Volkswagen Beetle Transmission Problems
18910111214»
  • leviatleviat Member Posts: 1
    :mad: Hi I recently bought a beetle (transmission 5-speed manual) and I saw that on the highway the car to 63mph in the 3,000 rpm this, a very high RPM, my question is, I can change the differential to decrease engine speed if I can help To fix this, Thanks!
  • bubbakatbubbakat Member Posts: 1
    My 2004 Turbo beetle needs new transmission at 66K. I want to keep the car as long as possible, but my mechanic warned that if I have the transmission replaced, I might have further problems considering the luck I have had with this car. I would consider going to AAMCO -- which AAMCO did you have your car repaired? Any recommendations?
  • jmargaretjmargaret Member Posts: 8
    I have a 2004 turbo covertible transmission that went out at 70,000 miles
    Paid a lot to get new one and still doesn't sound or feel the way it should.
    I had a headlite out that VW wanted 80.00 to fix. No one can get to it w/o
    Tearing off the bumper. Passenger door rattles. Water gets in when I go thru carwash. It goes on and on. Too bad cuz I like the look of it. And had a
    1973 bug for 10 yrs that never gave me a problem. Ugh!
  • beetleypbeetleyp Member Posts: 10
    Hi all,
    I purchased my 2005 VW Beetle Convertible used in 2010 when it was just over 80,000 - It was 5-years old, seemed like someone finished paying it off and traded it in for something new, and VW was phasing out the convertible at the time. I bought it because it seemed very stable, drove fine, and I'd had a 70 VW convertible before that I restored from bare metal back in 1988-1990. About a week after purchase, the check engine light came on. I took it into my local dealer/repair and it was the fan system for the coolant. $1,000 +/- later - I had new fans and no light. Yeah! I hadn't driven a new beetle before, so I didn't know that it wasn't supposed to shift down hard from 3rd to 2nd or 4th to 3rd. Occasionally, during the next 6 months, it would take a moment to kick into reverse - it'd rev and then jerk back once it kicked in.
    I stopped by my local dealer/repair for something else and asked if the hard shifting was normal - they did a peak on the computer system and there had been an alert by VW about it and an extended warranty for 6-years or 100,000 miles covering the Transmission Valve Body repair. So, they pulled it in and I was good as new a few days later. I thought that a letter was sent to all current owners, but figured that it went to the previous owner and they had no idea who I was.
    I then started to do more research. I haven't experienced the window motor issues, but that seemed to have happened earlier for most folks, so I'm assuming the previous owner had to deal with it. I did, however notice that whenever my tank is about 1/4 full, and I'm going up or down hill, it will suddenly gasp for air and cut out. When it happens, I just lift my foot off the gas for a moment and it goes back to normal and I'm off and going again after a brief coast. I thought that maybe I had gunk in the gas tank from previous owner and later had the fuel pump go out. When VW was replacing that, they sucked everything out of the tank and it was clean. I thought it was maybe the fuel pump starting to go out, but it's still doing it and I've heard from others that theirs do it too right about 1/4-tank.
    There are lots of issues with this batch of New Beetles. If you're looking to buy one, I can't recommend more highly that you purchase one of those after-market car warranty plans that they sell online.
    If your car hasn't hit 100,000 or 6-years, go to your dealer now and tell them that your transmission seems to be shifting hard. Ask them to look up the service bulletins from VW and any recalls. It can save you a world of hurt later on.
  • maxpricemaxprice Member Posts: 2
    Purchased this car new with the Tiptronic 6 speed transmission. The car now has 136,XXX miles. Highly maintained. The car would slip out of gear when driving or would not go into gear when shifting at an idle position. Towed to VW dealership - $4800 for new tranny. Towed it to AAMCO - rebuilt transmission for $4500. Going to try one more place tomorrow. This is frustrating. Should be put the money into the car or put it into a new car and sell the 2004 for parts and then scrap it? So sad to do that to a 10 year old car. It is a diesal and should have lasted longer than this. Suggestions anyone? :confuse:
  • geogaldo1geogaldo1 Member Posts: 1
    edited April 2013
    had the same problem with trans, took dealer to small claims. was told i should have taken vw corp to court instead. lost lawsuit. do yourself a favor and file small claims and take vw corp to court. my car only had 45k miles when it started shifiting funny. franchise only covered half the cost $2500. ontario vw. never by another vw. reported to bbb with their complaint. judge felt franchise was not responsible. elected to settle and not spend my time with another trial.
