Driving yesterday and it slipped out of gear. Was shifting smoothly up to then. Was able to continue driving by manually shifting from 1st to 2nd gear, but when upshifting to D, after about 5-10 seconds it slips out like its in neutral. Transmission fluid didn't look good, pretty dark (not red).
Thoughts? New Tranny? Other Options?
I have a 2003 Expedition and it has developed a strange vibration/grinding noise coming from the rear of the drivetrain. It seems to only do it upon initial exceleration. I am not sure if its coming from the transmission, rearend or transfer. Can someone give me some advice on what this could be or what I should inspect to further identify the problem.
David
as i mentioned the car was in the fors shop for three weeks, the did finally find two seals in the transmission that did not look good which they replaced. Transmission was reset again, I drove 1,000+ miles to let it adjust but have noticed no change. transmission bangs when stoping like before. Ford tells me they will get a transmission expert to see the car. The agency Manhattan Auto and its staff have been great and helpfull however the problem has not been solved. I feel the bang from the rear of the car and suspect the differentials slip seal, u-joint or maybe other rear end problem. Also thought it could be the car's computer hardware since the software has been updated more than once to no avail.
How is your doing? Can you tell me exactly what they did?
About a $10-30 dollar part depending on brand and quality.
https://www-odi.nhtsa.dot.gov/ivoq/
The skipping symtoms at 50 mph are similar to the same jerking caused by bad coils or sparkplugs but those have been recently replaced and the problem persists. I'd appreciate any Ideas as to cause and repair.
Jonbob0
Right were the TV connects to tranny, you will have a steel rod at end of cable, also attached to a return spring. If that rod is dirty it won't slide in and out of the sleeve like it should, that can cause high rpm shifts, and down shifts because the cable is not kicking back down when it should. So it will delay at the throttle body at engine causing high rpm. That wouldn't throw a code that I know of. Take a rag and spray cleaner wipe that rod down. Its free, its worth a try, it may be that simple. Good luck
I AM NOT SURE IF YOU STILL HAVE THE PROBLEM BUT...
If you are i can asure you that $16.00 will fix it, just go to your local auto motive store and ask for a MANUAL KIT for AIR SUSSPENSION it is very easy to install i did mine in under 1/2 an hour, or you can unplug the compressor located under the windshield washer fluid and hook up a wire to both RED/Black then hook em up to ur battery it will manual overide any switches that may be broken. if it still does not work then like i said go get the manual kit is cheapest. Another thing you can do is jack your truck up of its wheels and let them hang for a day, this will refill them. All this i have learned from my own Ezpedition 4wd 5.4 - 1999 V8 GOOD LUCK ----------
Check the battery connection/ i have had my car stall because of this dont ask me how bec idk either.
Check your fuel, when u go up hills could be that...
If it still continues or gets worse it could be your fuel pump is going out or...fuel pressure regulator.
These are the cheapest things to check and fix, if it continues id ask your local mechanic would be prob 100-200$ to scan truck for problems?
