Forester - Headgasket Repair & Engine Rebuild
99subgal99subgal Member Posts: 1
I'm hoping I might be able to get some feedback here. My lovely little 99 Forester was running fine up until about 6 weeks ago. Now it has always burned oil and my dealership gave the the run around saying it was "normal". Fine, so I've driven around with quarts of oil in my car for the last 8 years, and I dump a quart in every 500 miles. Every time I bring it into for oil changes them I've told them it burns oil.
So 6 weeks ago, I start the car and no heat. The temp gauge shoots up to H and then the heat kicks on and the temp gauge goes immediately back down to N. I call the dealership - they say the thermostat is sticking and I'm find to drive it - I get an appt for 2 weeks later.
2 weeks later, car is in the shop and I'm told because I've been driving the car and its been overheating the headgasket is cracked. So I pay the $1,700 to repair it and replace the timing belt and temp gauge.
I pick up the car and it is running WORSE than it was when I brought it in with the cracked headgasket and sticking temperature gauge. I call the dealership from the traffic signal up the road. They schedule another appt for a week later.
Week later I bring the car in and the oil light blinks on as I'm driving car into their driveway. Get a call the next day saying I need a new shortblock and it will be $3,000.
At this point I'm furious - have another mechanic look at car and they tell me 2 cylinders have problems.
I meet with dealership and tell them 1) they should have checked the engine/cylinders when they replaced the headgasket and 2) I'm not repaying them to do the headgaskets twice basically.
So they tell me they are crediting me for the headgasket repair job. And get this - the price is $3,000. It actually is $5,000, but they are crediting the headgasket repair job to that.
I'm just disguisted and furious at this point. Car has 140,000 miles, and I'm really anal about changing the oil every 3,000 miles - despite the fact since 12,000 miles the car has been having 6 new quarts of oil dumped into it between changes.
They are telling me "its my fault" the cylinders are bad because I allowed the engine to run repeatedly overheated.
Feedback needed please on the cost range for replacing a refurbished short block. Maybe an estimate of labor hours.
Also - your thoughts on my saga?
«134
    First off, that stinks, and I'm sorry that this happened.
    However, you do have an alloy block, and significant overheating will absolutely warp the heads. The thing to do would have been to shut off the engine the second the temp hit the red area.
    The other thing is the mileage - 140k is a lot of miles. Subaru did extend the powertrain warranty for some models (00-02 IIRC) but not yours, but even those were only covered for 100k miles and only if you used a stop leak that they added to the radiator.
    The dealer should have noticed the warped heads when they first changed the gaskets, but FWIW they are paying you back for their mistake.
    I would not go the refurbished short block route, as those will likely be warped as well.
    Sorry but I don't think it's fair to expect any more from them given the very high mileage and the warping caused by the overheating.
    You can call 800-SUBARU3 and speak to SoA customer service, ask them for a little help. It's still a very stiff bill you'd have to pay to fix it. See if they can pay for half of it, or offer any help.
    Be very nice. I used to work at a Help Desk and trust me, it was the nice, friendly people that got the best service.
    I'll be really impressed if they help, but it's worth a shot. Best of luck.
    -juice
  • ma99foresterma99forester Member Posts: 2
    bought a 99 in august. just replaced the motor.
    the heads on these are attached with 4 bolts. so the pressure on the head gasket is uneven. then, when the head gasket blows, a bunch of bad stuff can happen. sometimes, the motor can overheat, like in your case, which means new motor. what happened to me was that the gasket leaked antifreeze into the #1 cylender, constantly washing down the cylender walls, reducing lubrication, destroying the piston ring. Then you need a new motor.
    I bought and shipped a crate motor from: www.ccrengines.com. Basically a brand new motor, and it comes with a 36,000 mile warrantee.
    as much as I now hate subaru, the ccr engine folks are great.
    the ridiculous part is that dealers wont take more than 1500 for a trade in, because they know about the head gasket issues, so, as bizzare as it seems, it makes economical sense to put in a new motor in a lot of cases.
    a few things to watch out for when replacing your engine:
    1. get a new radiator. its worth the few extra bucks.