  • rbean1rbean1 Member Posts: 1
    2002 beetle was misfiring in the rain. Mechanic said to replace spark plugs. Next rain, problem returned along with two transmission codes. Then car started having trouble getting out of 2nd gear. Mechanic referred me to transmission shop who said transmission needed to be rebuilt to the tune of $1600-$3000! And this still would not address rain misfire issue. I never use dealer because of high repair costs but broke down and decided to take it to dealer for 2nd opinion. Dealer says transmission is fine! Water test showed Crack in ignition coil caused misfires when it got wet in rain. Misfires caused transmission codes which cause transmission to go into "fail safe mode" causing wierd shifting issues. Coil replaced, transmission codes cleared and shifting fine. Glad I took it to dealer to learn my transmission did not need a 3k repair. I have not driven in rain yet so jury is still out on misfire fix but optimistic At the very least it is worth paying diagnostic fee (110) at dealer to diagnose problems before expensive repair. Dealer will credit back fee if you have them complete the repair. Wish i had gone there first before spark plug diagnosis!
  • neisalneisal Member Posts: 1
    My husband and I purchased our 16 year old daughter a 2008 Beetle. We thought it would be a good starter car for her. Two weeks ago, she was driving down the road, and she says that all of a sudden after she turned, the car slowed down and she though maybe she ran out of gas. She says that she was trying to press on the gas and nothing happened. People were driving around her, and so she turned the car off, and then turned it back on. She said it felt that it kicked into gear and then she was able to drive off.
    Yesterday, she made a left turn and the same thing happened again. She said the car slowed down again, and she pressed on the gas and nothing happened. She said she pressed on the gas real hard, and the car took off on her. She lost control of the car, and went up the curve, hit a construction sign that broke her windshield and then she was stopped by hitting a light post. She said she was braking the whole time.
    Of course my husband and I did not believe her, and we were very upset with her. We felt that maybe she had taken the turn too fast. When the police came to investigate, they said that the tire marks were way past the point of her losing control after a turn. As I read on this forum, it what people are describing, is what she described happened. The damage to the car is extensive, and I can not believe that she walked away from the accident. Another thing the cop found interesting, is that the airbags did not go off. He says with the impact of the sign, and then the light post, that her airbags should have gone off. I am so scared for her to drive this car again. Any information would be helpful so that I can get rid of this car.
    We had a 2004 that did the same thing. Left us stranded on the interstate and in town several times over a week long period. Had 3 different transmission specialists plus the dealership and they all said the same thing...needs a new tranny ($3800-4000). We sold it off for pennies on what we paid for it and got rid of the headache. We bought a good old 2002 Jeep Grand Cherokee....American made. No more imports for us.
    Your daughter is probably telling the truth on this one. :lemon:
  • bad04beetlebad04beetle Member Posts: 3
    Wow! so glad your daughter is ok! We got rid of our 2004 ...just could not risk something bad happening and refused to put anymore money into the car!! I myself have been a long time Honda owner, my daughter now has a Civic. Lost money...but her safety was far more important!!
  • calitricalitri Member Posts: 1
    To Perotma: My wife has a 2006 VW Beetle with only 34,000 miles. The car is at the dealer as I'm writing this and they inform us that she needs a new transmission; the cost $6,000.
    We never received any information concerning an extended warranty for a transmission valve body. regardless I can't imagine an automobile with only 34,000 miles needing a new transmission.
    I would appreciate any information that you might have that would help our dilemma.
    I have a 2004 beetle. Covertile that had to have new transmissio at 70,000 miles. Took out a loan an paid for it( missed warranty also-something I knew nothing about). Now- 3 months later it needs new motor! Can't pay this time. Its just sitting in driveway. Please please let me know of any recalls. I have all paperwork. Have all paperwork. Just waiting!!!
