Visitor Agreement.
I do not have snow tires on my Prius. On the interstate, I reduce my speed about ten miles an hour under surrounding traffic most of the time for both safety and fuel economy. My fuel economy due to the low-resistance standard tires is 52 MPG summer and 48 MPG winter. My compromise is traveling a few minutes early to work, rather than rushing at dangerous speeds along curves that take at least thirty hits on the guardrail every winter within one mile of roadway.
If you are going off-roading in winter on forest service traces, then take a different vehicle than a Prius. You are going to need more clearance anyway. However, I have made it up mining road grades with a half foot of powder on ice, experiences some slippage, at slow speeds. I typically leave for work at 4:30 AM, when the roads are not plowed, but still get through because the idiots have not blocked the way yet. I have no place to store tires in my condo, so buying snow tires would put me in an awkward storage situation for six months of the year.
A good snow tire will be made with softer rubber, more tread resistance, and reduce fuel economy. If traction is your priority, then buy a winter tire. If you can be reasonable in driving behavior, you should not experience the need for a snow tire. The vehicles that I pass in the ditch are almost always all-wheel-drive sport utility vehicles operated by over-confident, ignorant, inexperienced, drunk, or hot-headed drivers.
I have been thinking for quite sometime that there was something wrong with the fuel gauge. Says I'm low but only let's me put ~$6.-$7 in.
Also, check Consumer Reports, which discusses the rating types for dry pavement tires, all-season, and winter snow tires. Ask a good dealership concerning your choices. The winter season tires will have softer rubber, wear more quickly, and can be studded. Check your local state laws concerning dates when studs must be off the roads because they are restricted due to destruction of pavement in some states. Your dealer should know about any restrictions.
We own a 2007 and live in Michigan and agree completely with our fellow New Yorkers that on ice and snow many a time we feel like "sitting" ducks just waiting for an accident to happen because of the TCS kicking in.
Anyone know?
http://www.greencarcongress.com/2009/02/bridgestone-int.html
Bridgestone Introduces LRR Ecopia EP100 Tire at Chicago Auto Show
11 February 2009
Bridgestone Americas Tire Operations (BTAO) officially launched the Ecopia EP100, a low rolling resistance tire which provides drivers with improved fuel economy without sacrificing wet handling performance.
The Ecopia tire line targets fuel efficient vehicles, including hybrids and electric vehicles and will be used in original equipment and replacement applications. The new Ecopia EP100 is the first aftermarket product in the Ecopia tire line for the North American market, and is a summer replacement tire fitment for popular fuel efficient, hybrid and electric vehicles including the Mini Cooper, Toyota Prius, Honda Civic Hybrid, Nissan Versa, Toyota Corolla and a selection of other conventional vehicles.
Available in H- and V-speed ratings, the Bridgestone Ecopia EP100 has a UTQG of 400AB and will be offered in six different sizes ranging from 14-16 inch. The tire will be available in March in the first phase of a two-phase rollout in 2009.
The Ecopia EP100 incorporates Bridgestone’s NanoPro-Tech materials technology which controls the interaction between polymers, filler materials and other rubber chemicals used in the manufacture of the tire. (Earlier post.)
Design elements in the Ecopia EP100 include 3D Cut Circumferential Ribs to help reduce irregular wear and lessen road noise. Consistent Surface Contact, through a special tread block design, improves wet and dry handling and reduces irregular wear. Interconnected Rib Blocks enhance wet performance and help reduce energy loss. High Angle Lateral Grooves are incorporated into the Ecopia EP100 to help avoid hydroplaning.
Bioman
If you can assure yourself you'll never scrape a curb, you can remove them without losing any functionality.
Thanks guys,
Bioman
In a wind tunnel on a dyno, MAYBE, but even then it doesn't seem to intuitively make sense. Let me know the next time you do any extended driving in those conditions
I recently bought a low mileage 2005 model that I have up in Utah (approaching snow time). The previous owner put a set of Big O's top of the line tires on it even though it only had 22000 miles on it.
I am curious how these tires will fair in winter driving... I have heard good things about the Michelin Hydro-Edge in snow and slush, and of course there are the pure winter tires like the Blizzak and Xice2.
I am quite curious as to what most of you folks do who live in the part of the country where there is that "white stuff."
My previous vehicle had AWD. I notice no less traction with my Prius. When I drove snowplow for CDOT, I usually had 20 vehicles in the ditch each shift on six percent grade in every snowstorm. I never had a problem with my vehicle. The people in the ditch were always driving at excessive speed for conditions. I climbed down an embankment to one car and felt for tread. There was none.
The disadvantage of using chains is that you can only travel a maximum of 35 MPH. That is why you will almost never see chains on a snowplow. They need to be able to drive faster than that to keep up with the storms. Now, I drive the county buses. Again, never chains. The buses need to travel at highway speed to maintain a schedule.
Studs are nice where state laws allow the use. Studs destroy roads. Only use them if you actually find a necessity for them. Parts of rural Idaho, for example, do not plow roads or salt down to pavement. However, my observations in Utah during a snowstorm were of excellent snowplow equipment, better than the equipment in Colorado.
Road conditions were outstanding. Therefore, I would not invest in anything but an All Season Radial. If that gives you actual trouble at speeds of 35 MPH in one of your snowstorms, then experiment with Dedicated Snow Tires ~ studs ~ and chains or socks.
When I went by the Big O tire store... to get information on the tires on my '05 Prius I asked them if they were something "special" for winter driving, but they said no it was just their top-of-the-line all season tire.
I have been considering purchasing an extra set of wheels and mounting a pair of Michelin's Xice2 tires or possible the Blizzak's from Bridgestone. Either that or switching over to Michelin's Hydro-Edge tires and then taking the Big O tires down to my '08 Prius in Vegas.
However it sounds like as long as I don't drive like a maniac that these Big O tires should work fine, thank you for your assistance.
Thx..Ron
The only difference I can find is the weather has steadily gotten colder thru this time frame.
Any tips out there? Am I missing something? Does some filter need changed? Is it the colder air? I am confused, especially since it has been a fairly gradual decline.
All that said, what do I do? I might be able to get different tires and go back to my old rims since I got the tires and rims from Discount Tire but what tire do I ask for? I'm very depressed at the drop in mpg. HELP! :
Second, if you changed from an OE tire to a replacement market tire, expect a further drop in fuel economy.
Third, if you went after a tire with god treadwear ratings, expect another hit in fuel economy.
Be aware that there is a 3 way relationship between rolling resistance, traction, and treadwear. Rep[eat after me: "There is no free lunch!"
So I'm thinking the problem isn't the rims.
If you want more detail:
http://www.barrystiretech.com/rrandfe.html
Again, thanks and if you know of a good tire, I'd appreciate the info.
Now the speedometer is crazy. It reads 80-90 when I know I'm only going 40-50.
Did they mess something up when they changed the tire.