    2. if its a standard, replace the clutch. you've already got everything apart, so all you have to pay for is the part which is cheap.
    3. make sure your mechanic and ccr engines are ok dealing with each other - this is important if you have a warrantee issue.
    4. have your mechanic double check which cam sprokets you need on the new motor - there are two different types.
    5. if ou burned a bunch of oil for a while, you might need new catalytic converters because the old ones mght be fouled with burned oil.
    sorry. have fun. it sucks.
  • asaasa Member Posts: 359
    I think Subaru knows they have a continuing problem with failed head gaskets because they now recommend adding Genuine Subaru Cooling System Conditioner” per Subaru TSB 09-42-05 (of April 15, 2005). The TSB is applicable to all vehicles. A head gasket failed on our '04 without a repair resolution and after the dealer adding one or two bottles of the 'Conditioner', the leak seems to have been stopped ..... but for how long? You'd think that after a long history of gasket failures, Subaru would re-engineer the application or materials. We're not real happy owners either.
    Wrong.
    The heads should be attached with 6 bolts, as can be clearly seen in this photo:
    Perhaps your mechanic broke off (from over-torqueing) or simply overlooked two of those studs, if so he's completely incompetent and is to blame for the problem, not Subaru.
    Where'd you hear that? That's not true at all.
    Here is the actual text from Subaru:
    Service Program WWP-99
    Dear Subaru Owner:
    This email is sent to you in the interest of continued customer satisfaction. Subaru of America recently announced a campaign on certain model year vehicles starting in 1999 through 2002. Official Owner Notification Letters will be mailed to all affected customers starting in late February through May of 2004. The timing of the mailings is based on the vehicle model year, starting with oldest affected model year in February through the newest affected model years in May. The following text is similar to that contained in the Official Owner Notification Letter that will be sent to you during the mailing phase affecting your vehicle. Therefore, this email is most likely arriving before most owners will receive their official Owner Notification Letter in the mail. Please do not schedule your vehicle for an appointment for this campaign until after you have received your Official Owner Notification Letter, unless you are experiencing vehicle problems. You can contact your local Subaru dealer for any questions related to this or e-mail us at Subaru.com, contact us.
    All vehicles? Where? Source?
    My '98 Forester was not affected.
    Our late-build 2002 Legacy was not affected.
    My sister's 03 Forester was not affected.
    My brother's 04 Legacy sedan was not affected.
    All vehicles? :confuse:
    C'mon folks, these forums are only useful when the information shared here is accurate. Spreading misinformation like this is harmful to everyone, both Subaru and the customer.
    I'm correcting you because I don't want Edmunds members to run off looking for a TSB for their car that simply does not exist.
    Please, folks, check your sources, quote them, offer references when they're available.
    That will make the advice here a lot more useful.
    Thanks all.
  • xwesxxwesx Member Posts: 18,004
    In the 2007 Outback/Legacy owner's manual, on page 11-15,
    "Always add genuine Subaru cooling system conditioner whenever the coolant is replaced. Change the engine coolant and add genuine Subaru cooling system conditioner using the following procedures according to the maintenance schedule in the “Warranty and Maintenance Booklet”."
    Apparently, they do not want to take any chances... ;)
    That's not quite the same as saying "they have a continuing problem with failed head gaskets".
    That hit 99-02 models hard, sure.
    I haven't seen reports of head gaskets failures for 03 and later models. Nor did any of the Subarus in my family get a notice that it was to be added.
    No, it is not. I just wanted to put out correct information for those who own, or are interested in owning, Subaru vehicles manufactured post-TSB. I cannot say for sure whether owner manuals from 03-06 request this additive, but it would stand to reason. If not used, I imagine this could be grounds for warranty denials.