  • ericm1461ericm1461 Member Posts: 3
    Now my wife's Bug has joined the many here with transmission issues. It started at about 44,000 miles. Same thing of inttermittantly lurching and not shifting. Took it to a Big specialist and he was reluctant to work on it, but did do a service of the oil and filter. He said the 6-speed autos are terrible and advised us not to buy another VW! This from a VW specialist.
    So we made it a couple more months and finally took it in to another reputable transmission shop that my auto buddy recommended (forget the shifty VW dealer in Dublin). They gave us a best price of $5000 for a rebuilt transmission. i am not sure that even addreses the possibility of the tcm being bad, which from what I have read here could cause the problem in the first place.
    I am pissed. My wife drives very conservatively and bought the car new. This is absurd. The car shows on KBB as having a fair value of $6000. We are honest folks and could not sell it without telling about the transmission problem. I found the class action attorney listed before and emailed her to see if the case is still viable.
  • dee119dee119 Member Posts: 2
    I Just bought a used 2005 turbo convertible and I'm having the same probs. I took it to the dealer after reading all the blogs on the possible problems and at first the mechanic tells me there is no fix. Then I mention the recall, which expired in 2011. And suddenly he knows what I'm taking about. My car stalls and recovers even on the freeway at 80mph. He wanted to replace the fuel pump at first, his diagnosis, but I told him that from what I've read, others have replaced the MAF, fuel filter and fuel pump but and the problem still exist. I wasn't comfortable guessing at what the prob could be. Of course, there are no error codes which I already knew that because I had taken it to my own mechanic. The dealer tells me to try to call customer service and maybe they will help me. I do call the and get a rehearsed answer from the rep so I call corporate and get a very nice lady, Emily Goga but when she calls the dealer they tell her they suspect a different transmission problem other than the valve recalled part! And I have to pay $120 for the dealer to diagnose the problem, she won't take my mechanics word. But that VW in no way could help with the cost because the extended warranty has expired. On top of that my airbag light has come on and they want $600 for a module that has gone bad. In my opinion, VW is ok with having unsafe vehicles on the road. :lemon:
  • classyirishclassyirish Member Posts: 4
    What is the TCM? I replaced a 600 dollar part that has resolved the dying issue when you slow down and the really hard JERK after a 15 minute warm up. It still does jerk from 2nd to 3rd, but not as hard. VW dealership gave a 1400 price tag to replace valve body and AAMCO gave a price of 1600.
    Mine is a 2004 vert turbo with tiptronic. 124,000. I bought it used, title was LEMON, but hey, most of the lemons are finally fixed, right? well, things have gotten better with it. I love the smooth ride, the gas mileage, but in town always has me nervous because of the herky jerky stuff.
    I also emailed the attorney that has the class action, I have NEVER heard back from him/them so I don't even know what is going on with that.
    I am 500 shy from the 1400 to replace the valvebody. Thinking by the end of the year should have enough.
  • vw_johnnyvw_johnny Member Posts: 6
    edited July 2013
    Well, it has been 25,000 miles and 2 and half years later and the transmission is still working great - so far :shades: . The rebuilt valve body from The Transmission House in Covina doing good.
  • 1kylerichards1kylerichards Member Posts: 1
    I got the same song and dance from Volkswagen. 62k miles car shifted fine when cold would not shift reliably when warm. Checked and had extended warranty on car for valve body. VW refused to change. Checked on line for valve body rebuilds, removed the valve body, had it rebuilt and replaced myself, car runs like it was new. Very simple fix. Remove pan from trans,remove valve body, send out for repair, reinstall. Fill with expensive fluid from VW and drive. VW has been ZERO help with the issue.
    edited July 2013
    We heard the same thing. Our VW specialist said it worked for one person he knew. He recommended never to buy a new VW.
    Went to GMC. Leased a Buick Verona for $217 a month (24 months) for what it would have cost to replace the tranny. Apparently, if the Valve Body has gone bad for too long it damages the rest of the tranny. Talked to quite a few folks on this.
