John
The Acura is strong on the open road but terrible off road, so it depends on how where you plan to drive.
Let us know what you buy.
Good luck,
Rascal
Unfortunately, the paint chipping issue is for real--I have a pearl red, sudan beige two tone and I have had some of the paint flake off on the two tone rocker panels (the pearl red is only on metal--I think the rocker panels may not take the paint as well as they should). I am going to talk to the dealer about this at my 6,000 mile service.
Otherwise, I absolutely love this thing. I think the MDX is a good vehicle too, and reasonably priced against the RX30, BMW, and ML320; the Montero is in a slightly different class---more truck, less carlike. Personally, I finally sat in an MDX, and although its wider than the Monte, I still feel claustrophobic in it, but that is probably because I'm used to the Montero. The Montero's large amount of headroom gives it a very nice feeling of spaciousness.
I think the MDX would be fine if you aren't going to do a lot of offroading. The MDX does fairly well off road, but over the course of time, I would be concerned how tough it would be, and how well it would hold up--I don't think any MDX's were entered at the Dakar rally's; there is probably a reason for this.
2. Dont get the Montero hitch. I had mine installed for about 150.00. The wiring will cost 50.00. I am waiting for Mitsu to break out the harness separately like they have in past years. If they dont I'll just have the guys do a univeral type fit.
3. I have no problems with my Sudan beige chipping, it is solid color.
4. Re:MDX Great on road, poor off road. On a recent TV report, Car and Drive I think, they bashed the off road handling stating limiting ground clearence and rear end got too light with faster off road driving.
I like the on road sporty handling and better milage but really didnt like the increased road harshness and noise. very noticable to the group of 5 I took with me when we tested the MDX and Monte back to back.
"Stiff Seats", yes my inital thought too but as a guy with a 90 year old back at 40 I found out that soft seats over a long trip much worse. You will notice that the MB seats are also firm and they are a respected part of that SUV. Firm is better the longer you drive. Ask a trucker or anyone with a bad back who is sensitive too this.
5. Icruz: I am very glad to hear do did alright. That is a fast speed to hit someone with the front of you vehicle. I guess those guys over at the sequoia site can stop second guessing the abiltiy of the Monte to preform well in a 40mph crash test. Glad to hear your going for another Monte as well.
the world's top producer of timing belts.
Anyone that tells you not to worry about your timing belt for at least 100k miles is a nimrod for MOST cars.
SOME Acuras can go 105k miles, but until about 1997, the recommendation is 60-75k.
ALL Porches, 45-60k
ALL Saab, 35k
ALL Subaru, 52-60k
ALL MITSUBISHI, 60k (except 83-86 pickup 45k)
Most Fords, 60k, a few 100k
Toyota Rav4 and 4Runner (most) 60k
to give you a bottom end...Fiats, 25-30k
Valve to piston clearance is none closer on Hondas than other engines by the way...and Hondas are 60, (most older ones), to 90k
You can find places that will just JUST the timing belt all day for $300
BUT, I do agree, replace them ALL, the waterpump, and even some "O" Rings and seals on some engines, and THAT will cost you more. My bet is a dealer will hesitate to just do the timing belt solely, at least I hope so.
The junkyards are full of engines that snapped those so-called 100k mile timing belts..MOST cars do not have them, but SOME do.
And..oh yeah..the Firebird, the 69, that had the 400 engine was FAMOUS for snapping timing CHAINS..too funny..
I concur with you about the Acura off road, I saw the TV show that said it was a mini van made into a SUV and it hated being off road but they raved about it on the pavement.
By the way, what is a GSR?
Just my two cents, and that is about what its worth...now, time to go fire up the Panhead, (thats a Harley).
Rascal
Talking to the service manager on the Monte engine, it sounds like the base engine goes back to the 1980's, is this true, and good or bad?
Saabs really suggest it at 35K! WOW theres a design flaw or an overly conservative reccomendation.
About the valves, I am no mechanic but I think you will find that Toyotas valves do clear and will not be damaged in the event of a timing belt break. At least that is what I was told by several mechanics including toyota about a 1990 Creseda. I think they said the camry also is designed this way.
What is a GSR? That is an acura 1.8l little sports car that is a blast to drive and a wounderful value for what they charge for it.
