Subaru Forester (up to 2005)
1311312314316317344
  • 4mygrey4mygrey Member Posts: 26
    ...the parking lot at my workplace is made of pulverized oyster shells....
    Sounds like a descrption of coquina. You wouldn't by any chance live in the coastal South, do you?...
    Sorry for the delayed response...Southern Maryland, so coastal Mid-Atlantic. I guess it's possible...I'm not sure if I assumed Oysters, or if I heard that somewhere. It's not really common here, but this particular lot is in a historic area (but recently constructed). Of course, you can't catch oysters here anymore even though they used to be abundant, so I don't know where the shells would have come from exactly.
  • eps105eps105 Member Posts: 216
    Same thing has happened to me last year -- needle was way below E on several occasions but low fuel light didn't come on.
    I was going to report that the warning bulb had burnt out next time I took it in for oil change, but a few tank-fulls later, it started illuminating when expected, just above the E.
    I think there might be a design flaw or software glitch we are exposing here.
    Bottom line is, low fuel light or not, be sure to fill your tank before it goes below E.
    Elliot
  • rsay777rsay777 Member Posts: 100
    I've read that it is a good practice to fill the tank when it gets to 1/4. on long trips I plan my stops around filling before it hits the E. Not always possible but most of the time. Bob L.
  • bluesubiebluesubie Member Posts: 3,497
    For those not on nabisco, this story is in the NY Times (you need a password):
    http://www.nytimes.com/2005/02/18/automobiles/18warn.html
    "... Sam Later, 36, a systems integration analyst from West Paterson, N.J., found that the automatic climate control in his Subaru Forester was letting him freeze in the winter and boil in the summer - despite a temperature setting of 76 degrees. After complaining to the company and being told "the system is performing as designed," he got out his toolbox and traced the problem to a badly placed temperature sensor. His solution: a 12-volt fan that blows air over the sensor. "It forces the sensor to react to the slightest changes in temperature," he said. Mr. Later has now sold 20 kits to other Forester owners, who can make the repair with a Phillips screwdriver, a 10-millimeter socket and some duct tape.
    ANOTHER Forester owner, Peat Romano, 43, a thermal processing specialist for a pet food company in Lawrence, Kan., has tinkered with cars since he was 10. But he now arms himself with a fast Internet connection instead of a wrench. "I scour the Net for information on how to improve my 2004 Subaru Forester XT Turbo," he said. One handy trick he has learned is how to cancel his manual transmission's annoying hill-holder feature by adjusting some well-hidden nuts. The hill holder applies the brakes when the car is stopped on any grade with more than a three-degree angle. "If I had wanted an automatic," he said, "I would have bought one." ..."
    Peaty doesn't post here, but same does. :-)
    -Dennis
  • p0926p0926 Member Posts: 4,423
    I've gone 25-30 miles with the low fuel light lit (not for the faint of heart) and had maybe 1/2 a gal in the tank when I filled it. The hilly terrain might have been your undoing... I think the intake is at the front of the tank so when you're going uphill you can starve the engine even though there's still gas in the tank.
    I think you're right about the Forester's sensor being designed to cancel out the effects of sloshing. On other cars I've owned, the light would initially come on when going up a hill or thru a sharp turn and then go out again. With the Forester, once the light illuminates, it invariably stays on.
    -Frank
  • edunnettedunnett Member Posts: 553
    Besides leaving you stranded w/o gas, my husband's CR-V owners manual reads that letting the gas get "too low" (whatever that means) can cause serious engine damage, engine misfires, and damage to the catalytic converter. Now I don't know if the folks at Honda are being alarmists, but after reading that, there's no way I'm waiting for my low fuel light to go on. 5 minutes of my time here and there is worth a new engine and cat.
    Elissa
  • njswamplandsnjswamplands Member Posts: 1,760
    hmmm i live in da hills of NJ so maybe thats what causes extreme panic when the gas lite comes on. i drove about 10 miles after the lite came on before dieing of gas thirst going uphill.
    however, in my odyssey i still have around 80 miles of range left when its lite comes on, about 4+ gallons left.
    and on a not outta gas note.. i drove the FXT for the first time in a bit, and wow that power band is fantastic. makes driving the twisties so much fun. can only imagine what an STi must be like...
    Nice to see an Edmunds member in print again!
    -juice
  • mpgmanmpgman Member Posts: 723
    Really pleased so far, especially with the winter fuel mix. Mostly highway driving around 70-75 mph with a bit of city driving, maybe 5-10% with an X automatic. Light on the pedal. 28 best, did it twice on pure highway.
