Jaguar XJ Series Engine questions and issues
                    I purchased a 99 XJ8L with a remanufactured engine at 54k miles in 2003. My CHECK ENGINE LIGHT came on @72k in 2007 so I went to my mechanic who worked for Mercedes-Benz. He has a side business. He said I needed 4 sensors @1600 and an Air Flow Meter @ 260.00. The job was done but the C.E.L. stayed on. I took it to the dealership. The service man said that my air filter housing was cracked along with a hose and minor wirirng of 307 dollars. He called me and said everything is ok and to pick it up after he test drives it 5 or 10 miles. It was driven 18 miles. The service man called me and said I would need another engine. I still owe on vehicle. Is it worth the money to fix or should I suck it up and take lost? Is there reliable data on these engines?Are there legal avenues to pursue? The car was doing fine before I took it in.
Another possibility is the need to replace one or both of the main radiator hoses due to corruption over time.
There were quite a few Jags converted to the 350 Chevy engine in and around the Portland, OR area and the shop charged $1,000 for the conversion.
Repair the starter problem, fix the oil leak, and have it detailed before putting it up for sale. (you never get a 2nd chance at a 1st impression)
Does anyone have any idea what this might be? Oil looks clean, warms up to just slightly above the "N" on the temp gage.
Lost in Charlotte,NC
Also, you MUST use 20W50 oil. If you have lighter oil, you will lose oil pressure in this engine
As for hard starting, this may be a different problem, with the ignition sensors for the flywheel rpm and the crankshaft sensors. They fail with age, as they heat up.
there are also sensors for engine temperature that will shut the engine down if the sensor (right or wrong) "thinks" the engine is overheating.
These are all kind of typical Jaguar V-12 issues. You need to have these things diagnosed one by one.
Are you using an OEM filter and the proper weight oil?
My books don't go back that far to locate your oil sender but surely the person who works on your car would tell you?
OH WAIT! I see a diagram. It looks like it is between the V of the engine, up front, and there's a long hose arching over it. It's a small round cylinder with a wire attached to it that screw in.
The book says:
12 cylinder:
Open the bonnet.
Disconnect the battery earth lead.
Disconnect the rubber boot and the transmitter feed wire.
Unscrew and remove the transmitter
Fit and tighten the new transmitter.
Reconnectthe transmitter feed wire and the rubber boot.
Reconnect the battery earth lead.
Close the bonnet.
Have just completed 100k miles so not too many for this year.
I would caution you though that trim packages don't often translate into any extra value, since they don't represent any major mechanical or body changes of any kind, just cosmetics. Also, the reason they are rare is because not many people ordered them.
so you may indeed have one of 273 but it may not matter as far as value is concerned. Still it's nice to have something a little different and it might represent a small bump in value if you want to sell it--maybe 5% or so.
Good Luck
Craig
Thank You
someone posted on one of the forums that his connecting wires where loose on the throttle. I have cleaned all connectors with the connector cleaning spray - from pepboys and never had any problems again. the throttles cost me more han 2,000 and it was a simple connector issue to the sensors on the throttle.
I've recently encountered the same problem as described above in these last two posts after returning from a long mountain trip back home. I have a '99 XJ8 and the throttle stuck as I tried to break at the first traffic light. Didn't want to stop but after hitting the brakes hard and steady, it slowed, shuddered, stopped and stalled. If I hadn't reacted quickly enough, I would probably have plowed into a vehicle at the light. Ugh! My now disappeared mech told me last year the throttle body would probably need some work or costly repairs down the road, and he was right. It won't start at all now and is sitting in the drive till I sort all my options out, plus already bought a '97 XJR, heh heh! Double trouble eh? Stability Control Failure light is on the dash, already located the inertia fuel disconnect switch under the passenger floorboard, which wasn't triggered, and already disconnected the battery to see if it's an ECM issue as to why it won't start. Any ideas out here?
Zagzilla
Thanks for this info. I can't remember now if I had turned off the cruise switch on the gear console when this situation occurred now, but stopping the vehicle and trying to get it started again was a battery draining waste of time. It's been sitting in my driveway since the incident while I pondered the best possible solution to it's diagnosis and repair. My solution so far was last Monday,,bought a '97 XJR, LOL! Already had issues with it, being christened in with a new alternator after the old one fried to a crisp Saturday morning.
Cheers,
Jagzilla
I would only buy it on the presumption that the locked motor diagnosis is correct, and pay accordingly---in other words, pay the junk price for it. That's the only rational way to approach it.
A 2000 XJ8 is not a valuable car. If you really want one, just go buy a running one for not a lot of money.
Basically, this car, with a bad engine, is totalled. And even if the engine weren't bad, you still can't check out all the other functions (AC, trans, suspension, brakes, electronics), so it could end up running and *still* be a loss to you.
I'd say "pass" or buy it for what you can sell it to a wrecker for.
in going up a steep hill should the oil flow back in the oil pan and the crankshaft and piston rod ends hit the oil. This would build pressure in the oil pan and valve covers making for oil leakage and a engine mess.
Also if the valve cover gaskets were very bad or the covers loose this could have made you problem. Replace the valve covers is not a big deal, and maybe a good pressure wash and hot air dry will take care of you problem.
Let me know!
