Subaru Impreza Accesories & Modifications
Discuss the add ons and changes you're making to improve your Impreza here.
I don't want the conventional bungie cords, but rather what I was hoping to find was something with vinyl straps with plastic snap connectors, something like what you might find on a fanny pack. So far I haven't had much luck in finding this.
However...
I was wondering about the cargo net that's offered for the Baja's bed.
Any thoughts? Do you think this could work on the roof rack, and/or cargo area? Does it stretch to fit cargo? Do you think it might be too big?
Bob
For the Baja I'm sure it's fine, but not for my needs.
Bob
-juice
Thule also sells one. I don't have any experience with it. Looks similar, a little more expensive.
Thanks dustin
-juice
-juice
Either they changed the mounting or you're RHD.
Under the passenger seat is where mine was.
Now I have under each seat.
-Dave
So, they did indeed changed the mounting and where mounted.
all this cost 1,900 im selling everything for 1000 thats a damm good deal Intake, cat back exhaust is SPT Down pipe, and heat sheild, up pipe are cobb
-mike
Many thanks for helping in advance.
-mike
I bought my 07 wagon in Mar so it wasn't a late 07 model.
I do have something on my dashboard that looks like a mic and I remember I was told by my dealer that I did have bluetooth, so it would be a bummer to not have it since CA laws will start no cellphone in june 08.
Let me do a quick bit of research on the bluetooth for yah.
-mike
-mike
Alex
They're all over the place nowadays.
The ECU will auto-remap though if you do decide to put them on.
-mike
-mike
I'm trying to decide between an acrylic bug deflector or a vinyl hood cover. What are the benefits/draw-backs of either purchase? Is one better than the other?
Thanks for your help!
~Seth
Problem with a bra is that it will build up dirt under it and then the vibration of the hood will grind that dirt into your hood. The other problem is the area under it will fade at a different rate than the rest of the car.
I'm a big fan of the acrylic bug deflectors, at least on my SUVs, not particularly on my subies.
-mike
I'm mostly just looking to not look at a little area of chipped paint already on the front of the hood. Sounds like the bra may cause more of these little areas. Thanks for your input on this.
~Seth
I was just quoted $400 for the part and $198 for installation.
A lot of money for something that is "XM ready." Anyone install it themselves?
thanks heaps
Almost everyone falls under the 3750 service if you read the fine print.
I just sold a Legacy and had all the records and the buyer didn't even glance at them. It was strange. :confuse:
As for the poster, and the voiding of warranty, that is the same across the board with any and all manufacturers.
With that said, I've run my LGT wagon at Pocono Raceway and Watkins Glen with no issues
-mike
I'm back because my 2002 wrx wagon (123,000 miles) has moved past doing majority (all work) @ dealer to my local guys up the street.
What I need now? Struts in rear. I'm fine with being pointed in various other directions, but after seeing the depth and breadth of info and realizing my experience in sorting is negatively affected by the infrequency in doing this kind of potential "upgrading" tells me to ask you all some questions.
My questions:
1. Subaru dealer quoted something like $750+ for replacement of rear pair. Local guy quoted something like $550+ for same pair of what must be OEM replacement. I'll go to the local guy on that one, but...
2. Local guy said if I could find them myself, he'd put them in. Suggestions on tracking down a worthy replacement pair? Suggestions regarding just going ahead and replacing all four (and purchasing a set of four) versus waiting for fronts needing replacement?
3. If I bought replacement (just rear, or both front and rear), why not upgrade? I'm NOT a tuner, but on the other hand, it would be fun to finally make changes that are upgrades that push the car's fun factor (which I modestly enjoy but do not pursue in any serious manner).
I'm seeing the most references on the web to KYB, then Tokico, and a bit on Koni. Am I over-buying to look into the KYB GR-2? the KYB AGX? Would these require purchasing some kind of additional kit just to install? I'm seeing AGX's from $450 to $650 for set of four, but is that overkill for me. With Tokico, I'm seeing reference to the HP gas strut and prices @ around $360 for four and for the Spec D set @ about $600. Am I overbuying? Will they be more trouble that their fun factor on city streets?
4, Though mentioned above, do I need to purchase supporting materials in order to purchase upgraded struts? Likewise, with closer to OEM replacement, is there another purchase I'll end up making that I should factor into the deal (I HATE getting suprised after the shipment is on it's way I needed more to get the work completed).
Sorry for the length and sorry if my brief search into other posts missed what would have been the answers to these questions. Any help with part or all would be greatly appreciated. I've loved the car as a daily driver. I'm even working my way thru a 2nd teenage daughter who will learn to drive while learning to do so on this manual transmission.
Thomas in Mpls
For a street car daily driven, the GR2 is an OEM replacement and a good one at that. I always suggest people replace struts in sets of 4, because if 2 are bad, then likely all 4 are bad. AGX is similar to GR2 but are adjustable so you can adjust to a stiffer setting. Konis are a lot of labor because they are inserts.
As for installation costs, it should not cost more than $300 for the labor for all 4 and shouldn't take much more than 1.5 or 2hrs to install. We have done all 4 on a sedan w/o air tools in 27 minutes.
I would go with the GR2s which can be had for about $89/each at various online resellers.
-mike
Local guy that's done work on this car (cylinder and radiator work) wants $522 for labor to do the install so I guess I've got to ask around about that piece if you're estimating $300.
Glad your advice matches what I seem to have come up with, though as I really want to get that new ride feel back.
Any thoughts on the benefits of those strut tower mounts?
T in Mpls
-mike
checked about five places about putting in the struts and plates (front and back) and the estimates ranged from my regular guy @ $522 all the way up to $1000. Three of them were in the $700 range. OUCH! Guess I'll go back to the guy I already have working on the car for $522.
Thomas in Mpls
