Also, have you had any problems with the side doors as others have mentioned?
Thanks for any advice you can give. I am considering a 2010 EX, but I don't want to make an expensive mistake.
http://automobiles.honda.com/news/press-releases-article.aspx?Category=Fit%205-D- oor&Article=2006031670437
So he said very sheepishly, "yeah it's covered". I believe this must be a dealer scam, where they charge us for the repair, AND also bill Honda for the warranty work.
If you have vibration issues, get it fixes while under warranty, and make sure the dealer does not scam you!!!! Our warranty was 60,000 not the 50,000 that the dealer repeatedly said it was.
go google selection bias when you have some free time
I would love to see a forum on edmunds called "Would you buy your vehicle again? Why or why not?".
Be forewarned, though. The older the vehicle, the more complaints there are, and some of them are duplicates. You may be looking for a long time.
More often than not online forums are filled with people having problems. People who don't have any problems aren't going to go posting it nearly as much as those who have problems. Google any make or model and you'll find posts of 'never buying this again' or 'class action lawsuit'... every manufacturer can't make every vehicle perfect.
I've been fortunate enough to not have any problems, and hope those that do will find a solution that satisfies them. At the very least, don't go by just this forum here, check out odysseyowners.com or odyclub.com to broaden your research.
Good luck!
Here's what I am experiencing. Between 1000 & 2000 rpm I hear a tapping noise almost like a valve is tapping. I usually experience this with the ECO mode light on and minimal load on the engine - not trying to accelerate hard and on level ground - sometimes even requiring a quick blip or flutter of the accelerator pedal with window closed.
I have also experienced some shuddering when been more aggressive with the throttle and driving more like a sportscar. Obviously, i don't get a chance to drive without my family so the sportscar stuff is few and far between. Could the shuddering be a more pronounced version of the tapping - increasing in decibels along with fuel consumption?
I'd appreciate any info on whether these noises are related or independent of one another as well as there causes and corrections?
In addition, I wanted to get your experience on the Michelin Tires with PAX run flat system?
Honda dealer says there is a campaign on the 2007 & 2008 models but they reportedly have not seen this problem in 2006 that much. Trying to get Honda of America to help out on this one. So far they are down to $1000... We'll see!
In diagosing the torque converter issue, I had the shudder and a tapping noise like a valve tapping or knock sensor. The dealer did a software update to tell the transmission and torque converter to change the shifting points. The update made the noise and the shuddering much worse.
I don't mind paying something for this repair if it is out of warranty but based upon the 2 possible causes and the process of elimination I've gone through to date, Honda of America should be willing to pay at least the labor. I am sure I can get the part for $500 or less.
Other than this and the crazy PAX system problem, I like this van, the styling and the way it drives as compared to the competition - Toyota and Chrysler.
CAN YOU SAY "CLASS ACTION"?
I THINK U CAN!
Can I get an AMEN!
I have an 2006 that I bought used and they said they'll replace the torque converter and do the front end alignment which is mandatory after they remove the tranny for just over $1000 reduced from $1800. I have 66K on it and would have addressed the TC sooner but the shuddering was not that frequent. I had a tapping noise that is the TC rattling but it was masked by a bad wheel bearing / wheel hub assembly. Once I replaced the left rear wheel hub assembly, I could easily hear the TC chattering. When they reprogrammed my TC or tranny, the noise and the shuddering got louder and more frequent. In its present state, I don;t think it'll last another six months - either I'll get sick of dealing with the noise or it'll simply fail.
If I was working right now, I'd look for another minivan but would either buy something else or find another Non PAX-Touring version with a warranty and no current TC problems - probably rare.
Before my PAX, TC and Wheel Hub problems I used to joke with my wife about pimping the minivan out because we have so many little ones and will need to drive it for a while. Pretty sad when a $40,000 vehicle has so many problems.
I sincerely hope your Honda dealer is not blowing smoke.
Please keep me informed: tsventuri@embarqmail.com
If i could make a couple of suggestions:
Note your mileage and make sure you have all records saved regarding the replacement for the future. Regardless of whether the dealer did it under warranty or not. I have not read every post on this site regarding this issue, but I am getting the impression that some people are only getting a temporary fix from the replacement.
Also, if you can, compare your MPG before versus after the replacement.
What year, model and milege Ody do you have?
I am trying to find info on a class action suit regarding the TC & tranny problems. If I cannot find one in progress, I may be starting a new post collecting data about the problems people have experienced with this issue.
I am thinking about all the data that will need to be collected in order to document this issue for Honda or a court to take action.
Good Luck on your trip and keep me posted.
e-mail: tsventuri@embarqmail.com
You will probably need a new torque converter. We all are having the same problem. It seems like many of us with the 2005's are hitting this problem around the same time period. Honda will not cover it unless you raise heck...even then, they will only pay a small amount. I have a list of around 20 others who are going to be sending a letter to Honda soon demanding a service bulletin.
We leave for the long rode trip on Friday. Wish us luck.
Make sure that any fluid change or topoff, should be done by a honda dealer for warranty purposes make sure the paper work is legible for future reasons,
Some times they may use any non-honda endorsed product as excuse to reduce or refuse a warranty.
As for the software upgrades, at least in my case, I would again have to agree that the software is a waste of time. It made my shuttering and crazy noises associated with the tranny slapping the final drive louder and more frequent than the old software. I am trying to dig up the money to replace the TC or otherwise decide whether to just dump the vehicle for another. In the meantime, the software is so bad that I am trying to see if they can remove the update because the previous version was better.
Ask the dealer for an estimate to replace the TC if your vehicle is out of warranty - probably $1800 to 2300. Then ask them for assistance given the history of the problem for the model. If you bought the vehicle new and kept it serviced at the same dealer, they are probably going to be more inclined to help you and keep you as a happy customer. Just a theory, but....
just wanted to chime in in case we do manage to get a class action going. :sick:
if carmax is one of those places that will take the van back? get your money back. i love hondas and i love my van, but this problem is a lasting one and if you have no warranty? a very pricey one. a new torque converter will cost you 2000+ and a new transmission? thousands above that. it seems to be a problem just with the 2004-2008 models? maybe you could get a newer or older one?
This is an ongoing problem and I came across a bulletin from Honda. For those that want to comfirm their problem or throw it in the dealers face click on the PDF link below...
http://www.in.honda.com/Rjanisis/pubs/SB/A09-053.PDF
Just to let you know the VIN#s mean absolutely nothing. All cars need to be fixed. And don't let anyone or dealer tell you that they will replace the fluids on the tranny. That only will bandaid the situation and probably won't come back until after warranty. If out of warranty, you can have the dealer/tech fight for you, bring a copy of this bulletin of course (give you more fighting power) and offer to pay only 25% of repair cost.
I went through this and I know it's not fun. Take it from a pissed off single mother of 3 children and 2 are disabled. No one sells me a piece of crap.
FYI: Once torque converter is replaced. Make sure they also change the rear motor mounts as well. Vibrations damage it. If under power train warranty, rear motor mount is covered. Don't let them tell you it isn't. You will need realignment as well. Bide by the warranty on the new torque converter. When warranty is up. I would recommend using Amsoil or changing your tranny fluids twice a year. If not it will come back again.
Good Luck!!!
check it out, print it out, take it in.
Just so you know. My vehicle was well maintained at a Honda dealer for all maintenance. Up to date and on time. I still had the problem. You also may need a new motor mount. Have them check it. If not, it will cost more to go back and replace. I hope I helped.
Good Luck!!!
