Are automobiles a major cause of global warming?
11516182021223
  • larsblarsb Member Posts: 8,204
    It doesn't. There are normal temperature variations every year.
    Trends are what should worry us, not individual years which were below or above the norm.
    PS. How did this car forum get hijacked into the "Global Warming Discussion Forum?" Very few of the recent posts have anything to do with cars.
  • jd10013jd10013 Member Posts: 779
    I believe the title is "are cars a major cause of global warrming" I see no hijacking if the topic remains with global warrming. If someone doesn't believe cars are a cause, then it only seems logical to present other reason, and evidence
  • grbeckgrbeck Member Posts: 2,358
    larsb: It doesn't. There are normal temperature variations every year.
    Except that temperatures recorded in the year 1816 weren't the result of "normal temperature variations." (And those low temperatures weren't only recorded in America - Europe also experienced them. Crops failed in Europe that year because of late freezes.)
    Those temperatures were the result of dust left in the atmosphere from a volcanic eruption the previous year. Which undermines your contention that dust in 1934 caused the high temperatures that year, and supports kernick's post that dust will LOWER temperatures by reflecting more solar heat.
    lasrb: Trends are what should worry us, not individual years which were below or above the norm.
    Then why did you single out the year 1934 in the first place?
    It was always my understanding that the dust bowl was caused by two things
    1. drought, which is actually quite common in that part of the country. In '34, it was a particualarly bad one though.
    2. horrendous farming practices that destroyed the top soil and allowed it to be blown away.
    I don't remember it having much to do with temps, but I could be wrong about that.
    I didn't "single it out" at all. It came up as in context as "contrary to current trends 1934 was the hottest year in the USA ever."
    And a volcano erupting and causing dust in 1816 does not "undermine" my contention that the dust in 1934 caused the higher temps at all.
    It's obvious that "world-wide dust events" cause cooling, and we know that from the death of the dinosaur, and the concept of the Nuclear Winter, et al.
    What I was talking about was a localized area in the USA suffering dust bowl conditions and said dust contributing to drought. A drought means hotter than normal temps because the cooling periods that are created with thunderstorms and rain are not seen.
    We KNOW the Dust Bowl did not cool the USA in 1934, since that was the hottest year on record.
    1934 May
    Great dust storms spread from the Dust Bowl area. The drought is the worst ever in U.S. history, covering more than 75 percent of the country and affecting 27 states severely.
    To say that the dust had nothing to do with the drought is just as ludicrous as saying it had nothing to do with the heat.
    drought has nothing to do with temps. It's bassed on the amount of rainfall an area recievs compared to the normal average amount.
    Did you not see my earlier statement?
    Drought "by definition" has nothing to do with temps.
    But you LOSE THE COOL AIR associated with RAIN when there is a drought. THAT FACT ALONE means that in drought conditions, the overall temps will be hotter because of the lack of cooling days you lose with the lack of rain.
    Let me ask you a question.
    Which month will be hotter:
    1. A summer month with zero rain.
    2. A summer month with rain 15 days of the month.
    See my point now, finally?
    If your statement is true, it can mean part of the country is warming and part is cooling. The Midwest and Texas are seeing record rainfall. They must be in a cooling trend. While CA is in drought conditions. The UK has had record rainfall. So we have a wide variation in World wide weather. This would go against a World Wide trend of any sort. Something many scientists that are not sucking on the GW teat are saying. I don't know why it is so difficult for people to accept that politicians contrive scenarios to make themselves look smarter than they really are. By the time they are shown to be full of crap they have made their millions and are living off the fat.
    where I live in central va, we often experiece droughts in the latter part of the year, sept-dec. Its no warmer than usuall as the cold air from the NE is moving in, but sometimes the fronts are strong enough to keep the gulf moisture in the south. It's not that uncommon durring those months to get no more than an inch or two of rain. despite low tems in the 30's and high temps in the 60's. But because the rainfall is so scarce, We're considered to be in drought conditions.
    I think what you mean is droughts are usually accompanied by higher temps, but not defined by them.
    and yes, sometimes when it rains it actually gets hotter. unless its a long lasting, pouring rain, the humidity will spike which traps an enormous amount of heat. And the humid heat is far worse than the dry heat. Again, where I live, rain in the hot months usually leads to heat index's of 102-108 degrees.
    spot on. another thing the GW crowd ignores. the amount of precipitation world wide is very consistent and constant. where it falls may very, but always falls in about the same amount.
    One of the symptoms of the current warming trend is periods of unusually high rainfall for some areas and shifting rainfall patterns.
    Not surprising that some areas will experience more rain.
