Chevy S10 - GMC S15 and Sonoma 4WD Issues
ok so i have a 89 s10 extended cab 4.3ltr 4 wheel drive...kinda lol but ok here is the problem one day it worked fine and the next it wouldnt engage 4 wheel...i have no clue whats wrong with it...i know the drive shaft for the front end spins so its not the tcase i was wonderin if the front diff is vacume controlled i tryed pullin my skid plate off and i dont think anyone has takin it off before cause the last bolt tore the [non-permissible content removed] outa my knuckles lol but i did see somthin that looked like a o2 sensor and what looked to be a vacume line i think its a vacume line there are 2 lines that come off and i know one is the breather but i need some help the sooner the better...you might try emailin me with some info...[Email removed] thanks
-mat
-mat
Jamie (stumped)
It has the pushbutton 2WD/4HI/4Low buttons on the dash, its a 6cyl with the 4 speed auto trans.
My problems is this:
Used the 4x4 in HI range this past weekend on my property to pull some old tree limbs to the dump and also at my friends place as well. No off roading or any of that stuff just used it to get up the lawn instead of tearing the lawn up.
Now I'm having issues with the 4x4 disengaging, it goes back into 2 HI but the transfer case is staying locked in. I can move/spin the front shafts but the shaft that goes to/into the transfer case doesn't move or spin at all. It used to move freely when in 2 HI but now it doesn't.
All my tests that I have done so far is with the truck sitting on the ground running and in park.
I know the 4x4 front shafts are disengaged because the wheels move freely across the pavement. When engaged they do the chopping and sliding event. THIS not my problem its to the transfer case is where its all happening.
I am having a lot of drag on the road to the point its eating my gas mileage. There is a slight vibration and I have to lean into it to get it moving.
One tranny shop told me it could be some plastic pins or bushings in the transfer case or possibly a fork or two that are going/have gone bad. Without opening it up they cannot tell me what it could be. The price could be a 100 or 200 up to a grand for a used rebuilt transfer case installed.
From reading past replies it seems there are some pretty smart cookies out there but cannot get a bite on any of my post.
Oh well, if anyone is out there tell me to kiss your [non-permissible content removed] or something.
Jack
The last two times that I have gone out and started the truck, it has been in 4 hi even though it was in 2wd when I parked it. From what I can tell, the 4wd is engaged, but it goes back into 2wd with no problems when I push the button.
My wife drove it for a while today and she said that she caught it switching from 2wd into 4hi while she was driving down the highway.
Any ideas on this so that I can look into it myself?
thanks!
When you push the button for 4wd hi it just ticks and the service 4wd light comes on. It then goes back to 2wd and service light goes out.
Any thoughts?
Problem: 4Hi and 4Lo won't engage, Low xfer case engages but front wheels don't.
Symptoms: When I bought this truck used I noticed that after engaging 4Hi
there was a vibration around 50-65mph. After 20-30 miles the vibration would
go away.
Didn't use 4Hi/4Lo for quite a while.
After recent snow storm when I tried to use 4Hi. Upon disengaging there was
an oscillating vibration that would lower in frequency until stopping front
wheels. When accelerating noise is not heard, only when coasting or decelerating. At this time the vehicle was out of 4wd. Vibration did not go away after 20-30 miles.
Just the other day after another snowstorm, I tried the 4Hi/4Lo and it won't
engage 4WD only low range. I get ONLY a click for 4Hi and a click and a clunk
for 4Lo. Seems as though I get the low range but the front axle won't engage.
When engaging the 4Hi and traveling 5-10 miles I heard an occasional couple of knocking noises from what appears to be the right front wheel/hub. Pressing 2Hi button stops these random knocking noises.
The lights corresponding with the buttons on dash work properly i.e. 4Hi lit
when 4Hi pressed and 4Lo lit when 4Lo pressed, 2Hi lit when 2Hi pressed.
What suggestions does anyone have and what should I check for?
Our mechanic messed with it, trying to take it in an out of 4hi, 4low, and 2hi. Now it works fine. He says because we hadn't used 4wd in over a year, the actuator was probably stuck. He went ahead and had me go to a transmission shop for clarification. They said the same thing but warned me that possibly something is starting to 'go'. I did ask him why it sometimes takes a couple trys to get it out of 4lo back to 2hi and he said that is perfectly normal. I have left a message for our potential buyer to let him know the outcome, however, we have had an intermittent problem with the abs/brake light coming on and staying on when you start it. It hasn't happened in weeks so we thought it fixed itself. Lo and behold, when I started it at the store this morning, the darn lights came on! Turned the truck off, restarted it, and then they went out. Our poor little truck just doesn't want to leave us, I guess! Hoping it doesn't happen again until our buyer comes to pick it up.
I thought those were only in Honda's!
Can I get a better understanding of your vehicle concern? What year/model is your vehicle?
Best,
Sarah
GM Customer Service
got it to work for a while unhooking by my battery cable and reconnecting it would temporarily fix the issue but now nothing works and i have no 4 hi goes to 4 low with no problems
Our primary diagnoses are performed at our dealerships, and so I would recommend an appointment at your preferred dealer. We could look into your vehicle's information to see what we can learn, if you like. Please email us the last 8 numbers of your VIN along with your name/user name and contact information.
Best,
Sarah
GM Customer Service
go away.
