Works perfectly with the keyfobs. argh! Any help would be greatly appreciated, thanks!
HELP PLEASE
Anyway......
- disconnect neg. battery cable
- remove the air intake plumbing
- detach the throttle cables from the throttle (both: from gas pedal & from cruise control)
- remove the 2 top motor mounts
- emergency brake on & block the wheels, put the trans in neutral.
- use a ratcheting strap from the top motor hoist loop to somewhere sturdy on the front of the car & pull the engine towards the front. It doesn't go to far but its enough for you to get access. The engine actually "rotates" forward when you pull on it - its actually pretty cool.
-take off the accessory drive belt & belt tensioner
- unbolt the power steering pump & move it out of the way.
-remove the black plastic cover over the windshield wiper mechanicals.
- remove wires & bolts from alternator
-remove alternator
I don't remember if you have to move the wiper linkages on that side out of the way...you might have to. You just loosen the screws on the joints and slide them out...don't remove the screws, they're a bear to get back in
install & reverse the procedure to put it all back together. Its a REALLY tight fit so you'll have to really work at it to get the old one out. Turn it in every direction to finesse it out of where it is.
Some people say its a lot easier to get at it from the bottom, I'm not sure as I did mine from the top. Expect to burn the better part of an afternoon getting it done...its not fun but its certainly doable by a shadetree mechanic. Be sure to check autozone for the instructions as well as I'm sure they';ll give you some better detail - at least you know what you're up against now.
Good Luck,
John :shades:
My temp gauge on my 98 Venture moves to high (extreme right-red) and shuts down the van. No battery power to start...nothing, completely dead. Replaced the alternator and thermostat...$750.00 (ouch). Got the van back two days later the temp gauge is high and the van begins to power out. Maybe I need a new battery, is it electrical, does it have to do with the heating/cooling system. I dont know, and niether does my mechanic. Has anybody had a similair problem or does anyone have a solution. Thanks.
Yesterday my van had the oil pressure light come on, I parked it while it was idling it died. Engine turned over when I was cranking it but would not re-start.
I was going to try and fix that issue today so I took the battery out and gave it 14 hours on 2amp charge overnight
When I replaced the battery, I have NO POWER inside, no lights , no radio, nothing!
I have over 12V at the battery, I checked all the big fuses in the fuse compartment in the engine compartment. When the fuses were out I ensured that I have 12V at the "positive" side of the fuse holder.
The door alarm rings when the key is in the ignition, but as soon as I turn the key to "on" or "start" the dinging stops. Actually as soon as I try to ude ANYTHING with current this stops the door alarm. ie turning the light switch on or plugging anything into the lighter. It seems that this shorts something out?
What am I missing?? There has to be a main fuse or something that I dislodged when removing the battery???????? This is really confusing that I have absolutely NO POWER anywhere, but the battery is showing 12V
Thanks, I hope you can help
I fixed the electrical problem, I had no completely tightened the positive terminal on the battery post. I am dumb, I'm gonna have to blame the cold (Canadian winter working outside = COLD)
Thanks, now just gotta fix the oil presure problem but that is in another post
Yup that's the place...Hey I am having the same problems with my doors that you have described here. My venture is a 2000 though. It is irritating me about as much as an out of tune bee would irritate me.(bees are our enemy on my planet) I would really appreciate it if you could Email me or post me a reply if you find a solution. I will do the same if i find it first. My word or na-noo, na-noo.(i know, weak) Will look in as i usually do. thanks...Lew.
I thought of doing it myself but I need a little nudge to tell me where to look for it and I thought maybe someone else has the same problem, plus my fuel gauge says I am empty when I sit at a red light or driving takes a long time for it to go back up. Plus I have the bucking problem to at one time or another. Am I crazy or is this VAN? Did anyone find out what kind of recalls it had cause my dealer said they are NO recall's on the Chevy Venture vans plus if they were my mileage is above warranty. I bought it used. :sick: :lemon:
Any suggestions?
This has been going on since i hade the pressure control solenoid changed in my tranny, gas guage no longer works, i push brakes and gas guage goes down, I push gas and it goes up. abs and service engine lights are both on now and codes say evap system malfunction. cooling fans do not work. and now it wont start, no turn over from starter period and when it does and shuts right off, overhead information center displays dashed and thats it now speedometer or temp guage do not work and light that illumites PRND321 doesnt work. when this light is on the van will start. is this a computer related problem and if so which one? also once it starts the battery indicator flashed and so does security and oil but all fluids are good, new starter and battery
I have no idea where to start with this. Any help would be amazing!