My 69 Firebird had the "economy" motor the 350. I wish I had the 400. We had 3 over many years and never had a timing belt problem. With the kind of HP these things were capable of putting out it would not suprise me that you could break a lot more. I ran a little known 428 Pontiac 4 bolt main designed to run against the 427 Chevy for a while there. Now that thing had HP and torque and could break everything if you were on it all the time.
I'll take my chances and not do the belt until closer to at least 90K. Perhaps I will change my mind about the Mitsubishi if I hear about early failures or in retrospect I have driven it harder than what I had anticipated.
There are a lot of posts recently about the VSC. Here is an old post. While I think the VSC is probably a good idea for some folks I dont think it is for everyone. These quotes were taken directly from the Feb 01 Four Wheeler review of the 2001 4wd of the year article they ran.
Anyone thinking about a Sequoia should read this, as well as the posts here and other articles.
"...I think Toyota's engineers out smarted themselves" -Jon Thompson
"The weight is bad enough, but the real problem is the traction control system, which when activated feels as though the engine has lost all its power" -Greg Smith
"Generally I'm a fan of Toyota, but somehow things went awry with the traction-control system and the VSC system on the new Sequoia"...."once you get it off-road and demand performance, forget it" -Michael Rudd
"By the end of the test, I was wishing I had brought along some wire cutters: -Craig Perronne refering to the computer traction control systems
They did like the window in the tailgate feature, large and comfortable interior but did not like the "marginal handling" and felt the engine was "adequate".
This was one of the first reviews that I think really looked hard at the Sequoia as a 4wd vehicle. there are other articles but they only seem to qoute the toyota ads making me think that there might be an advertising dollar influence there. I was suprised to see the TV review of the Acura for the same reason. Several good reviews and then the TV review which blasted the MDX in several important areas.
I guess you just have to take everything into account, rank it according to objectivity and ultimately keep your fingers crossed.
Good luck selecting your next SUV.
Your opening statement, "I dont disagree that the manufacture suggests replacement far earlier than I would do it. ".....
I never said that the manufacturers suggest it far earlier ...so I do not understand your point, there is nothing to agree to..or disagree to, I never made that point.
I suggest that the engineers have to take into account the average driver. As far as recommending changing timing belts earlier than necessary, I do not believe that. If they suggest one too prematurely, then they get the reputation of a maintenance intensive design, this is NOT a good thing.
I suggest that if you want to scrimp on something, the timing belt is NOT the thing to scrimp on. Gates makes more timing belts than anyone in the world and they state that 60,000 is their benchmark and I accept the advice of experts. By the way, Mits, like most Japanese manufacturers, suggest 7,500 miles on oil changes too, but I go every 3,000 miles...so do most mechanics worth their salt too..
I have found that it is better to be pennywise than poundfoolish and tend to follow the recommendations of the engineers who design these cars as they should know, they spent millions of hours and dollars designing these machines. Of course, we are each our own captain.
As for me, I enjoy tinkering on my cars and bikes so I do the maintenace pretty close to the recommendations and anyone still in warranty should be prepared to defend your maintenance schedule if you expect to turn in a claim under warranty.
Your GSR, (Integra) depending on the year, should be changed at either 90k or 105k.
And your 350 Firebird did not have a timing belt, it used a timing chain.
Also, I could not tell you about a 1990 Creseda specifically, but the toyotas, subarus, hondas, mits, nissans etc would all experience severe damage if a belt broke...(discussion of this is also on the gates home page..www.gates.com).
The only machine that I have ever seen that could ignore the books were Harleys, and that is why bikers ride them...they ride them till they die, then they fix 'em and hit the road again....
Peace,
Rascal
4wd: If you are going to do major offroading, the Monte wins hands down.
Engine: The V-6 in the Monte is a relatively older design that has been tweaked for max. HP and performance--it should be very reliable. Mitsubishi puts a higher tech engine in the Japanese version, but it can't handle the sulphates in U.S. gasoline. The Montero has plenty of power for the highway and inclines; light towing should be ok (I plan to tow a small fishing boat behind mine in the spring) but if you are towing medium to heavy (2500lbs+), go with the Seqouia. In fact, the Seq is underpowered for its class too--if you are going to do heavy towing, I'd strongly consider a Tahoe/Yukon/Suburban.