    Yes that does sound pretty alarmist to me and I fail to see a connection. I've heard that letting the tank get too empty can lead to the fuel pump over-heating (theory being that the gas actually acts as a coolant) and I've also heard the theory that the emptier the tank the greater the possibility that the fuel line will suck up debris which could clog the fuel injectors. Not sure of the validity of either of these arguments but even if true, neither would damage the engine or catalytic converter. And although it's purely anecdotal, I've driven hundreds of thousands of miles on numerous vehicles, almost never fueling up until the low fuel light comes on and I've yet to experience any negative effects.
    -Frank
  • baydrivebaydrive Member Posts: 48
    That sounds very strange indeed. I had a CR-V for 4 years before buying my Forester and I let the low gas light come on all the time before refueling. Maybe I was just lucky but I had no problems with that car at all. Maybe I shouldn't wait so long to refuel with this Forester....has anybody have any problems (besides running out of gas) with this practice?
    They are just being extra careful when they send out warnings like that.
    -juice
  • pertpert Member Posts: 19
    Bought my first forester in June. A used 2004 with 4000 miles. Like the car. One thing i dont like is the brake peddle travel before the binders grab. Can this be adjusted so they grab sooner. Also need a rear dust deflector as I live 1 mile up a dirt road. Ill also put some more aggresive treaded tires on when these cheapies ware out. Any thoughts on that. Like this Edmunds. Ive learned quite a bit about subies.
    I just did a radiator drain, flush, fill. on the 03X. Everything went OK. I refilled with a 50/50 mixture and topped off as needed until the overflow bottle was half full and the radiator was full. After driving 25 miles or so.
    I now notice that the bottle is empty and there is green liquid dripping out of the 3/4" long hard plastic tube next to the petcock drain. The liquid level in the radiator is so low I can't see it. Should there be a washer on the petcock? there wasn't when I removed it to drain the radiator. The petcock is tight. Any ideas? Bob L.
    One of the Forester's few "flaws" is its long brake pedal travel (which car reviewers invariably point out). I'm a little surprised that since you've had it since last June you haven't gotten accustomed to it (do you alternate cars?). IRT tires, TireRack is an excellent source for information and offers reviews and side by side comparisons.
    -Frank
  • once_for_allonce_for_all Member Posts: 1,640
    it doesn't sound like a simple air lock and underfill. Must be a leak somewhere (John, restating the obvious).
    29.4 mpg on my last tank '03 XS 5 speed. 90% highway through lots of rain and keeping up with traffic at 75 to 80 mph. Great car.
    John
  • c_hunterc_hunter Member Posts: 4,487
    Hmmm, If I remember right, you're not supposed to remove the petcock -- just loosen it enough to start the flow out the drain tube. If you take it out, then coolant will drain through the petcock hole itself in addition to the drain tube. I suppose it's remotely possible that the o-ring on the petcock got mangled when you removed/reinstalled it. That would be my guess, though it's going to be messy to investigate!
    Craig
    pert: you gotta get used to the dual-stage brake booster. It allows for smoother stops, is the reason they use it.
    Press hard and the brakes are plenty effective, though.
    robert: you think something might have cracked? I think mine is plastic, is yours?
    -juice
    Craig, you're correct. The o ring was lost during the draining. I called two dealers.
    First dealer said I needed to buy a new radiator to get a new petcock. (must think I'm an idiot) no business from me ever.
    Next dealer got the measurement of the o ring from a radiator in parts and he has an o ring in stock. This dealer gets my business in the future.
    How can these two dealers be in the same business? Bob L.
  • rhody_marcorhody_marco Member Posts: 21
    Good morning, all...
    The low fuel indicator came on last night during the homeward commute. I was six miles away from the cabin. This morning I drove to work with clenched teeth, as the nearest gas station was 12 miles away.
    The car conked out at mile nine - 15 miles after the light had came on the night before.
    I was climbing a modest hill when I first felt the engine starving. As I passed over the top, it quit completely. I cranked it a few times as it rolled down the other side - nothing.
    I coasted the next 1/3 mile to the bottom of a hill - easing through a stop sign into the parking lot of closed restaurant. It was here on flat ground where I was able to restart the car.
    I drove the next 2 miles at 45 - 50 MPH on a flat straightaway without trouble. I "eased" through another stop sign, with the last mile before me. Climbing a small grade at 35 MPH, there was just a hint of starving. The car hesitated once as it travelled the final half mile downhill. A 300-foot flat stretch at the bottom - and the rise into the gas station - caused no trouble. A favourable traffic signal didn't hurt my cause, either.
    So it appears the car can stall on low fuel going down a hill, as well. I wonder if the low-fuel signal fails to consider the new in-tank filter design. I'd be interested to know if the low-fuel indicator behaves this way with the previous under-the-hood fuel filter.
