2 - Car headlights can't be adjusted or turned off at night, no matter what I put the setting to they stay on.
3 - Rear windshield wiper will move but it swings in the opposite (wrong) direction
4 - My mirror adjuster doesn't work.
I just bought this thing with 77k miles on it for 5grand, did I get hosed?
#2 The headlights are run by a dashboard mounted light sensor; if it's dark, the headlights are going to turn on automatically.
#3 Can't help ya.
#4 Make sure the adjuster knob isn't in the center (off) position. Other than that, make sure the fuse isn't blown.
Good luck!
I researched and finally found a fix for non functioning Driver Information Center.
The solution was similar to that found for similar modules on other brands of vehicles.
Remove the Driver Information Center Module
(See GM manual for procedure)
Push back clips from black housing box and carefully remove circuit board
Place circuit card flat on table.
Place display and component side of circuit board facing up
Rotate circuit board so the display module side is facing you
There are button switches on either side of the display module
Look at the right button switch.
Next to it just left and above are four 1/4" X 1/8" black components attached to the circuit board
They are marked 430, 430, 820 and 820 reading from top to bottom.
These are resistors with 43 and 82 ohm values.
On the two modules I have repaired the problem was with the top most resistor. It is marked 430 and is 1/2" above and 1/4" to the left of the right button switch. The soldering to the circuit board had fractured. I resoldered the resistor into place using a bit of solder and 15 Watt pencil soldering iron.
All fixed.
The problem is NOT the black spot on the display in the upper left corner
The problem is NOT the DC to DC converter modules.
Why does it come loose?
I believe the resistor was part of the circuit which supplied power to the display module plates.
The resistor came loose due to the metallurgy of solder. The solder often is a mixture of tin and lead. The tin is more strongly attracted to the copper in the circuit board than the lead is attracted. When hot, when within 10% of melting temperature (resistors designed to run hot), the tin near the circuit board face will move. Having moved there is stress in the solder at the locations where it left. These holes create high stress in the solder structure, this leads to a fracture staight across the mounting face of the resistor as smooth and complete as if a knife cut the resistor loose. This only happens in designs which allow parts to heat to values close to the melting point of the solder. This rarely would happen in the past before surface mounted components. The cure would be higher temperature solder, cooler running parts, avoiding flat straight mounting interfaces, etc. Reheating the joint sets it right for a while.
Key words:
Chevy Venture 1999
DIC
VA344314KMD
VFD Vacuum Fluorescent Display
Futuba VA3527 2-BT-225GN
Penne
Did you replace the relay? If not do so and if that doesn't help, replace the fuel pump.
http://newrockies.com?ap_id=iykeus
Tonight the light for the shift display (P R D ! 2 3) started flashing on and off. With in minutes I lost all dash lights and the automatic headlights went out. Headlights worked when I turned them on manually. I get home and the chime for when you leave the headlights on is chiming away, even though the headlights are off.
Checking around the vehicle I find, no running lights, or break lights. None.
So my vehicle chimes when the drivers door is open, I have no dash lights, seems as though the odometer is not advancing, no running lights, bo break lights.
HELP!!!!
any ideas???? i cleaned every connectors from battery to starter,
My dash panel also acts weird. Most of the time the temp gauge is pointing some odd direction, like straight down or straight up, even if the engine is hot or cold. Other times the other gauges will act up like that too. According to the car, I have cruised through my neighborhood at 140+mph. The gauge panel issues started after I had the dealer work on the engine and replace the crank position sensor. I am wondering if they damaged a lead or connection to the engine computer.