    But in Central Texas, some of the towns which have had large amounts of rainfall are not even as wet as 2004, or even 1997.
    Gary says, "Something many scientists that are not sucking on the GW teat are saying. I don't know why it is so difficult for people to accept that politicians contrive scenarios to make themselves look smarter than they really are. By the time they are shown to be full of crap they have made their millions and are living off the fat."
    I hear:
    "Blah blah blah Conspiracy, Crooked Politicians, blah blah blah Contrived Problem, robbing us, blah blah blah."
    Gary, as much as you want to believe GW is just a political scam by US politicians, how do you explain scientists in so many other countries saying we are in a warming trend?
    Did at some point a few years ago some Secret Worldwide Politicians Association have a Top Secret Meeting and say, "We should get some scientists to start saying the Earf is getting warmed by human activity, then we can STEAL money from the people and supposedly attack this non-existent phenomenon and all get rich !! HAHAHAHAHAHAHAHAH!!!!!"
    You see how silly that sounds?
  • robertsmxrobertsmx Member Posts: 5,525
    Honda Civic hybrid base MSRP is $22,600
    Honda Civic LX manual base MSRP is $16,960
    So, you spend $5640 more to save what exactly?
    I was catching up with the posts that I missed over last few days and came across this one, addressed to larsb. The argument to that point was about conservation of fossil fuel but this was off course and talking about ownership costs.
    The funny thing about ownership cost is, that if more people actually did math, they will start to look beyond initial costs. And trucks/SUV market would die sooner than it will otherwise. So, back to conservation we are. I was in Houston over the weekend and while driving around in his Pacifica, I asked him what mileage he gets. He told me 17-18 mpg. Then he told me that he doesn’t care, because his company pays for it. I didn’t say much, but to me, some things go beyond how much they cost you in monetary terms.
    I’m about as happy to get 32 mpg on a highway trip in my 06 TL as I’m in my 98 Accord, even though TL costs me 8% more to refuel (premium versus regular grade). For me, it is more about how many gallons I burn. And I’m not really looking forward to recoup the premium of owning a more expensive vehicle, again, in terms of $$$ alone.
    consensus is not science. at one time so many scientist thought the world was cooling, we were entering the next ice age. there were even plans being developed to coat the poles with soot so sunlight wouldn't be reflected back. But anyhow, science is about fact. facts that can be proven through expirimentation. and thats what global warrming lacks. Its all theory, conjecture, and unreliable computer models. There is deffinitly a political aspect to it, even if you don't see it. why else, if we are in such dire straits with this non-sense, would countries like china be exempt? why the whole scheme of carbon credits, which basically allow a country to pollute as much as it wants, so long as its buying credits to do so?
    Follow the money my friend, and you'll find your answers.
    How do you explain that? I’m not trying to tie global warming to this effect, but unless we understand factors affecting climate patterns, we shouldn’t go deeper into it. I’ve seen enough anti-GW arguments already, using “facts” like… oh but it was so cold yesterday…
    Besides, we also need to discuss UHI effect that I asked you specifically about.
    What facts do we have that dismiss global warming completely? Has someone provided a model on where the world is headed to, in the near and distant future? Where can I read about it? A common scientific source of information would make for a good foundation to discuss here.
    Well, here is one part of "GW" which is not conjecture, opinion, or theory:
    The world is warming.
    The CAUSES of that warming are up for debate. The fact that we are warming is no longer debatable.
    See my chart on a previous post, and there are other charts also:
    And:
    Summary: Warming Effect is occurring.
    Causation: Unsure.
    the fact is, when temps are averaged over the entire globe, on a 365 day period, there is very, very little warmming occuring. no more than a degree or two. thats why you always here about a high temp here or there, or flooding here or there, or whatever. when you examine it on a global scale over a full year to exclude regional and seasonal flucuations, there is scant evidence of a warmming trend. if you expand it to more than one year, there is no real temperature change. the hot and cold years will balance out.
    I will be looking forward to a link to a scientific study from you (or someone else) that says that global temperature has not increased. We will go from there.
    larsb: And a volcano erupting and causing dust in 1816 does not "undermine" my contention that the dust in 1934 caused the higher temps at all.
    The volcano erupted in April 1815, and the cooling effect was witnessed in the summer of 1816 - or over a year later.
    The fact that there was lots of dust in the air in 1934, and it was a very hot year, does not "prove" that dust had anything to do with the record heat that year.
    The effects of the 1815 eruption were not experienced for over a year, so that undermines your contention that dust in 1934 also caused record high temperatures in 1934.
    larsb: We KNOW the Dust Bowl did not cool the USA in 1934, since that was the hottest year on record.
