thank you very much for your time.....
Hi everyone, any help you could offer would be more than greatly appreciated. I bought this truck over a month ago, so i am not super framiler with it yet, anyway it drove fine for the first 3 weeks of coarse, then one morning i went to the truck drove about 8 blocks could heard some squelling(which would happen for 20-30sec when truck started) the truck started to kick/jump as if it was running outta fuel, i put the accelerator down to keep it from stalling out, pulled over, it idled fine looked under the hood, nothing obviously out of the ordinary got back in when i tried to change from 1st to second again i lost power and had to hammer down the accelrator trying to get home drove sorta normal for about 8 blocks heading back, then started dying again and finally stalled out a block from home. After that could not start truck at all, engine just turns with no start, not even any kicking or combustion. Had a weak spark so replaced the wires coil, disct cap and rotor and plugs, so i have good spark to all 6 cylinders tested out good, there is fuel coming out of the tbi unit, i can hear the fuel pump start and i replaced the pump relay to make sure that was not of issue, i have not been able to start car with starting fluid or pouring gas in...running outta ideas here...if you have a suspesion or something i should check please let me know! Thanks alot!
-Chris
Thank you for your help
Someone said it had to be alternator. I replace alternator, still nothing, no sound or click. Now someone said it must be starter. Where is the starter on this truck and I thought if it was the starter I should hear a clicking sound? What do you think?
So I swapped in the instrument panel in my 99 S10 with used unit. The PRND... had gone out. The new unit seems to work perfectly in every way but the truck will now not start. I get the solenoid click but that's all . Does not turn over all. The voltage meter reads no more than 10V but as I recall you never got he full 14V until the engine was actually running. So, before I re-install the old unit , Is there anything related to the instrument panel that would prevent the truck from starting. Where else can I look for problems. As I said I get solenoid click, instruments light up, engine does not even attempt to turn over.
Thanks in Advance
John
e battery it should have about 12.5 V with no load and yes 14.3 after starting
Don't have to much information on a 25 year old truck. The switch will power certain fuses, that is a good place to start, no power at your fuses then trace to where it should come from. All the ones you listed with no operation, are switch powered.
I heard that a fuel pressure of 30 lbs or less was bad. Would low pressure prevent an engine start? Good pressure is 50-65 lb. However, I don't smell fuel in the intake after turning key to start without pumping gas pedel which indicates fuel pump is not being told to pump at start up. I also read from another message 108 that if the TPS is bad it won't signal the ECM that it needs fuel as it is telling it that it is not starting. What is a TPS?
I've replaced the inexpensive - plugs, plug wires, fuel pump relay, and checked fuses. I don't want to replace fuel pump or coil or distributor or ECM or injectors until I get better intel.
Reliability report at MSN Autos for 1996 S10 says common problem on this vehicle are failures of the fuel pump, fuel injectors and EGR valve passages. Failure of the fuel pump and fuel injectors may prevent the vehicle from starting. The cost to repair the fuel pump is est 250 parts 130 labor. The cost to repair the fuel injectors is est 95 parts 195 labor. The cost to repair the EGR passages is 16 parts 58 labor.
I have 150K miles without tuneup and never used a fuel injector cleaner solution in gas.
I've read there are a number of sensors that can tell whether the engine is hot or cold which if messed up could cause a similar no start problem. However, my problem persists hot or cold. I can restart without starting fluid if done within about 15 minutes of a shut off. Some gas must not have evaporated yet.
The check engine light goes on and stays on for a week or two then goes off for months. I never had the code checked.
Has anyone fixed this problem for good and how?
We were searching possible problems for our 2002 S10 4.3 as it began with misfire and he replaced the Spider Injection (brand new), complete tune up and truck has good fuel pressure 65 lbs. at idle. Nothing is working and were are at lost. The truck runs, however random misfiring at cyl. 3 and will not rev up. We came across your post and noticed that you a lot of made sense. Any help is greatly appreciated.
And clean the pump contacts.
thank you
The brake lights are drawing what little power is getting through the poor connection.
