Recommend it be towed in for actual diagnosis as continued driving is not good for it.
-mike
:sick:
I had thought you needed a scoop to clear the taller engine but I guess this guy made it fit under the stock hood.
I am new here, and I am in need of a headlight lens cover for the RH (passenger side) of my 88 Thunderbird Turbo Coupe. It is not an actual headlight lamp, but a rectangular plastic cover that covers the plug in (xenon) type light. It just snaps in, and I have lost mine - or either someone needed it worse than I did, I guess. If anyone knows of where I can find one, or a pair, please let me know.
Thanks guys!!
I bought clear corner lights for my T-Bird, was an aftermarket part, but fit and looked great.
Converting 6 V to 12 V
Visiting Host from "Classics" (just happened to have this in my files)
ie: what's under the hood, the speed capacity,the frame length,how many miles per gallon, what size of tires and so forth.
I would appreciate very much if some one could help me and supply me with the information.
Turn signals work
Headlights work
When braking, only the passenger side lights up-
the driver's side does not light up
Help-where to look, suggestions-and other Sherlock Holmes
input is appreciated.
Jerry643
any suggestions would help
Thanks Desi
Dave M.
I did get the it installed : it turned out the sterro itself was bad; i retuned it and the new one is working perfect . Its all good
Desi
I know its the fuse but when I checked all the fuses they were fine????
also my right front passenger side is pulls to the right when driving is it hopefully
just the alignment because my wife lives at a condo with alot of bumps so you dont drive fast do you think thats the cause
pls advise
Dont know about the radio.
any kind of sound out of the radio?