    Actually, the head gasket problems hit '96 through '02 models hard. It was only addressed by Subaru in the phase II engines, for some reason.
    Not that this is indicative of widespread problems, but I heard from a fella in California about his gasket saga (1998 Outback, green), which lasted about 2 years and is just now coming to a close. He ended up having the gaskets (and a bunch of other work) replaced to the tune of $2200. His wife wanted him to dump the car, but he was stubborn and went ahead with the fix. Having owned it since new, he is convinced it has a lot of life left and the $2200 is well spent. I cannot recall the mileage - I think it was in the 80K range.
    Funny enough, I get many many emails from people who do Google searches and come up with my page covering gasket replacement on my '96 back in Sept '05. So many that I finally set up a folder on my email program called "Subaru Correspondence." :blush:
    I'll check in my sister's Forester Owner's Manual next time I see her, or my brother's 04 Legacy. I seriously doubt it, though.
    What section was it under?
    I don't see how Subaru could deny a warranty claim unless owners were officially notified (or unless it's in the manual, like for the 07s).
    I also wonder if it's in the Tribeca's manual, as the H6 wasn't ever really affected by the issue.
    I guess what set me off was the "all vehicles" comment, I still doubt that's true.
  • smittynycsmittynyc Member Posts: 289
    I can't say for sure whether it was mentioned in the owner's manual, but I am positive that there was a TSB about the coolant additive for my 04 Forester X.
    No, I agree with you fully about spreading mis-information or just inflammatory posts in general.
    As for the coolant additive, it was in the Maintenance section (section 11 in my manual) under coolant replacement.
    Out of curiosity, is there not a law that manufacturers not require items specifically from the manufacturer unless those items are provided free of charge? If this is the case, this Subaru coolant additive must be a commercially available item. Is that so?
    I don't know whether there's a law like that. It seems like there are an awful lot of products -- from vacuum cleaners to printers to water pitchers to various kids' toys -- whose consumables are available only from the OEM.
    I do know that you can buy the OEM coolant conditioner from your local Subaru dealer, or from any dealer which does online/phone parts orders.
    I've been told it is exactly identical to Stop Leak.
    MythBusters had a cool episode about ground pepper doing essentially the same thing, i.e. they put pepper in a radiator and tested to see if it would clog up the leak.
    Guess what? It worked! :D
    Myth confirmed. Ground pepper has the same effect as Stop Leak.
    MythBusters had a cool episode about ground pepper doing essentially the same thing ...
    I missed that one! Got any details?
    SUVs and Smart Shopper
    Oh, I thought that they could not require, say, that you "must" use OEM fuel filters, air filters, oil filters, fluids, etc; they could only specify that the items used meet certain established industry standards. Perhaps a specialty additive like the "conditioner" is exempt from that requirement. Even though, for the Legacy, it is a required maintenance item...
    Maybe it is another of those myths, though! I love finely ground pepper. It might not be a good idea to make coolant both sweet and spicy..... :surprise:
    Yep, that's due to the Magnussen-Moss Warranty Act. If they require OE stuff they must provide it to you for free.
    As for MythBusters, yeah, they used an egg, too. I only caught part of the episode, though. Cool show. :shades:
    Hmm I know about the magnussen-Moss Warranty Act, but how does that effect the use of XYZ fluids? A lot of cars these days require special ATF, Power Steering fluids, and now it looks like coolant as well. They are not "readily" available from 3rd parties, so while they don't "require" you to use theirs, if they are the only ones on the market you are required to use it.
    -mike
    Well, put it this way - they have to make the information on what additives they use publicly available, so that the aftermarket has a chance to come up with their own formula that meets OE standards.
    In other words, Subaru can come up with a formula, but if they patent it and they're the only ones who make it, they cannnot require that you use that specific fluid unless they provide it to customers for free.
    Example: they can require SH grade oil, but not a specific brand.
