Chevy Colorado and GMC Canyon Electrical Problems
mikeof48mikeof48 Member Posts: 5
edited August 2017 in Chevrolet
My 2004 Chevrolet Colorado LS would not let the drivers window down nor lock or unlock with the remote fob. It is traced to the wiring going through the door. Has anyone else had this problem and will GM help get it fixed?
«13456714
  • jtenpasjtenpas Member Posts: 7
    SEE BELOW MESSAGE FROM OTHER THREAD.
    #30 of 31 Re: 2004 Colorado remote lock problem, Please Help [delawhere1] by mike2250 Feb 19, 2007 (5:34 pm)
    Bookmark | Reply | E-mail Msg
    Replying to: delawhere1 (Feb 19, 2007 4:33 pm)
    I recently posted about my experience with the same problem, Here in Florida we don't have cold weather so I knew it had to be something else. I took it back to my dealer who actually has a service department that doesn't let phantom problems go. The mechanic who worked on the truck told me it primarily happens on crew cabs and is aresult of the electrical clips on the bottom of the control module not being properly locked place. Repeated slamming the door and riding over bumps dislodge and then intermintedly cause the problem. He properly reattached the power plugs after applying dielectric grease to the contacts. So far so good.
  • gmrozowskigmrozowski Member Posts: 1
    Air Bag failed to deploy in my brother's 1995 GMC Canyon Pickup Truck. Mechanic said this was because he did not apply the brakes during the accident ?
    Air bags only deploy during a severe change in g-forces. Basically if you come to an almost instantaneous stop, the air bags will deploy. If you hit something that gives under impact and allows the vehicle's momentum to continue, the air basgs will probably not deploy.
    kcram - Pickups Host
  • snaproll1snaproll1 Member Posts: 88
    You just saved me a lot of aggrivation and a trip to the dealer, thank you for your post.
    My truck just developed the same problems. I rode 30 miles, turned it off to get directions, started it back up, pulled into a driveway, visited for a couple hours and then the truck wouldn't start, just solenoid clicking. The driver's window wouldn't work and on the dash it said "ABS Fault". I didn't have time to mess around so I got a jump and it started right up but the driver's side window, door locks and fob still wouldn't work.
    I drove home just fine and the next day the truck started just fine and the window worked. I drove to an auto store figuring the battery was bad. I had it completely discharge last week forgetting a cooler I had running off the cigarette lighter. I figured the rapid charging might have cashed in the battery. (If you haven't discovered it yet, the battery is a "new design' and only available from the dealer of course). So I didn't get the battery but got jumper cables and took a deep cycle I had laying around for insurance if it happened again. The rest of the day, no issues. I thought everything was just fine. That was yesterday.
    This morning, same cr#p. Truck battery was down, solenoid clicking. It jumped right away but the window, fob and locks were out again.
    I hit internet and found your post. I took the panel with the buttons out, it's two screws in the grip, tilt forward and lift out. There are three wiring bundles that go into the window, lock and mirror unit. They have a little lock tab, press and gently pull out. Just to see the rest of it, I took the unit out of the panel, that's three screws. The unit has a white back held by one screw and plastic locking pressure clips on the side. I opened the unit and there is just a circuit board. I wanted to check inside for water damage I figured might have trickled in when the window was open. The board looked good. I put everything back together but sprayed the wiring bundle and socket with contact cleaner. (Of the three plugs, two are the same size so mark them to get them in the right place. I didn't do this but it was evident because of the wiring lengths). I snapped the plugs back and and the door locks and window came back to life.
    I'm not sure if the weak battery is related or not. I also took apart the back door window switch panels and the one on the passenger side, but I think it was the driver's side that was causing the problems as that is the only one I used the contact cleaner on.
    What a weird problem.
    Other than that, I have 62K miles on my '05 extended cab. Initially I had a bur rubbing on the brake drum that made a horrible grinding noise. They took care of that in the first few days. After that not a stich of problems for the first year then the blower motor went out on the heater/AC. That was $200 bucks but I found out it's easily replaced by the owner, it's on the front firewall.
