Subaru Forester (up to 2005)
But a dual-stage booster will always feel different. It does allow smoother low-speed stops, plus it doesn't feel jerky or catchy like Mercedes' brakes do.
-juice
Also, anyone selling their armrest extension? We would like to get one but think $95 is a bit steep to pay for an armrest
The Subaru ski / bike/ kayak / etc. attachments used be, and I think still are, re-badged Yakima.
DaveM
I have Yakima crossbars and Yakima ski clamps on my Outback XT, and there is plently of clearance for most skis. However, I have a new pair of Fischer RX-8 with Rail-flex bindings and lifters, and there is only about 1/2" inch of clearance between the binding and roof when I transport those skis. Getting close. This makes me recommend you test-fit your skis and rack on the Forester if possible. Doesn't Thule or Yakima offer angled ski mounts?? That might be a safer bet if you can't test fit.
Craig
Does the subaru ski carrier come with locks? Or are they purchased separately.
They included the locks in the past. I assume they still do.
FYI - Yakima (and I think Thule) locks (actually lock cores) have to be purchased separately. The idea of purchasing them separately is so that you can buy a 4, 6, 8, 10, etc. pack of cores which allows you to use the same key for all your accessories.
DaveM
Thanks in advance for any input.
If the wheels are over-torqued, you will get warped rotor syndrome and eventually, warped rotors themselves.
Also try rotating your tire, that sometimes helps too.
John
asa: that's a bit strange, given it's not a high compression engine.
Carbon desposits can form in the cylinders, though, and oddly enough the best suggestion to prevent those it to run the engine to redline once in a while, say once per tankful. So hit the gas!
Also make sure you don't have any loose heat shields on the exhaust, those can rattle and that might sound like knocking.
Maybe toss in a bottle of Techron to clean the fuel system, can't hurt.
-juice
-Dan-
-Dennis
Just don't torture yourself too much by looking at the STi version.
-Dennis
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The Mazda Mania Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Asa
-juice
-Dan-
I have had one in my 98 Outback for about two years now and I don't really buy into the performance increases that they claim. My mpg hasn't really changed either and stays consistent between 22.5 and 24.5 depending on the season and gas formulations.
You will save money on not having to replace the paper element filters over a couple of years. This is assuming that you adhere to the recommended change schedule. Ecologically speaking, you will be contributing less to the local landfill.
Thanks for the reminder though, its about due for its annual cleaning.
One tip, keep a regular filter available to swap in while you are cleaning and letting the K&N filter air-dry.
Alan
98 OBW Ltd
But how do you clean a K&N and be ecologically minded?
I've run a K&N in my wife's OB and an Amsoil in 3 of my Subaru's since '98. I always felt the the Amsoil made the turbo (WRX and FXT) spool slightly quicker, but that could be in my head.
I just switched back to OEM in the FXT after all of these years because the filters were letting in too much dirt (used oil analysis). The K&N in the OB was letting in less dirt. Probably because the OB is used mainly for 25 mile weekday drives to work vs. harsher conditions with the FXT.
-Dennis
Mike
Also...want to carry bikes on the car...are there options for the back besides the hitch mount? (I don'thave a hitch.) I've seen people with bike racks strapped around their trunks or smaller hatch backs...would something like that work on a Forester??? I'd like to avoid the roof since my current bike is heavy and would be hard for me to get up there.
Thanks everyone!
I use Naval Jelly to melt the rust, then apply touch-up paint, about $5 or so per bottle at the dealer to get a perfect color match.
mike: Bobistheoilguy did an interesting study and found that the increased air flow was almost negligable, but that the air was actually cleaner with a plain paper air filter vs. K&N gauze or even Amsoil oiled foam.
So I'll also stick to stock.
-juice
PF Flyer
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
-Dan-
I guess Baja and OBS/Impreza RS are the only ones left with steel hoods.
-juice
-Dan-
What year OBS is that? I know the WRX has an aluminum hood, since 2002. But I'm not sure if the OBS' is steel or not. It was before 2002, but since then I'm not really sure. What model year is that one?
This much I know, there are aluminum hoods on these Subarus:
2003+ Forester (all)
2005+ Legacy and Outback (all)
2002+ WRX and STi
I'm not sure about the TS, RS, and OBS.
-juice
-Dan-
If you get a paint chip you should touch it up ASAP. Galvanizing is just a coating, I'm sure it can scratch off the paint, and you end up with surface rust.
Naval jelly to clean it up, then touch-up paint, should fix it up.
-juice
Thanks pal,
-Dan-
Yeah, an auto supply store will have some.
Wear gloves, then brush some on the spot, wait a bit, and wipe it off with a disposable cloth. Repeat until it's clean.
Then wash the area so it's completely clear and clean, and touch it up.
-juice
-Dan-
What may I expect to be paying if work is done by the dealership?
I live in the Philly area.
Hmmm, we have a 2003 Forester and it has NEVER made the sound you describe...
Hoping late May/June?
It's a goopy liquid that removes rust. You'll probably find it at Home Depot, Lowes, Ace Hardware, Menard's, etc.. You paint it on and wait maybe 30 minutes or so depending on how bad the rust is; wear gloves and eye protection. It works really well and rinses off with water.
