Jaguar XK-Series Chain Tensioner Replacement
Mr_Shiftright
Member Posts: 64,481
This topic is for discussion of chain tensioner problems on some of the older XK models, and how you deal with them.
I just spent $4200 to replace the tensioners, chains, etc on my 1999 XK8. Neither dealership nor Jag will do anything to help. I know there are two service bulletins on this problem (303-30 and 303-68). I'm new to the Edmunds forum and I couldn't figure out how to read your posting. Do you have any additional info on the problem or how to resolve it with Jag?
Thanks, Bruce
It's not a matter of "If", just a matter of "When" for failure of tensioner parts and expensive damage. However, if parts are replaced before failure, it's not too bad, less than $1000, parts and labor. Furthermore, there are some special alignment tools needed, such that an owner should not do the work. Five tech hours and abt $350 parts. I will have them do that.
Thanks, Bob
I also read a comment in another forum from a Jag mechanic in CA that has seen literally hundreds of Jags with the 4.0 engine from 97 to 99 model years - and never, ever has he seen one where the tensioners failed.
Is this a real problem or is it overhyped? I am getting contrary advice. Any input?
http://www-gatago.com/alt/autos/jaguar/38509443.html
Of course, in terms of "percentages of failures" it may not be very much, but if the music stops and you're the one without the chair, well then the percentage rate of failure is 100%.
But sure, it's not like every 4.0 is eating its tensioners...but I don't think people are making this up.
I've read several articles and I'm only finding minimal reports of issues with this 2nd year AJ-V8 engine which is still in use 9 years later, just a little bit improved.
Here are a couple of informative links I enjoyed reading:
http://www.jagservice.net/jaguar_v8_secondary_tensioners.htm
http://www.racinggreencars.com/modern/The%20Jaguar%20AJ-V8%20Engine%20Strengths%- 20and%20Weaknesses.pdf
Jag has redesigned the tensioner system using much more robust parts, and I believe they sell this upgraded system as a kit. Ask the party you bought the car from if the new tensioners have been installed, and get a copy of their receipts for this work if possible. Take your car to a mechanic experienced with these Jag engines and ask if your engine has the new tensioners. The mechanic may have to do some dissasembly to find out, but it will be far less expensive than replacing the engine.
Thank god the chain broke during start up. I had to have my Chain Tensioners Replaced and all 4 of my chains !!! This cost me $2650. I would love to get something from Jaguar. They know about this problem. They have upgraded the
Tensioners 2 times !! But I BOUGHT THIS $90,000 CAR WITH 65K MILES FOR 15K OUT THE DOOR. I love my Super Charged VDP !!!
I hope that I will not have to order parts from INDIA someday.
Please click on this link for more info on Chain Tensioner FAILURES !
Thanks - any input would be helpful
Starting to get expensive to maintain (average $4K/yr) without inspecting/replacing the tensioners. Have not decided to replace or to sell the car.
Been a joy to own and drive on long trips.
Will miss it as it is the best car I have ever owned.
The new ones are not as pretty and they are up to $15K higher than I bought mine for some 9 years ago. As I go to dealerships of different manufacturers, I can not find a 2008 car I like as well as my 2000 XK8.
BTW, for those who haven't, plugging your IPOD into the cassette player is a real treat on the top notch stereo system that is still much better than my Lexus top of the line system.
As the proud new owner (2 weeks and counting) of an immaculate '97 XK8 coupe, 32k miles from new, I am in the process of equiping myself with tools and knowledge to do some level of routine maintenance myself.
I have seen on Ebay, a selection of workshop manuals on CD. Some claim to be factory certified others don't. Any guidance here would be appreciated.
I have also read the past posts on the infamous chain tensioner situation with interest. I have the full service records for my car and it doesn't appear the upgrade has been done. It runs like a dream currently without the slightest hint of a rattle, even on cold start. Is it possible to do an inspection of the current tensioners to assess their condition, or is the fatigue failure such that there is no visual evidence until it fails?
Finally for this post, my driver side headlamp has moisture in it. Are these sealed units or is it possible to get the unit out to dry out the interior?
Thanks for any guidance you guys can provide.
Al
:mad:
