Code 12 means that the battery was disconnected within the last 50 starts. This is normal if battery was disconnected. If not have the battery tested and check both cables.
Code 31 refers to evap solenoid circuit. Check for loose, broken, or shorted wires in the charcoal cannister solenoid wiring and connectors.
Code 55 means end of message
Corkscrew
Thanks for the advice.
Corkscrew
Also, after I get this problem fixed, will the check engine light automatically go off or will I need to have it reset?
Corkscrew
Sorry my dihlema doesn't amuse you and I prefer not to take to a place that charges an arm and a leg to fix that why I thought some one on here might have an explanation. Clutter up this forum... Excuse ME!
Crap Truck looks like you got a hold of a ASE mecAneck or "Goalie" had a problem like yours. This is a forum to ask ?s and hopefully get answers, not a put you down and ridicule people place. I don't say much on this forum but when I see somebody like this "goalie" %$%^^^^%, remember everybody likes a little A%%, but nobody LIKES A , well you know the rest. If you live in glass house DO NOT, repeat DO NOT, throw rocks. I think Edmuns should get rid of MR. PERFECT so that he doesn't CLUTTER THE FORUM WITH HIS WORTHLESS INFO. I agree with you, besides I've seen plenty of bad fixs by certified, experienced, and OVERPAID mechanics. If I had a fix for you I sure would help. MAYBE GOALIE GOTS THE ANSWER. Good luck, remember if you aint HELPIN YOU ARE THE PROBLEM.
kb500
goalie, you are not the person to decide what gets posted here... I am.
kb500, you don't need to make it worse by replying.
Understood?
kcram - Pickups/Wagons Host
My engine light came on my 2004 dodge ram 2500 5.7 Hemi so I did an OBD test with my scanner and got the U0155 message which means lost communication between the PCM and CCN so I performed the actuator test (dash cluster test) and got this instrument cluster failure message code AC 10 it means ABS messages not received. Anyone know where to start to correct this problem?
Sorry for the double post. wanted to explain the situation a little better.
http://www.obd-codes.com/p0306
http://www.obd-codes.com/p0300
Corkscrew
WHERE IS IT LOCATED ON THE VEHICLE?
Corkscrew
Do a google search on the TSB number and you will see the vehicles affected and the procedure the tech uses to repair that problem.
I have this TSB listed for 2006 and 2007 rams so keep the alternator in mind while diagnosing your problem.
Corkscrew
http://www.obd-codes.com/p0113
Corkscrew
Random Misfire Detected
I would check the plugs and clean or replace them.
Corkscrew
- - d o n e- - so i took it to napa today, and all their code reader would do is say error, it doesnt seem to be getting worse, but i cant find out whats wrong with it. kinda irritating if a know what i mean. :mad:
Corkscrew
http://www.obd-codes.com/p0303, as for 02s and egr I need the specific P code to give you more info and if you smell rotten eggs in the exhaust then you have a problem with the cat. Sorry but I would need to be there to check the reader. Pep Boys and Auto Zone will check codes for free.
Corkscrew
Corkscrew
Today I drove to the coffee shop two minutes down the road from work. I was in the coffee shop for like 3 minutes, and when I got back into my truck and tried to start it nothing happened. My truck has Tip-Start, and no matter what I tried to do, it wouldn't do anything... no crank at all. The yellow check engine light was illuminated, so I opened up the hood and checked all the fluid levels. This is the first time the truck has given me any trouble at barely 300 miles away from it's first 50K. As soon as I got back into the truck and tipped the ignition switch, it started right up as it normally does.
Is it possible the relay that actually powers the starter is going to belly up and it's blowing a code because the ecm isn't sensing power when I tip the ignition switch to start the truck?
Ski in TX
601 Internal Control Module Memory Check-Sum Error. any ideas. The truck has about 168,000 miles on the clock.