(Ps. I just found a coolant leak...the crappy dex cool stuff...and it's leaking right by the belt and battery...could that be a cause of the problem or is it something with the wiring? No fuses are blown)
I have a 2000 Venture. A few weeks ago I came out in the morning and it wouldn't start or turn over at all. It bleeped 1/2 second then went dead. We jumped it, took it to church, turned it off. An hour and half later dead again. Jumped it again. Took it home, let it run for about half hour. Turned it off and let it sit for a few hours. Started right back up again. We thought we were going to need a new battery, but for a couple weeks now it has been running with no problems of dimming lights or things not working. Then yesterday, without warning, after running errands, we came out of the mall and it wouldn't turn over or start. Had to have it jumped again, took it home. Shut it off, and tried it again, and it was dead. Wouldn't even turn over. Sat for about 8 hours (til hubby got home) who jumped it, let it run for about 15 min. Shut off, and then tried it and started right up again. Turned it off til morning (9 hours later) went out to start it and it started up. Took my daughter somewhere this morning, came home, turned it off. 5 hours later started right up again.
so...last night after my hubby had to jump it for the 2nd time and I sat in it letting it run for 15 min, I noticed it was vibrating a bit (never had before) like maybe it was hesitating and possibly wanted to quit (but it wasn't real noticeable, I just notice the slight centimeter of anything wrong with this van). I wasn't sure if that was worth mentioning or not.
Also, my gas gauge has not worked in over a year (hubby said has nothing to do with it). Oh yeah, my check engine light has been on since right after inspection last year (never went off). My hubby's friend had a code reader that told him has something to do w/extreme cold and a hose or fuel injector or something (can't remember right now), and then told him how he could turn that warning light off. So he shut it off.
I am soooo hoping someone can help us out with this as we do not have hundreds of $ to spend on this thing. We want it to last us 1 more year then we are getting something newer (with 3 kids we have to).
Thank you so much in advance for helping us out. We appreciate it. God bless,
Penne
Same here.
Same here.
>We jumped it ... Jumped it again.
I don't have jumper cables at home or another vehicle with which to jump it.
Same here.
>my check engine light has been on since last year
Same here.
The only thing I can think of that is the least bit "different" is that several weeks ago I noticed that whenever it started up there was the sound such as an electric motor might make if you were trying to spray washer fluid on the windshield. That sound may have always been there, but I just noticed it a few months ago.
What should I do to diagnose what the problem is??????
....Ooops!! I just now remembered that two days ago I started the engine and then between the radio chatter and the passenger chatter I somehow stopped concentrating on what I was doing and tried to start the engine when it was already running, but I realized something was wrong and immediately stopped trying to start it. Could this have some bearing on the problem???
But HOW do I test a fuse? They are all colored and have a number such as 20 or 40 on them, but is there something obvious about a broken fuse? And how do you go about geting a fuse OUT to check it. I've tried pulling and squeezing but nothing happens.
Thanks so much in advance,
Penne
If your hubby has a meter have him check to see that it is charging while the engine is ideling. It should give you a reading around 13 to 14 amps.
If your hubby does not have a meter, ask the nearest autoparts place to see if they would check it in the van for you. Most will do it for free.
Thanks again,
Penne
Would I need a special tool to extract a fuse from its slot?
I tried to pull on one and tried to squeeze it a bit to release it but maybe just should have pulled harder.
>it wouldn't start or turn over at all. We jumped it ... Jumped it again.
I was finally able to get someone to drive over with a set of jumper cables but my Chevy 2000 Venture didn't crank at all, so I don't think its a battery problem. What does this leave? Fuse? Starter?
Lights, horn and radio work fine, so I never really thought that it was a dead battery or that the jump start attempt would work, I was just trying to eliminate some possibilities. Whats next???
I went to an auto parts store to look at circuit continuity testers but they varied by voltage and price and nature of the probes. So I didn't know what to buy and wound up not buying anything with which to test the fuses since I just don't know what I am doing.
Do I remove the fuse box that is above the battery first? How?
another possibility might be the key itself! These vans do have that antitheft key fob thing. Do you have a spare key to try?
In the end... you might need to find yourself a good mechanic. Not always a dealership one either!
The one I had the car towed to said it started several times.
He turned the key and it made weird noises but started once.
Then he turned the key several times and it started without the weird noises.
So I drove it about one mile away and stopped for a quick purchase but it would not start, so after sweating in the hot interior of the car to try to get it to start and sweating in the hot sun waiting for a tow truck, he now says its the starter: 258 dollars please.
I posted it in audio forum but looks like we have more traffic here.
Sid
