Subaru Forester (up to 2005)
Are there any relatively easy (DIY), inexpensive mods that can be done that will signficantly reduce the body roll without negatively impacting the overall handling dynamics or ride (I don't want it any stiffer)? I am thinking perhaps a larger rear sway bar and or a strut tower brace. I believe that the stock rear sway bar on the XS is 17 mm. Does the XT or a WRX come have a larger sway bar (22mm? ) that will bolt right on and make a substancial difference?
Your thoughts and sources for body roll reduction would be much appreciated.
I just did a rear sway bar - the 20mm from the Sti, and new mounts, with PolTec end links, and the PolTec bar collars. Worked slick and the car is definitely snappier in turns. Entire job is well spelled out on another site, grep sway bar and scooby from google. It should get you there.
There's some concern that the 22mm bar is too much for the rear links on the 04 XT's to handle. A couple of people with bigger bars have reported snapping off the weld where the new end links attach. This is usually the result of more robust autocross driving, but I've seen some Boston potholes that qualify as canyon driving, so it wouldn't surprise me if the same snapping would appear.
My understanding is that on the 05's and 06's the rear sway bar is already heavier. I've heard 22mm but can't confirm.
Also, there's collars / adapters available to beef up the rear links, but some people have just replaced them with the more expensive Sti or aftermarket links. Depends upon how hard you're going to push the envelope when you're done. Definitely get the weight off the rear wheels after the mod and make sure you can't flip that sway bar. Of course, use jack stands.
In my case the dealer's already made it clear that he's not going to warrant anything I did. I can agree with him re: PolTec equipment and non Subaru equipment, but I think he should at least warrant the Subaru equipment. At least he didn't try the "whole car warranty is invalidated scam" Them there would've been fightin words.
So far my modest list of mods is
1) Sti sway bar and mounts
2) PolTec endlinks and collars
3) Grillcraft scoop insert - best thing I ever did for my XT
4) Added a glove compartment light - that was so easy and simple I can't believe I put it off for almost two years
5) replaced the instrument cluster plastic with the one from the 05. The painted silver rings arouns the tach / speedo look much nicer.
HTH
Larry
Still don't care for the new tail-lites, but all the young car dudes - - - gathered around this nice looking Champagne Gold Opal - - - that I informally quizzed liked 'em big time.........who knew?
best, ez......
Are there any major differences between the 04, 05, and 06's that would make one a better choice over the other?
I'm all for saving money if I can get a low mileage 04 or 05...
Dawn
-Drive shaft bolt fell out, causing shaft to make violent rattling sound when delerating. This happened during a trip from Virginia to Massachusetts.
-A/C belt tensioner jammed itself into timing belt cover, frying the A/C belt and scraping against the timing belt. Replaced: A/C belt, A/C belt tensioner, timing belt cover, and timing belt.
-O2 sensors (check-engine light came on)
-Transmission-neutral switch failed (car was stalling when shifting to neutral)
-Speed sensor failed (speedometer was bouncing around or just showing 0)
-Clock-spring wiring ripped itself apart (airbag light on, horn and cruise didn't work)
-Front tie-rod had to be replaced for car to pass inspection
Note: tie rod perhaps front end accident related; drive shaft bolt, perhaps had to pull the engine/tranny out; A/C belt tensioner, maybe the pulley was bent out of alignment causing a bearing failure; tranny issues--pulling and replacing? wrecking yard tranny? Speed sensor--someone maybe messed with the odometer?
Hard to say, sorry about all the problems.
John
Chuck
Absolutely not, but there are isolated cases of rudeness.
-Dan-
Since you're starting with 17mm, you will get diminishing returns. I've also heard the front ones are a bear to install. Maybe hire paisan to install it if you're in the tri-state area.
82k miles when purchased, eh? Does CarMax include any kind of warranty? I suspect they didn't really do a thorough inspection if all those problems slipped by.
2006 gets:
* turn signals in the mirrors
* clear lens tail lights
* projector beam headlights
* flip over cup holders for the rear seat
* rear seat arm rest
* 173hp (vs. 165) and AVLS (varies valve lift for high-rev breathing)
* about a 1/2" lift in the suspension
* new fabrics (same as Tribeca's cloth)
I think that's about it.
-juice
Switching to 17's makes it all come together nicely. Some other suspension options are Forester STi springs from your dealer; Forester STi take-off struts/springs from http://www.jdmpartstx.com/; or brand new adjustable STi struts and springs from http://www.rallispec.com/product-suspension.htm.
Sticking with only upgrading to an STi swaybar will probably be enough for you since you don't want a stiffer ride.
-Dennis
-Frank
I spend quite a bit of time reviewing posts about RSB. Yeah, I think a STi will satisfy provide the improvement in handling I am looking for.
-juice
Can anyone tell me if the STI rear sway bar will also fit the LL Bean model with the self-leveling suspension?
-Frank
It would be hard to convince the bean counters that there is a need, basically. I wouldn't want to be the guy presenting that proposal:
For about $400 extra per unit, the already good results won't improve at all, but we can pretend they did!
veritasusa: they should, the self-leveling is built-in to the shocks themselves and should not affect the sway bars at all.
-juice
Suggestions welcome.
A3 - love it but it's tiny. Only if you have 0 kids. 2.0FSI is a hoot but add quattro and options and it's pricey.
