Subaru Forester (up to 2005)
As with most rust removers, the main constituent is phosphoric acid with a ph of 1. Definitely don't get it on yourself!
Quite effective at neutralising the rust though. You need to wire brush the area if there is scaling or loose material.
Cheers
Graham
Trying to decide whether to go for Subaru vs. Yakima/Thule ski carriers...
It's right at the edge of the hood, near the wipers. I'll have to be very careful not to rinse it under the hood, sounds like.
-Dan-
-juice
Subaru Forester Gets a Reshaped Alter Ego (Inside Line)
Do a limited run, just 500 or so, to keep it exclusive.
-juice
-juice
Anyone else?
At least the filter and drain plug aim down in the Subarus. That keeps the mess out of the engine bay.
Honda puts the oil filter on the exhaust header side of the block, spills/leaks have been known to cause dozens of fires on 2003 and 2004 Honda CR-Vs. There's a thread here on Edmunds discussing this.
-juice
We had a 2000 Odyssey. You had to remove the right front tire to get at the oil filter and clean the spilled oil off the plastic shroud. I HATED changing oil on that car. (We traded in the Odyssey for an Outback.)
Len
I'm a value guy, but I'm also patient, so I might be likely to wait until the incentives appear on the 06s. That could take months, though.
Miata is also a bear to change the oil - the filter is on the side of the block. It's a mess every time.
-juice
Subaru May Switch to Toyota Hybrid System (Inside Line)
Larry
HSD works only on the cars that are FWD based. Even the AWD RX400H is mechanically a FWD vehicle with a seperate electric motor for the rear axle added on.
So Toyota has not engineered the front electric motor to power the rear wheels.
Subarus are kind of the opposite - they do not have a gas engine that does not power the rear axle.
The viscous coupling won't mate up - the front axle would start on electric power, and the VC would bind up and move the rear axle. That's not a desired effect.
It'll be interesting to see if they can engineer HSD with a manual tranny and VC, I doubt they will.
So my crystal ball says - we will only see hybrid Subarus in automatic form. The auto AWD is at least capable of disengaging the rear axle (by inserting that fuse).
-juice
2) Is there any product which will clean the w/s wiper blades? I wash the car weekly and wipe away the black residue buildup on the wipers every time. It takes 5-6 wipes of my towel to get the wipers nearly clean. Doesn't seem to be such a problem on the rear window.
3) Also I heard several years ago how to get your windshield absolutely clean. As I recall an auto repair show host mentioned it on his radio show. I can't remember its name, but it was an auto liquid whose chief purpose wasn't cleaning windows. It cut through all the film on the window that sometimes even windex doesn't remove, but it left a slight residue itself to deal with.
thx
Asa
Have it checked and good luck.
-Brian
-juice
Asa
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Also, my son in law is moving to Ft. Collins and asks the perennial question:Outback or Forester? Any thought? Dealer recommendations?
Hard to explain, but the Forester is just more fun. It's lighter, spunkier, I dunno. Legacy is a lot nicer inside and more refined, but for me fun wins out every time.
-juice
Since my daughter has totalled a couple of cars in her early driving career, maybe the stodgier OB would be the ticket.
Thanks also for the other comment about the heat shields, but what makes them whistle at a certain speed? Of course, yesterday I couldn't get the bird to sing no matter how fast I went.
Spend the money on driver training instead. Bob Bondurant can help her. :shades:
-juice
I have 3 choices:
An 03 XS manual 22K miles (with tow package, armrest extension, rear bumper step guard) for $17,999. It appears to be like new. Is that a good prive? Need to make a decison soon or this one could get away!
Could also get a new 05 (similarly equipped but with out tow package, armrest & bumper guard but w sunroof) for ~ $22,400 (after $1,5K rebate). I don't mind buying used as I only drive 10-12K per year and the $5000 savings (after sales tax added) seems worthwhile to me.
However the last option of an 06 with supposedly mildly improved engine output (taking non-turbo) and improved suspension have me 2nd guessing :confuse: . I can afford to pay more, but prefer to save the money unless there are real, noticable improvements. Unfortunately, I have not been able to find any 06 test drives to learn if the engine and suspension differences really noticable, nor can I find the EPA figures. Can you point me anywhere for such information?
That's a fairly heavy boat, I might wait for the 06.
The prices you've been quoted seem a little high, at least for the MD/DC area. You can almost buy a new one for the price of that '03 you were quoted. Check fitzmall.com for reference.
-juice
....a brand new '05 Forester X was advertised in the 5/21 Sacramento (CA) Bee: $18488 after $1500 rebate"....
-juice
Bob
In the UK the Forester was rated for 3960 lbs even back in 1998 with a 2.0l engine pulling it.
SoA is already very conservative, so 2400 lbs with a whole bunch more power and better brakes should be fine for a new one.
-juice
I have towed this boat with a variety of what some might consider "incapable" vehicles include a 88 Grand Caravan FWD w 3.0L engine, a 94 Ply Colt AWD with 2.4L engine, a 97 Caravan FWD w 3.3 engine (all previous vehicles have been Auto tranny), and last week a 03 Forester W 2.5L non turbo engine. Never have had a problem pulling boat out of water witjh any of them -- was nervous at 1st w FWD vans, but the all have just walked up the ram with occasional wheelspin if ramp was wet. One the highway they do fine pulling at 70 mph, but need to downshift for even minor inclines. When pulling over the Cascade passes, they have often been in 2nd gear at ~ 4,500 rpms to keep speed at 55 -60 mph for a mile or two, but they make it just fine. My Colt did need its AT replaced at 70K - how much of that was due to the boat is anyone's guess.