    Just this summer I noticed that the front tires were wearing badly and I had them aligned and rotated. They were off on all three things, camber, toe and castor or whatever. Because of the wear in only 2 years I think they must not have been well aligned at the factory. Oh, also the headlights were also set too high and everybody hit me with their brights.
    Shortly after I got it, maybe 6 months the steering started to make a kind of 'clunking' sound around corners, haven't figured out what that is. There is also a 'lifter tick' it's had since day one.
    Generally it has been a good vehicle but it's starting to rattle and feel like my old Explorer did at 120K miles.
    Again, thanks for the info on the weird electrical problem. Like I say it saved me a trip to the dealer, probably a new battery I don't need and a lot of screwing around on my own checking fuses and troubleshooting it myself.
    Well... the problem returned two days later. Same thing, dead/low battery, driver's window out, door locks and fob out, abs fault on the instrument panel.
    I called the dealer, sounds like they never heard of this problem. The guy I did talk to says the ABS fault is problably because of the battery being low.
    So something is draining the battery along with the other problem.
    I'm guessing it must have to be in the driver's door unit. There is a small ciruit board and possibly a weak component like a resistor or something. I'm guessing this because I had the problem, took the unit apart like I say above and the problem was fixed. Nothing else was done to the truck other than messing with this door unit. Perhaps the problem is somewhere else and disconnecting this unit resets something somewhere else, but at least it appears narrowed down.
    I've scheduled an appointment at the dealer in a few days but the window is open right now, so I'm going to mess with it and see if I can get it to work. I'll report the findings if I'm successful again tonight.
    Well, I got home, truck still not working, took apart the window module again, took out the wiring plugs, spayed them with contact cleaner and taaa-dah, the window and locks work again. Definitely something is funky with that module and it's connectors.
    Based on this, reading an earlier post where the dealer told the guy that "the circuit has to cool from raising both windows at the same time" or whatever is complete cr#p.
    The conditions were dry the first time it happened, the truck had just been driven 30 miles, shut off, restarted again, parked for a couple hours and the problem came out of the blue. A jump started the truck, it was driven home, parked overnight, the problem healed itself. Fine all day. Next morning dead. As soon as I disassembled the module and sprayed the contacts with cleaner it worked again. Fine for the rest of the day. Next morning dead again. Drove it broke all day, it didn't heal itself. Got home, cleaned the contacts again and the problem is fixed.
    So the first time it fixed itself, the next two it was broken until I messed with the window/lock/mirror module, cleaned the contacts and it worked right away. It's hard to believe it could be related to anything else like the instrument cluster.
    I still have the dealer appointment for this Friday so I'll keep posting if the thing dies again or if the dealer has any fixes. In the mean time I'm going to have to drive around with a screwdriver, can of contact cleaner and a spare battery and jumper cables :(
  • mikeof48mikeof48 Member Posts: 5
    have had the problem once, where the Colorado's windows, locks and remote wouldn't work. My mechanic showed me that the wiring going through the front door was pinched and probably shorting this out. I asked the dealer ( It's out of warranty) and they said the next time the problem occurs to bring it in. My mechanic suggested twisting the wire to see if this would allow everything to work properly. So far, at 53,000 miles, this has only happened once, but it might be worth looking in to.
    It crapped out again. And I fixed it again. In to the shop today. They say it's the BCM. I told them to call it the BECM, Big Expensive Computer Module. It's three hundred bucks and some change. Maybe they're right.
    Having taken it apart I can't see how wiring is getting pinched in the door. I wiggled the wires and connectors, no effect. It was only when I unhooked the harnesses and sprayed contact cleaner on them that it worked.
    The dealer I'm going to are pretty square shooters so I'm going to trust them... this time. If the problem happens again in the next few days I will raise holly hell for sure.