    Funny part? We went the VW dealer to try and get the recall honored. They said no. Told them we would never buy another ever. Walked out the door. One guy followed us... Said "I drive a Toyota".
    Enough said...
  • maw322maw322 Member Posts: 1
    2006 with the same problem as all the rest, tranny fine when running cold... but once the car is warmed up, it lurches between 2nd & 3rd gears and the car throws forward when down shifting to a stop. VW dealer says I nned a new trNsmission, but it's more than the car is worth-what a waste :(
    I've posted before about my beetle and paying for new transmission. Mechanic told me he would never take on a beetle again. Then I started having various engine problems totaling $5,000. New mechanic told me not to waste any more money on it. Prob have another problem later. How long does ANY body think it will be b4 a recall on this nightmare?
    It only had $70,000 miles on it when it started! I got the warrany letter AFTER it expired. Had prior owner.
  • thinman63thinman63 Member Posts: 1
    My wife has an "04 Beetle convertible turbo. Transmission skips gears, gets stuck in gears etc. Same story I have read over and over. VW sent a notice about the valve body replacement but I arrived in the mail after it had expired. We paid to have it replaced...$1000. No real change in the problem. Car has 82,000 miles on it. I would like to have it work right for her. Where do I go from here?
    So disappointed....
    That's what we did. My wife's 05 Bug was in pristine condition, 48k miles. We got $4500 trade in for a Buick Verona, which we love.
  • brokebeetle06brokebeetle06 Member Posts: 1
    Hi, I saw your post #787 and am very interested in learning more about who you used to rebuild your valve body. My story is very similar to yours. Just had my transmission control unit replaced which seemed to fix the shifting issues for about 10 minutes until the car warms up. My mechanic said he thinks It is the valve body but wouldn't know until he gets into it. He recommended replacing the transmission all together, but I'm concerned about ending up in the same place if I buy a used transmission. I Will not buy a new tranny, just don't see the point if in 60-80k it's going to do the same thing. I just want to get this car running and out of my life. What a nightmare! I'll spare the details as so many have experienced the problem already. Can you tell me how difficult it is to do this on my own. Are you a mechanic or a very talented DIYer? I have a friend who is a commercial mechanic and I can use his shop and tools. I am very handy myself, and would like to know if I could pick your brain a little since replacing the valve body seemed easy for you. Like you, VW is no help. They told me the warranty extension for the valve body expired in May of 2013. I knew nothing about the extension. My car has 89k now.
  • vwbugssuckvwbugssuck Member Posts: 15
    Take it back to volkswagen; the valve body is/was under warranty to 100,000; I did it a few years back and so far so good. I don't know about any warranty expiration; I can't believe they can do that. Go to Volkswagen and make a HUGE stink!!!
  • clarissawzclarissawz Member Posts: 1
    Having the same problem as everyone else-- hard shifting from 2-3rd and 3rd-4th. Took it into the dealership and was told it was a faulty valve body and would cost $1800 to fix. Called VWA an they said the warranty on my car expired in 2012. Basically, it was a waste of time to even call them, they were of no assistance. I blatantly asked them what all of the new owners of these cars should do, sell it and pawn off the problem onto another person or just drive it until it breaks down? She said "that is up to you." Ridiculous. I wouldn't even know where to begin on filing a class action lawsuit but, if anyone has any information, please contact me.
  • exit152exit152 Member Posts: 1
    edited January 2014
    I have a 2005 New Beetle. I am the second owner and I was never even aware of the valve body having any issues. I got the vehicle in 2010 with 31,290 miles on it as a high school graduation present and now fast forward to 2014 with 86k miles and the bug started having all the same issues as everyone describes. My parents paid for the diagnoses once for other reasons that were supposedly causing the hard shift etc... and the second time to see if VW would be of any help and come to find out they were not. The valve body warranty ended on 9-27-2011 and I got the car on 7-29-2010 and was never aware of the warranty until I started having issues with the vehicle. I spoke to the Assistant Manager at my local VW and they processed a case, but VW did not want to help at all. My car has been sitting in the garage and it has not even been completely paid off yet and I start school back up in a few days without a car for transportation since I commute to school. I just wanted to say THANK YOU VOLKSWAGEN for making my first car and my favorite model a nightmare!! I'm never purchasing a VW ever again.
