Honda CR-V Navigation System
Questions about your CR-V navigation system? Ask here.
Check the search on the left for other makes/models or visit the generic Navigation / GPS Systems discussion.
Garmin Nuvi seems to be really cool compared to OE Navigation systems. The Garmin Nuvi comes with different accents as well - it is fun to listen to instruction in different European accents:)
There is also other things that you get with that two thousand dollars. You get a back-up camera, which once you have, you find how much it helps, like when backing into a spot, you can see the curb so you don't hit it. Also, you get 270 watt sound system (instead of 160 watt), a seventh speaker, a sub woofer, and a digital audio-card reader.
Go For It!
Can you update your navigation system operating system, and if so how do you do it? I connect my nuvi to my laptop once every two weeks to download firmware updates to the operating system and to download icons, MP3 songse etc.
My question concerns using a flash memory card (I'd prefer CompactFlash because I have some of them.)
I want to know exactly what I need as far as an adapter is concerned to be able to use it in the vehicle. I'm looking for specific name/numeric description of item and possibly brand because I'm non-techie.
Also, I want to know how big a memory the card can have and still have it work. I ask that because I'm not sure if there is a limit.
The owner's manual says this: "The card limit of the player is 255 folders and 999 tracks. If the card has a complex structure, it takes some time for the system to begin playing it."
I'm not sure what all that means. I'm not sure how much memory 999 tracks (regular rock 'n roll stuff, mp3 files) would take up on a flash card.
So first I want to find exactly which adapter I need. And then I want to know the maximum memory I can have in a CompactFlash card and not overdo it.
They say it takes a PCMCIA adapter, Type II.
And the most they've worked with is a 1 gigabyte (one gig) memory card. So it's up to someone else to try a card with more memory and report back.
I can't find pc card adapter please help me and let me know exact model number or upc number to buy it. I've tried more than couple already but it won't fit in my pc card slot, they were little too big. I've got sandisk Compact flash card with adapter. Pleas let me know what to do...my email address is strikerscricketclub@gmail.com
thankx
And the back up camera is nice as long as you don't get too dependent on it that you become sloppy about backing up. It has blind spots so do your head checks.
Do you think I get can this part? If so where?
It was made by Mitsubishi Electronics.
If not how can I replace the whole system ?
the Technician should have been bonded and insured to cover such loss. Or, if he was a smart one, he would have disconnected the negative terminal at the battery.
I am sure Honda sells the unit by it self, the cost is around $3000.
ITem 4
2698382 004 1 NAVIGATION UNIT (AVN-DVD) (ALPINE) GRAPHITE BLACK MSRP $4249.72 Discounted price: $2974.80
Majestic Honda
then you have to but a memory card too.
Follow this link. you can find the PC card reader
PCMCIA Type II
http://www.amazon.com/SanDisk-Adapter-SDAD-67-A10-Retail-Package/dp/B0002JC2QE/r- ef=pd_bbs_sr_1/103-5246857-6187020?ie=UTF8&s=electronics&qid=1179429899&sr=8-1
I was able to load about 980 songs on the card. 4GB is perfect for the 999 file limit that Honda imposes. I'm still trying to tweak how to best arrange the songs on the card in the folder. The great thing is that it will display the Artist, Title and Album name on the screen. That's just awesome!!
But I can tell you this. The sound quality is awesome!! It totally blows away using your iPod through the mp3 aux jack. This is pure uncompromised sound coming directly from your mp3 file to the stereo. For about $60, I essentially have a 4GB iPod equivilent loaded into my CRV.
Finally, the navigation of searching through the 999 files is great. There is a keyword search where you can type in a partial keyword and it will find all songs that match that keyword. Type in "MAD" and it will retrieve all your Madonna songs for example. Then, you can just select which song you want to listen to and it starts playing immediately. Once the Flash Card loads for the first time and reads the file structure, access to any and all the songs is instantaneous. No lag switching between songs.
If you love your music and can live with a 999 file limit, then the PC Card is your best solution to getting the best quality music and functionality out of the system. Leave your iPod at home!!
So, the initial question posted in this forum asked if it's worth $2K for Nav. Given that Honda gives you an upgraded 270Watt system with 7 speakers and subwoofer, a backup camera, and a PC Card that can essentially double as an interal 4GB iPOD Nano, then I say emphatically YES, it is worth spending the extra $2K, because this is best bang for your buck for a nav system your going to get.
