The back door has developed rust spots around the window frame. Has anyone had any problems like this occur? Is there a TSB about paint problems?
I'm new to this forum. Just picked up a 96 mont w/133k. Antenna motor will not work. (no noise) How do you replace the power antenna. It looks like its sandwiched inside the fender.
I searched other posts and found good advice on the whip, but nothing on the whole power antenna.
thanks,
dsgnr1
I just replaced a cracked manifold. Not a major issue. Finding the part was the real adventure.
Now....there is a noise coming from under the hood...a clunking sound heard when accelerating or when pulling a hill in top gear. I have been told it is either 1) a burnt valve 2) A lifter arm which has malfunctioned 3) some sort of chain loose in the 4wd mechanism
-The engine (as weak as it is) is not losing power, skipping, etc. so I do not think it is a burnt valve.
-I have no opinion re: the lifter arm.
-The vehicle is not makes the same sound whether in 4wd or not.
Somebody. Please help me : (
I'm curious - how much did you pay for it?
I want to do some touch up work to the hood of my 1996 Montero. How would I find the correct color of touch up paint. The color is like a dark chocolate brown. I've tried to get this info from archive Mitsu with no luck. there is a plate with some color numbers under the hood, but it means nothing to me.
dsgnr1
i.e., L77 for the top color, and S74 on the bottom. The website [https//:www.paintscratch.com] has pens and bottles and spray cans to fix chips. Thanks again. Now on to find the Chiltons Manual for the 1996 Montero
dsgnr1
"Was wondering if anyone might know what the problem is that I'm experiencing. Have a 2001 Montero Ltd with 58K miles on it. No problems at all up to this point. On a trip from New Mexico to Arkansas with the family we experienced a situation where the Montero wants to die and not idle. I can start it back up and drive, but when I stop and try to idle it dies. It's Saturday evening at 7pm and the nearest dealer won't be open until Monday morning. We're staying in hotel right now in Fort Worth. Any suggestions as to what to look for in hopes that I might be able to remedy this myself?"
Let me know what you have done.
We put in a higher grade of gasoline and it solved the problem!
http://www.4x4wire.com/mitsubishi/tech/throttle_body/
The web article shows how to clean v6 3.0 throttle body.
dsgnr1
It is NOT a jeep but I know of someone taking a stock Montero 01-02 down the rubicon trail near Lake Tahoe (very rugged) and he made it. He lost some body plastic as you would expect. He was mad at his wife is the story.
The stock tires are horrid and the REVO's make driving in 2wd similar to what I had to do in 4wd before.
I have a Dodge Ram Diesel 4wd and if you compared its abilities with the Montero you would laugh. I ALWAYS take the Montero x mas tree cutting on the forrest service roads in the snow because it does so well.
I have had NO service issues, breakdowns and it runs like a top. The unibody does not flex much if at all.
Braking will be worse due to an increase in unsprung weight, and your speedo and mile counter will be inaccurate. Cornering will also be worse due to the reduced tread width. MPG will also likely rise as you tend to open the throttle more to get the vehicle moving.
especially regarding the tapping (engine knock?)
i have a ford explorer that has knock from a lifter/rocker arm probably.it DOES lose power/compression. .acceleration has suffered..but still driving for years like this
i am about to buy a 1994 Montero SR 4x4,109k all options,leather.looks great.....but it has a very small but noticable ticking from engine. he says it comes and goes..im thinking he didnt change/add oil religiously,
what would a valve job cost for this truck.or what does a full engine go for? i'm sure it will last years as is.since my EX has run for 4 years this way. but id like to get it fixed if its serious and will get worse!!
the deal seems great,he took my offer of $3k. i drove it and feels great
please email me at clujenul@yahoo.com if you have advice !
Please keep the discussion here so everyone benefits!
unless i'll get auto-notification through the boards software?
Original tires still have plenty of remaining tread, but they're a bit old and I want to get new ones for peace of mind if the wife/daughter drive it while I am away.
I have seen various posts as to replacement tires, including one fairly recently on the Bridgestone REVO A/T which was very positive. What I would like is a tire that doesn't have a lot of tread noise at high speeds as the wife drives from Houston to Austin at a speed slightly below Mach 1. Any recommendations are appreciated.
Oh, will mention one other thing. Just a month ago I bought my wife a new Land Cruiser, she and my daughter are die-hard Toyota fans (the daughter has a RAV4). I have driven the LC about 500 miles, I must admit that I enjoy driving the Montero more than the LC. Tried to talk the wife into buying another Montero, she was scared off by all the recent concerns about Mitsubishi's continued presence in the USA. Needless to say this cost me a lot of money!! Mike
Aslo, look on the tirerack site and you will see they are #1
PS I hope your Dad has better luck with his JGC than I did - i had two of them (97 and 99 models) and they gave me quite a number of problems. In fact I traded in the 99 at 19,000 miles for the Montero.