  • 2006btl2006btl Member Posts: 1
    i have a 2006 VW Beetle. My transmission is having problems. i'm worried that it's going to leave me stuck on the freeway. I called a friend of mine who works at a repair shop and he said, oh yeah, the transmissions on those fail prematurely. It's typically the Valve Housing. i'm going to have it checked for sure. I see from reading this forum that this is a known problem and it appears the VW is not assuming much accountability for their product. I sincerely hope that VW is manufacturing their newer transmissions with better reliability. If Not,....then BUYER BE WARE!!!! Thanks for this forum.
    Welcome to the forums. Be sure to let us know how things play out. Hopefully yours turns out to be something minor, but sharing the info benefits us all
  • debbie157debbie157 Member Posts: 1
    edited August 2014
    I feel somewhat bad reading about your problems with fairly new/low mileage bugs. I have gotten a lot of life out of mine bought it new in 2001 and it has 251,000km (150,000 miles) on it, is an automatic, diesel engine but now I think the transmission is going ... a least three times, I after I have left a stop, all of a sudden, bang, just like I have hit a big unexpected pothole - very jarring and then it just carries on - I have had a number of other instances but not as hard ... a bit disconcerting, discussed the problem with my mechanic ... transmission .. he said it would need to be rebuilt at a cost of $4,000 and my car isn't worth that ... I fully expected to get another 100,000 km out of it .. engine is great after some initial issues with the diesel and it still looks pretty good other then the grid which gets hung up on everything ... would appreciate comments from anyone else who has experienced this/solutions .. am not keen to give up the car although have to admit have bought a new Mini (delivery not until November) Thanks
  • sadbeetlesadbeetle Member Posts: 1
    Having the same issues as a lot of people here. I wrote a letter to VW, and just thought I would share it here...
    Dear Volkswagen Customer CARE,
    I know you are aware of the problem that many people are having with New Beetles Transmissions, but I want to write to you about my problems, mostly because I think it will make me feel better.
    When I was a kid, I have great memories of riding around in the very back of my parent’s orangey red VW Bug. We didn’t even have to wear seat belts. I can even remember what the seat tasted like. Yeah, I also have memories of being stuck on the side of the freeway, but my dad knew how to fix it and it was never very expensive.
    When I was a teenager and it was time to get my first car, my dad took me to the used car lot. They had my DREAM CAR. It was a yellow convertible bug for $1200.00. I begged him to get that one. No, he said, VWs break down too much and I want you to have a reliable car. We got a 1984 maroon Chevy Citation 2 for $1050.00 and I paid him back over time for it. I named it Ruby.
    I went to college, graduated, got a job, and thought it was time to get a “new” car, so I got a 1994 Ford Escort Wagon that worked well for a few years, especially since I had a dog, until it didn’t and I needed to get a new car.
    Then one day, I was driving down the freeway, and in front of me I saw an aquarious blue new beetle convertible, with a black and white dog looking out at me from the back seat. This was a revelation! I could have a dog, AND I could have a convertible beetle! This car became my new dream car. I was not sure if I should get a convertible, because that seemed rather impractical. My boyfriend said, go ahead, this is probably the best time to get a car like this, if you wait till we have kids, then you would probably get something more practical.
    So I got my 2004 Aquarious blue new beetle convertible on my dog’s first birthday, May Day 2004. This is also how I remembered how old she was. I took my dog everywhere in her little harness strapped into the back seat. We had fun with that car. We went to the Ocean. The wind flew through my hair. I figured out that I better keep baseball caps in the car. I was a convertible driver.