    Ok, Friday afternoon I get the call. The truck is not ready. They've discovered that the fuse block is bad and probably shorted out and probably trashed BCM. They said that they would get Chevy to cover the fuse block. How thoughtful. The truck was not drivable so I had to make due this weekend. The truck should be done today... unless they discover something else that is wrong with a 2 year old vehicle...
    Ok, got the vehicle back plus a $400 dollar repair bill. Everything was fine Monday until Sunday and the ####ing thing crapped out again, same problem. Ran fine, then out of the blue, wouldn't start, windows, door locks and fob inop. Jumped it again, got it home again, pulled the door module again, pulled the harness blocks again, sprayed them with contact cleaner again, reassembled the door again and guess what started working again. I wonder if the six or seven times I have done this to fix the problem might indicate that there is something wrong with the door module?
    I am so absolutely not a happy camper.
    Naturally it's the holiday weekend so I can't choke the dealer, who by the way is GUSTMAN CHEVY in Kaukauna Wisconsin.
    Ok, round two with the dealer... The truck is in right now.
    They assure me beyond a reasonable doubt that messing with the door module has nothing to do with the problem. That disconnecting the module only resets something in the BCM fixing the problem but not curing it. Ok, that is possible.
    So what about the $400 BCM they replaced? Oh it needed to be replaced they tell me. A code came back that said it was bad and had probably gotten trashed from a short in the fuse block they also replaced. Ummmm, ok. Well there was nothing that didn't work on the truck if the BCM was "bad" before. Oh, but it controls so many systems that there are ones I probably haven't used like the airbag. So in other words it would be the equivelent of taking the truck in for the window issue and having them determine that the fix would be to replace the worn tires. Then when the window still doesn't work having them say, "Yeah, but you needed the new tires anyway to be safe". Wrong. I would still 'take my chances' with the old BCM that worked rather than spending $400 bucks on a new one to 'be sure'. I authorized it to be replaced because they assured me it was the problem. It wasn't the problem. So we're going to have to 'talk' about that one.
    Now they are going to have somebody troubleshoot the relays and such in the truck. They're figuring that the BCM is not shutting off with the truck and running the battery down. That would mean that the BCM problem has to have the ability to drain the battery in a matter of an hour.
    My guess is they will replace some other part and want to charge me for it as the 'real solution' to the problem and still stick me with the bill for the BCM because it was 'bad anyway'. Again, that would be like putting on new tires, finding it doesn't solve the problem but saying, "You needed the tires anyway". I don't think so.
    I'll post what I find out.
    Oh yeah, one other thing. They scoff at internet, "You can read anything about any part on a car being bad and all of it is BS". Huh? Funny. According to them they have never encountered this door lock, fob, driver's window problem before. Their 'database' has no reference to it. So I guess all the other posts here about the problem "must not have happened". I guess all you other people are imagining the problem too.
    I did call the 800 Chevy number that somebody suggested earlier and opened a case. Those people are all trained very well. "We sympathize and understand" about 20 times in a 10 minute conversation. Then offer the, "And we'll give you something free" just to pacify you enough to not think the unthinkable of not buying another Chevy. Well??? All I want is my fricking truck fixed for a reasonable price or I'm going to trade it and never buy another Chevy product again.
    I won't guarantee anything, but about 2 years ago I had some electronic modules (AntiFreeze overfill & Airbag) on my wife's 2000 Buick go bad to the tune of $800. I contacted Buick via E-mail and asked if they had changed suppliers because my 1998 Oldsmobile had never had an elctronic module problem. By the time we were done the agreed to pay for the parts, so this avenue might be worth your trouble.
    Ok, back from the dealer. They have trailed it down to a weak battery... that after last week during the $400 dollar fiasco when I asked them to check the battery and it was fine. The battery was "only" $129 bucks (special battery, only available through the dealer of course).
    Ok, here's the deal (they say). The battery (only 2.5 years old) held a "good" surface charge but went flat quickly. If the battery went flat (possible short in the battery), when the voltage was low the door module would "lock up" and could only be cleared by disconnecting the door module, (except once if "fixed" itself without pulling the module).