Interior is a personal choice, but I personally think the Monte ltd is much nicer on the inside than the Seq. Sr5.
With regard to VSC: In all fairness, there are a number of articles pro vsc, some going as far to say that all SUVs should be equipped with it. I am a VSC convert; I think it is a good thing, and hope that the Monte will someday be equipped with it. Its only major disadvantage is during extreme offroading; it can be turned off however. Check out video's of vehicle with the VSC on and off; its very difficult to spin out or skid uncontrollably in a vehicle with vsc on. I also think an SUV with vsc would be less likely to roll.
The problem I have with the Seq however is with the Atrac. The Atrac redistributes power and braking when a wheel is spinning--it cannot be disabled. If one wheel is spinning, the Atrac may actually slow down the vehicle to regain traction in the spinning wheel--this can be a problem for traffic coming up behind you, as has been mentioned on some of the other message boards. I think adding Atrac to 4wd is overkill; it may even be potentially dangerous.
The Monte should hold up well over time--it is one tough truck, and probably the most underrated SUV out there. The Seq should do well too, but I would wait a year if you decide to go that route.
http://www.boatingmag.com/features/features.html?Feature ID=32
For other vehicles including the Montero Sport Ltd w/200HP :
http://www.boatingmag.com/suvindex.html
Anybody locate other similar sites?
There is no perfect SUV out there, and the Montero came as close to its purpose and size as it is.
The perfect SUV would be the Montero with the current off-road capability with an adjustable suspension to lower the ride height on the freeway and raise it for off-road condition. Add a 300hp motor, oh, make it 450.
Make the engine with the timing chain. People do not want to pay for maintainance even the initial price is thousands lower. They would rather buy something less with a acient rear live suspension setup that cost a few thousand more!
Also, I am still wondering where the 3 point seatbelts are in the back center seat (and the headrest). Does anybody know if this will be changed in 2002. By the way, has anyone seen a website that previews the 2002 model?
With regard to tweaking the engine for more power: If you are thinking about keeping the Monte long term, I would advise against a supercharger--it will wear out the engine sooner. If this is not a consideration, I'd recommend posting that question on the Montero board on SUV.com--its a bit more technical than the Edmunds board (in fact its usually way above my head).
Rattles: No rattles whatsoever in my Monte. In fact, that was the first time I've heard that one mentioned.
VSC prevents out of control skidding, and will lessen the chances of you spinning out--ie with vsc, it is much more difficult to do a donut. So if you like doing donuts in the parking lots, turn it off or don't get it at all. Like viet said, it is not a cure all, and other factors are important as well, but my bet is that the Monte will have VSC someday.
About the paint chipping: it is not a major cosmetic defect--you really have to look to see where it is flaking off. I am more concerned what it will look like years down the road than how it looks today.
I also think that the Montero is a very underated vehicle. I think that might be the reason why a few of us are undecided...not much media promotion so we have to find out the info by ourselves. We want a durable go anywhere (on any type of road, bumps,rocks,ruts vehicle. But, does anyone know about the absence of the center back seat 3 point seatbelt and headrest? Does anyone know how to get info on the 2002 model?
Only other issue is dealer can only offer
6 yr/100K miles or 6 yr/80K and I want 7yr/100K minimum and that @ about $1,400. extra.
Does anybody know if the factory standard 5 yr/60K Power train limited warranty includes the computers, anti lock brake system, power steering pump, etc.? I almost wish I had not test drove the Infinity QX4, it has some nice features that Monte needs to add (240 HP, Booze stereo with CD changer for 5 CD's, Michelin tires, memory seats). If I though Monte was adding this for 2002 I would gladly wait. Any help is greatly appreciated, I hate compromise and I hate the though of upgrading in two years.
