Kia Sorento Vibration Problems
I just bought a used 03 sorento & even at the time of test drive there was a noise that only happens when you turn the car off & start back up & begin moving about 5mph. There is a slight vibration under the front end. The dealer told me it is the abs pump activating but they are not kia dealers & wanted to see if anyone else has the same issue.
Brad
Brad
Everytime you start the car and put it in gear, either "D" or "R" and drive, you feel a vibration at the gas pedal and notice the noise within few seconds.
Brad
The TSB fix should be done under warranty......
This current visit explained to multiple people that this vibration is a big negative. Shared that people who drive my KIA have agreed that it is not normal. Surprise!!! when I pushed harder to quote tech who is checking out "customer states:vibration felt when driving at parking speed and turning"---"Found that vehicle vibrates BADLY when turning into parking space (slow speeds)". About time guys!!!
A fluid exchange to eliminate vibration was done. It didn't improve things so a STEPPER MOTOR is being added. Can someone educate me as to what a Stepper Motor does? Also, what kind of damage could this long term vibration have caused?
Anyone else had this problem?
Two Blue Eyes
BTW, I get a vibration for about a second when first moving from a stop in both forward and reverse. This only occurs after the car has been parked for a while. This may the the drive shaft torque issue mentioned several times in this forum. They have no fix at this point or so I've been told.
Took a lot of frustration to get taken seriously but the final resolution is good. It will take a lot of effort from the dealership to take away the months of frustration. Time will tell.
Two Blue Eyes
:surprise:
I'll look to see if I still have the receipt..should. I'll look this weekend in between watching the Olympics!!! Have not got my complete "fix". Oops...I digress. I'll check and do a post. Worst case I can give you the location of my favorite Service person. He's learned to listen when I have an issue. I get GREAT service these days. twoblueeyes
SUVs and Smart Shopper
Troy no luck on the receipt with the part #. Will post again...have to go through receipts for taxes so with luck it will be there.
I have a the same car with 5000 miles on it. I have not had any vibration probelems what so ever. It has Kumho Solas KL21 18" tires and Kia alloy rims.
The only problem I have is sometimes the nav package takes 5 minutes to load, the de4aler will reload the software when its in for its oil change other than that its been problem free.
As far as the spraying etc., I have found that the folks who prep new cars are pretty clueless about a number of things. For example, improper use of tire dressing can cause the brakes to not function properly if spray gets on the rotors. spraying undercoating which gets on drive shafts will cause vibration.
hope that helps. rr70
On it and never had vibration in the cabin... It rides rather smooth
