OLD CARS -The truth .Owners tales.How they really were.
Anyone interested in telling how it really was 30
+ years ago.Young readers staring starry eyed at a
Jag E TYPE may be keen to know what they were
really like when in easy supply and less than 2000
dollars for a good one.Ex jag engineer has stories
to tell! Other makes available.
All of this is a thing of the past, with the advent of fuel injection.
Still, I remember that cars were a whole lot less complicated, and they could be fixed easily. I have personally rebuilt carbs for around $10.00 in parts and a few hours time.The front engine/rear drive layout left lots of room in the engine compartment-I had an AMC Concord where I did'nt even have to get under the car to change the oil-everything was accessable from the top! (drain plug and filter)-all you had to do was slide the pan under (try that with a modern car).
Biggest disappointment was the big block Chevys -- all that hype and such a legacy in thier small blocks.
Cast iron wonders -- 352 and 390 Fords -- intake manifold weighed almost as much as a bare 283 block!
Loved that '56 -- put a Corvette 2 - 4 setup on it, switched out the Powergroan for a three speed, and commenced to clean house on everything on the road at that time.
Early 60's you could get engines from Chevy dealers -- warranty replacements -- for $25.00! Then they put a stop to it.
Remember the T-10 4 - speed? Blow third gear and cluster all the time! Then out came the Muncie -- we called it a rock crusher -- almost bullet proof, but slower to shift.
Automatics wren't getting it -- except for the Torqueflites. We used Hydromatics with Cadillac plates. Still remember that hard 2 -3 upshift -- the whole thing had to change -- and it was never smooth!
Leaking Holly carbs; pot metal Rochesters; Qudrajets (utterly outstanding carb once it was set up right), Carter AFBs (Pontiac loved 'em).
Remember using the flowmeter to set up your 3 deuces? Old Strombergs? Rebabbetting rods?
So much for nostalgia -- want to talk about reliability and maintenance?
Interestingly, the carburator is still king on the dragstrip, isn't it?
I'll always fondly emember my beautiful 1962 Impala Super Sport. It was a great car, however, the Powerglide had to be overhauled at around 60,000 miles. Coming up with 200.00 wasn't easy for an 18 year old at that time! Shortly thereafter, a valve job was required. The front end needed ball joints and control arm bushings.
This was normal stuff back then. If a car managed to make it to 100,000 miles it was pretty tired. Today, 100K is a walk in the park.
I had an Accord traded in last summer with 288K on it. Compression was still perfect, everything checked out fine. Outside of scheduled maintance, nothing had been done to the car!
Later on, I had a 64 Impala SS with the mighty 409, 4 speed. At 80,000 miles it burned oil and needed an overhaul. Pretty common back then.
That 409 couldn't handle, couldn't stop, and got 7 miles per gallon.
But...oh, could it blast off the line, and what a sweet sound.
Not as sweet as my first car, a 1952 Chevy. NOTHING sounds like an old six cyl Chevy with a split manifold and a pair of short glasspacks!
Wish I had those old Chevys back....
This time I wouldn't lower it. I would split the manifold. Put on an 18" glasspack on one side and run a straight pipe on the other.
Then I would find a long hill in a quiet residental neighborhood late at night. I would drop it into second gear going down the hill, let out the clutch, and rap that beautiful music.
They I would hope the cops were more understanding then they were in my Southern California neighborhoods so many years ago...
Do you remember that smooth mellow sound?
I almost bought a Chevy split manifold six -- around a 50 or so -- really can't remember. Was in Oceanside California.
Now, I'd like to build one more car -- a street car like we actually drove -- based on what we could afford. I can hear that Chevy backing down on the pipes or racking -- cherry bombs...
In the main, reliability is way beyond what we ever had, but I think modern cars are more apt to leave you stranded without warning.
Aside from high mileage failures like timing chains and such, 60's cars usually gave some warning before they quit. At least it seems like they did.
Some hints: 60's small block Chevy pickup engines usually had forged steel crankshafts.