    You're asking the wrong question; see above.
    Look, I'm 44 years old. I understand how things work.
    And you know what? NOT EVERYTHING IN THE WORLD IS ABOUT MONEY.
    Many, many things are. But sustaining the Earth for future generations trumps the almighty dollar.
    We should all want the Earth to be habitable when no one remembers what a "dollar" was.
    OK let me explain so my 8 year old daughter could understand it.
    "When it rains, it gets cooler.
    If it does not rain, it will stay hot."
    We have no facts to say it isn't happening, and the idea is deffinitly worth studying. I've never said it shouldn't be studied. But to declare that humans are warming the planet, demand drastic, economically crippling changes without any facts to back up the theory is foolish. People like Algore don't say its a theory thats needs more study, they say its happening and the world has 10 years left if we don't do what he tells us too.
    There is no way to know where the world is headed to. The only thing we do know, is that climate change on this planet is neither new, nor unprecedented, and often deadly. more than 90% of all life that has lived on this planet has gone extinct. And mostly from abrupt climate changes. there have been periods where it has been much cooler. there have been periods where its been much warmer. there have been temperate periods like what we currently enjoy. But, the only constant is change. Or, do you suppose the planet has always been one temperature, and always stayed that way till people arrived and started burning coal and oil?
    Without people burning fossil fuels, what made the glaciers that reached down to iowa melt and retreat into northern canada? what made the glaciers in green land recede to where they are now. what caused the glaciers in norway to melt forming the fjords that are there today?
    but if you want something on what may be driving climate change, read this
    link title
    Counterpoint
    Anyone heard any car news re GW lately?
    Thats the whole point. The whole global warming thing needs much, much more study. And its premature to declare we have 10yrs left.
    This a long one with lots of info and graphs. it may take you a while to read.
    link title
  • kernickkernick Member Posts: 4,072
    I've posted some of these comments. Why? No I'm not trying to make it look like there's no GW. What am I trying to point out - that I wouldn't mind seeing the Earth warmer. How much? Oh maybe another 5F would be nice.
    If you look at population distribution and how many species live in any given climate, you will see that the warmer climates have higher population densities and the most varied lifeforms. If people don't like warmer weather, why has there been such a shift in population in this country? I'm sure Minnesota and Montana are very nice, and Canada has vast stretches of land, so why do so many people flock South when they retire?
    Where am I going to live when I retire? Somewhere warmer than New England. When people stop moving to Arizona and Florida, and start moving to Alaska then I'll believe that people want it cooler.
  • texasestexases Member Posts: 11,165
    One more thing to consider - oil availability. Could be a much greater near-term issue.
    I really thought you were joking. It is a heat sink. All that concrete soaks up the sunlight and retains heat. Another good reason NOT to live in a city. I would buy it if you said all the hot air coming from NYC, LA & Washington DC was causing global warming. So what do you feel there is to discuss? I think big cities are a blight on the land. Hard to drive though one and not think the same thing. I cannot think of a city over a million people that I would even want to visit. Including San Diego. The only reason I go downtown is to visit the zoo.
    When there are unknowns involved, is it a bad idea to tread with caution? But wait a minute… did you say that the world is naturally getting warmer? Then who are these people who keep claiming that the world hasn’t gotten warmer, but it has gotten cooler? It looks like we have three factions now, perhaps four. Would be nice to get vote for each to see where we all stand.
    A: There is global warming and human activities are accelerating it.
    B: There is global warming and human influence is insignificant/non-existent
    C: There is no change in climate.
    D: It’s a mess. I don’t know.
    I wonder which of these anti-GW people would pick. What would you?
    Do you think this is a realistic depiction of what is called "Urban Heat Island"? And here is a thermal picture of north-eastern USA. Dark colors are cooler clouds, and white blotches represent cities (as in UHI).
    Anybody questioning human influence on weather and environment should visit third world countries where limited to non-existent regulations have resulted in horrible conditions. I can't imagine what our part of the world will be like, if everybody chose to be that way... ignore the impact. Fortunately, we don't, and a good reason why we can even talk about new cars being so much more cleaner than those from the 1960s.
    I am not a Scientist or an activist involved with (or against) the global warming phenomenon. But, I’m fairly logical when it comes to addressing claims like this. Let us begin with a simple question: How quick was the recession?
    Anybody claiming that climate cannot change is about as crazy as some who believes that there is no difference between an accelerated change versus one that takes a “natural” course.
    The UHI idea is to show the impact we have on the environment. It isn't about discussing quality of a zoo in the city. But clearly, for you, city offers horrible conditions, but why? I thought claims were being made for no-impact by humans. Has that changed?