    Then we got married and had kids. The top stayed up. I became a stay at home mom. Which meant that I got to stay home, but we had less money. The good thing was, we weren’t putting miles on the bug by commuting every day. The bad thing is, I can’t afford to fix the multitude of problems that start popping up on my car. I have to close and lock the door using a complicated OCD routine so that the window doesn’t ruin the top, which had already started fraying and growing green plant matter no matter how much I treat it. The trunk leaks water so there is a smell of mold coming out of the trunk. The material is coming away from the back window. The top won’t go down all the way and there is mysterious paraphernalia hanging down from the sides. The top leaks water down the inside of the front windshield. The check engine light is continually on. Oh, it costs $100 every time I want to find out why the check engine light is on. It is very inconvenient and costly to go to the dealership when you have 2 kids and 2 carseats, so when I do go to the dealership, I expect them to fix the problem. My window had problems since the day I got my car, when there were 13 miles on it. For some mysterious reason, the fine mechanics that work for VW can never seem to figure out the problem! I bet they could now, since it is affecting the top and is really seriously messed up, now that the warranty is expired.
    Now the kids are 5 and 8, and finally, I could put the top down again! Except, I couldn’t, because there is something wrong with it and won’t click into place. So, it stays up.
    I have been trying to save money to fix all these problems because I planned on keeping this car forever. I want my kids to remember mommy’s cool car. I want them to beg me to drive it when they turn 16.
    Now, at 75,000 miles, it starts shifting hard and I find out that the transmission needs to be replaced. The VW dealership quoted me $7000 for a new transmission. They casually mention that these cars have a known problem with their transmissions and they are not surprised. What?! This car is worth $3000 on Kelly Blue Book. But without the transmission working, it is worth $0. I start reading VW forums and find out that there are many livid and heartbroken people on there that have similar stories to mine. I find out that VW had admitted that there is a problem with the valve body and they will replace it as long as the car is under warranty. What good does that do, when your car is past warranty (I had the 7 yr extended warranty) and by the time the valve body is replaced, it has usually ruined the transmission?
    I am so sad and frustrated by this. My dream car had turned into a lemon. I am disappointed in you, VW. From what I read from other VW owners, I don’t expect you to do anything about this or even read this far, but this is my therapy, because I still love my car and am heartbroken about this. What do I do? Spend a ton of money on my car which could fail again unreasonably soon, and still have all those other problems that I still need to fix, not to mention the inevitable MORE problems that are to come? Give up on this car, and have to make car payments on another car, when we are still making car payments on our 2nd car? We can’t afford to do that.
    I ask you VW, PLEASE stop making your cars so cute! You are luring people into buying them because they LOVE you! Make the insides work just as good as they look on the outside! Please stand behind your product and help people who have been lured into buying a lemon disguised as the cutest car they have ever seen! You are breaking our hearts here.
    If you have actually read this far, then thank you for listening. See you on the road, probably in a Ford.
    Sarah Armstrong
    It is tough when something you really want to love disappoints :'(
  • sunknotssunknots Member Posts: 1
    I bought my 2005 Volkswagen Beetle and July 2014 and 8 months later I'm having a problem. My problem seems to be in the braking when I brake my car lurches or jerks. I've taken it to the shop several times and they tell me my axles are broke.The next thing I know I'm paying for a broken spring and my car is still jerking when I brake. It seems I'm having the same problems everyone else on this website. My car is automatic. I'm doing a lot of googling I don't have thousands of dollars to put into this car. If only I had Google before I bought this car I wish I had done my research fortunately it seems that we are going to carry the weight and spend all the money to repair these cars and Volkswagen seems to be getting away with murdering our wallets. Well I'm not going down without a fight. I will be contacting VW corporate office & I suggests everyone else do the same. They're the ones who created these LEMONS. GOOD LUCK EVERYONE.
  • itsnotherbieitsnotherbie Member Posts: 1
    edited May 2015
    Hello everyone! I am not sure yet, but i found out after having the same problems as everyone else has. I Also do not having the money to sink into my money pit.. I have been slowly trying to find the real problem myself..I keep smelling radiator fluid. after i have driven it. for about fifteen min. or so. its not the car over heating. Its the transmission.. like everybody, mine runs great when its cold but as soon as it gets hot! (as Betty Davis would say) get ready for a bumpy ride. I have put in a new water pump. all new temp. sensors from top to bottom. fan relay. and just now pulled apart my dash to find were the fan modular is. And to my surprise is they forgot to put the thing in the car, in mexico! So i don't now if this is going to fix the problem. but i am sure its a good leg to stand on when i sue them for a bad love bug. it feels like VD LOL good luck everyone. i hope this helps us all?????????????? please check to see if they forgot yours to
    i am the owner of a 2003 silver convertible with 48,000 mils also bad windows bad top bad everything.
