanks for your thoughts.
Unless there is a sale at a local tire dealer, you should make out better financially by purchasing tires from tirerack or the internet sales site for discount tire. Good luck in your tire search. Ralph
I would also ask the eBay seller for the factory Michelins if they came with the rims; I've tried Bridgestone, Falken and Michelin and Michelin has been the best all-around choice for me in terms of treadlife, quietness and traction (in the southeast, at least).
I have a 2000 Accord EXV6 Coupe, and have been doing the same research via ConsumerReports and TireRack. Consensus seems to be that since Honda 'recommends' V-rated, that is what should be on the car. Although I'll never even drive as fast as the speed rating of an H-rated, I've basically been advised that the car was designed with certain characteristics, e.g. suspension, etc., and that handling may suffer even at regular driving speeds with non-V-rated tires.
My research has determined a)that most of the H and V rated tires in the current CR report are unavailable in the 205/60/16 size I need, and b)that many of the ones that are available are sub-par for my needs. I too live in the Northeast (NJ), and want/need tires that will not only perform on dry pavement but also wet pavement and occassional snow.
I've researched the following tires available in the required size and V speed rating:
Michelin Energy MXV4 Plus
Yokohama Avid V4S
Sumitomo HTR+
Pirelli P6
Bridgestone Turanza LS-V
The Pirelli gets poor/terrible reviews from sites like TireRack and Epinions.
The Yokohama, while it gets high marks for dry and wet handling, is rated poorly for snow handling, something that I can not afford to give up.
I'm leaning towards the Bridgestone Turanza LS-V for a couple reasons. First, it's cheaper than the Michelin, about $120/tire at TireRack vs. $160/tire, ergo 4 tires for the price of 3. Second, it's not a Michelin. I was very displeased with the OEM Michelin MXV4s that the Honda came with, and replaced them with Toyo Proxes within the first 20k miles. I liked the Toyos very much in most conditions, but as they wore their wet handling seemed to suffer.
I haven't yet discounted the Sumitomo HTR, and may also look into the Goodyear Eagle ResponsEdge. Unfortunately, I really like the Falken Ziex ZE512, the Goodyear Assurance TripleTred and the Continental ContiProContact, but alas, they are not available in the needed specs.
I hope this helps, and will let you know once my decision is made within the next few days. I want to get some miles on the new tires before the snow begins to fly.
If anyone has additional input, it is welcome!
Rich
They are easily as good as the Michelins, and cost less too. More grippy than my Goodyears in turns and more predictable on the interstate than either my Goodyear or my Michelins (which were prone to hop over expansion joints more readily than these, decreasing my stability at 70 MPH), although they are more aggressive (firmer) in the ride department. I love them though... My tires are stock size for my 4-cyl Accord of 1996, 185/65 - 15...cost was approx $490. The Michelins were over $600, and the Goodyears were cheapies (and it showed when driving them) at $320.
I know they are different types of tires (mine are an H rating) but they do great, rain or shine!
The ride seems a bit harder and I feel the imperfections in the road more, but I expect this will mellow out as the tires are broken in. Handling seems fine and they seem to grip the road well. I am particularly interesed in how they will do in rain and snow--although I am happy to wait for the later.
My tires needed replacment to pass inspection which expires at the end of the month so I could not wait for Tire Rack. Amazingly the difference in price between a tire shop in Manhattan and a Firestone Care Center on Long Island came to $100 per tire. And the tire dealer didn't have them in stock (2-3 week wait) whereas FCC had them in stock. I paid about $150 per tire and could have gotten Michelins at a similar price at Costco which is giving a $60 rebate in Michelins until early November.
Good luck with your search. I am delighted mine is over.
Bill
Keep doing your research. there are more tires out there. As someone mentioned, don't be afraid to buy them directly from Tire Rack.
Probably because they were charging $175 a whack and making a tremendous gross on them!!
As noted before, they are very sensitive to the road surface and each imperfection--the only negative so far.
Do you notice more road noise, and a rougher ride, than with the michelins?
I took a test drive yesterday. It seems to be a solid well built car. However the ride was not acceptable. On the smoothest of roads it felt as though the highway was corrugated. Does anyone know if this is built into the car or could it be the tires?
To herbert: Make sure you drive an LE or XLE, the SE model Camry will be rougher/sportier than the LE/XLE.
When bled down to the correct spec, the ride dramatically improves.
True enough, but I don't think he'll find it cushy enough to be happy, even running at 32 PSI. The Accord is made to be a sporty sedan, if not a sports-sedan. A Camry-like ride will probably make him really happy. I just can't see someone who likes how big GM sedans rode liking how a Honda rides. I drive an Accord (2 actually), and I like the balance of ride/handling, but it is certainly rough over old interstates in need of repair, especially when compared to cars like Camry and the Honda Odyssey minivan (the only real "smooth" cars I have been in lately to compare it to).
Instead of just scuffing my tires, which we've all done before, I heard the distinct sound of metal scraping against concrete. You guessed it. I ended up scraping the aluminum rim.
What's worse is this incident came shortly after an argument with my lovely bride. I believe her final words to me before I left for the store were something like "what goes around comes around." I guess I got what I deserve.
Anyway, can I have a body shop sand out the scrape or is it more cost effective to simply purchase a new rim? Thanks - Kelly
You can get like new refurbished rims from a number of companies that specialize in this kind of business.
http://www.wheelcollision.com/honda1.htm
http://www.handaaccessories.com/accord.html
A replacement tire being considered is the Kumho Ecsta ASX in 195/60VR15. It is listed as an ultra high performance all season tire. The kicker is they are listed for like $45/tire right now, or just less than half the cost of the Michelins. Kumho actually made the tires I used to use for track events a few years back, a DOT R-compound tire, so I am familiar with the brand.
I haven't tried it on my 04 sedan, but just looking, it appears a full size tire would not fit. (not enough height??)
I've come close to picking up a full size rim and tire, but doubt that it will fit. I guess I just got to get out there and give it a try.
Mrbill
I am wondering that myself. I will measure the tire, and check it with the wheel well tomorrow.
2006 Accord EX Wheel
Any help is greatly appreciated.
It looks like I'm going to beat the snow after all, and maybe in the spring I will be able to enjoy the handling.