    Any thoughts ???
    Peace.
    Marco
    BTW...there was no backfiring or otherwise unwanted detonation from the engine either time I ran the tank dry. So I would think that the engine, oxygen sensors, and catalytic converter were not harmed.
    *** Title edited for the benefit of njswampland ***
    *** Formerly, "Yet another localised fuel shortage" ***
    hey how about that for a title post lol
    The hill you say?
  • forestspiritforestspirit Member Posts: 1
    I am having the same problem; tappets make noise when the engine is cold, gets better as the engine warms. I too was told this was "normal." Well, is it? Did you find out what caused it? What are the consequences if it is not fixed? This is a 2002 Subaru Forester still under warranty.
    Should I just sell it?
    Wow! that's got to be a record of some sort... running out of gas twice within a week?!?! If it was me I'd start fueling up when I reached a 1/4 tank. Especially considering you live out in the boonies.
    So it appears the car can stall on low fuel gowing down a hill, as well
    My guess is that the fuel line started sucking in air on the uphill but there was still enough gas in the line to get you over the crest. Once you completely drain the line it takes a while for the gas to work its way from the tank back to the engine so it wouldn't immediately start again even if it was full.
    -Frank
    I was able to pump only 15.04 gallons into the tank afterwards. The pump nozzle clicked off a dozen times for the last 50 cents before I gave up.
    That's another of the Forester's quirks. You'll get only an additiional 1/4 gallon into the tank after the first click. It clicks every few cents after that. This holds true among several stations and the different pumps they use.
    Peace.
    Marco
    BTW...mileage this time was just a tick over 24 MPG - a bit disappointing. Conditions were roughly 50% country roads, 15% city, 35% highway. I used the remote starter less frequently this time - about 30-minutes worth of idle.
    You're kidding right? There are plenty of FXT owners who would LOVE to get 24 mpg! (there are a few who can't even crack 20 mpg)
    -Frank
    p0926 said...
    "There are plenty of FXT owners who would LOVE to get 24 mpg!"
    I've a Forester X, not an XT. So I was hoping for a little better without the turbocharger.
    Marco
    Oops, sorry about that. Yeah in that case, while 24 mpg still ain't bad, I'd expect to get a little better also.
    -Frank
    yah juice i also drive a p/u. like to put me thru the windsheild if i dont remember what im driving. the forester has great stopping power. ill just have to get use to it. thanks frank
    Hey Swampy...
    I changed the title of my post upthread - per your suggestion. Have a look.
    Marco
  • subearusubearu Member Posts: 3,613
    You've read your owners manual, right? It states to NOT do this. IIRC, you can ruin your vapor recovery system and cause a CEL.
    FWIW, I let the pump stop automatically and then round to the nearest nickel.
    Interesting about the hills and low fuel. While I typically do fill up before the light goes on, I'll make a note to fill up immediately if the light does go on.
    -Brian
    "IIRC", "CEL" ??? Please translate.
    FWIW...the owners' manual says that the tank holds 15.9 US gallons. I've run the tank "dry" twice. Each refill barely topped 15.0 gallons. It's a little disconcerting that one can damage the fuel vapor recovery system by merely filling the tank to its "rated" capacity.
    I've never owned a car where filling to the nearest dollar wasn't always possible. The behaviour of this Sube is new to me.
    Peace.
    Marco
    IIRC = if I recall correctly
    CEL = check engine light
    I believe that manufacturers of all new vehicles caution against "topping off" the fuel tank.
    -Frank
  • dcm61dcm61 Member Posts: 1,567
    IIRC, Subaru states that 1 gallon is not usable.
    DaveM
  • toasterpilottoasterpilot Member Posts: 48
    I was driving my '01 L from Franklin, PA to Chicago when I noticed the CEL. Being an avid reader of this board, I realized that I had just stopped for gas and had most likely made a clickless cap close. The next morning the CEL was out. I guess it needed some time to reset.
    By the way, this is my first post. I started reading this board when I had my first Subaru,a '98 OB Ltd Ed. It was totalled while parked and unoccupied.
    The Forester was bought used with about 96,000 miles already on it. Best car ever. I'm Still getting about 21 on the highway.
    Also, thanks to the experts here, I knew to have the radiator treatment dumped in before I left town. SoA told me that the car had been in twice for warranty--a wiper blade and a new cigarette lighter.
    Someone struck a note with me when they called the Forester a toaster--hence my name. That the thing is silver only makes the illusion stronger. My real name (as if I had to mention it) is David.
    Hi David and welcome. Great screen name! It's Bob who calls his Forester the toaster so you may have to pay him a royalty fee ;-)
    Yep once the CEL is triggered by a loose gas cap, it can take a day or two to reset itself.