  • VWhaterVWhater Member Posts: 1
    Regarding the multitude of horror stories about VW Beetle (and other models) transmission problems, I would like to share my experience with my 2001 Beetle.
    Last year, I began having problems with transmission slippage upon take-off. I’d step on the gas, but the car wouldn’t go right away; then, it would suddenly grab with a jolt that threw me back in my seat. Years ago, I had a similar problem with a Ford Taurus, which I resolved simply by adding transmission fluid. I’m not a transmission mechanic, but I know that the function of the transmission is accomplished by the flow of fluid under pressure that actuates valves. So when the fluid level is low, it takes longer for the pressure to build, and when it suddenly reaches the right pressure, it causes a violent reaction inside the torque convertor, rather than a smooth transition into drive mode.
    I inquired with a lube shop as to whether they could add fluid to my VW transmission, and they declined for two reasons: 1. The transmission is a sealed unit, and 2. Because there is no transmission dipstick, there is no way to determine the fluid level, and thus no way to know how much fluid to add. They suggested that I take the car to the VW dealer to have them do the service. So I went to the dealer.
    The service manager said that they would have to do a complete transmission service, which included a transmission pan seal and a filter, which cost about $135, and it would require five quarts of special VW transmission fluid, at about $50 per quart. Do the math, and we’re close to $400 for “parts”, and the labor – which would include re-programming the transmission to the computer for a total cost of $840 for the complete job. I don’t know if that service came with any guarantee to fix the problem. I declined their offer.
    Turning to YouTube, I learned that there is a fairly easy way to add fluid to this transmission. There is a vent hole in the side of the transmission which you can access by removing the battery and the tray it sits on. There is a plastic plug that covers the hole. This faces toward the front of the car, so it’s not too difficult to access. You may need a light to find it. (Check on YouTube if you can’t locate it) I had to pry off the plastic cap, and in the process, a piece broke off and fell down inside the transmission. I was not happy because I knew I’d have to remove the transmission pan to get it out. This was a bit intimidating.
    I ordered a new transmission pan kit with a new filter and soft-rubber pan seal from Napa Auto Parts for about $35, and I bought four quarts of fluid, which they recommended. The total cost was under $70, with salestax. I was still nervous as to what I was getting myself into.
    I jacked up the car, secured it with jackstands, and poked my head down there to take a look. It turned out to be a very easy job: just four bolts (10mm, I think), one at each corner. I placed a pan below to catch the old fluid and easily popped the transmission pan off and let it drain for a few minutes. (The old fluid was more black than red) The filter inside the transmission is not bolted in; you just pull it off, and push the new one on in its place. I cleaned off the pan, removing 126,000 miles of metal particles from around the magnet, replaced the seal, and tightened the four bolts that hold the pan in place. The piece of plastic that had fallen into the transmission was lying on the pan, by the way, and was discarded.
    To refill the tranny, I had to use a plastic tube and funnel – about ½ inch in diameter, if I remember correctly. The book shows the transmission capacity to be 5.6 quarts. When you drain the fluid, it doesn’t drain completely, so 4 quarts of new fluid should be about right. One source suggested Valvoline Max-life Transmission fluid for VW. The manufacturer lists VW on the bottle as one of cars that can use this fluid. Most parts stores can advise you on how much to add for your car. Replace the vent cap, and reinstall the battery tray and battery, and it’s time for a test drive.
    In my case, the hard- shifting problems went away completely. It’s been about 6 months now, and about 6,000 miles, and that problem has not returned. I believe that my home-transmission-service turned out to be successful. If you decide to do this service yourself, you may wish to purchase VW trans fluid from a VW specialist supplier, which will cost more, but may give you more peace of mind.
