Chevy Suburban Transmission Problems
in Chevrolet
I own an '88 Suburban, and I have posted here before. Now, I have a transmission problem. Does a transmission that "whines" in the morning when it's cold mean that the transmission is failing? It also doesn't want to shift out of reverse and into drive, or out of first into second. Once the vehicle warms up, the whine fades away into only whining at the top of every gear, until it is completely warmed up. Once it's warm, the transmission shifts perfectly, and the whine completely ceases. It doesn't slip the slightest bit, but it does however, like to kick back into first when turning left, causing it to surge forward, and depending on how fast I'm accelerating, kick the rear end loose and I fishtail some. This all started about a week ago, when my area got the sudden cold weather.
I'm not sure what happens when the transmission warms up that could make this happen. Any ideas?
It feels like the transmission misses a shift and on the next turn it locks into position really hard and abrubt.
Bret
Until 07, all 2500 series Suburbans used the 4L80E tranny. This is a good tranny but you will definitely miss the extra gears from the Alison, esp. if you tow alot in hilly areas.
I have a 1998 Chevy Suburban 4x4 with the 5.7 and the transmission is the 4L60E...we are on our 3rd rebuild of this transmission within 9 months, the first rebuild lasted 6 months, thought to be faulty converter, 2nd rebuild lasted about 1 month, 3rd one lasted less than a week, 488 miles to be exact. On the 2nd and 3rd time the rear planets have been chewed up and the rear thrust washer has been basicly welded to the shaft. was going up a hill this last time and just seem to start sliping and got really noisy, pulled over and made it up the hill to turn off on outer road, went to back up reverse is gone.....put back in drive and wasn't even able to limp it home...
after the 2nd rebuild we replaced the radiator with GM (has the cooler in it) we took the factory air transmission cooler off and replaced it with factory line....anyone have any ideas as to why this would keep going out....short of buying a brand new GM tranny what could be done....
any help aprecciated,
Heather
___________________________________________________________________
Sounds to me like you are getting very poor quality rebuilt transmissions. I am assuming these trannies have some kind of warranty, right? But it is a pain to have to have the vehicle in the shop for replacement. It might be time to bite the bullet for a new GM unit if you are planning to keep your Suburban.
the other thing we heard was gm trannys didn't take good to rebuilds.....
we are definatly keeping suburban till can upgrade to newer burb in year or two...does the newer ones with the 5.3's have the tranny issues like the older ones where you was almost guarenteed to replace tranny at 130,xxx range?
that's about to the point we are....have to shell out 1500.
Heather
____________________________________________________________________
Take a look at this forum....you will find many posts of Tahoe/Suburbans with tranny problems with the 5.3 engine.
Very common problem with the new generation Suburban/Tahoes. These transmissions have a history of failure at very low mileage compared to GM transmissions prior to 2000. If you are keeping the vehicle you might want to have a GM facility do the repair. AAmco or any of the other rebuilders can be pretty hit and miss when it comes to a fix. Make sure you get an iron-clad warranty no matter who does the repairs.
The transmission/overdrive unit is both mechanical and electrical with computers in the system too. You need a professional transmission expert to diagnose your problem. Find a reputable GM dealer or transmission shop with qualified techs.
We drove to a 2d mechanic who very promptly yelled at us for shutting off the engine given that the engine was dead, shot, kaput and might not start up again. This he said based solely on the clanking he heard which was incredible loud.
The car has nearly 179,000 miles on it and a rebuilt transmission (in 2005). I have someone who has the 350 engine with "low miles" (he is not certain how many) and will install it for $500 (cost to remove my engine and put new one in) and will charge $400 for the engine itself. This almost seems too good to be true, for if we can do this for $900 and keep the car for our family for another few months until we are able to find a newer Suburban, it would seem we could then trade it in or resell our car for at least $2-3,000.
Any thoughts? Are we crazy to think this might work? Right now, our car is sitting 5 hours from our home, so our options are limited.
You really don't know what kind of condition the engine is in......'low miles' is suspicious.....and who knows what make or model year this engine came out of (and why it came out). What kind of warranty will this guy give you?
I have a 2000 suburban that is doing the same thing and was wandering what you did to correct this 4wd problem.
Thanks for your input,
BC
It did. It was hot out that day and we had stop and go traffic the Tranny shifted down from OD to 2nd to accomodate the cruise setting. Long story short... Hit one hill the tranny let out a gawd awful whine (sounded like power steering pump) and one hill later the tranny was grinding awfully. Horrid sound. I knew the tranny was chucked! - No over heated tranny light or indication on the display. I am assuming that you didn't have the load I had. (I was fully packed for the beach 5 people in the machine towing my motorcycles. Chucked both planetaries front and back. 'AAMCO' replaced those and some seals installed a new updated' pump body (supposedly to improve fluid flow.) and recalibrated the Transmission shift points. The main issue they said was that the fluid pump - quit pumping fluid. That is essentially what caused a catastrophic breakdown. (I love my suburban's, this sucked! $3k to have fixed!) Kinda ruined my vacation too. I don't know what you could do to prevent this. Other than having a tranny place pull your tranny and check the parts thoroughly. (Supposedly I could have had GM install a new tranny for $1500 with 100k warr. Who knows now.) Hope this helps!
