Visitor Agreement.
I think you're likely looking at an electronic control issue rather than some physical problem with the engine and/or battery
Good Luck with your car. :shades:
The entire kit for a 2.0 is $150 on Ecstuning
Sometimes, if its flashing red, it can also mean the the car is running low on coolant. do NOT buy GREEN coolant from autoparts advanced! you MUST buy Vws G12 Coolant. Yes, its more expensive, but its the only coolant that will work in a Vw Engine properly without throwing weird codes and causing problems. You can also add some distilled water.
Please Help ?!
Thanks for any input!
Phil
Pump is +/- $500. I went to a local junk yard and took one out of a 1997 passat (completely different engine and model # on pump but the hose inlet and outlets were the same). Be sure to take the plug from the new used pump, change the bracket and wire the beast in. Tight fit but you can get it in. Hopefully this will save someone some dough.
Also find a used MAF in the junkyards if possible, call them all, $50 instead of $250.
We expected to see a red hot engine but did not. The car had no compression. We had it towed to a VW service center. They said the engine is shot (pistons melted into the cylinder walls) and has to be replaced. They've quoted $6900 and no guarantee the repairs stop there. HELP! Anyone have ideas of how a car goes from running fine to a catastrophic event in a matter of minutes? Should I just give the car back to VW and call it a loss? I'm frustrated!!!
I know it must be a vaccum leak .There is a small can like item around all the vaccum lines ,could that be leaking or bad? what is that part?Thanks
after complete worm up, works normal.
If your check engine light stays on and the shop has checked/cleaned replaced the mass-flow sensor and/or the oxygen sensor, have them check the carbon cylinder, it may be cracked, thus affecting the vacuum.
Good luck
1. After running the car lower than I normally do on gas, the gas light comes on and I go to the gas station to put gas in it, and now it won't start for a few minutes. It takes like 5 minutes to start. It cranks but won't start.
2. After I cut it on and off so many times, like if I have a couple errends to do in town it takes like ten minutes for it to start back up. Again it cranks but won't start.
It's like it gets too hot but my tempature gauge doesn't show anything on it. It doesn't blink red or anything to let me know it's overheating.
I have a few codes that come up on the computer that diagnosed it, egr valve, turbo coolant malfuntion, o2 sensor bank 1 running to lean. I've replaced the o2 sensor and it's still saying it's running to lean.
Please I need help and ideas for how to get my car running right
Bel Air Car Guy
