Toyota Solara Audio Systems
Share questions and answers about CD players, stereo systems, XM and Sirius, iPOD, and tape decks.
I've never before had an antenna like the one on the Solara.
Might that design be an issue?
Meegwel
Is yours fixed yet?
Did your problem get fixed? How?
enctiger
But my stereo was fading in and out on a random basis so I took it in under warranty last month and guess what... they replaced the amp... and guess what, it didn't fix the problem. I'm taking it back in Saturday and I'm glad I found this forum so I can show them that someone successfully had theirs fixed with the switch behind the rear seat. I had tried telling them I thought it was the switch that kicks the amp in and out when the top goes up and down but they still replaced the amp. At least I have a new amp now that didn't cost me anything.
Anyway.... yes, it is the switch.
Has anyone replaced the switch on their own? How much was it, and how difficult was it? I have an extended warranty with a $100 deductible, and if I can do it cheaper than that, I'll do it myself.
Typical radio allows you to minimize the effect or even defeat it. Check your user manual to make sure. It should be part of the Tone control of the radio. Toyota may call it by different name but the concept is still the same.
Good Luck
jt
I was wondering where can i get the code for my OEM cd player,i don't have the manual.Call the dealer or what ?
THANKS
Could you please advise if switch can be accessed through trunk on passenger side or do you have to remove rear seat ? Please confirm location of switch ? Do you have part number of switch.
Sit in back seat passenger side. Remove panel which is on top which is below rear window, same panel where seat belt goes into panel at top. You will need to remove #2 phillips screws which hold panel in place. Screws are hiding behind seat belt front cover where belt goes down in panel, under cup holder which allows arm rest cover to lift off and one more right on left side of head rest in corner. Remove panel. You will see switch which is in verticle position. Remove switch with torx screw driver. (2-screws) You will need to purchase switch qty-1 p/n: 84231-06010 switch 2008 price approx. $22.00 and go ahead and purchase some new panel clips, qty-4 p/n: 75868-06020 $2.00 each. Note: remove two washers which are under old switch and place under new switch. Reverse assembly with everything.
If for any reason you want to by-pass switch, just unplug switch. Radio will still work in standard mode. The amp sound will not increase in performance when top is down and sound will not be as sharp. This will allow you to save some money if budget for new switch is not available..
Gus
Paula
Any advice or experience?
My 2003 had the JBL "premium" sound system, which I don't believe this new model has.
I believe that this sound system is inferior to what I had in my '03, and I'd like to try to remedy that.
What have others done to improve their sound? I was thinking of first simply trying replacing the rear 6x9 coaxial spears. I'd like to take this one step at a time as this is a brand new vehicle and I'm a tad hesitant about making any major changes.
Any suggestions?
I left detailed procedure how to install and parts needed Switch was approx. $20.00
The switch is on the passenger side. I took both sides thinking it might be on the drivers side. It's on the passenger side behind the roof motor - sort of hard to find. It is a switch which is black with a black rubber covering on the switch itself.
I've managed to remove the panel but can't see any vertical switch. An earlier post says it's covered with a black rubber jacket? How big is it?
Is it UNDER the arm rest? I didn't remove that panel - yet.
What wiring is running from/to it?
Help!
I just went to the Toyota dealer. He says part number 84231-06010 is a courtesy lamp switch - cost=$20.50. He gave me a print out/diagram and that part number goes to a courtesy lamp in the passenger door. Then I gave him the clip number 75868-06020 and, while this number matched up to clips, they were $5 each. Kinda pricy for a small piece of plastic. Now if I can't get the right parts I'd like to just bypass the switch if only I could find it?