    The last service trip they got a code back that said the BCM was dead and assumed this was causing the door problem. They did a search for that code and found a service bulletin saying the fuse block could be the cause. They checked the fuse block and found a burned spot. They were kind enough to replace the fuse block on the 2.5 year old truck but wouldn't cover the BCM it apparently took out. The theory is that it could have cashed in the battery as well. Or the battery could have cashed in the fuse block which took out the BCM. In any event, the theorpy now is that the weakened battery not holding a charge would die at random times and the low voltage would lock up the door module. Replacing the BCM and fuse block "fixed everything"... except for the problem.
    I'm wondering now if something is whacking the battery that they haven't found, that ruined the last battery and this new one, holding a charge longer will just cover up the problem until it is ruined. According to them, there is no draw on the battery anymore (something like .29 ma).
    Apparently the BCM has a sizable electrical draw and if it is not "shutting down" properly. According to them this only happens when the key is fully removed from the ignition.
    The bottom line is I have $500 in bills for stuff that shouldn't fail in 2.5 years. Life goes on... unless this fails again.
    The dust is starting to settle. Today I call the Chevy hotline to see what they can do.
    In short (literally) over the weekend (the day after the service) the blower fan started to act up, would only work on high and eventually started blowing smoke and burnt wiring smell. Back to the dealer on Monday. Turns out the blower motor resistor just happened to fail the day after they were charging and discharging the battery to trail down the window problem to the battery. So there's another $130 bucks. There is a harness between the resistor and the wiring that was burnt. The mechanic said it didn't look like a good connection. I wonder if they has to disconnect the harness when they replaced the blower motor that failed last March.
    Aside from wrapping the wire into the steering shaft I think the mechanics at the dealership are pretty competent.
    So the truck is 2.5 years old and has had 5 major electrical failures, the BCM, the fuse block, the blower motor, the battery and the resistor.
    I'll post what the Chevy rep has to say...
    Oh, yeah... I guess in the last post I forgot to mention that when changing the battery they managed to get a wire from the battery terminal to the bed cap light wound into the steering column. I picked the truck up, made a left turn out of the dealership, went to straighten out the wheel and it was like the power steering failed. I drifted into oncoming traffic but managed to yank the wheel back to the right with a loud thump, (wire broke). I get back into the dealer. The guy who changed the battery just left the cable hanging over the steering shaft and didn't bother to connect it back in a retaining clip. I'm not too shook up about that. It could happen to anyone. I've done stuff like that before. It makes me wonder though if this guy maybe used to work for ValueJet.
    Final post...
    I did the Chevy complaint line... they offered me a one year subscription to the "Jelly of the Month Club"...
    Seriously, they wouldn't do squat about the $800 dollars worth of electrical repairs this two year old truck has had. To dismiss the situation they offered me a 'maintenance package' (oil changes and tire rotations) "worth $390 dollars!!!"
    Tire rotations?
    Oil changes?
    In other words, a chance to find other stuff wrong with the truck to stick me with more bills.
    Yup, this is the last Chevy product I will ever own.
    I sure hope the company goes bankrupt soon. They are well on their way.
  • canyonblues1canyonblues1 Member Posts: 3
    I bought my 05 Canyon new in June of 05, and i think it has been at the dealer for repairs as much as it has been in my driveway. I have had tons of problems trying to get the blinkers, running lamps, cargo lamp to work simultaneously. So far, the only fix that seems to have been effective was a wire harness replacement underdash, and a computer replacement. I suspect the dealer mechanic is at fault for the "faulty" fusebox, and another "defective" harness. I am very dissapointed in this truck and GM service and will positively never buy GMC professional grade again. Also, when cold starting, the engine doesn't want to catch, then it does and after I release the key it keeps the starter engaged for a couple seconds more. If this truck was paid for I'd drive it off a cliff.
    Now my check engine light is on and the truck is 2000 miles out of warranty. I get a letter from GM telling me there is a rough idle issus thats causing an engine light problem. I plan to take it in and let them determine the error code. But its just one more frustration.
