Lincoln Owners Club
I'm looking for individuals with extended
ownership experience with Lincolns. I own a 69
Mark III and 82 Mark VI and need help locating
quality parts and servie for these cars.
http://www.autopedia.com/html/HotLinks_Lincoln.html
Mr. Shiftright
Funny to find you under this catagory. I've seen you either in the Saab/VW or Audi forum! Thanks for the help.
I need to find a reliable source for parts for this car. I'm currently restoring a Packard but will soon begin to focus on this very wonderful "modern" example of autmotive engineering excellence. Whenever I take this car out for a spin I'm always amazed by its 7.5 Ltr. monster under the hood.
http://www.me.mtu.edu/~prater/carpics/fords/lincolns/70mark3.jpg
mr. shiftright
PS: Frederick....get a copy of hemmings motor news if you don't have one...should have some good mark III sources...if you're stuck, e-mail me and I'll dig around for you!
best, Mr. Shiftright
<<A HREF="http://bigjoe409@aol.com.">bigjoe409@aol.com.>
I'm looking for "local" Sothern Cal. suppliers I can contact and go see the parts they've got for sale.
I ended up having to take parts from a 69 Thunderbird in order to repair the problem on the Mark III. The clerk at a very well known L.A. parts yard said that " he'd seen a lot of Mark III's up until 5-6 years ago" but that "they're nonexistent in the yard today." Rarity of parts for this car is building even in major markets like Los Angeles.
Im sure that these older cars are drying up because they've all been crushed at the wrecker (especially after the two gas crises in the 70s)...this is why, ironically, you can often find parts easier for the rarer cars, because they were never junked in the first place (like early T-birds, Vettes, most ragtops, cars like that...)...
I had to brase the replacement arms before I put them back on my car because the stress fractures on them were already apparent when I picked them up. The replacement job is not so hard but you won't find an arm that you can just drop into your car without reenforcement work on them.
In any case, I've been searching for a front header for the car and may have found one! Thank you!
Separate issue....I'm thinking of getting the car repainted....any suggestions. It is silver. I would like to get a pearlescent silver for the refinish job (if they make such a color.)
You not likely to find many of these cars in the junk yard because they've proven to be relatively durable, although the 5.0 Ltr. engine is a bit anemic. I've ridden in numerous VI's still serving as airport limos in N.Y.C.
I have only one comment about your repainting job. If you look closely at your VI you'll notice that the, I believe it's burgundy colored, pin striping on your car is in fact painted on the car. This is a little bit of a problem when you consider repainting the entire car because it'll cost extra $'s to have that pinstripping repainted. The second problem you'll encounter is that I think you have a Cartier "CC" stenciled into your pinstrip line somewhere on the car. This kind of detail is what makes your Cartier different from your average VI like mine and if not preserved you'll deminish the value of your car with a new paint job unless your old original paint is completely shot.
The early 80's was not the best time for automotive painting technology here in the States. Many upscales American manufactureres switched to the new European style paints that put a clear coat over the base color coat to make the color look deeper and richer than your traditional single stage paint used for years here in the U.S. Unfortunatly the early clear coats here in the States were not very stable and quickly began to deteriorate when exposed to the sun's harsh violet light.
You'll have to have that old "bad" clear coat entirely removed and then repiant the base metalic coat over the old metalic coat finishing off with a new quality UV protective clear coat. The pin striping will come after the final clear coat has cured.
My clear coat is really looking bad. especially the left side of the car. The hood is now a totally different color. it just looks aweful! Altough I do not drive the car during the harsh salty winter here in the northeast. i do not have a garage to store it in. it was garage kept before i bought it and now i'm sure the sun is what killed the clear coat! i don't recall a "cc" in the pinstripe, but then again, I've never looked. i'll have to check.
i'm wondering, too, about the vinyl top. it is a medium gray and still in good shape, but the elements are not treating it very good. i don't expect it to last real long. i wonder if it would be easy to replace the top?
i've been amazed that this car has held up so well. i mean it is so sturdy. no rattles or thuds or squeaking of any kind! my parents also now have a '93 taurus and it makes more rattles and bangs and thuds than you can believe. not to mention having the head gaskets replaced twice for their 3.8 liter engine. i also had to replace head gaskets in my 94 cont. they are right when they say, that they just don't build them like they used to! of course the ride, handling and interior of my 94 are way better! that's just a given. with interstate highway cruising though....it is a tie!
Thanks again!
I am like you in that I live in a very harsh enviroment where I'm not able to garage my car. I live near the beach and the salt water will just eat up your car in a matter of years as well as the harsh summer sun. I've taken to covering my car with a car cover regularly and that seems to have really slowed down the deterioration of its finish, roof, and interior. The suon on the top of your rear seats as well as the dash will just eat them alive.
I done a bit of asking around about the problem and already recored the radiator in an effort to fix the problem but that only seemed to reduce the temperature build up to the point of preventing total boil over. Someone else has stated to me that they thought a head might be cracked. I know that this is a possibilty but I'm a bit surprised by this. The long block engines are really huge and I'd have thought it'd blow head gasket before it gave up and burst a block.
Anybody with Mark III overheating problems out there? What was your problem and what did you do to remedy it?
Your condition sounds fairly normal, really, if indeed it's a hot day and traffic is heavy.
I seriously doubt a cracked head...that would cause an immediate and catastrophic overheat, since you have exhaust gases heating the cooling water...such a diagnosis does not match up with your symptoms.
Also, check your thermostat for both condition and temperature range. If it's been a few years since you replaced it, do so with a summer range thermo and see how that works. But the overflow bottle will save you antifreeze and helps the environment, since anti-freeze is poisonous to animals, who lick it because of the sweet taste.
