Subaru Forester (up to 2005)
Greg
Forester scores were "Better than Average" and "Good", respectively.
I like the Tribute's styling, and Mazda offers a 3/50 warranty vs. Ford's 3/36. But Subaru tops them both with 5/60.
I test drove and like the Jeep. It did fell a bit "tipsy", but it's not meant to be driven as aggressively as a Forester can go. Autoweek rolled one over, and I found DCX's excuse rather lame (uneven pavement, as if road crews check that all the time). A european magazine also rolled one over, so it wasn't a fluke. DCX should make DSC standard, like they did for the ML.
-juice
1) intrusion of the tranny/t-case into the footwell areas of both front passengers
2) cheap fascias on the dash, and no gear indicator on the dash (only next to the center mounted gear selector)
-mike
Ross
By the way, right after you submit a post you will get a duplicate if you refresh the page. It's a "feature" of our software! ;-)
tidester
SUVs
If a quiet ride is your main concern, you may want to look into Grand Touring tires rather than performance tires. Check out a site like Tire Rack (www.tirerack.com) for more info. Also, you'll most likely NOT find an all-season tire that performs well in snow. Nothing beats dedicated winter tires.
FYI, my Geolandars lasted 45K miles and they've been a good all-around tire.
Ken
-mike
I'm in the process of deciding whether or not to get Full-Replacement Value insurance for my 2002 L from the Dealership or from my insurance company. The Dealer is more but I can get coverage for up to 5yrs, but it's $$ up-front. Insurance company is only 10% extra to my current annual policy but I can only get coverage for up to 2yrs.
Is it worth getting the insurance for the long term or will I get enough from 'the book' price? What is the rate of depreciation of the Forester that insurance companies use? Has anyone had any experience with this? As owners, we've all raved about the high re-sale value but how is that reflected this 'book' price? Thanks.
Mike
-mike
A longer lasting tire usually has a harder, less sticky compound, so it may not grip the road as well. But it might address the noise. I'm not familiar with Toyos, though.
I would not worry about the speed rating too much, since you're not going to drive over 100mph, but do look at the load rating. I think the stock tire is:
215/60R16 85H
The important number is the 85, which tells you how much weight the tire is designed to handle. You do not want to go to a lower number, or it will adversely affect your payload (how much weight you can carry).
You can also check the UTGQ ratings. They will be something like 180BB. The first number is the tread life rating, the second is heat resistance, the third is wet traction. I would try to find something 200AA or better. In fact, if you go with a lower speed rating (S or T), just make sure it still has a heat rating just as good as the stock tire does.
So, we get to see the Forester 6 days earlier than Japan? Wow, for once, we are first! They usually preceed us by 6 months!
torquan: isn't it under warranty? It's a safety feature, so it might be covered. Could be just a short circuit or something. I rented a Montana minivan in Florida that was brand new and it had the same light go on. They told me to keep driving it for the week, that it was OK unless it blinked. But check with Subaru, for sure.
Mike: it's hard to forecast depreciation 3-4 years from now, but so far the Forester has done well. A new model is around the corner and that could have some effect, so waiting for a 2003 could help you.
-juice
What was the pressure you ran Geolandars at? My dealer actually recommends 42 psi (gasp!) for Geolandars. I never went that high, but did like the "road feel" and handling at 35-38 psi.
The Yoko Avis tires are not bad, a bit less noisy than Geolandars. The problem with Avis is that their max psi is 35 and geolandars's 44. I run on Avis at 30-32 psi. I get a bit less bumpy ride, but not nearly as much of road feel, and handling suffers a bit. I also get worse gas mileage on the Avis tires as compared to Geolandars.
I still have a set of 3 Geolandars in my garage, with circumference only 5/32 less then brand new ones. Any good ideas how to put them to use eventually?
adanne- How long have the new tires been on? The last time I changed tires I was ready to take them back due to how loud they where but 100 or so miles later they quieted down considerably.
I am interested in buying a couple of accessories, the brush guard and fender flares, and was wondering if anyone had experience with installing these themselves. Thanks in advance!
They come with two strips of two-side tape, plus they bolt down in about 4-6 places. It's not hard, just do it slowly and carefully, and clean the car before you start.
If you end up buying it, I'll e-mail you some photos and a few more tips. The trick is to remove the lower tape backing first, then the upper one, with the flares already bolted in place. Also, you have to peel just enough off so you can reach the backing after you bolt them down.
It's easier than it sounds.
-juice
The stock Geolandars on the Forester S have a load rating of 94H with a max load of 1477lbs. UTQG is only 200BA, though.
Wow, I can't believe we get to see the new Forester before Japan also! That's pretty cool. I wonder if it had to do with how many more Foresters they sold over here in N. America.
