Mazda B-Series Transmission Problems
This is the place to downshift and discuss your B-truck's malfunctioning tranny
kcram - Pickups Host
must be a defect in manufactoring clunking when switching from second to third gear and sometimes winding out and jerking the truck when changing gears.
So when it made a funny noise upon starting it up he decided to sell it.
But,for some reason,I can not find a book or a person with the know how to tell me How Much Gear Oil does it take.I would really appreciate any help
The truck has also been lowered and now has 17" tires on it.The rims are 1200.00 not bad considering I got the truck for 500.00.Question is will the speed-o be off and how bad?Sorry guys but,I have no Idea and,I'm counting on your help.Thanks a million up front.
2001 Madza B300 was that the servo was melted and that meant the transmission needed rebuilt. They rebuilt it and put in a new converter at the cost of $1391.00 .
Good news is that the truck is running like brand new.The tech said that it had a ford transmission and that when they built the rangers and mazda trucks that they put the exhaust too close to the transmission and that it heats up and over time, melts the servo. He sees it all the time. Hope this info is helpful to you.
Rebuild recommended so far, but I don't want to throw money at it if it is something easy to repair.
http://www.freeasestudyguides.com/automatic-transmission-tcc-torque-converter-clutch.html
If you can locate the torque converter clutch solenoid and temporarily disconnect it, and if by doing that your symptoms go away, then the solenoid is probably sticking and not allowing lock-up to release (same as not depressing the clutch on a manual transmission car when you come to a stop). So you stall.
Don't drive the truck any distance with the TCC solenoid disconnected!