Good luck to everyone thinking about an EX-L with Nav.
Also, I'm finding that it's always playing many of the same songs over and over again. I have over 900 songs on the card, and while in random mode, there have been some songs that I've heard 4 or 5 times, sometimes even after just having played a few songs earlier.
Therefore, I question their software algorithms for creating a true "random" session. Even after a week, it's easy to determine that the functionality is flawed. I'm also not suspecting that the Honda service technicians are even going to be trained to understand my problem or even care about my concerns. They'll probably just scratch their heads and not understand what I'm saying.
Anyways, just be on the lookout for issues like this when using your PC Card and report back if you find similar problems.
I can tell already that the Honda software has very few Points of Interest in their database, and hasn't been updated in quite some time. This software appears to be far inferior to the offerings of someone like Garmin.
I'm not as familiar with it as many others. Can I download from i-tunes to the flash card or will it prevent me from doing that with purchased music?
Your detailed explanation of where to buy and how to do it was helpful so I thought I would ask about this.
Once you have the .mp3 file on your hard drive, it's as simple as copying the file to the Compact Flash card.
the other day my 02 CR-V sat nav decided to continually restart itself after the inital disclaimer text. it does not even come up with disk read problems.
i've pulled the fuse "8" to see if this would reset the unit but no joy.
is it worth disconnecting the battery, or has it decided to give up on me?
any suggestions would be greatfully appreciated.
Mike
Call Honda Corporate and see what they will do for you. The number is in the Owner's Manual.
We live in Northern Virginia in Stafford County which is just outside the Metropolitan Area. As a result, we are part of what Honda calls "unverified" territory. While most of the roads seem to be there, the POIs are almost non-existant. The Wendys which is right off the highway and has been there for more than 10 years isn't even in the Honda database, nor are most restaurants or shopping.
How can anyone actually travel with the Honda Navs? It's nearly impossible to find a restaurant or gas station when travelling.
We were coming back from Williamsburg and looked up "McDonalds" and the stupid thing referenced a McDonalds more than 1,000 miles away!!
The stupid Nav doesn't have a freakin' clue of where you are or where you need to go to get a freakin' hamburger!!
I cannot find one positive thing to say about the Honda Nav System. Not one...........
I am sure if you took it out and put it up on ebay there will be more than a handfull of bidders.
Did you call Honda Corporate and expressed your thoughts, just like I suggested in the previous reply to bigdog? You know they are not mind readers, if you don't tell them, they don't really know what you are thinking. Most likely all it takes is the updated DVD from Honda, if they have one for yout area. They release new DVD almost every year.
Did you or bigdog test the Nav system during your test drive? If not, then why complain?
The problem is with Honda's "Unverified Routes" where they don't include POIs (or very few). Unlike Garmin, which has POIs for everyplace within the US, it appears that Honda took a simpler and cheaper route by not going the extra mile to include a more comprehensive database.
As for an updated DVD, I have a 2007 CRV (built in April 2007), so it should have the most updated DVD already. If not, that's total BS on Honda's part for not putting in an updated DVD. Online, the DVD for the CRV is totally different from any of the other vehicles.
I guess I'm just curious if others are finding the same issues, particulary with the POIs. "unverified" could have drastic impacts when traveling with this nav system. Having a nav system is much more than just providing the routes on the road. POIs are just as much an integral part of the equation, and Honda's Nav system simply sucks at it.
But you have to admit that even with a poor POI database, it still beats driving around trying to find a street, or getting a map.
Thats how they designed it to work.
http://www.collegehillshonda.com/honda_crv_accessories/2007_crv_electronics.htm
http://www.collegehillshonda.com/instructions/gen3_crv/08a44.pdf
I have mine set to "Auto" mode, and nothing changes when I turn on my headlights. It remains in Daytime mode. The only way to get it to change to Night mode is to go to setup and manually select Night mode. It's probably a software bug. Personally, I don't like the night mode, so I'm happy to keep it on daytime all the time anyways. It does make the cabin nice and bright at night though!!
thanks ahead of time!
Can anyone recommend me a card that will work in my nav unit that will support SDHC and sizes larger than 2gb?