Topic: replaced timing belt at 62k miles
Date: 2000-05-05 10:44:46
hopefully everyone can get something out of this. i had my dealer replace my timing belt, water pump, all other belts, and spark plugs at 62,000 miles on my '97 LS 4WD. this set me back a cool $1,122 but i plan on keeping the car awhile and don't like to break down on the side of the road. the generous dealer even threw in a $28 loaner car. i asked to see all of the parts and the timing belt looked brand new. i know they say "you can't tell when a belt is going to break", but i bent the belt backwards and didn't see crack one. the thing was as strong, stiff and durable as any new $82 dollar belt i've seen. here's my point: don't think you have to replace the thing right at 60,000 like mitsubishi says. i'm not providing any guarantees here but my new belt is going at least 90,000. also, i did all my fluids myself (diffs, tranny, x-fer case, oil) and saved about $300. it's not that hard, just takes about 4 hours the first time.
Somewhere in between is probably accurate if you go 4wheeling much, I do not. Mine is a 2wd that will see little more than a gravel road and may one day pull a small camper a few miles. The belts are fantastic compounds these days too.
Good luck to all,
Rascal
rascal2064@yahoo.com
On the 2001 Monte Ltd.s with a 5 speed, does it rev 3000 rpm @ 70 mph? I saw this in two different posts and was surprised it was so high. This would help explain the Monte's poor gas mileage. This is a great board! Thanks for all the help!
Also any information on extended warranties for 7yr/100K miles, would be greatly appreciated.
Was most impressed with Audi(most expensive). Test drove it on a back road that happened to be flooded. The dealer elevated the pneumatic suspenson to the max and said "Have at it!" No problemo! Acura MDX has great shoulder/hip room, and handled extremely well, but for an SUV, the rear suspension/springs seem to be too low, a real rock banger. Montero was a bit spongy in the turns, but has good ground clearance, 4wd low range, easily removable 3rd seat, and nice storage area where the third seat would fold down (usable if third seat is up). Volvo is great looking. Comfy to sit in, nice features, but haven't had the drive yet. Haven't heard of their reliablity problems. I'll probably narrow the choice to two, then flip a coin!
At 60,000 miles, I plan to tackle the old spark plug change myself but will like go to 75k miles before I do the timing belt.
Peace,
Rascal
If money is no option and you don't need lots of cargo space, I'd have a tough time passing on the All-Road.
Best of Luck
drew
I checked my Acura GSR manual which states that the belt is recommended (with an * that states recommended only, implying not definitely needed) at 90K. Now this is a very high performance, high reving motor.
As far as power, I drove both back to back and would say the Montero could keep up with the Seq under all road conditions and excell off road.
As far as reliability. The Montero beat the LC in Austraila this year. They use Monteros (Pajero's as they call them) in many difficult places in the world (Africa and Austraila to name a few). In those countries they are highly touted for reliability. I couldnt see this at first glance living in the States either. Toyota spends a lot more money here. Now that thier cars and trucks are increasingly made in the States I wonder (as do many) if the quaility will fall.
I ran into a chap from Africa a couple of weeks back who had 2 monteros in Africa. He stated he was looking to buy the 2001 now that he is in the States. I asked him about reliability. First of all he NEVER had a problem with his Monteros. Second, he said that it is a given that the Montero and LC are the ONLY svu's people really trust in Africa. He mentioned one other area over there where they dont even have a dealership but due to the great reputation of quality they still prefer and drive Montero's. Now I dont know if I would go that far with any suv but it sure sounded good.
You right on one thing. If you are only going camping 1-2 x/year that changes things. In your case if you need the extra size I would get the 2wd Sequoia and save the money. It sounds like you dont need a 4wd/AWD at all. The 2wd might even get better milage. The Sequoia boys are upset with Toyota because most are not getting the sticker quoted mileage. Most are getting around 11mpg.
Good luck!
What I have heard is that the clearence is such that if the belt breaks the out of sync valves cannot hit the pistons. This is what you really worry about with a belt break. Some of the newer models with variable overhead cams may be different now.
Timing chain or belt. both wear and I believe the chain sproket can jump if worn. I generally dont change them before the factory suggests, I trust (perhaps too much) that I drive well enough and that the recommendations are well within reason.
Oil changes: we agree, simple, cost effective and although synthetic oils can go much further than 3K it is not the breakdown here but how dirty the oil becomes. Since most of us dont have extra duty oil filters like the ones from Amsoil (? sP) that really take out the crap and can be changed under the hood without dumping the oil I do change my oil every 3K.
