K well lets see where to start.. Im thinking about purchasing a car an evo or a charger havn't decided but anyways its going to probably be around 20-35k(depending on year). My big concern is on my credit report i owe credit collector money from a bank issue i havnt fixed yet but i will eventually. Will this effect me in any way? i would be putting aprox 10k down on the car, and i would have a co-signer with a cred score of about 780. what would u recommend? any info will help, Thanks a bunch.
SUVs and Smart Shopper
Specifically, I'm looking to lease an SUV. I'm not particular on the make or model. Just want a good, solid deal.
Unless I'm missing something, I can't seem to find a good place for this info. I can browse the various "Lease Questions" forums particular to each car, but that takes a LONG time, and I'm not sure if I'm missing any.
Could we start a new thread in the "Smart Shopper" forum? It seems like an "Exceptional Deal" thread would be a good idea, regardless...
Or is there another forum you can recommend that deals with this issue? Like a fatwallet or slickdeals for cars?
MODERATOR /ADMINISTRATOR
Review your vehicle
Review your vehicle
I have since driven it some 500 miles,and still have 4 ,"not readies" and they will not reset..The two most important is the oxygen and evap modes...
I cannot pass inspection in NJ without them,and have failed once already...My Saturn is a 1999 SL,manual everything.
Has only power brakes...no other power options...the readouts also show no codes,so there are no problems indicated on the analyzer...HELP
Also, Those Dreadful State Vehicle Inspections may help.
Dave
What are the odds that the motor would go bad in both the passenger & drivers side of the same car. The window mechanism was used very little as we use a/c or just the vent.
Motor?? Help... Other ideas of what the problem is.
If they went out at the same time I might do a double take but you said the failures occurred a couple years apart so I don't think there is much of a mystery. You're dealing with a 10 year old vehicle and components have a finite lifetime.
Check the Oldsmobile Intrigue group for related topics.
Review your vehicle
kcram - Pickups Host
Roball
Review your vehicle
Review your vehicle
Thanks in adavance
Thanks again
As you get familiar with our forums, you'll see that often a discussion will entail numerous threads and if you post in an existing discussion, you'll be off and running with a thread in that discussion.
There's a bit more in the Help file linked at the bottom too, if this is clear as mud. :shades:
