I personally have the factory Bridgestones on my 08 Sport, and had them siped right from the beginning. They have worn 1/32" in 5000 miles and did okay in the snow, too.
I've been looking at the Bridgestones and Kumho brands but have not made up my mind as of yet.
What kind of tire did you go with and what kind of mileage did you get out of them? I think the Toyos would have done better but while having it serviced by Toyota somehow they all got 36 lbs of pressure in them and wore the middle pretty good before I caught it.
Thanks in advance for any replies and help.
Don
I was unimpressed with the performance of the original Toyo tyres on my 2005 Kluger (Highlander to you) and they wore out at 44914 km (28,000miles). The Toyos had poor grip under most conditions and very poor lateral stability. They were particularly nasty off bitumen
I do some off bitumen work and wanted a good mud/snow tyre with good on highway characteristics. I fitted Yokohama 225/70R16 102H pattern G051 H/T-S 30 months ago.
I now have about 75,000 km (say 48,000 miles) on the Yokohamas in 30 months and they still have probably 20,000 km wear. I checked tread depth last night and they are wearing consistently. Wet weather gripmis still good although I feel that they are just staring to go off a bit.
It is however critical to get the Kluger alignment checked about every six months (four wheel alignment on laser machine) as they do slip out, particualrly if driven over bumpy surfaces and check inflation regularly. They are less susceptible to inconsisntent tyre pressure than many vehicles but it does affect wear and handling.
Cheers
Graham
Separate to the tyre choice question, I also have been caught with the overinflation game. Recently noiced that handling seemed shaper than usual and found pressures above 40PSI. Also, tyre shops tend to overtorque wheel nots. Last tyre rotation, I found nuts over tensioned dreadfully and had to buy a long breaker bar as I could not easily remove them. A reasonable torque wrench can be picked up for less than USD100 and socket is about USD 10 so you can easily adjust the nuts. If you don't you risk damaging studs and brake discs.
Cheers
Graham
I have an 08 HiHy limited with the 19's :mad: and want to see if you are still pleased with the Michelins. I am concerned where we do drive in snow for 5 mos out of the year and you seemed concerned with the height of the tire.
Any feedback would be appreciated.....Mark
Now I'm out $200 for shipping, even if I get the vendor to refund the $899 for the tires and wheels (Visa 'won't dispute shipping charges'), and am back to square one.
I visited the local Discount TIre and found these for about $160 each:
http://www.enkei.com/wdm.html
and with the Michelin tires I wanted (Latitudes) for about $1350 - plus of course the $200 idiot tax for trying to save $200 overall with the eBay vendor...
So beware of these guys - they're less than up front about their business practices:
Wheels and Tires International http://cgi.ebay.com/ebaymotors/18-Toyota-Highlander-wheels-Goodyear-Fortera-Tire- s_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1171Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318- Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem120382506186- QQitemZ120382506186QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Sounds to me like tey should alos be reported not only to eBay, but the BBB in CT.
That would be a red flag alert.
SUVs and Smart Shopper
Now my problem is getting the tire pressure inflation system light on the dash to go off. Will road test it later this afternoon and report back to everyone.
SnoSkier
Now, when my factory 19" tires wear out I'm going to give a shot at looking at 255/55-19 tires to replace the 245's. DiscountTire.com has a highly rated Hankook all-season for $185 w 65,000 warranty that they claim will fit without a problem.
Generally, you should only be changing the profile if you're changing the wheel diameter. (Going to an 18" wheel in the case of the 08 Highlander).
DiscountTire.com has a 'Tire Size Calculator' on the left side of their home page that can help you with these calculations and it will even tell you how much your speedometer will change.
As I mentioned in an earlier post, DiscountTire.com has a 'Tire Size Calculator' where you enter the current tire's specs and the tire you want to go to and tells you the differences in resulting TIRE profile. You also need to be sensitive to the wheel offset to avoid any problems. It takes some research on your part - call the big online tire sellers and/or trusted local shops and ask. Make sure you get a Fit guarantee just in case somebody makes a mistake.