325xi - too pricey for a compact IMHO, but very nice if price is no object. A little short on power given the weight. About to be replaced.
Passat wagon - nice but also being replaced. Roomy. 1.8T is fun with a manual. Poor service and reliability is iffy at best.
Mazda3 - cool little car, you can even get NAV on those. V50 is roomier, I wish the 3s was shaped more like a wagon and less like a hatch.
Forester - opt for the XT and all the others here will eat your dust.
CR-V - a bit less fun than the others here. Back seat is a limo.
RAV4 - look closely, it's really a 4 seater. 2.4l engine is an improvement over the 2.0l.
Pilot - compared to the others here it's a monster, huge inside and out, feels a lot more bulky. This would be my pick of this list only if you have 3+ kids.
Highlander - great on paper but it still makes me yawn. Maybe if TRD got its hands on one and really made it handle well.
Depends on my budget and my needs, but I'd cross shop a Mazda 3s 5 door, A3 Quattro, and Forester XT.
-juice
Decisions...decisions...decisions. That’s the best part of car buying, like that VW advt, blister continues to grow on my forehead!
VWs are funny, they have avid fans on one side and then people that were burned and would never (under any circumstances) buy another. Pretty polarizing.
-juice
I have a 2004 Forester X AT. Transmission fluid level looks fine, and there aren't any other symptoms -- slipping, noises, harsh downshifts, etc. I'm bringing the car in for 15K service in about a month, but I was wondering if I should have it checked out sooner?
-juice
Just got my 20mm STi RSB today. I will probably do the install this weekend. Hope it is as easy as it sounds.
VW could be made outside of Europe but it still has that European ride quality. Perhaps it's all about that multi-link rear suspension? I was told that Passat is made side-by-side with Audi A4 in Germany but I care less about where it is made compare to how well it is made.
By the way, which one would you choose from these two Subaru models, and why? I have never owned Subaru but come November, this may be the first.
No, that leaves 52% that haven't had reportable problems. It doesn't necessarily mean that all of those 52% are happy. But probably some of them are..
Owen (in a quibbling mood)
Soccer
Coffee
Samba
Bossa Nova
Gisele
The current Passat shares a platform with the A4, but the new one won't.
The Jetta and Golf didn't get an indy rear suspension until just recently. I believe they used torsion beams, like most minivans do, up to the Golf IV.
VW also still uses heavy cast iron blocks, even the new 2.0FSI engine.
In some ways they are very advanced but in others they trail.
Forester XT vs. Outback XT?
Forester is more frisky, quicker, more fun. Better city car, smaller though so better for 0-1 kids.
Outback is really nice, IMO, and roomier. Longer wheelbase makes it a good highway distance cruiser, but it needs more room to park too. Better if you have 2 kids.
I'm more into driving fun that space and luxury, so my pick would be the Forester XT.
-juice
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
It is. Just be careful not to overtighten the nut on the brackets (the bolt is made into the bracket). I snapped mine on the first try and removed it and ordered a new one.
I learned how to do the install using "Peaty's" site.
-Dennis
Starting in 03 to 05 NON Turbo is 17mm. I can't find the Spec on the XT, so won't even guess.
Just did my XT's so I'm sure about the 04 @ 17mm.
HTH
Larry
Time to go down to my local Subaru dealer.:)
Yep - an XT Limited auto (basically loaded to the gills) is 26 and change. 21/26 mpg for a 230hp turbo, yum.
-juice
ANYWAY, they had a handful of 2006 Foresters on the lot and in the showroom, and at least 8 - 10 Tribecas.
In short, the differences between the 2003 XS Premium and 2006 X Premium are seemingly substantial -- just about every touch point in the interior has changed since 2003 -- the new 6-disc changer, improved climate control, 3-spoke steering wheel, improved armrest, improved gauge cluster, better upholstery, etc., etc., not to mention the added boost in engine power and fuel economy.
Yet, there's several nagging yet menial omissions that I was hoping they would add, but alas they have not, so I will be waiting until the 2008 redesign. The omissions include the continued lack of front-seat lighting at night due to the dome light being in the back seat when you have a sunroof; the lack of a glove compartment light; and most important to me, still no steering wheel audio controls.
Despite that, it is a worthy improvement and still the best compact SUV on the market. (I am especially happy that they improved the cloth upholstery. To me, the 2003 XS cloth was so cheap looking that I bought the leather just to avoid the cloth.)
Elliot
My impression was that all besides the new bar all that was needed was the larger bushings. Perhaps some have managed to use the smaller clamps, but after struggling to get the new bushings in the old clamps remounted I thru in the greasy towel!
So I rebolted on the 17mm bar. Will call allsubaru.com Monday & order the larger clamps. With the proper parts & my newly acquired experience, it should take less than a half hour to do the job.
If I am missing any other details on this install, please do tell.
BTW, I just turned 60K in less than 3 years on my 03 XS and bought another set of Geolanders. Have read much mud tossed at them, but they have served me well. Would have gotten more mileage out of them but my curb-bumping messed-up the wheel alignment and shortened the life of the fronts. Anyway, I'm looking forward to another trouble-free 60K from this puppy on the way to 240K.
I think they are one-size-fits-all.
It took alot of effort, for me, to mount the "clamps" with the new bushings.
The existings will fit.
Were you installing the RSB with wheels off the ground?
-Dave
