Iwas driving and alternator belt fell off and i replaced it and car doesnt start. Battery is new and alternator just replaced,what could be?.power is ok (sparks are fine , gas is ok)Any ideas Thanks in advance
checked for spark there is none.checked all the wiring connections , looked for a fuel cut off switch couldn't find one, checked to see if the distributer reading ok and it seems to be. what else should i be doing?
Thanks in advance.
Anyone have any ideas?
Yes, it has started this issue since it was cold here in MN. I put the car in the my heated garage last night and charged the battery. It fired right up this morning. I'm now wondering if it is due to gas line freeze? I put some Isopropyl achohol into the tank to hopefully take care of that.
Were is the fuel filter for this car? I know there is one on the fuel pump in the tank, but is there one under the hood?
So now to the new problem as this didnt happen when I had ign system problems. I was headed home one day and I noticed my wipers were going slow in the rain then I noticed my tach drop to 0 then back to normal, them my speedometer kept dropping to 0 them back up. Then I noticed all my gauges were dropping and I was loosing power. then the car died and I got to the side of the road. About 20 min later it started back up again and drove 25 miles back home. But while I was sitting there I had no power what so ever as if the alt took a crap and drained my battery. But like I said 20 min later I had all my power again as if nothing was wrong. I am getting a code 34 again for the idle air control valve. I ended up putting in my old computer and drove it 5 miles away and it all happened again lost all power as if my battery went dead. Car wouldnt turn over and no lights or anything again. I just went back out there to try to start it and it acts like my battery is low. So could this just be a simple alt problem, funny tho that waiting 20 min it started back up and had full power when it first happened. I would have thought that it like my other vehicals when the battery is drained from the alt going bad that your not going anywhere. So hopefuly I didnt make this to lengthy or complicated.
Now have a new problem though, battery good, turn the key to on and all the dash indicator lights light up. If I turn to try to start, those lights go to black and not a sound of trying to start. Same thing happens if I press the brake pedal or try to turn on the headlights.
Can anyone help me please?
likley it is the position sensor, but best to do both at the same time.
M.
about $450.00-500.00 at a reputable shop.
M.
