Lincoln Town Car Electrical Problems
                                  in Lincoln
                    My 85 Town Car has a multitude of issues, the two most serious at this time being it's inability to stay running while idling in my driveway while still in park. It runs, once started, for about 10 minutes while idling. If I drive it, it stays running for about an hour exactly every time then shuts off immediately (not a slow gradual loss of power, it's instantaneous). The second problem is that my interior lights won't turn off now. The lights were all working properly and then my car died after it had been running for less than 2 minutes. I was idling while waiting to make a turn and the car shut right off again and when i opened the door the lights came on as they normally do and didn't go off until they drained the battery. The battery has since been recharged and the lights will not go off unless I dissconnect the battery cables. Also when the car dies, it won't start back up right away. I know that the problem lies between the distributor cap and the starter because I know the starter is functioning properly and the distributor cap is brand new along with rotor, plugs, and wires. Also I installed a new ignition coil. The cap is not recieving a spark from the coil though, which is the cause if it's sudden death and failure to start. It's very random though, predictable, yet random. Sometimes I wait 10 min, other times it's an hour and a half. The sweet spot seems to be at 30 min however. If the car sits for a while it seems to start fine on the first shot.
By the way, the service dept. is balking at replacing the dimmer switch. Does anyone know if it's such a big deal or that expensive? Thanks.
- Kurt Parker
Totally annoying to drive car at night due to most interior lights staying on. Lights do go out after 20 min but it is a constant drain on battery....Anyone know where exactly to look for this door closing sensor????
Thanks in advance!!!!!!
By the way, I discussed the lights-on issue with my pastor recently. When some of my fellow worshippers leave there headlights on just before church service stats, another member sends the pastor a note about the lights which he reads to the audience during the service. I reminded him that he nor the worshippers should worry about headlights that are left on for only a couple of hours. Hence, there is no need to read these notes during service. Headlights left on for two hours will not completely drain a good battery. And if the lights are left on and the battery is drained, we have jumping cables at the church and if the battery is suspect and does not hold enough current to start the car after two hours, this is a clear sign from above that the member needs a new battery.
When the "Delay" light switch is on, the headlights stay off when I press the key FOB to unlock the doors.
I research this a bit on the Internet and it seems that this problem occurred on some cars in California and a recall was issued. If anyone could point me to a service bulletin or know of this problem and help would be appreciated.
Marc
I was trouble shooting an Air conditiong prob. and started to disconnect harneses and now I have a blinking air bag light code appears to be 52. Any help out there.
The stator (magnetos) in my distributer where bad. When engine got too warm they would not make electrical contact thus could not produce the electricity to go to the coil, get amplified to around 25KV and return to the distributer, go out the distributer wires to the spark plugs (no fire....no start). When engine cooled car started right up and ran fine until it got too warm again ( usually when I idled going to yardsales) Hope this gives you a direction to explore. Paul
I opened the moonroof in my '96 lincoln and now it won't close (tried pulling it with no luck, it's stuck somewhere inside). I was advised to check the fuses and they appear to all be fine. When I press the button to close the roof, I hear nothing - does it mean the motor blew?
If so, what do you think would be a reasonable price for a replacement motor and how many hours it should take to replace? Alternatively, how long would it take to just close the roof without repairing the motor?
Thanks a lot!
While you are charging the old battery, spray WD40 into the slots where the window recedes. When the battery is fully charged, connect everything correctly and try to close the roof.
If your present battery is old, you may need a fully charged new one to energize the roof motor. Good luck.
-the radio will come on (to whatever station it wants to, and at any volume it wants to),
----(but you cannot adjust the volume, station, etc.)
-the only way to turn off the radio is to pull the fuse.
-the radio control buttons on the steering wheel do not work either.
any suggestions?
Second, press the "Off" button.
Lastly, disconnet the Ground, Negative, side of the battery and wait a minute or two.
Install the fuse.
Reconnect the Ground & maybe the unit will have reset itself to it's programed procedures.
FYI, the other high electric user is the rear window defroster, the one with the horizontal lines in it.
Thanks!!
Doug in Victoria BC
The hot air only coming out of the vents is an indication that your blend door actuator is stuck in the heat-on position. A few Lincoln owners on this board have said that the dash board and panel have to be moved to get to this part. The blend door actuator costs about $49.95; however, because of the amount of time spent removing and replacing the dashbord, the cost to replace the actuator runs between $500.00 to $800.00.
Perhaps one of the four door switches does not register fully closed, thus causing the interior lights to be on, drawing .32 amps.
Did you solve the problem?
Optional Information:
1998 Lincoln town car
Already Tried:
new battery and new alternator