Ken
So what I was saying was to avoid any tires with a load rating lower than "94" in this case. I think my tires are "97", so I'm in good shape, but they're not suitable for snowy climates.
200BA is not bad. The Duelers on the L model are just 180BB. Definitely look for an "A" in traction, so you don't hydroplane into an crash. Try to get an "A" for heat also, but it might be a bit harder to find.
-juice
This time they said it was a too-rich fuel mixture that may have fouled a plug. I'm not buying it; the still has the rough idle in the morning, and even after being driven for 10 or 15 minutes it will hesitate and lurch as if it wants to stall after stops at traffic lights and intersections.
Anyone have a similar experience or a suggested course of action? The dealer is 65 miles away -- not convenient for frequent visits -- and we're losing our patience, not to mention our faith in Subaru. (The Forester, BTW, is our fourth Subie.)
Mo
Kate .. I'm thinking Harley 3 Wheeler
- Hutch
Ross
Ken
Ken
Mo
Patti
-Frank
Frank: There are probably three closer dealers, but we do business with these guys -- two new Subies and a used Acura in the last few years -- because of the way we've been treated. But I've spent so much time there in the past three weeks I'm starting to feel like an employee .
Mo
It may be the plug wires, the ECU, or an injector. I'd maybe ask for a loaner car, then leave it overnight. Ask them to fix it, then test is extensively before returning it to you.
Remember, the sales and service departments are usually separate. If you feel like the other dealer is too far, you shouldn't feel bad about getting service a little closer to home. I'm sure they'll still sell you another car, gladly.
To change the air filter, I found it easier to remove the intake tubing from the MAF forward. If you take the whole air filter box out, you can better place the filter. That also eases access to the spark plugs, BTW, so change the air filter when you change the spark plugs to save time.
Ken is right about the other side, you may have to disconnect the windshield washer reservoir.
-juice
-juice
Juice -- Just 43K miles!? Sandy is still a baby! 66K miles and counting here.
Ken
And I know the sales and service ends are separate profit centers, etc., but I was treated so incredibly and stereotypically badly by our local dealer when we were shopping for a Legacy GT Ltd. a year and a half ago that I've sworn I'll never do any business -- sales or service -- with them again. Call me stubborn ...
Mo
Frank
Price from the dealer is $248. Has anyone added system after market? Also does the price seem reasonable?
Jerry
So I guess the Forester is still my primary car. Much as I love the Miata, the Subie does all the big duties, including hauling the family and all trips.
-juice
Hope this helps!
Ross
Since my 2002 Forester L didn't come with the key less entry what is the cost to purchase this option? It seems as though the plug-in for the system is just under the dash on the drivers side (lower left). Is this something I can get on-line and install myself like the security upgrade you mentioned for $140? Or would the dealer have to install this? Also what all does the key less system do? Does it turn on the the interior lights for example when the doors unlock? Does it automatically lock the doors when the engine is started? etc,etc. One more thing does the security system have an ignition kill feature? Thanks in advance for the feedback!
-Donn
For all others -- a question. My Forester (S Prem) has reached 3100 miles (appx two months). The manual says that engine oil should be chnaged at 3000miles UNLESS driven under *severe* conditions when it should be changed at 3750miles ! This sounds somewhat counterintuitive to me -- shouldn't the oil chnage be more frequent when the car is driven under severe conditions ? Anyway, I don't know enough about cars to know this, so I am asking all the experts out there...
Oh about the car -- so far it has driven like a dream. Probably the first car (though this is only my third) that I haven't had any chance for complaining (well almost none -- see below). Love everyhting about it -- especially the envy of friends when they see the moonroof !! Probably the only complaint was the ride felt a little bumpy. Found that the tire pressure was a little high -- 32 psi. Called the service dept at our dealer and they told me that they keep the pressure high to increase longevity of the tires.
The tire hasn't done too badly in what little snow we have had in upstate NY (we live in Rochester, not Buffalo !!) -- but recently I can hear some rattling noises from the back doors whenever I go over a bump -- my theory is that the speakers might have come loose on the back door panels -- is that possible. Anyhow, I will have the service guys take a look at it when I go in for the oil change.
Thanx.
The first oil change is recommended at 3000miles -- second @ 7500 and then every 7500 unless as above.
So another question -- how come the recommendation is 7500miles instead of the every 3000miles that was recommended on the previous cars I woned (95 Escort and 97 Galant) ? What is the usual oil change frequency for other Forester owners ?
A buddy of mine put the Sport A2 on his Forester S. They seem to perform a little better than the Geolandars according to him, but the difference isn't huge.
Dunno why the other cars recommended 3000. My previous 97 Camry recommended 5000 and our Jetta lists 10000. For my Forester, I changed every 5000 with conventional oil.
Ken
I do my oil every 7500 miles, but lots of my driving is highway and trips. I use my Miata for short errands.
-juice