    One last chance here from the dealer, GUSTMAN CHEVY in Kaukauna... I got a "We value your business, when you get the Chevy form, please check 'completely satisfied' or give us a call..."
    After a week or so I finally got a hold of the dealer rep in person. He was pretty understanding and agreed, it sounded like the fuse box failed and took out the BCM and battery, and their screwing around 'testing' the battery (running it down and charging it) probably spiked the resistor in the blower that failed the next day. He said he would contact the Chevy rep and see if they could get the company to cover some of it. He said since the fuse box is a "nonserviceable item" and the truck is only 2.5 years old and I'm the first owner he may be able to do something about the BCM and resistor, but probably couldn't get them to cover the battery.
    Hey... this is the first "friendly" contact I've gotten from anybody associated with Chevy so far.
    The woman on the "help line" that offered me the "jelly of the month club" package was constantly "apologizing" and "understanding"... she sounded like she was reading off a Q card. I finally asked her to stop apologizing.
    The funny thing is, their $390 dollar "maintenance package" coveres an oil change every 6000 miles and tire rotations for 24,000. Give me a break. They recommend an oil change every 3500 miles when you have to pay for it, but 6000 when they have to pay for it. That's 4 oil changes "worth $390 dollars!!!" in the 2 years 24K miles. They must use Mobil 1 or something. What a joke.
    Oh, and the rep from the dealer checked into it, they even got the mileage wrong. The truck had 64K on it, the woman said she'd start it at 63.5K and then she actually entered 17K, expiring at 37K. How's that for service!
    Don't buy a Chevy.
    I think the dealer is ok, the service guys are just doing their job to make money, but Chevy is a true disappointment.
  • dmathews3dmathews3 Member Posts: 1,739
    Only dealers recomend oil changes every 3000 miles. GM quit this a number of years ago as better engines and better oil entered the market. Unless your severe service you can go a whole lot longer. I suggest you read your manual and pick how you drive. Most GM vehicles now come with a oil monitor that will tell you when you need an oil change. This is a commputer that keeps track of just how you drive and then when the time is almost up will nag you for that oil change. I believe the Colorado has this feature but since I don't have access to mine at this moment I could be wrong. I usually shoot for about 5K just to be on the safe side.
  • motorhead1motorhead1 Member Posts: 110
    I have a 2004 Colorado with 60k on it and the lights on the radio are burning out. Has anyone else had trouble with this?
    Does anyone out there know if you can buy a battery for a Colorado truck some place other than the chevrolet dealer?
  • poncho167poncho167 Member Posts: 1,178
    You should be able to get one most anywhere. If you have a PepBoys auto by you they also carry AC/Delco batteries.
  • canuck16canuck16 Member Posts: 2
    I'm a newbie with a 2004 Colo. and am having driver's window and power lock problems. I checked the fuses (OK) and took out the switch panel on driver's door and pulled plugs and re-inserted. Problem still there. Also, remote won't unlock doors. Where abouts is the control module located? I will check that out next. Also, my battery seems just fine and I have the extended cab model.
  • robstuffrobstuff Member Posts: 5
    My 2005 GMC Canyon 5 cylinder has been in the dealer shop so many times that I fought and won an extended warranty. My latest troubles are an engine silouette check light that won't go off. This occurred after I replaced my original spark plus with Bosch Platinums. The engine also whistles when I turn off the ignition. In am concerned the dealer will try to attach the engine troubles as my fault. I welcome all comments.
    Seems kind of strange that your problem started after replacing the spark plugs. Not likely that this is the case, but did you accidently drop one of those plugs and crack the plug insulation which can happen if dropped on the pavement. A cracked insulation would definately cause ignition issues.
    All the suggestions are great. I was very cautious with the plug replacement.