Synthetic vs regular oil both changed every 3K, now thats another debate.
When this happens, like to me, I found it was because I didnt have my search criteria clear in my mind. No offense please, its easy to do with the vast choices out there. Dont forget to look at the 6 Cyl Subaru if you are looking at car-like SUV's. EVERYONE I know who has a subaru likes it as long as you dont do too serious off roading.
The ones that are much closer are called "interference" engines. On the Gates listings, these are denoted by an asterisk and almost ALL the Hondas ARE interference and Most of the Toyotas are NOT, (only a few are). So I stand corrected, even an old Harley wrenchead like me can learn something. I thank you for keeping my curiosity up.
I use the PureOne filters with great success and they do have the check valve that Mits needs (as does Honda). The MobilOne filter, (made by Champion), does not. I will use the factory filter or the PureOne, (Purolater) and no others. Tried them all, these are the only two I will trust, Fram included.
You are right, it is the dirt that gets to the synthetics too. I prefer the synthetics in cold and hot weather over standard oils, this is when the damage can occur worst, I have seen Mobil One take some scary heat and save an engine.
Peace,
Rascal
If you are concerned, you can leave the Montero ltd in all wheel drive mode all the time, at the cost of some fuel mileage. My is white with the silver modling. The truck is 8k miles.
How do you guys lock down the spare wheel? The dealer only has locking lug kits with 4 lugs for $23. and I am not buying two kits. Thanks and any hints on the break end period, in addition to not running at constant rpm and max rpm? Thanks for any help.
Congrads on your choice you got a great price given the rear air and hitch.
The rear spare already had a lock on it with the key in the left rear storage box. Take a look I bet you have one on already.
As far as the tires if you are going to spend $400 to get replacements why not consider a Bliztek (?sp) route. Our local shops will get you into a very nice wet weather/snow/ice tire for just over $400 with 4-5 seasons of free tire changes. You then put the winter tires on in winter and change back to your Geolanders in the summer. Unless you are hitting some pretty serious off road mud these Geolander will do ok.
It is my understanding that the 2002 will have the same engine as the 2001, possibly tweaked for a few more horsies, but no V-8 as of yet. The "new" engine I think people are referring to is probably the one in the Japanese version, which is light years from making it to the U.S., because it won't tolerate the sulphates in U.S. gasoline. If anyone has any info to the contrary, please share (and let us know where you got it from).
mp goodluck--your are right on with your pricing. Look around, you should be able to get that deal--just look at some of the previous posts (makes me jealous--I got mine 6 months ago, and it seems people are now getting much better deals now than then).
Who makes/distributes the Bliztek (?sp) tires? I could not even find them on an internet search.
Any conclusion on the octane of gasoline to use? Owners manual recommends 91 octane (my first Monte surprise - I was planning on running 89 octane), Manual indicates it will run on 87, but performance will suffer. Will 89 (mid grade)work o.k. or can it cause problems. Even my Acura Legend runs good on 89 octane.
BTW, there's enough power there, but it seems a bit harsh when you push it. Does anyone else feel the same way?
The tires are Bridestone Blizzak's but there are other winter specific tires, all seem to have a more aggressive tread. They need to come off in the spring/summer or they would likely wear out too fast.
I would go to online tire stores and local tire stores to ask. If you purchace the way I explained the local store should be providing free mount and balence each season for several seasons.
Im sure this would give you a better snow/ice/wet tire. If the tread is more self cleaning then a better mud tire than stock but nothing works real well for mud.
Good luck
Do you see anything about adjusting the outside temp sensor. Mine always reads 3 degrees warmer. Would like to either adjust sensor or reposition if I knew where it is.
I then ordered mine from www.magauto.com for just $71 but beware, this thing is like a Chicago phone book, THREE volumes.
I will see if I can find out something about that temp sensor..I just stick my hand out the window..lol
I will let you know what I discover.
Rascal
Patience in this soft market will pay off big. They are under big pressure to cut inventories with the "R" being used so much lately! This is a buyers market! You should get the rig (assume 2001 Monte w/rear air) all options mentioned for 34,700. + tax/lic. or close. Good luck!
Rascal