    -Frank
    Copyright infringement!! I'm going to sue!!!
    j/k
    Actually our Forester was named by several of my daughter's friends, a few years ago, when she was in high school.
    It's white, has a huge moonroof (for the toast to pop out of), and is boxy like a toaster; hence the name.
    Bob
    As long as it goes away after the car is warmed up, it is normal. My wife's 99 OB sounds like a diesel. It's the lifters.
    There's a link to a Subaru tech magazine that describes it, but I need to find it.
    -Dennis
    See you in court :). Do you know where I can get a bumper sticker to go above my tailpipe to indicate dark or light toast?
    About those noisy engines (before they warm up): if you pump oil, it goes up and then falls down; it won't fall sideways.
    But here's a more important problem: that little pin on the driver side floor that keeps the carpet in place doesn't seem to work well. I'm always having to rehang the rug on it. Any fixes?
    Maybe rolling a rubber O ring over it?
    David
    They changed the design in 03 and now the driver's floor mat fits very snugly. I don't recall the original design but I'm sure someone can help. If you can find an O ring that fits tightly then that should do the trick.
    -Frank
    spirit: my Miata's engine taps loudly on a cold morning, but it's a '93 and has been perfectly reliable.
    marco: I'll echo the advice to not top off too much, you might end up getting gas in the fuel vapor canister (and a check-engine light).
    -juice
  • growler5growler5 Member Posts: 67
    Maybe the fuel tank is damaged.
    Last winter I had a problem with the gas gauge and low-gas light coming on way too soon after driving 300 miles instead of my usual 480-520 miles before fill-up. The repair guy put the car (old Beemer) on the lift and was amazed to see the tank look like a crushed soda can. The combination of extreme cold (5-10 degrees), low fuel, and possibly a clogged vent tube created enough of a vacuum to induce the tank to collapse. Short term result - a 22 gallon tank shrunk to 14 gallons and $200 to fix.
    Long term result - I traded in the car (525i, 26.3 mpg over 118k miles) when I bought an '05 XS with stick-shift. The huge moonroof made the sale.
    Observations on the XS after 5000 miles and a dozen light-just-came-on fillups: full tank to gas-low light is consistently 13.8 to 14.0 gallons; 27 mpg since Thanksgiving. I'd expect to see 29 mpg or so when summer arrives with 10k miles on the odometer, and 31-32 mpg for long hot-weather trips.
    Given that you were able to pump 15 gallons into the tank, I'd wager that the tank level sensor is faulty. The specs for the Forester indicate that you should have 2 gallons left when the light comes on, which is what I'm seeing.
    Any one know of any negative concerns when using extended life coolant/anti freeze in the phase 2 2.5 engine? Thanks in advance. Bob L.
  • crashton6crashton6 Member Posts: 245
    I sure wish I was only getting 27 mpg. I only have just over 3000 miles on my XT & my mileage is 17-18 mpg. I love this car in every way but one. With all the talk of gas prices spiking up this summer things look quite bleak to me.
    Chuck
    As long as you flush all the old stuff out with plenty of water before changing I see no problem. My 2000 was changed to Dexcool long life at 30,000 & now with 102,000 on it there's not been a single problem with the cooling system. When I drain the cooling sytem for the timing belt / water pump change I will refill with it again.
    Chuck
  • stynkdurstynkdur Member Posts: 4
    Another clock fix success. Thanks to Pal.Rider photo on the Ultimate Subaru site and others input from here also, I pulled out my overhead digi-clock from my 2001 Forester L and fixed it. I was at first surprised to see that the tiny flat rectangle shaped resistor labeled 500 was still in place with intact solders at each side. But I went ahead and scraped the solders a bit to see if any cracks were apparent, still could not see any... a magnifying glass would have been a help, and I didnt have one. I just went ahead and fired up the soldering iron and melted fresh solder on top of the old solder joints and figured, it can't hurt. I reinstalled the clock in the car, and it has worked perfectly ever since. Who knows, maybe just the action of sliding on and off the wire harness and the fuse improved those connections and made it work. Electronics guru guy at work said it is possible for the old solder joints to look perfectly intact, but for them to be "compromised inside" and thus fooling your eye.
  • leo2633leo2633 Member Posts: 589
    Anyone know how to remove the rear defroster switch on a first gen Forester? The green background illumination light (as opposed to the amber light that comes on when the defroster is in use) burned out on my 2001. I've removed the black plastic trim panel around the radio/HVAC controls, but you can't see how the defroster switch (along with the 4-way flasher switch) are held in place. I don't want to keep removing pieces of the dash if I don't have to. Thanks in advance for any and all info.
    Len
    I bet it's glued in place.
    -juice
