Buick Rainier Repairs
Got issues with your SUV? Ask other Rainier owners for help here.
TV
Joe
Fan control - Fuse block-engine compartment 2004 - 2007, this part is causing the issue with the speedometer indicator to register incorrectly?
can you please let me know what they told you.
The Ohio dealer went to bat for me probably because I bought the Rainier from them brand new and have had all service work done at their facility. I suppose they don't want to alienate a good customer. Try to assemble as many complaints as you can find on internet regarding speedo failures so dealer has ammunition for Zone Rep. I think recalls were issued by GM for Tahoes, Envoys and some other SUV's. I don't know why they have not included the Rainiers. Could be it's because this vehicle is an orphan so there won't be any repeat customers. But then again if you are mad at the Rainier would you ever consider buying an Enclave? It's been a nice vehicle otherwise. Good luck.
my dealer tould me it would be 100 just to look at it
and god knows how much to fix
anyone got any advice?
i bought it at 39,000 miles
now its about 47,000 miles
still in warranty..
The Ohio dealer went to bat for me probably because I have the Rainier services there & have had service work done at their facility on my Rendezvous. I do not think they want to alienate a good customers. Kerry Automotive Group just bought this Buick Dealership & are quite large in Greater Cincinnati. Try to assemble as many complaints as you can find on internet regarding speedo failures so the dealer has ammunition for Zone Rep. I think recalls were issued by GM for Tahoes, Envoys and some other SUV's. I don't know why they have not included the Rainiers. Could be it's because this vehicle is an orphan so there won't be any repeat customers. But then again if you are mad at the Rainier would you ever consider buying an Enclave or any used car. One last thing... I have 38,500 miles, just a little out of warranty. Good luck.
For the second time I had the check engine going on, after scan at Dealer the
To make a long story short it was the ignition switch. Apparently, the Rainier switch sends a voltage to the computer and if the computer is happy it sends the start voltage to the starter. When it would not start it was only getting 2 volts out of the switch. Switch was $38.00, trouble shoot $80.00, and about $100 to install the switch.
Joe