I know that if I lowered the price to around $5,000 I'd certainly move the metal. This is what I payed for this car two years ago. It is cosmetically restored and a looker at a distance. What is your gut accessment about the future market for a car like this. 1969 is begining to be one of those middle years where income and memories don't match for most collectors.
I sense you've been around the block a few times so just be honest at tell me your thoughts.
Understood, thank you for the input. When you say the Mark III "is a sedan" how does that differentiate it from a coupe? The official terminology for these cars is a personal luxury coupe. I agree that this car is near market value since I've had more than a couple of buyers interested in the car near the $5,000 price range but I do know that there still are plenty of these cars around on the road.
Oh, related to a previous question about paint. I priced repainting with several local shops and many say it will cost between $2,000 (extreme low-end) to $4,000+. One said "time & materials."
I think I'm going to try and hold off at least another year. That's a lot of dough!
I read your post in the Lincoln Towncar & must agree about the trips and comfort comments. I drove my 81 mark on a 300 mile round trip last summer and have driven it on 500 mile trips previous years and always loved the comfort and ride...its premium! I even think it rides better than my 94 continental on interstate travel.
Thank you,
Frank
Today, both the diamond jubilee or the designer cars are worth the same...about $7,500 for a very very nice one, which is only about $500 more than for an ordinary Mark V. So the collector factor does not have much bearing on the worth of the car. No doubt this is because they made so many of them (over 72,000 Mark Vs, and more than 15,000 collector models, of which many still exist). So the law of supply and demand seems to indicate that this car will hold its current value but not appreciate very much.
Nonetheless, it sounds like at $4,000 you are getting a fair deal, and perhaps with luck you could even turn a small profit on the car later on.
Believe it or not you probably are getting even better mileage on your VI than you've stated. Lincoln's 5 Ltr. 302 cu. in. V-8 is no rocket but with its overdrive auto trans you will get nearly 20 MPG around town and over that on the highway.
I own an 82 with digital dash and info center that regularly states 22 MPG when I'm driving on a open highway. This is an amazing figure for a car as heavy and old as the VI. The car is a bit of a dog climbing hills or passing at lower speeds but it does get "great" gas mileage. I personally find that its sheer size alllows the Lincoln to merge and or pass anywhere I choose to do so.
Long live the American Land Yatch!
I too have the Digital Dash and trip buttons with my Cartier. The only trouble I have is the clock or date sometimes changes & the Distance to Empty sometimes messes up.
On long distance trips the "Destination" feature is awesome. Punch in the trip miles and it tells you when you will arrive - based on current speed (and much more)....pretty cool for an old boat! (I'm sure yours has this too!)
Long live the aircraft carrier!
I ended up having to call the account from my cell phone to reschedule and apologize. I eventually made the sale but I ended up towing the car to a nearby Lincoln dealership and renting a Toyota Corrola for my trip to Nor Cal. Bummer of a car to have to drive North to the Bay Area.
After twice going through the digital dash's conniption fits an automotive electronic specialist shop told me that the grounding connection for the dash display module was was a flat male/female connector right on the floor board behind the gas peddle. If this connection becomes loose you'll have all kinds of strange and expensive problems with your digital dash.
The remedy is to have a screw and eyelet connector put on the ground wire and save the headaches for something else.
"Enjoy the ride" should've been the Mark's tag line.
Is it possible to interchange the window seals on old 68-70 Thunderbirds with those of a Mark III? I need new rubber for my side windows and it seems that there is a heck of a lot more after-market repros for Thunderbirds than there are for the old Marks.
There were well over 100 Lincoln's in the show and great examples in every class. The 50's Mark II's nearly took up a third of the entries in the show. Man those late 50's convertible and hard top slant window Continental Mark III's were some of the flattest longest boats I've ever seen.
In any case, it was a very fun to see all these cars. Some in very nice original condition. My wife decided that she liked a very dark blue metallic Mark II with a two tone leather interior the most. I don't think she knows that these cars are already in the $30K plus region though.
The car that intrigued me the most was a V-12 Zephyr 2 passenger coupe that had a rear end on it that just didn't stop. The car looked like it was designed to be driven backwards all the time. The car was pretty much in organal which I personally always enjoy seeing because you you can still smell and see the history written all over the car.
Are they a good car? I would love to have one for a summer cruiser.
My neighbor had one stashed away, along with three other Lincolns. One looked like a '50s model, one '70s, and one was a late '80s Town Car.
I've only been in the US 10 years, so I don't recognize all that many of the older cars, but I love those big old convertibles!
series. I have an 80 MVI and my dash module goes on strike every now and then. I'll use your tip
to check it out. I think you've saved me a lot of
grief. My barge has 32000 orig miles on it and
was a former calif car. Regards, mikem24
A two door sedan would be a 2 door with a B-pillar. Or a 2 door version of a 4 door family car.
The 70's saw car makers calling any 2 door, like the 1973+ Grand Prix or Monte Carlo, which had B pillars, a coupe.
Now, it seems that "sedan" means any 4 door car and "coupe" means any 2 door.
Most price guides should show this type of value...as "poor" or "fair" condition. Your agent must not be looking in the right place.
I would love to have one, but I already have a Wildcat Convertible, so I will be looking for a 4door sedan.
Good luck
Anyway, you might take that advice...get an appraisal and if you have a garage for the car and will only drive it a limited number of miles, you may be able to get an agreed upon value. Otherwise, the book value is what you'll get from a regular insurance company and this seems fair enough for the car you described.
