Pontiac Grand Am Service Engine Soon / ABS / Trac Off
                    Well, those three things pretty much sum up what im going through right now.  All three lights are on and when you make a hard right or left turn and accelerate at low speed the car seems like the drivetrain is missing, almost like it's skipping.  If anyone has any suggestions please let me know.
See also: (Video- 6:31) Grand Am ABS/Trac light troubleshooting
This could be anything from a cracked vacuum line to a bad computer. The scanner will tell you what the computer thinks is wrong.
Jen
Did replacing the ignition switch work? I have replaced hubs and the abs computer. I would have never guessed the "ignition" switch. I'm wondering what the ignition switch would have to do with the traction control and abs.
PLease write back and let me know if it was the ignition switch. thanks
Our 3.4 2002 Alero (65,000 miles), has a problem with acceleration. It is very sluggish when accelerating, although after about a 5 mile run on the freeway, it improves, but is not perfect.It's now virtually impossible to drive safely, and on an incline, we are in trouble!
About 10 days ago, we filled it up with gas from our usual gas station, and inserted a well known make of fuel-injector cleaner, which we use about every 3 months. Therefore, we thought it may be some dodgy gasoline. So, when it dropped to about 1/4 full, we filled up again, but it has made no difference. Now the 'Service Engine Soon' light is on, but is not flashing. I've checked the fuel cap, and that seems to be fine.
Can anyone advise before I take it to my shop for yet more remedial work!
My Trac Off light has been coming on quite frequently over the past couple of weeks. Usually if i would turn off my car and turn it back on again the light would go off. I noticed that when I am driving with the Trac Off light on my car kicks back when ever i accelerate.
Yesterday my Service Engine Soon light and my Trac Off light came on at the same time. Again, whenever i accelerated my car would kick back. I pulled over and turned off my car and turned it back on a couple of seconds later and my car did a powerful kick back when i put it in Drive. That scared the crap out of me! After I left my car off for a about 10 minutes and turned my car back on, both lights turned off.
Now the day after, both my lights are now on and they do not turn off. I still get that horrible kick back when i accelerate. BUT if my car has been turned off for a couple of hours it does not do the kick back when i put it in Drive.
Another is the shaking my car does when I drive, it might mean that my tires need to be rebalanced. Does that sound right?
My last problem is this rattling noise that sounds very very loud when i am braking or the first time i accelerate. The noise eventually fades away once i am driving (or so i think). I notice that when i have my car on and i put it in park, the noise quiets down. And it quiets down when I turn off my air.
Ok that is the jist of it! Hopefully someone else can help me
Any information would be greatly appreciated.
-Krystal
and service vehicle soon, lights come on when i put the car in reverse. when i put the car in park, turn it off and restart it , they go off. but come back on again when i go in reverse. any one know what causes this?
thanks , Hook
Jim
Good luck,
Jim
As far as the coolant temp, since it's winter and you have a new radiator then maybe it's just normal? The low coolant light itself won't have anything to do with the operation of the fan.
193K is a lot of miles for a Grand AM!
Also, a couple times when coming to a stop there is a grinding sound (abs??) and the car slides a few feet before stopping. It has only done this twice since the lights came on almost a week ago. I have an appt with the dealer in a few days.
HELP ME! what could be wrong and how much could it cost!
J