    Another example: they can require DOT3 brake fluid, but not their own.
  • larryinallarryinal Member Posts: 2
    Posted this over at 'sub crew - prob and solutions' but wanted to post here also. Had the valves replaced in my 99 forester (sohc) engine. Valve clearances values shown on the underside of the engine hood show a fairly wide range =
    intake 0.10 - 0.25 .. exhaust 0.15 - 0.30. The shop that did the engine work set the upper value on initial replacement to allow for break-in - 1000m later they re-adjusted the valves to tighter (lower clearance) and now am having power issues, i.e. hesititation on acceleration and surging of power in certain rpm ranges. Anyone have any experience in setting valve clearance. I am wondering also if I may need to reset the ecu?? thanks .. Larry
    I thought these valves were self-adjusting? :confuse:
  • leharveyleharvey Member Posts: 10
    They may be but there are 'specs' for clearance.
    These were replacement valves so adjustment would be necessary on initial install I would think??
    You didn't reference the correct TSB; this is straight from an image of the official TSB. I've listed two in hope that people can link to one or the other:
    http://www.scoobymods.com/forums/showthread.php?t=5316
    http://www.scoobymods.com/forums/attachment.php?attachmentid=4015&d=1120308728
    It reads that anytime coolant is changed, the Subaru stop leak must be added to the fresh fill and is clearly directed to 'All Models' on the header.
    They only say that WHEN SUBARU PAYS FOR THE REPAIR. It doesn't require it for non subaru paid for repairs. It also doesn't specify that it should be done on all repairs, if it were required they would have to put it in the owner's manual or notify the owners.
    -mike
    Still useful info. Thanks. :shades:
    Definitely useful, just didn't want folks to get the wrong idea.
    -mike
    I want to be clear that other than our head gasket woes, our (5-Speed) '04 Forester is a blast to drive and I like knowing that my wife and family are safe. We'd never owned an AWD vehicle before and the accelleration and handling are exceptional -- and ours is only normally aspirated. We'll see how long the engine lasts. The dealer added stop leak and it stopped coolant consumption for several months, but the steady drop in the bottle has recently resumed. However, there are definitely worse things in life to be faced with, right? :surprise:
  • colosubcolosub Member Posts: 2
    My 2000 Forester has had to have 3 O2 Sensors, 3 rear wheel bearings, and 2 head gaskets replaced. Does anyone know if these issues have been alleviated in the 2007 models? Any independent reviews I can read with proof in regards to these problems? I am trading in my 2000, and not sure if I want to deal with more potential problems, although I love other features about the car.
  • 98in_cuse98in_cuse Member Posts: 9
    I had to have a couple of cylinders "machined" and the valve guides repaired a couple of years ago on my '98 Forester. Since then the check engine light keeps coming on with the same message about misfire on the cylinder, but the shop keeps changing the explanation. I replaced the spark plugs twice and the wires again, they then blew out the injector and switched the wires. Now they are saying that the injectors need to be replaced. I am taking it to another shop for a post mortem but it may be at the end of the road at 130,000 miles as I am afraid it may be endless. I would like to hold onto it for two more years but hearing some of these stories, I wonder. The afore-mentioned job cost $1900, not to mention the followups. I did complain to Subaru but got no response - there was also an issue with warranty on the spark plugs. I don't know if this is a different issue from the one you are discussing, but it's interesting...
    Might be the ignition coil, too, that would trigger a misfire CEL.
    Wheel bearing design changed significantly for MY2003. They now use sealed ones, completely different. We haven't observed nearly the same level of problems.
    Head gasket materials were revised several times, and again, the frequency of complaints here on Edmunds is way down.
    I didn't see a major pattern with 02 sensors before, so I cannot comment.
    If you check Consumer Reports, you will see higher problem rates on engine (headgasket) and drivetrain (wheelbearings) on certain years in the ranges I describe, so yes, they seem to have improved measurably.