    After reading other posts on this door lock/ power driver's window, my take on this situation is to not panic and throw money to a garage or dealer. My theory is that this particular circuit in the Body Control Monitor (BCM) or in the main Computer is sensitive to high loads. This extra load could be when the driver is putting his window up or down and maybe also the passenger is doing the same while at the same time one of them hits the door lock button. This load is not high enough to blow this circuit's fuse, but is high enough to heat up that circuit in the BCM or in the main computer. This then takes awhile to cool down and resume it's function. This scenario has happened to me twice. Once a month ago and once a year ago. Both times I checked the fuse for this circuit and it was ok. I also took the switch panel out of the driver's door and removed and cleaned the wire connectors. This did not fix the problem. However, in both occurences I waited a week or so and then this circuit started working again on its own. The next time this happens I am going to try disconnecting the battery for a few hours and see if this lets the computer or module kick back in. I know not all Colorado/Canyon owners have this problem, but maybe some of us have modules or computers that are more sensitive to the electrical load in this circuit.
  • clydetheglideclydetheglide Member Posts: 1
    I have a driver's side rear blinker that does not work, bulb is fine, just no blinking in the left turn mode, nor the 4-way flasher mode. So, I bought a lighting control module, but I'll be darn if I can find out where it's located on the truck. I'm hoping someone out there can give me a clue as to its location. If not, it's off the the dealership I go. And, we all know how much fun that is
  • opssgmopssgm Member Posts: 1
    Same thing I am reading - at first it was an intermittant issue, then last week it seems to have become permanent. My drivers window will not go down, locks do not work with either the remote or the inside switch. In addition, my fan control will only operate on high. Lastly the left side of the radio/CD player lights are out. After rearing all these entries and researching the web, it appears that this is a far from isolated issue.
    I tried removing the switch panel, pulled all the connectors and reattached - nothing.
    Checked the wire bundle that goes from the door to the cab/frame - no signs of damage or pinching.
    This really has me torked as I do not want to get bent over at the dealer.
    The truck is a 2004 Colorado LS 4x4 Crew.
    I have not checked the fuses yet - but I suspect that will not be the problem.
    Open to suggestions or a number I can call to "have some meaningful dialogue" with a Chevy rep.
    Help
  • jaybird710jaybird710 Member Posts: 2
    does any one know of a adjustment or is it another electrical moduale proplem
  • iaff_blniaff_bln Member Posts: 1
    I have an 05 colly that developed this power lock and driver side window issue. I have checked all fuses, d/c'd battery and left it sit for four hours. I tried removing switches and opening them up, cleaning and re-attaching them. I even went as far as doing the same for other three doors. and still nothing. It has been two days since issue started and all I did was to remove driver side panel to fix my exterior lock. But here is the funny thing, I contacted two Chevy Dealers in my area today. Both dealerships say they have never heard of this issue before now. I have search several forums to find many people having the same issues. Kinda funny that alot of others are having this same issue and dealerships have nothing to say except to bring it in for a diagnostic costing $90.00 an hour. :mad:
    If its under warranty should be no charge. If out of warranty and it is broken then I would contact Chevy and plead your case. Be polite and shed big tears.
  • donboudreauxdonboudreaux Member Posts: 4
    I have 1 2008 GMC Canyon purchased September 28, 2007 and the battery went out at 350 miles, battery replaced, and went out 11 days later, would not jump start. Dealer kept it 5 days and was not able to duplicate problem. 3 days later battery dead again, dealer kept it 8 days and unable to duplicate problem. 5 days later battery dead again, 604 miles on it. Dealer still unable to duplicate problem. I have filed with GMC to have it declared a lemon. I have requested a new vehicle, or a full refund, waiting for GMC to review and offer a solution.
    As for the dealer not being able to locate the problem, I dont believe that. It's more likely they just don't want to take the time to find it. Next time tell them to check for an intermittent short to ground somewhere close to the firewall. I have had two defective under-dash wiring harness' replaced to repair faulty lites and blinkers. These shorts caused problems in one of the computers, so I made them replace it also. It took a ton of determination and close to two years to get these problems straightened out to this point, so stay with it. It is my opinion that the dealer will have to see that determination before they will take on the responsibility. Keep all dealer reciepts, and know your states' Lemon Law, these may come in handy. Anyway, hope this helps.