    My car is still a VW, and I now have a new transmission problem: The car recently stopped shifting altogether. I believe that this is a failure of the transmission speed-sensor, which controls the shifts. I can shift manually from 1st, 2nd, and 3rd, but I can’t get into 4th gear. ). I think this is a ‘limp-home’ mode. My VW, for now, is the stick-shift model I always wanted!
    I have to wonder here about the VW organization. If you take most any other car into, say, Jiffy-Lube, and ask for a transmission service, the cost will probably run well under $200, so why does the VW dealer want $840 to do this service? I could do this job in about an hour, with a 10mm socket, a ratchet, and an ordinary VW jack. If they wanted to, they could make a transmission fill-tube which would go into the trans vent-hole so that anyone could add fluid, and maybe even have a dip-stick. Instead, they tell people that the transmission is a sealed unit that only they can service. Why? It’s all about big profits!
  • orion311976orion311976 Member Posts: 1
    Has anyone checked this out?        https://en.m.wikipedia.org/wiki/Volkswagen_01M_transmission    read the weak points section...sounds alot like ya'lls problems..
  • xwill1993xxwill1993x Member Posts: 1
    I have a 08 VW beetle 2.5l it will go in reverse but not drive what can be the problem with my car
    Assuming it's an automatic. Could be low transmission fluid or the transmission control solenoid. The Beetle doesn't have a transmission dipstick, so you'll need to get it to a repair shop have someone get it up on a lift. Hopefully it's not anything worse than that.
  • HeyMzParkerHeyMzParker Member Posts: 1
    VWhater said:
    "Regarding the multitude of horror stories about VW Beetle (and other models) transmission problems, I would like to share my experience with my 2001 Beetle...."
    I'm extremely new to this and I wish I had known about this years ago back when they first came out and that way I wouldn't be so gung-ho about keeping on this car but this is my baby and even though you have VW hater I feel like you gave me a little bit of Hope. it's really sad that VW company would give products that enticed a multitude of people only to be completely let down and show how ephemeral that product is I've been having the same similar issues and my car was parked for a year until two three weeks ago we decided to send it to a mechanic it wouldn't start after a while it just stopped turning over so they replace the timing belt and since it came with a water pump I'm praying that he replaced the water pump because as I used to drive it back in 2018 2017 which my Volkswagen is a 2004 and it had less than 126000 Miles it would not go into 4th gear it decelerated after a while if I would try to press the gas and it scared me thinking that it was a transmission issue and some the guy who sold me the car said that it may be a transmission issue but I feel like if you replace the transmission it's still would give you that problem.
     now from the get-go I felt like it was some fluid issue, and I was like okay maybe it needs to get more fluid then I found out that you couldn't just get into the fluid easily the car would have to be lifted and all kinds of fun stuff okay now I'm here I've come to this form after leaving a YouTube video that said it may be some module that holds all the wires and circuitry getting wet and causing the computer to not function properly to the transmission and they said that that issue may be the reason why the car doesn't want to shift then I see you after reading so many horror stories and almost about to cry I just went to does anybody within 2019 or 2018 have a story because all those people were from 10 years ago and I was like is this like the people who said they euthanize their Volkswagen Beetles so you showed me there is a glimpse of hope maybe if I do this and replace all the wiring properly to that module that those two things in conjunction will give this car a little bit more life until I just give up all hope I'm driving that car around because I dreamt of this car I saved hard-earned workable 70-hour weeks saving up to buy this car cash so the title can be handed to me. I PRAY YOU ARE THE ANSWER TO MY PRAYERS.
  • mechatony11mechatony11 Member Posts: 3
    I apologize for bringing up this old thread. I had a similar issue with my car, and it turned out that I had a faulty torque converter, it causes transmission to slip in all gears, shudder and overheat. I did a lot of searches on this issue and came on in depth article which may be worth reading, search for "Troubleshooting Volkswagen Transmission Problems on YOUCANIC" and you will see an article that goes over common causes and possible fixes, you can read about it yourself. I hope this information can assist someone else with a similar issue.
