transmission bell housing area , it stops at 75 mph or if you push in the clutch.
Anyone have this problem or any answers or fixes.
you have to get under and shake you drive shaft, if there is any movement
then replace those u-joint about $12.00 each one and the carring bearing will cost about $350.00 from dealer. A shop can charge you about 600-900 the change them. There are cool hillybillys and readnecks that will show you how to do it yourself on utube. :shades:
Thanks for the info on the drive line. I have 62K on my 03 Tacoma 4x4 extended cab. I still have the vibration between 40-60. When I get new tires this year, if the vibration is still exists, I'll check those u-joints. Did you know that the grease for the u-joints is not just the regular grease they use on the rest of the chassis? Check your owners manual for the right kind.
Thanks again,
Brepei
I have a 2007 Tacoma 4x2 TRD access cab, i just turned over 100000 miles about a month ago and i started to get a ticking sound from the engine, i just assumed that it was because it is cold ( it was February) so i let it go, then i started to get a bump from the rear end when in low speeds ( 5 - 10) now i am getting a heavy vibration from what feels like the drive axle in speeds between 50-70 but only when i accelerate and it clears up after i pass 70. i tried fully cleaning the full system with the 4 STP cleaners and it felt like it helped a little but not very noticeable. Thoughts?