    And yes, UHI effects goes down as you move farther from the cities, but does that mean it doesn't affect the climate in ever expanding city? And that is with plenty of regulations.
    read the link I posted, and pay close attention to the graph comparing land recordings to satalite data. It clearly shows very limited warming, well withing normal variations. and since the satalites don't suffer from the heat island effect, and correspond with weather ballon data.......its quite a leap to say the earth is warming beyond normal ranges.
    This article comes flat out and says "automobiles are the second largest cause of global warming":
    "Automobiles are the second largest source of global warming, creating nearly 1.5 billion tons of CO2 annually, reports the Natural Resources Defense Council........"
    Carbon this footprint
    Nothing new there. Somehow we seem to have a better record of Sun's activities over last 300 years than we do keeping temperature records over last 100. :P
    "Climate changes such as global warming may be due to changes in the sun rather than to the release of greenhouse gases on Earth."
    Ah, may be! Does that prove human influence can be ignored and we can rid ourselves of all the "clean air" regulations? Why not?
    Global Warming is. It is BIG MONEY. The US alone plans to spend $6 billion over the next few years studying GW. How much will be spent to disprove all the GW theories?
    If that was the case you would not buy anything made in the highly polluting Chinese factories. You buy from China because it is cheaper (LESS MONEY) and they build things that would not be permitted to be manufactured in the USA.
    I don't understand your point. the satalite data clearly shows no unusual warming.
    comparing global warrming to clean air is like comparing apples to oranges. wanting cars to burn cleaner so the air is of a better quality is entirely different than wanting to get rid of them so the planet won't burn up. I'm all for clean air, and we do a great job of in in this country. not perfect, but very good. There are still things to improve, and air quality is a much more worth target of activism and funding than GW.
    Out of the four I listed (A, B, C, D), which would you associate yourself with? Let us first establish if earth is indeed warming, or not. We can't argue without a baseline.
    Explain. And, what do you mean by "clean air"? Hey, doesn't earth go thru natural cycles of clean and dirty air? ;)
    Mixing clean air discussions with GW is a stretch. We are trying to keep the air clean for our own health. CO2 is not pollution. Every time you stand close to another human you breath CO2.
    I wouldn't fall into either of those. there is a slight increase in average temps, but nothing staticticaly relevent, or outside normal climate fluctuations. it all depends on what timeline you want to use. over the last 100 years? thousand, million? if you use the last 150yrs, its about a degree or two higher. not significant to me, but technicaly warmer and well withing normal varations.
    where did you come up with that? you confusing me again. are you equating dirty air with warm air and clean air with cool air? never heard that one before.
    You've just told us that you prefer to live by the real jungle over the concrete jungle. Why?
    Besides, would you mind preparing a list of gases that you want to discuss, and those that you don't want to?
    Which one would you fall into? I'm unclear about your stand. It seems you're trying to make your point both ways. The question is simple... "Is the earth getting warmer"? Answer can be a simple yes or a no. Which is it?
    depends what you consider warmer. if the one degree increase in temp over 100-200 years is warmer to you, then technicly, the planet has warmed since the last ice age. but, if you take out the little ice age, and look at likely temps from the medival warm period, then no, the planet hasn't really warmed up. It all depends on your timeline.
    Some chick named Putt says its so and you believe her. The UN report says 15% for ALL modes of transportation if I read it right. Too many wannabes are jumping on to get a piece of the pie. She heads up a think tank. You know one of the places where if you think it is hard enough, it IS.
    That money is not making anyone rich !!!!! It's financing research !! It costs money to pay researchers, to pay for consumables and equipment, to pay for computers and upgrades and software licenses, pay electrical bills at the lab, to pay the janitor, etc.
    No one in the research world is getting rich off that $6 billion dollars. They are spending the money trying to find causes and solutions for the warming we are seeing.
    Gary says, "Some chick named Putt says its so and you believe her."
    A) She did not say it, and B) I never said I believed her.
    no one in the research world will get their grant money (their paycheck) unless they start with the conclusions that man is causing global warming. Neither the UN no any other polictical body is going to fund research into weather on not GW is real.
    You are a funny guy. So that is why Al Gore left office with a million bucks in his pocket, and is now worth well over 100 Million dollars. You think he has not cashed in on the GW fortune? Why do you think he got picked up by Apple and Google. He has the inside track to the GW money. Knows the buttons to push and the ears to blow in.
    You like to use the word conspiracy. So I will say it. This is not a conspiracy. It is business as usual in our Congress. Pork Barrel politics at its finest.