    Juice,
    Thank-you very much for the quick reply.
  • jetfishjetfish Member Posts: 15
    Hi everyone,
    Now it's time for me to change the air filter for my Forester '99 built in Jan'99. I am not sure which brand of the replacement air filter I should buy. I searched on http://www.autopartswarehouse.com/shop_parts/air_filter/subaru/forester.html
    and found there are a few brands for Forester'99 such as K&N, Denso, NPN and unbranded OEM. The prices vary from $60 to $9.
    Which brands do you guys recommend? I'm from PA.
    I'm not totally certain but I think Subaru uses Purolator filters. The oil filter for my '98 was Purolator, and I replaced the air filter with one and they looked the same IIRC.
  • chienchien Member Posts: 6
    98 Forester, 104,500 miles. It seems worth it to rebuild engine but really would like opinions. I'm nervous about future breakdowns of other parts.
    No major problems before this. Car runs tight, no weird shifts, clangs, wobbles, noises. Body in good shape. Been rearended 2x at low speed, but frame OK. Front windshield cracked 2x and replaced; power steering pump replaced. Preventative replacement of water pump and timing belt at 60K big service.
    Head gasket blew 75 miles from home. Stopped as soon as temp rose and found ugly oily bubbly in coolant overflow. Local shop flushed radiator, new thermostat, etc. did not fix overheating. Pressure test showed head gasket problem. Towed car back home to my mechanic as I am AAA Plus member (100 miles free).
    My trusted mechanic says rebuild your engine, oil and coolant mixed in engine so head gasket repair won't be enough. Rebuilding my engine costs $3100, includes 3 yr unlimited mileage guarantee. Labor $1400. Includes new water pump, new seals/gaskets, new oil pump, new timing belt, new rings, new cam bearings, regrind valves, recycle bloc and cylinder heads.
    Tradein value seems low $3600, used car prices around $4500-5000. I bought Subaru expecting 200K so upset at this major engine flaw. Prefer not to buy new car, but am liking Honda Element.
    Opinions/experiences on rebuilding your engines would be greatly appreciated!"> :confuse:
    I had the same or a similar thing happen to my '98 - it didn't overheat and blow up but I had to have half of the engine rebuilt due to cylinder misfirings. That was at 113,000 and I'm now at 136,000. It seems to happen to most of the '98's and some of the later models and most say that if this is taken care of the cars can run forever. I had some problems last summer but these seemed to be cured by a coolant flush and conditioner, new filters, though I may have routine engine issues with summer heat. But it's running great now and I'm trying to go for 200,000 - waiting for a better alternative.
    If the body is good, I would do the repair, especially with the waranty - you also seem to be getting more work done than I had to do, so I can't comment on the price. It may be a closer call with your costs and the value of the car. There are others in this forum that are better on the mechanical and cost issues!
    98_incuse
  • p0926p0926 Member Posts: 4,423
    I don't know, when the cost of the repair approaches the value of the vehicle most people will recommend you go the new car route. How much for a remanufactured engine?
    It does seem a shame to give up on an otherwise good vehicle and unfortunate that the headgasket failed in the worse possible way. I had a Nissan that developed a head gasket leak but the leak was external so was cheaper to repair.
    Unfortunately, headgasket failures is the biggest issue with your model year. By nay chance did you get the coolant conditioner added?
    FYI, I believe that Juice sold his 98 Forester this past summer for $5k.
    -Frank
    So, just to clarify, the mechanic drained the engine oil and there was coolant in it? I ask, because if there was just oil and/or combustion gunk in the coolant, you need not go overboard with the head gasket repair. At 118K miles, that engine has a lot of life left. Barring warped heads, replaced gaskets will likely extend the reasonable life of the car through 200K or more miles.
    I 2nd the nomination for a re-man....
