Visitor Agreement.
you can check a few things to see if this might be the problem..
you mentioned gasket burned, head gasket??
* did you notice exhaust bellowing white smoke before it stop running?
* check the radiator, to see if you have any oil in the coolant?
* any water or coolant in the exhaust system?
All indicates a blown head gasket, due to incompatible and chemical reaction of different metals of the gasket and engine.
and in fairly good condition, also the water pump will cause your van to over heat.But if the water pump was bad ,you would have noticed a antifreeze leak
even while it is setting still and engine not running ! If it is really hot where you live you might want to clean the radiator, dirt and grass will get caught in front of the radiator and you can clean it with a water hose , look in front of radiator and check for blockage !
What is this and just how do I fix this.
Cant seem to get a hold of my sons or they would be able to tell me they know this kind of stuff. Help for I don't have the cash to get it in the shop and I am looking at starting a job here soon as Friday!!
I am on a Why Me Syndrome Fast reply is needed! More information on this I think its some thing to do with the transfer case for it would kind jump when placed in drive. 3.8 engine no other problems that are not of normal wear and use.
I have had a Drive line drop in a Jeep Wagoner so I know the feeling of something like that going out.. as well I have had a Piston shoot and brake and Arm and this is not no engine trouble it runs the same and has power so not no cam trouble... it has to do with the braking and drive mechanical parts.
ie oil coolant and such. Nothing looks out of the norm under no cracks or dings on any of the cases no leaks out of the norm. Few months back it did over heat but its cause stupid has not changed the coolant in the last three years I was gone and its in break down so I was looking to get that flushed and freshened and the oil changed along with a new set of wires and plugs and maybe a new fuel filter as well here with first new job check.
Had a similar problem. Changing the air filter solved it a couple of times.
