Subaru Forester (up to 2005)
Cherokee or Forester? Well, they're very difference tools for similar jobs.
The nice thing about the Soob is that the center differential allows truly full-time AWD, with no buttons to push. So if you are going in and out of slippery conditions, you don't have to worry about turning it on or off.
Also, since you're commuting, I think you'll find the Forester is more comfortable and efficient. The guys don't have to know that!
Get the Forester, and slap on the rhino bar and fender flares. Your secret is safe with us!
-juice
By CHERYL JENSEN
HREE years ago, when I had a chance to directly compare small sport utilities, they were easy to rank: Subaru Forester first, Honda CR-V second and Toyota RAV4 third. There are more players now, and they are better -- but harder to choose among.
1. FORD ESCAPE With an independent rear suspension and rack-and-pinion steering, the Escape handled accurately and predictably, and it rode well. On loose, washboard surfaces, it refused to skitter or skate. Although a four-cylinder engine and five-speed manual transmission are standard, we drove a fancier XLT with a V-6 and four-speed automatic, which upshifted smoothly, downshifted quickly and didn't hunt for gears on hills. The economy rating is only 18 m.p.g. in town, but the Escape can tow 3,500 pounds -- by far the most in this group.
The four-wheel-drive system is automatic, but it also has a dashboard switch that locks the center differential, splitting the torque equally between front and rear wheels -- an advantage in deep snow.
Though it is 17 inches shorter than a four-door Explorer, the Escape feels relatively big, and its 33 cubic feet of cargo capacity give it a slight edge. The XLT's reclining, split rear seat folds very flat, and the rear seatbacks recline for comfort. On the minus side, there are head restraints and shoulder belts for only two back-seat passengers.
Other interior touches were also unimpressive: a flimsy rear cargo cover, a balky seat-folding mechanism and sloppy-fitting upholstery that partly covered the lower child-seat anchors.
2. TOYOTA RAV4 The last RAV4 was severely space-challenged, but the '01 is roomier. The second-row seats slide 6 inches fore and aft, providing a tradeoff between legroom and cargo space. They can even be removed.
The RAV4 is nimble, too, and easy to drive, although its body movements are not as well controlled as the Escape's.
Although the base price of $19,145 is attractive, it does not include features standard on the Escape, like antilock brakes and air-conditioning. But prospective buyers might consider that Toyota has a better record than Ford on quality and reliability, according to several customer surveys, and that the Escape was the object of four recalls before it had begun to sell in volume.
3. (tie) HYUNDAI SANTA FE In my view, third place is a tossup between the Hyundai and the Subaru, which are actually quite different. Someone who wants a more trucklike vehicle, with a lot of features at a reasonable price, may find a lot to like in the Santa Fe. Those who want more of an all-wheel-drive station wagon should be pleased with the new Forester.
I liked the Santa Fe's exterior styling, and that swoopy design carried over nicely to the interior. The softer ride results in a fair amount of body lean. The Hyundai did not seem as quick as the Escape; it was the heaviest vehicle in the group, and it had less horsepower and torque than the Ford.
3. (tie) SUBARU FORESTER The Forester feels the most like a car, although its ride was a bit stiff. And compared with the Escape, RAV4 and Santa Fe, washboard surfaces seemed to bother it more.
The Forester's new features for 2001 include a 31.5-inch sunroof that extends over part of the back seat. The downside is that it cuts into headroom back there.
5. HONDA CR-V Compared with the others, the CR-V felt most like a nose-heavy, front-drive car. Over a broken surface, the rear tended to hop and skitter, and the Honda felt less agile than the lighter RAV4. Nor did the CR-V seem as sturdy or stable as the others, especially on rough roads. But it does have clever touches, including a cargo cover that turns into a picnic table and a deep bin for wet clothes under the rear floor.
By JAMES G. COBB
LAYING musical driver's seats attunes one to a vehicle's personality, strengths and quirks. Solid and substantial, the Santa Fe exceeded my expectations. The much-improved RAV4 is impressive in many ways. But the Escape was the standout, striking a fine balance between fun and utility and capably handling every road, trail or track maneuver.