    Without install labor, a reman costs the same as the rebuilding of my own engine - $3K from both Neco and CCR. A new engine is $5K (from Jasper). A cleaned up salvaged engine with guarantee was $1500-1800.
    The coolant conditioner was for the 99 engine which was a SOHC vs my engine, a DOHC. I never got any notification from Subaru about it.
    The sale prices for a running car are $4-5K. My car is not what I would call "running", so I guess it's value is $0. It goes for 5 - 10 miles before overheating. Some might try to trade it in without mentioning the head gasket but I just can't do that. I'm mad at Subaru for ignoring this, so my next car will not be a Subaru -- probably a Honda.
    I'm not sure if the oil was drained but the first mechanic I had the car at did a pressure test after trying the radiator flush/new thermostat route. I had checked the oil before leaving on my trip and the oil on the dipstick was brown not black. I didn't realize what I was looking at but my trusted mechanic says that indicated that oil and coolant had mixed in the engine and compromised the bearings. He'll have a closer look before the rebuild starts.
    I thought a lot about getting a new car (Honda Element springs to mind and I got quotes from CarsDirect and others) but I decided to make that $5K bet that I could keep the Sub running at least 3 more years as everything else on the car seems in good running condition.
    Personally, I hate throwing away stuff that still has use in it. Would love a new car but that would cost $23-25K and I don't want to buy on payments or lease. This was not an easy decision to make and it still depends on what my mechanic finds when he pulls the engine. I'll know soon!
    Thanks for your input!
    Sell it as is or to a salvage yard. I wonder how much they'd give you for it.
    Not much, generally a non running car will not bring in much money. :(
    -mike
    Hi all -- re: the DOHC engine flaw causing blown head gasket.
    I ended up getting my blown engine rebuilt. Not an engine swap but my original engine rebuilt, with new rings, new water pump, new timing belt etc. I really wanted a Honda Element, but this was $5K vs $25K.
    I am the original owner. The body is still good and the car mechanically well-maintained, so I felt it was the most practical solution.
    My mechanic used a shop and person he absolutely trusted, and he is hard man to please. It took a 5 weeks because of end-of-year supply problems, but I got it back in late January and it runs really well. I also replaced the cassette player with a CD player and had the car detailed inside and out, so it would feel like new. My mechanic told me to let it warm up for a few minutes before taking off so the aluminum parts and steel parts were near the same temp.
    So far, so good. Everything runs smoothly and there are no new noises,weird engine shifts, or temperature issues. I'm taking it in soon for a 1,000 mile oil change as the engine is "new" still. I do smell a slight burning odor at the end of the day when I garage it, but it is slight.
    This may not be the best solution for everybody, but for me, who hates throwing away good things, it was. I figured it was an unacknowledged (by Subaru) engine design flaw. A rebuilt could make the engine go another 50-100K (I hope) which for me, means another 5-10 years as I don't drive more than 10K/yr.
    I also have a long-term relationship with a trusted mechanic who has maintained this car from Day 1. He did not push me to rebuild the engine because he knew it was a lot of money and a big decision, but I know he also likes to keep cars on the street for as long as possible. Most of the cost was for the rebuild itself. There is a 3 year warranty on the engine, parts and labor.
    I loved my Subaru before this, and hope to regain that love and trust after a few more miles!
    Thanks for the update, chien! It sounds like you went all out on it, so there is absolutely no reason why it should have any engine problems in the next 100,000 miles.
    When I purchased my first Subaru, I had several problems that made me want to tear out my hair. I flatly declared that I was going to sell that car and never buy another Subaru. I, like you, decided that it was cheaper to keep the car I had than to buy something else. I am quite glad I did. Even though that car took more than a little of my blood and tears over the years, it turned out to be a fantastic machine. All told, my ownership experience with it was quite rewarding.