For sure, going to 20's will give you less height of the tire sidewall (because you'll be moving to 50 series tires) making you more susceptible to pothole damage (a big concern in my part of the country) and will probably result in a rougher ride and a change in handling. If you live where the roads are straight and smooth that will matter less to you. Good Luck!
Is this a common problem?
Can you just get this little piece and replace them?
I may try touch up paint.
Today at Discount Tire, I bought MB Seven X wheels ($78 ea) and Michelin LXT A/T P245/65R-17 at $179 ea (60k miles warranty). Mounted, CERTS (replacement guarantee), TPMS rebuilds -- out the door $1350 or so. I have already submitted my $70 rebate and will put my 19" wheels up for sale on craigslist and/or eBay shortly. Even if I only get a couple of hundred for the set, I'm nearly down to a grand net cost.
Driving home, seemed somewhat quieter. I won't be able to test them in snow for some months, but I'm optimistic. I'll post back after some more miles and weather.
The real problem with the Highlander is that in order for the car to hold the road Toyota requires the Castor and Camber and Toe in to be set so that it causes fast wear on the inside edge of the tires. This is just one of the things that come with owning a Toyota Highlander AWD vehicle. The original set of tires that came on the car had 31,000 on them and they still were not worn down to the tread indicators in the center of the tire but the inside shoulder of all 4 tires was worn to the cord so they had to be replaced. The 4 runner as an example does not have this issue.
Good luck with tires hope this helps nsome of you with the tire issues
In any case TireRack now has the Michelin Latitude Tour 255/60-19 for a special of $108 each if you're willing to be aware of the size implications. And, if you can get the $60 off that hotrod28 mentions, it would make for a nice deal!
They all told me that if it came with 245/55 R19 then they would not recommend me to change even it is a standard size for base model. And ABS and Speedometer may not work properly. At last they mention that my car warranty may void.
So I have to stick with Bridgestone Dueler for $179 a piece. That is the internet price from Firestone. Where can I get better price?
Any of you who change the tire and rim size had talk with your dealer or Toyota Agent about this matter?
Please update the information thanks.
The difference in resulting tire dimensions WHEN NEW is minimal: the 17's diameter is .07" less, the circumference is .22" less, and the speedometer will read .16 MPH less ... once you wear your 19" tires down by just 1/28" you hit the breaking point, and you'll be smaller than those new 17" tires! (1/28" = .0357" * 2 since we're dealing with circumference = .0704"). Why doesn't that change affect your ABS and speedometer? You don't buy new tires every time you wear new tires down by 1/28", do you? And... considering you have about 8 to 9 32nd's of wear from new to worn, you'll be FAR below the the dimensions of a new 17. It's just a matter of mathematics.
I suggest you go to the dealers and ask them to show you what is different. You can also go to discount tire at http://www.discounttire.com/dtcs/infoTireMath.dos and do the calculations and print that page out and take it with you. What they're telling you about switching to 17" wheels/tires just doesn't make any sense at all IMHO! :confuse: It's a shame that they won't try to assist you - probably some recent hires from Plymouth or Oldsmobile dealerships.
I could understand Toyota's concern for those who are changing to 255-60/19's to broaden their tire choices - that changes dimensions significantly (diameter by 1.44" and circumference by 4.52") ! Personally, I would not do that move.
Toyota Dealer told me that they will not do that kind of change and warranty may void but they didn't explain me why.
Sear Tire center manager came out and check wheel and brake clipper clearance and he told me that I can go down to 18 the most because of the clearance. And he mention me about how hybrid system engine, motor and recharging system set up. So I have to order Bridge Stone Dueler HL for my HH. I will stick with that for a while. There may be more choice after 1 year later.
:mad: :mad:
Since I've already bit the bullit, I'll just wait til I go in this fall. I will post details though, when I get 'em.
Finally, Toyota taking care of somebody if that news is true.
So far....so good.....
I briefly considered going to 255/55/R19 per a previous poster (awl1), but I saw more people with success going to the R18's. Also asked the Discount tire tech and he mentioned that going to 255/55 R19's would probably wear fast too (just like the OEM 245/55/ R19's) due to the wheel size and dynamics of the vehicle. He thought that I'd get more lifetime on my tires going to the 18" rims. We'll see...