Our Monty also had the same problem with the tire cover but was out of warranty when it showed up. I started pricing a replacement when some kid rearended me and drove off while I waited to turn into my neighborhood. Problem solved as he got just into the cover. By the way I caught the kid two months later when I saw him at the gas station and followed him to school. I called the cops, he was arrested, fined $500, and I heard he lost his license for a while.
The valve noise described on the older 3.0 liter Monteros is similar to the sound I have heard on my Diamante. The noise on mine started around 65k right before I had the timing belt replaced. The noise is gone now thanks to the timing belt that broke at 87k due to a faulty part in the Mitsubishi timing belt kit. Mitsubishi did come through though and did a head/valve job on the engine which took care of that problem. My opinion is that other than being a little annoying, if the Monty has the noise you knew about it when you bought it and due to the cost of a valve job (around $3,000) you will have to live with it. Despite Mitsubishi's toubles I am amazed that they covered this repair given that the shop who replaced the belt was just an independent shop.
Have any of you had the same, I know that every Montero I have listened to around here has the same sound but I wonder if there is an identified fix or whether it is even important.
Of course, the dealers know nothing
I think overall the dodge, jeep products are improving in quality. I have an 03 Dodge Ram Diesel that is doing well and if anything can break a vehicle its that cummins motor in there. I dont think my auto tranny will hold up long term but I knew that going in and wanted to hold onto my wife and my coffee rather than the shifter.
Good luck on your tire selection. If you can afford the Bridgestones you will not be disappointed. The other advantage I didnt mention is that you virtually cant get them to hydroplane, not that I recommend you try, once off the ground the car spins fast but the original tires and other AT tires I have driven dont do nearly as well.
I just wish they made these in 17 inch high load rating for my truck.
I must respectfully decline gtroop's Firestone recommendation due to personal prejudice - I lived (and suffered) through the Firestone debacles in the 70's and haven't had that brand since then.
Dodge must certainly have their act together, everywhere I go in Texas I see tons of the Ram trucks. I've talked to a few owners, they seem very satisfied. So far I haven't seen many of the new JGC's, will look again when I am back in the USA in late may.
No metallic sound on my Monty. Everything quiet under the hood.
Is this a modification or parts that can be installed on my 2001 to raise the payload rating (GVWR)?
Regarding my idling problems a few months back. Don't know exactly what the cause was. I assume it was just bad gasoline. Had a tune up and a new battery put in as quickly as I could. Never had the problem again. Thanks for all the help.
Recent Monteros are always loaded and are now most heavily discounted new Mitsubishis. If I were to get one I'd go for a new 2005 (just shy of $30K before TTT - $7K off the MSRP). Used 2004s sell in high 20s, 2003s mid 20s, and 2002s low 20s. You'd really have to get something much cheaper than that to justify the loss of the extended powertrain warranty (only applicable to the original owner) and the risk of getting an abused truck.
But again, $30K will get you a nice Pilot or a new Grand Cherokee V8 4.7l for superior offroading. Montero's price should decrease a few more Ks at the end of the year (that's when loyalty rebates kick in too), so I'd wait as long as possible if I just had to have it... Who knows, they might even go back to the free maintenance program which is worth a lot when you have to change so many different fluids ($$$) in this monster.
I don't plan on doing serious off roading...I just like the way it drives and the romminess. However, with only 15/19, I am really worry about the gas expenses. If I can get a brand new Montero for lower than $30K at the end of the year, I think I will consider it. Otherwise,I might consider other cars/trucks. It is for myself and my wife have a minivan already, so I am not using it to take my kids around. I just want something that is fun to drive. Would you consider a Pathfinder?
No.: TSB-02-55-005
DATE: July, 2002
MODEL: All with A/C
SUBJECT:
MUSTY ODORS FROM AIR CONDITIONING
(A/C EVAPORATOR COIL TREATMENT)
PURPOSE
This bulletin contains instructions for applying Mitsubishi Cooling Coil Coating to help eliminate musty odors emanating from the air conditioner evaporator coils.
BACKGROUND INFORMATION
Symptom/Condition
The customer may complain of an unpleasant, "musty" odor in the passenger compartment when the fan blower is switched on. This condition can be related to the area where the vehicle is operated, occurring more often in humid climates.
Cause
The unpleasant "musty" odor from the air conditioner system occurs when condensation, which is a normal occurrence, forms in and around the air conditioner's evaporator coil and mixes with airborne pollutants and
Where do I find the complete bulletin with the "instructions for applying Mitsubishi Cooling Coil Coating to help eliminate musty odors emanating from the air conditioner evaporator coils?"
Even if your vehicle is within the warranty period, "the dealership is not going to do anything about it, if [technicians] cannot verify the concern.... "
You, Your Vehicle and the Technical Service Bulletin (TSB)
LTD likes: rear a/c, room for 7 (in a pinch), tuck away third row, capable off-roader, nice interior, doesn't require premium fuel, good looks, good driving position.
LTD dislikes: tumbling rear seats don't offer enough cargo space, average brakes, a bit floaty (maybe I'm just used to my other car), hate the rear cargo door configuration, no optional NAV, spare tire cover clear coat is separating after only 4 years of life (garaged, no less).
How do you define fun to drive?