1. FORD ESCAPE Its V-6 was peppy, its transmission was smooth, its handling was quick and sharp, its steering was precise and linear -- no wonder the Escape felt best on-road or off. On the test track, it was the least likely to come unglued.
Further, Ford's four-wheel-drive system -- which can split the torque between axles -- showed the most promise in light off-road driving. The Escape was able to climb partway up a steep hill of sand.
Negatives? Though the controls seem durable, bits of trim felt cheap. The instrument panel was the most trucklike. The cargo area was spacious but lacked the storage nooks and trays of the others.
2. TOYOTA RAV4 The original was frisky, but too tiny and tinny to be taken seriously. For 2001, the RAV4 has grown up. Adults can use the back seat, and the comfortable cabin is plush and Lexus-like. The styling is fresh and the instruments look great, with metallic trim and a sporty, central tachometer.
When pushed, the RAV4 seemed tail-happy, and its scant clearance made it the least adventurous. Also, Toyota makes you pay extra for items that ought to be standard.
3. HYUNDAI SANTA FE The Santa Fe feels larger and heavier than its rivals, more like a midsize S.U.V. from Detroit, and it came across (surprise!) as the most upscale. Its body structure felt strong and solid, and its road manners were generally good. The Santa Fe also had the only shift-it-yourself automatic, an aid on hilly back roads.
On the track, the Santa Fe fell in the middle of the pack -- not as proficient as the Escape or as eager as the RAV4, but more predictable than the Forester or CR-V.
4. SUBARU FORESTER You sit down low in the Forester, your first clue that it really is a car under the skin. And since it is classified as a car, the Forester meets the stringent safety and emissions standards of automobiles. Subaru's sophisticated all-wheel-drive system, which seamlessly shifts power not just from front to rear, but also from side to side, is a positive. But the horizontally opposed four-cylinder engine lacks punch.
The Forester is a pretty good car, a safe choice for someone who wants a small, all-wheel-drive wagon. But it didn't deliver any thrills, and I found it the least fun to drive.
5. HONDA CR-V Its sales success notwithstanding, the CR-V felt outclassed in competition. This is partly because of its dated design and partly because of its sedate four-cylinder engine. The least expensive test car, it also felt the cheapest.
In cornering, the CR-V tended to plow ahead, and it was hard to steer during a panic stop -- the kind of maneuver required if you topped a hill to find a deer in the road.
Although I took some note of the postings here, the enthusiasm of Subaru owners can also be taken as self-congratulatory--I bought it so it must be good. I'm sure there were many Ford Pinto owners who defended their selection as do Kia owners today. The one thing we didn't consider was price since the Forester was not the least expensive choice--nor were we going to buy a Lexus or Mercedes.
Everyone has to decide what is best for them. What amazes me is that people will buy strictly on brand loyalty, styling or even "its got to be made in America". To say that I'm going to buy an Escape because it looks nice and that people are not really having trouble with them and the world is just full of gripers, just doesn't make sense when you consider safety, peace of mind and the big financial outlay.
Also reviewers have cast a shadow over the independence of their writing if ads and favours are involved in the publication. This is not a whine about the Forester's low place in the reviews posted, but simply the fact that there are different strokes for different folks and we are happy--so far--with our choice.
Cheers, Al
As for self-congralutory attitude, it's present on every forum of course, but Subaru fans seem to be a little more objective than Kia ones, IMHO.
You see, I do not congratulate myself on that Accord purchase. Cannot wait to rid of it.
Smooth tranny? C'mon, that's the nightmare-ish CD4E used in 4 cylinder 626 models that are known lemons. Read the Escape topics.
The reviewer does not mention the Escape's 4WD system is part-time only, and can only be used on slippery surfaces else binding of the axles will occur.
If the Forester's unibody makes it a car, shouldn't the Escape's also qualify it as a car? The platform is a 626 (car), and so is the powertrain, with a Taurus engine and a Contour/626 transmission.