  • jacksan1jacksan1 Member Posts: 504
    We have an '01 Forester L with 99,640 miles, and during a recent trip to our local mechanic, we discovered that there was a coolant leak from the head gasket. This car was serviced during the recall for the head gasket (WWP-99) back in 2004, and followed the maintenance schedule faithfully since which was required under the extended warranty for the head gasket coolant leak to 100,000 miles or 8 years from the initial date of service.
    Since when this was discovered, I only had less than 400 miles to go before this warranty was going to run, so I immediately took the Forester to a local Subaru dealer. However, later, the dealership reported that it was oil that was leaking, not coolant, and so this extended warranty for the head gasket did not apply. I naturally contested it (my mechanic said it was coolant), and in the end, Subaru USA agreed to pay half the cost of the head gasket repair. I did not want to agree to this, but I just could not risk having the warranty run out during the dispute process and needing to pay for the whole thing in case they turned out to be right about the coolant leak. If I had had several thousand miles left, I would have pushed the issue back to Subaru and insisted on a second opinion to decide whether it was oil or coolant leaking.
    I am now wondering whether it is some kind of a standard response by Subaru to pay half for the repair of the recalled head gasket claiming an oil leak versus coolant's in the hope that an owner would just accept it as I did. Has anyone had this kind of experience?
    I believe that when your head gasket is leaking, BOTH oil and coolant get mixed together and cycle around in your engine. Your mechanic probably did a compression test and found the head gasket was leaking. I had oil globs in my coolant overflow tank. I think your dealer was trying to get you to go past your warranty mileage which is very, very unethical.
    Just the fact Subaru USA agreed to pay half means you were in the right and they were trying to get you to settle. Also very, very unethical.
    I have no idea what recourse you have -- perhaps registering a consumer complaint with your state Attorney General or suing the dealer and/or Subaru USA in Small Claims court for the other half. Depends on how upset you are. And don't buy another Subaru if you can't get resolution from them.
    Big companies count on you folding. I've had problems with Verizon Wireless and CIGNA Healthcare and had to spend many hours writing letters and talking to customer service reps (who should be called customer DIS-service reps). They simply ignore you unless you persist, persist, persist. It's not the money, it's the principle.
    When I first got the bad news about my car, I found a site dedicated to the Subaru head gasket leak with many disappointed and angry owners. Maybe there is a suggestion on there that will help you figure out a course of action. Leaves a bad taste, doesn't it?
  • vlh2vlh2 Member Posts: 1
    I have an 02 Forrester that developed head gasket leaks. I took it to the dealer and they didn't mention the recall or that it may still have warranty on it, just want a couple of thousand dollars. I took it to a repair shop and in the process of starting to repair it, they found the recall and called me. I verified with them that there was only coolant leaking and took it back to the dealer. The dealer then called and said one was only leaking coolant, but the other was also leaking oil and the warranty wouldn't cover it. I told them I had had it checked by someone else and had verified there was no oil leaking. I finally told them to only fix the one, because at this point I didn't trust them at all! I haven't called Subaru yet, but plan on it.
    Some 02s were covered, others were not. They had a running change during that model year, supposedly.
    That's what I heard, anyway.
  • gherman131313gherman131313 Member Posts: 17
    2003 2.5X Forester, 110,000 miles. Was told by dealer oil leaking from head gasket. Called Subaru, they offered either to pay half or $1,000 off a new Forester.
    I had the head gasket work done, wound up costing me around $600.
  • vtdogvtdog Member Posts: 163
    My son has an '02 Forester which was bought used (off lease) in '05 from a Subaru dealer. He now has about 75k, but I don't think the recall for head gaskets was done. He did have the 60k service at a Subaru dealer, but I don't remember reading anything about a recall, or special additive to the coolant change.
    How would I check for him to see about the heaqd gasket recall?
    You should get the VIN and call 800-SUBARU3. They should have the info.
    If you have an acct on My.Subaru.com it may also have it. I know it did for my old 98 Forester, but...I was the original owner. Not sure if it will catch data from a previous owner.