Perhaps the biggest weakness in using a smaller rig to tow is that you are not going to do 0-60 quickly & you need to be mindful of stopping distances. But other than that, I have reconized no problems towing with any of the above. I pulled with the the Forester about 15 miles , including two moderate grades. It did not struggle at all - I would say did better than any of the others.
The manual on the Subie worries me a bit, but with all wheel drive, I think it would be fine.
New 06 Forester Model Changes May 16, 2005
Subaru Plaza; P.O. Box 6000; Cherry Hill, NJ 08034-6000; 856-488-8500
Dear Subaru Retailer Subaru of America is pleased to announce the pricing of the redesigned 2006 Model
Forester line-up.
The 2006 Forester comes with additional horsepower, improved driving performance,
enhanced fuel economy, and new design cues that will keep it at the head of its class. The lineup
has been simplified to just two trim series, the 2.5X and the 2.5XT. The 2.5X model has an
MSRP of $21,795 for the manual transmission model. The new Forester 2.5X features a 2.5-
liter engine with i-Active Valve Lift System (variable valve lift) which increases total horsepower
to 173, and maximum torque output to 166 lb-ft at 4400 RPMs. Also, the 2.5-liter turbo engine
horsepower will increase from 210 to 230. Forester will have the most powerful 4-cylinder
engine in its class! To complement the additional horsepower and low to mid-range torque,
driving performance is further enhanced with improvements to the suspension, braking and
transmission.
New design elements to the front fascia, rear garnish, and side cladding give the 2006 a
distinctive new look. All models have new fenders, bumpers, front grille, headlights, fog lights,
and hood and rear combination lights. The 2.5X models now have body colored side cladding
and bumpers. To help protect this attractive vehicle, a security system is now standard
equipment on all Forester models. Overall utility is also improved with a new standard
multifunctional center console that features a comfortable front seat sliding armrest, and new
rear cargo utility bars (2) and hooks (4). The center console can also be flipped 180 degrees to
provide additional cupholders and a small tray. Also, a new rear seat armrest and an extended
rear seat cushion enhance the passenger ride comfort.
The new 2.5X Premium Package is designed for customers who prefer upgraded features with
cloth upholstery at a value-driven price. The Premium Package has the following items:
• Power Moonroof
• Alloy Wheels
• All Weather Package (Dual-stage heated seats, windshield wiper de-icer, &
heated side-view mirrors)
• 8-way Power Driver’s Seat
• Limited Slip Rear Differential
• 6-Disc CD Changer
• Automatic Climate Control
• 4-Upgraded Speakers
• Larger Side-View Mirrors with Turn Signals
• Leather Steering Wheel/ Shift Knob/ Parking Brake Handle
• Electronic Brake Force Distribution
• Body Color Door Handles
2006 Forester - Page 2
The retail value of the Premium Package is $3,350. To help you move customers up to the
2.5X Premium Package model, we will offer a $1,000 discount, which will be shown on the
Monroney label. The discounted price of the Premium Package is only $2,350.
The L.L.Bean Edition with 4-speed electronic direct control automatic transmission has an MSRP of $26,895.
Finally, the 2.5XT base model was eliminated. The 2.5XT Limited, now with 230HP, includes
sport-design luminescent needles with metallic needle caps and an engine cover. Desert beige
leather upholstery will now be available for certain exterior colors. The 2.5XT Limited MSRP
starts at $27,895 for manual transmission.
The 2006 Subaru Forester pricing will be posted on Subarunet.com in vehicle pricing
information, under the vehicles tab. Destination and delivery charges for 2006 Forester models
is $595 (Alaska is $745). Price lists for the port installed accessories and port packages are
also posted to the Subarunet.com.
We are excited about the significant enhancements made to the 2006 Forester line-up and
are confident the new Premium Package discount will provide your customers with an even
greater value on the best compact SUV on the market.
Good Selling!
Fred D. Adcock
Executive Vice President
Solid.
2006s - give it about a month.
-juice
Did have a surprising problem develop recently: I had a crack or split develop in the vinyl trim on the driver's seat, on the left side of the seat bottom. I had a guy come out to repair it; he says he has seen this kind of thing happening more often on newer vinyl.
Repair came out OK -- color doesn't quite match, texture is a little different, but it's better than cracked vinyl.
Anyone else seen this on a newer Forester? Is this common on vinyl-trimmed seats? Or just another sign I need to lose 20 pounds?
Larry
Then I told him I'd already had it repaired, and he said in that case there wasn't anything he could do.
Ah well. Live and learn.
The dealer referred you, they were the ones that should have offered to fix it for free.
-juice
-- The dealer should have asked me to bring the car in so they could evaluate the problem firsthand, i.e. determine whether the problem was due to a failure of the seat material (covered) or customer misuse (not covered).
-- They can't evaluate it now that it has been independently repaired.
-- They will reimburse me for what I paid for the repair (only $32, but 32 bucks is 32 bucks)