NY Times says the H4 lacks punch, while the Washington Post though it was a 6 cylinder! Different perspectives?
As for made-in-the-USA hype, I don't buy it. Heck, one could argue Subaru is owned by GM, so ultimately it's an american owned company. Jeep is owned by Daimler (the Chrysler half is silent), so technically a Neon is German owned.
-juice
Well, we picked up our black Forester S+ yesterday and I'm already in love with the damn thing. One big reason we might have bought the Cherokee instead would be the price difference.
Chrysler is offering a $1500 rebate so it's about $3K to 4K difference between a loaded Cherokee Sport & the Forester S+. But so far we aren't regretting shelling out the extra cash.
We had a Honda Civic EX before, and the Forester
feels like a Civic on steroids! The Forester
has way more power, handles better & just feels more agile & muscular than the Civic. It's not
too wimpy compared to the Cherokee either!
One complaint about our Forester though:
it has this annoying rattling sound coming from
the driver's side seat belt anchor (right behind
your left ear). Anyone else have this rattle?
And the whole car tends to gently wobble when idling.
on the Forester...The manual says
15, 25, 40 & 45mph for normal driving
20, 30, 45 & 55mph feel more right to me
though (around 3000 rpm). Am I gonna get killed on gas mileage?
Also, I'd welcome any comments on breaking-in a new Subaru. The manual says keep it under 4000 rpm for the first 1000 miles. This seems unusually gentle.
Eric
I find that shifting a little higher than 3000RPM (about 3200RPM) yields smoother shifts. Higher revs don't necessarily mean worse milage. It all depends on where the engine is most efficient. I've heard reports of owners who got better milage from shifting higher vs. at 2500RPM.
4000RPM is pretty commonplace. I've heard that a lot for new vehicles. Since the H4 engine has plenty of low-end torque, you probably won't need to hit 4000RPM+ for normal driving. After the break in period, you'll have all the chances to really experience the boxer engine.
Possibly an even more important factor is to not let the engine stay at one RPM for too long. This means varying speeds and gears on highway driving and not using cruise control.
Ken
http://natescape.com/subaru/
Sweet-looking Forester!
It looks you have a pretty tall passenger
I have the same Forester color except mine has
the rear spoiler & the fender flares.
Have you thought about tinting your windows?
I've been thinking about tinting mine to cut
down on heat/glare but was wondering if anyone
else has done it.
-Eric
Russ
Have you had the tint long enough to see if it
cuts down on interior heating?
About this driver side rattle,
it seems like I'm the only Forester owner
with this annoyance (tiny rattling inside the seatbelt anchor). I called the dealership & they said they could try to fix it but I'd have to leave the car with them for a day.
-Eric
-Tony
I have had my car since the very end of September and therefore can not comment on the tint cutting down on heat. I suspect that it will help. There are quite a few post from people that the Tint will cut down on the heat. You should try doing a search in the modifications section.
Russ
I plan to get the windows tinted before the summer. I have a toddler and a baby, so it'll be important. Can you get the moonroof tinted too?
Russ
I plan to tint my black Forester once I get around to it. Thinking about 20% or 35% tint, what do you think?. Tinting the sunroof seems unecessary, I agree. Speaking of which, one good solution to my seatbelt rattle seems to be just open up the roof. The windnoise drowns out everything
I just hauled our Christmas tree home which would
have been hell to do in our old Civic.
I don't have kids but I've carried 3-4 adults
in my Forester & heards plenty of complaints about how cramped it is in the back. There's probably plenty of legroom for kids though.
Back to Foresters, the car I ended up with had the "Premium Sound Package". Yuck. I gotta get under that front seat and yank that "sub-woofer" out of there, it throws off the bass-treble balance dreadfully (I can't hear the treble and midrange parts because of the boom coming from under the seat, even with the bass turned all the way down to -5!). That, and the auto-dimming mirror, are in my opinion the two worst options that you could get for the Forester. (Well, the auto-dimming mirror at least is easy to work around, just put a patch of black tape over the front sensor and use the button on the left to pretend it's a "real" mirror).
