Subaru Forester (up to 2005)
I used snips and cut an access hole for the oil filter, so that I could do it without removing it. It does tend to keep the engine bay cleaner, but I doubt it's necessary (other Subies with the same engine don't have it).
4 quarts and it reads high? Mine takes 4.6 or so. Make sure the engine is warm before you start to drain it, and remove the oil filter, too, to make sure all the oil drains out. Also try to keep it on relatively level ground. Finally, if you only put 4 quarts, make sure to check the level again after a short drive.
-juice
4 quarts shouldn't show high on the dipstick assuming you've completely emptied the oil pan before refilling. The dipstick is a little tricky to read, however -- does it show high on both sides? I go with the lower reading.
Ken
Ross
St. Patrick, our "older" Forester is back at Martin Subaru for a third attempt to get the Duelers balanced. Is this bad service or are these tires just difficult to balance (as in, out-of-round)?
Jeff
I got 28k miles out of my Duelers, and also couldn't wait to do the swap.
-juice
Of course, while my Forester's getting better with age, my poor wife's 1998 Volvo S70 cost us $500 this week. Well, actually, it was my wife and her treatment of the Volvo that cost us $500. She hadn't maintained her Toyo tires at all (now it's my job to), and it came back to bite her in the [non-permissible content removed], stranding her in north Atlanta with a blown tire. You could see metal coming out of all four tires.
She got about 35K miles out of 65K mile treadlife tires. Pathetic. She will be keeping her new Pirellis balanced, rotated, and properly aligned from here on out. Ahhh...the trials and tribulations of marriage translated into automotive terms.
Later,
burnsmr4
-juice
That's why you have a 150 lb roof capacity, double what the XTerra can carry, for instance.
I've hauled two 6'x8' sections of pressure treated fencing on top of my roof, as well as 8 foot 4x4"s on a different occasion, never had a problem.
-juice
How did you cut that to get at the filter? Use X-Acto knife or such?
And, I did ride the L onto ramps just to get at the cover screws....makes you dizzy getting the beast to drop. Damn age creeeeping up. Not much room under there on the driveway sand.
THX !!
PS Does that thin FG/plastic really protect anything?
OCD will soon take over and you will rotate her new tires every 1K miles.
Greg
It does not protect in the way a skid plate would, no. But it does keep the engine bay a bit cleaner.
If it bothers you, yank it out, no biggie. If you are going to do water crossings or drive on sand I'd put it back or install a skid plate.
-juice
My next challenge is getting her to give up her car (GULP -- and drive mine) for a day so I can get her timing belt changed...7,000 miles late. That's what I thought when she first called me about the tires. LOL! I nearly fainted, 'cause I knew THAT would cost more than $3,000 to repair if it broke.
Ahhh...married life. ;-) I love it!
burnsmr4
Greg
"Happy families all have car-obsessed spouses who love and enjoy their Subarus. Every unhappy family owns non-Subaru makes." (c) Kate5000, Edmunds Townhall.
Seriously, in my family it's ME who cleans and waxes cars for fun, checks tire pressure, takes cars for oil change and to mechanics for check-ups and repairs. I can even tell alternator from starter and I don't immediately faint when looking under the opened hood!
kate, soon 20 yrs to be married (to the same guy, btw)
-juice
I am ever so impressed. Given that my wife does not drive and is a bit vague about finding the car in car parks (it's sort of purply blue...) anything car related is definitely my problem. I am making sure my daughter does not suffer a similar fate.
Cheers
Graham
Thank you for the (thoughtful) lift to my day.
The Nissan Xterra factory rack is rated for 125 pounds.
The optional "heavy duty" Forester roof rack (which looks like it is made by Thule) is rated for 150 pounds. I do not know what the standard plastic rack on the Forester is rated at, but on most cars it is 75 pounds.
I really like the option of getting the Thule rack that fits in the Forester's rail system, it's a lot more useful than the rack on the Xterra.
John
The CRV's roof rack is rated at 75 pounds. Most SUVs have racks rated at 100 - 150 pounds. The 4Runner's roof rack is rated at 165 pounds. My Explorer's roof rack is rated at 100 pounds.
Bob
Ken
synthetic oil - Generalization with synthetic oil is difficult because the way they are made and what they are made from, is very different from each other, unlike dino.
