Ford Expedition Stalling Problems
jdstoepfel
Member Posts: 5
in Ford
I have 2001 Expedition that the enigne will occasionally surge while coming to a stop. It seems as if you were stepping on the accelerator when you actually aren't.
It also has an intermitten vibration at medium speeds. The vibration feels as though you are driving over groves in the road.
Any ideas?
Jeff
Any ideas?
Jeff
I was driving 65mph the other night and it just shut off. I coasted to the side of the road. Put car in park, turned key off and it started right up.
Good luck!
It had to get pretty bad before it finally triggered the computer though. When it finally did, it had stalled 3 times in a one hour period. That was the worst it had ever been, and that's when it finally came up with a code they could read.
Best of luck~
Becka
Were you able to find the diagnostic code. Mine did the same thing today when turning onto a ramp off of a highway, but no light came on. I lost all power and had to coast to the side. Put vehicle into park and turned it off. Then turned it back on and it started right up. No lights or error codes came on... please help !
Good luck
Best of luck~
http://www.expeditionforum.com/forums/showthread.php?s=3c9cc7cad3bdb8c3c9c1493b7- 346ea76&postid=11808#post11808
here what daves1955 said
I got a call from dealer two this afternoon. Apparently there is a TSB (Technical Service Bulletin) that covers this problem. According to the TSB there is an electrical lead that runs around the power steering pump and oil pressure sending unit. The electrical lead may rub the power steering unit and cause a short to ground.
According to the service adviser they put some heat shrink on the electrical lead and ran the vehicle over the past two days. They did not experience the cutting out at idle.
Also according to the service advisor the problem with the electrical lead can cause any of the following.
Hard starting condition.
No starting condition.
Rough idle.
Cut out at idle.
Cut out when cornering.
The total repair bill is 79.00 for one hour of labor.
Since I am out of town this week and next, my wife will pick the vehicle up this weekend and take it for a ride to deterrmine the outcome. Hopefully the problem is solved.
he later said that fixed it. I am going to try to find what TSB that is and get more details. But i think i can find where the short is now based on that info above.
0)checked the check engine light code (was P0430 bad converter?) Yea right!!! dealer repair $1800. I didnt do that yet.
1)Changed fuel filter (was slightly plugged anyway after 90,000)
2)Changed spark plugs (looked good but fairly worn)
3)cleaned idle control valve (idled smooth before and after)
4)removed butterfly air plenum and EGR valve and cleaned EGR VALVE and AIR passageways (slightly clogged passages)
5) I added a fuel pressure monitor gage to verify the fuel pressure stayed constant during the hesitation. (it avererages 30-40 psi with vacuum hose connected to fuel regulator and nearly 60 psi when removed)
6)I tried "capping" the vacuum tubes to the fuel regulator,egr,evaporaative control valves to verify that none of them add or cause the hesistation. (they did not)
7)Checked throttle control sensor restance was smooth and constant. (no dead spots)
8)even dropped the gas tank to check for dirt on pump pickup filter screen( no dirt was clean)
9)replaced PCV vlave and rebuilt pcv hose assembly with plastic elbows since origianal rubber ones were collapsing (no improvement on hesistation)
10) did the TSB where the oil sending unit cable is covered with plastic tube and had the PCM reflashed with later firmware (no improvment but was supposed to help with hesistation due to alterantor/pcm interaction)
11) Replaced all coil on plug coils with aftermarket substitutes. (problem solved!!!!!!) check ebay.
So besides doing the easy stuff (PCV and hose, gas filter,plugs,firware,etc) I would go put the coils with the plugs since I now find that they fail in a very soft way where they tend to fool you with that intermittancy when they cut out sometimes once in 50 miles or more. I measured the restance of my old coils and new ones and they all meaure about 5500 to 6500 ohms on the secondary and old ones looked perfectly fine go figure.
Any resolution to this? I am feeling the same thing. It happens at 2500-3000rpms while accelerating. Like a buzzing in the gas pedal.
Mark
Anyone know the correct part # for an 03 5.7 Expedition coil pack?
Wedo43">
Is it a stutter, like it lost all spark momentarily?
Does it happen more often when turning or making u turns?
wedo43
I just put my 03 in the shop Monday and had the manifold, plugs and plug boots replaced. Ran great for the 1st time in a long time. Did all this to get it in shape before a 12 hr family trip. It rained hard last wed's night and we began our drive early Thurs morning. Within the 1st 5 miles it was starting to stutter again and within the hour it was running so bad it was missing on at least 1 cylinder.
I did alot of research on this and other forums. Common causes for this problem include
1- A wire that runs along the outside of the power steering pump rubs its jacket off causing an intermittent short, most notably when turning. This can be found under the truck on the drivers side of the car. I traced mine out and. while I could see where it would happen, the was no rub through.
2- A cracked manifold, leaking coolant ports and or leaking manifold gaskets. Can cause an air leak and additional moisture that can get inside the plug boots and into the coils. Mine did have all the above.
3- Due to additional hoses on the passenger side there is greater condensation that quite often seeps into the plug boots and coils. This (condensation in the boots and coils) is the most common problem and now that I think back on it, I had been experiencing episodes like this after big rainstorms for about a year.
Now that a couple of dry days have passed, it's starting to dry out and run better. I went on ebay and ordered a new set of coils complete with new boots for $75.00 and freight. I'm going to remove the existing set and dry them out thoroughly before the drive home then install the new ones when I get home. I'll keep you informed on results but after reading all the postings, I'm pretty confident this will completely fix the problem.
My suggestion would be to search ebay for Ford Coil Packs, order a set and have a local mechanic you trust put them on . In the Dallas area I would expect to pay less than $200.00 for this task at the local Kwik Kar.
It's a cheap fix that more than likely will solve your problem. If not, it was a heck of alot cheaper than taking to the dealer. He'd replace the manifold the plugs, coils and boots to the tune of $2-3K.
Hope this helps,
wedo43
NEW IGNITION COILS 97-05 FORD EXPEDITION V8 DG508 (8)
they are sold by global-automotive. $95 for eight units. I wouldnt have done the intake manifold though if your idle was perfect like mine. The packs are the same for 5.4/4.6L.
NEW IGNITION COILS 97-05 FORD EXPEDITION V8 DG508 (8). It could also be the pcm needs relflash or the oil sender unit wire running near the power steering pump is chaffing and short to ground but I doubt it. By they way I figured out why the coils confuse the pcm. first if the missfire is occasoinal intermittant then the pcm wont give a code. Also if you get a bad enough misfire for the moment the pcm turns off that fuel injector to that cylinder and makes the truck run like crap even at idle. Then I found if you turn the truck off and restart the problem will go away and run ok (idle /accelerate) till the occasional misfire occurs again to confuse the computer. If any of you see that problem then change the coils.
Mark
Wedo43
PS-faisal56, you didn't give us alot to work with. What kind of sound?
What I am going to do is replace the coils to see if it works. Did you notice that the vibration/slow acceleration/stuttering was worse when A/C is running?
BTW, did replacing the coils work for you? Thanks.