That being said, we did go out with friends in the back seat and they thought it was spacious enough (they're probably 5' 8" and 5' 9-10"). I think it wouldn't do too well with a bunch of 6-footers in there, but should do OK for most other situations.
New to the forum . . . have decided to buy a Forester and am considering buying used. I've seen a 1998 S series, 5 speed, 26,000 miles advertised (by a dealer) for $17,900. I would welcome views on the 1998 model and what folks think is a reasonable price.
I'm also looking at new Forester Ls. Can anyone recommend a good dealer in the Washington, DC area?
Juice:
Was'nt the steel safety cage improved in '99s and up? I think I saw/heard this on a Dateline NBC crash test episode...maybe someone in the know can clarify.
-Tony
What's the Kelley Blue Book on the 98 Forester S? That's pretty low milage so the dealer might be commanding a premium.
I currently own a 98 Forester S 5-speed and enjoy it very much. Like Tony writes, if you can afford it, get a new model because of the improvements Subaru has made over the years.
Some of the improvements are:
- Engine switched from DOHC to SOHC
- 5-speed tranny upgraded
- Some modification to safety cage
If I were to buy that vehicle, I would check the 5-speed tranny. Early 98 models had a faulty pressure plate that caused premature wear. Later 98 models (manufactured after March 99) have improved trannies.
Ken
The prices for a new Forester L is not going to be that much more than the $17K vehicle you were looking at.
Below is the link to Fitzgerald' Auto Mall. Their Subaru store is in Rockville, about two blocks from White Flint Mall, on Rockville Pike. Look up new Foresters on their site and you will see their bottom line no-haggle price on all models they currently have in stock. Besides the new Forester, we also have a '96 Impreza Outback, and both vehicles were bought there.
Bob
http://www.fitzgeraldautomall.com/
Did you put 17" wheels on your Forester? Those
wheels appear larger than the stock 16s
Unfortunately for me Oregon prohibits tinting any of the forward windows. But I've seen
plenty of cars around Portland with total tint jobs so maybe it's no big deal. The one tint place I talked to said they'd tint my car any way I'd want it, but for cash only & no receipt.
Pretty shady!
-E
-Frank P.
The new one is a better deal. The '99s got extra chassis bracing and cruise control standard, plus the Phase II engine. The 2000s got a few more options standard, and the 2001 got even more plus a face lift. So you get 2 trip odos, outside temp gauge, window antennae, and a bunch of other stuff in the deal. Plus 3 years longer warranty, and a new car to boot, all for $1400.
Darn, I just talked you out of buying mine used, didn't I?
I have a 35% tint, and the A/C is frigid most of the time. I keep the fan at the "1" setting and it's still too cold - so I manually turn the A/C on and off every few minutes or so.
I think by 35% they mean the amount of light allowed in, and so it would mean roughly 65% of the heat is blocked as well.
My seat belt doesn't rattle, but let us know if you figure it out. It is adjustable for height, so try a different height setting to see if that helps.
-juice
A question: I notice your crossbar on your roof rack seems to be over the door pillar where I've been trying to put ours. Did you have any difficulty mounting the front bar at that point? There seems to be a lot of bow to the crossbar so it is impossibly tight. (I do have the shorter bar on the rear). Any suggestions would be appreciated.
Cheers, Al
-juice
Bob
-juice
Mike
Walter Creedon
Also join us under the Owner's Clubs topics (Subaru Crew), which are more active.
-juice
This summer I was on some very steep and badly eroded logging roads. I followed the owner's manual advise and used second gear, but felt I should have been in a lower gear (especially coming off the mountain). What gear should I use on steep mountain roads? Is it alright to use first gear, or should I continue to use second gear?
Thanks a bunch.
Ray
Using first for very low, crawl speeds is fine. Actually, driving on sand I found 1st gear was best, and my manual tranny's 1st gear ratio is higher than your auto's.
-juice
You guys do a great job with this site!!!
Ray
Anne
Ouch. A lot of people here have missed her. Please wish her my best if you do speak to her.
-juice
-OregonSubie
Anne
-juice