Dino oil swells seals. Early on, and some now, synthetics didn't, so if you had a significant amount of dino use, and then switched to synthetic, the seals might relax a bit, causing a leak because everything had taken a "set".
I personally like Mobil 1 because they have tried to make their synthetic mimic all the ancillary traits of dino, to make the transition to (and from) seamless. This includes seal performance. You could even mix it with dino without any issue. This is also not true of some synthetics.
I usually put at least 5K miles on an engine before switching.
Factory fill oil is nothing special, but it usually has a dye added to assist them looking for leaks early on. It is good to change early and often, not because of the oil, but to keep a fresh filter available to catch things during the break-in, especially with the small filters in use today.
Frank
Mike
The plastic racks on the Forsters at the dealer seemed sturdy, but I'm a bit dubious. For hauling our canoe I think I'd have to invest in the square crossbars and towers.
Bob
- Hutch
On the way back on route 80 I nearly got sideswiped. I had to do one of those maneuvers you see on the Subaru commercial. A quick right and recover at 65-70 is not something I like to do but there was good stability and response. If the other driver had another coat of paint there would have been damage to both cars.
Has anyone noticed that if you try to keep close to the speed limit nearly every car on the road passes you?
By the way PSU won. It wasn't pretty but a win none the less.
It's not actually the weight on the roof that's the issue, but the distance above the centre of mass. If you mount a heavy load high and try to turn a corner, the load has a multiplying effect, trying to tip the car over. This is particularly apparent if you undertake a lane change suddenly, say to avoid an animal (or human) on the road.
It may not seem particularly important. However, a beloved friend mounted a load on the roof of his Legacy, set a trailer behind and then set off to deliver said load to his son 400 miles away.
He dodged a pallet which had fallen on the road, rolling the car four times, stopping his breathing and breaking his neck high and rendering him a quadraplegic. His wife, sleeping beside him, suffered severe bruising and resuscitated him. The dog, asleep in the back seat was pretty shaken up.
Four awful years later, he has died after suffering horrendous complications from his injuries.
The excellent crash cell of the Subaru is not a universal protector. You still need to engage the brain when loading it.
Not so cheers
Graham
I'll be driving my 00 Legacy GT sedan (Rio Red).
Jim
P.S. just had to replace the oil pump on my wife's 98 Forester (@68K).
Steve
I've hauled some big loads, including 4x4s, 2 6'x8' sections of fencing, a 21" deep double dresser, you name it, it does the job.
After reading Graham's post I would say that it's capable of loading more than a safe amount, so it's up to you, the owner, to abide by that 150 lbs limit.
-juice
Ken
The hood is also aluminum. No rust, less weight. Open one and lift it - the difference is very noticeable IMO.
-juice
I noticed that the rear center headrest goes down and contours with the rear seat unlike my 02 Forester. I had to take the center rear headrest off to allow me better visibility to the rear. Does anyone know if this headrest will fit the 02 Forester?Can we order this new lower headrest? I also noted that there was an 02 legacy with one I asked the parts man and he said there was none available for the 03 Forester unless I ordered the whole seat but there was one in black or beige for the Legacy, though the 02 Legacy had a grey one like my interior. He said it was $130.00 but didn't know if it would fit my Forester and didn't have one in stock.
Thanks for any information.
Gene
Is this a simple install that I can do myself or should I let the dealer install it?
How is this installed on the bumper? Is it simply glued in place or are there some holes that need to be drilled?
C
C: I think, but don't quote me on it, that they use two-sided tape. That's how my fender flares attach (plus a few bolts).
-juice
Len
Once it's down sit on it for a few seconds. Also, make sure it's warm outside (closer to 80 degrees).
Good Luck.
-juice
Steve
There were some things that were annoying though. The first was that the rear hatch had to be slammed extremely hard to completely latch. There were many times I had to pull over after driving a few yards to slam it closed.
The rental didn't come with keyless entry and there wasn't a keyhole on the rear hatch, so the only way we could unlock the hatch was to open the driver side door and then hit the unlock button. Is there a hidden key hole in the rear hatch somewhere that I missed? I think keyless entry would be a must with this design. Or, is keyless entry standard and they just didn't give it to us?
The car only had 3000 miles on it but had many rattles from the dash and the back. Granted, I bet those 3000 miles were pretty hard.
All in all, it seems like a great vehicle. I will recommend Subaru to my fiance when she replaces her volvo next year.
Steve