  • ejvodka78ejvodka78 Member Posts: 1
    i am having the same problem, have you tried the replacing the relay yet?
    Just a followup on the issues I had with the windows and door locks over the summer.
    In 20/20 hindsight it looks like the problem was the fuse box that the dealer replaced under a precautionary "service order". Since I had the fuse block replaced, and battery I haven't had any more problems. I think it's pretty evident that the fuse block must have some defect in it that caused the BCM and battery to die. Again, Chevy covered the fuse block but refused to cover the battery or BCM. I did the complaint line thing up the food chain and they offered me their "Smart Care" package, "a $390 dollar value!" that consists of 6 oil changes and a tire rotation or two. No, they are not using Mobil 1.
    The dealer, Gustman Chevy of Kaukauna went to bat to try and get the Chevy rep to cover some of the $800 in electrical problems I've had with the truck but the Chevy rep held firm, no dice. Ok, no problem. No further Chevy purchases. I'm sure by the time I'm ready for a new truck Chevy will be bankrupt.
    The dealer however did give me a check for about $250 from a 'good will' standpoint as they agreed that all these electrical problems happening so quickly made sense that the shorted fuse block caused the other stuff to fry. I'll give them good marks since they stood behind the sale even if the manufacturer won't stand behind their product. I hope to do business again with Gustmans; occasionally they get Fords and other products as trade-ins... I might buy one of those from them, but a Chevy? Never again.
    I am sure you are upset with this matter but seriously do you really think Chevy is going bankrupt? Not a chance in our life time, they are too successful of a company. If this would have happened with you buying a Toyota would you have felt the same way?
  • bjohns19bjohns19 Member Posts: 1
    I'm have the same problems too, except my truck will not start at all, the engine will turn, but it wont start up. the windows and locks will now work. did anyone ever get a fix on the problem?
  • cyrecyre Member Posts: 1
    Has anyone any idea what I need to replace to get the heater fan to work on 1,2, and 3?
  • tommctommc Member Posts: 66
    Bad thing about this is having a vehicle that is just not reliable, and you're doing without it on numerous occasions. Terrible situation. Any update on this? :confuse:
    Usually the blower resistor located in the hvac air box. Check in at AutoZone for the part and location. About $20 if I remember correctly.
    Hi:
    Yes, after all attempts by the dealer, and GMC, failed to reproduce the problem after
    about a month in the shop, GMC has agreed to buy the truck back and give me a
    full refund. It took a LOT of threats of a lemon lawyer to convince them this was
    the best option for them.
  • moe25moe25 Member Posts: 3
    I bought my 06 Colorado truck in Sept. 06. I am now on my third set of lights, a year and a half later! It sounds like a ground problem to me. Anybody have the same problems. My only other beef with the truck is paint chips. I have found chips out of the paint on the front bumper, hood, the front of the rear fenders, and on the rear bumper.
    On December 28 GMC agreed to give me a refund for the vehicle. I mailed in all paper
    work requested on January 2, 2008. On January 7, vehicle returned to me. On January
    10th the battery went dead for the fifth time. I called GMC support on January 11, and they now refuse to give me a refund or replace the vehicle. They offer to pay me for the 30 days the vehicle was in the shop. I will have to hire a Lemon Lawyer.
  • velcroidvelcroid Member Posts: 1
    There is a GM service bullitan out on this. They have to replace Both the blower motor resistor And the Blower Motor. Per PI# T3407. I know cause it happened to me.
  • puregreenpuregreen Member Posts: 24
    Whenever i shut the truck off the horn makes alittle chirp not a full honk, anybody know anything.
    Sounds like something related to your security system? Some people's cars security are automatically set once they remove the key and a few seconds after that.
    The key is still in the ignition but in the off position, it just started doing it any other ideas. Thanks
    So it sounds like you have a security system, right? If you do and this is the same chirp you had been getting when the alarm is set then I would say this is an ignition switch problem. Have you consulted your dealer?