If you can get the pistons, a 283 crank in an early 327 block made you a 302. Destroked 327.
2 - 4 bbls ran good on Chevy smallblocks. 3 - 2 bbls didn't. 3 - 2 bbls ran good on 389 and 400 Pontiacs. I didn't have any experience with 2 - 4 bbls on these engines.
348 and 409 Chevys ran good on any carburator combination. I liked 2 - 4s better than 3 deuces.
Never was happy with the Chevy big block -- way too much torque and way too much reciprocating mass.
Anyway, thanks for a chance to say something about the old cars. Can you still hear the vibrator on the old radio?
'49 Merc, Buddy Holly, and Sharon -- at the light, 56 Ford rapping up alongside. Ha!
-no comparison w/brakes-thank goodness. my first car was a hupmobile that i traded a neighbor for $20. pumped up the tires-fresh gas-oil- pushed it-kick start w/1st. gear and off to san diego.ahhh
the 50s were a great time---
But, you know, the 66 is more fun to drive than our 99 Concorde but for different reasons. The Chevy is just fun and the Concorde is a pleasure. Wouldn't want to give up either one.
How many of you remember fender benders in your old cars that you could actually drive away from. Sure these cars didn't have all the air bags, ABS Eetc., etc. of old cars but then I never ended up in an accident that I couldn't drive away from in these cars.
Talk about disposable autos! These earlier car were not and when something didn't work you knew exactly why and it didn't take a rocket scientist to fix it.
t
I'm not big on every dumb "safety" device. A lot of them are pure junk. But when the combination of the collapsible steering column and 3-point belt came along was when a LOT of serious accidents became survivable.
If you get an old car just be aware that if something intrudes into your front end, it doesn't have to penetrate very far to take your head off. The steering column will deliver the force quite efficiently.
Didn't collapsing columns happen in '67 or so -- when Nader made the big push for better occupant safety?
Seat belts were already in there -- what -- about '63 or so? Then front discs became readily available in '68 or so. I guess most of the hard core safety stuff has been around for 30 years or so.
Interesting note on safety. I drove a wrecker while I was in college in 1968. Alot of bad wrecks in those days were single car, drinking, plain stupid or passing on two lane roads.
Odd that as cars improved, the designers messed up by going to rack and pinion steering on very light, but fast cars. I believe R&P steering in light cars at high speed cause quite a few interstate accidents.
I've seen young people drive small cars 90 or better -- car probably exerts less than 100 pounds on the road, tires at at their upper limit (80 MPH), and the driver is fooling with the CD or something ---
Older cars got your respect or they hurt you. Newer cars just don't give any warning.
Straightforward design -- no real tricks to it except for removing and installing the damper. Use a puller -- always.
Depending on the year of the engine, you can look at the casting marks on the front of the heads -- double humps mean fuel injected with bigger ports and valves while a small diamond on top of a rectangle means power pack heads (which became the standard).
Only thing I didn't like about the small block was that you had to loosen the oil pan to take off the front cover.
If you get the car -- hope we hear how it is going. Good luck.
I still love that car for saving me without seat belts, air bags, ABS or AC. Just three speed manual xmission, one tail light, one mirror, and a gasoline heater were standard and enough.
You are absolutely right, modern cars are safer, and as you imply, I'm not sure about the drivers either.--------dranoel
It stemmed from the fuel pump being mounted on the engine and designed to pull the fuel up the fuel line, I think. It seems like he installed a fuel pump by the gas tank to push the gas, and solved most of the problem.
We also had the problem with a 1978 Toyota Land Cruiser -- stalled once as I was pulling out onto a 4-lane highway and made me just about crap. That's another story.
But on modern cars, it's just about unheard of, probably due to better engineering and very high fuel line pressures.
Aside from the water trick, some people used to put clothespins on the fuel lines to carry off the heat (dubious, but who knows?) and some tried to block the heat by wrapping the lines in aluminum foil.
I think the old flatheads were the worst...with those feeble 6 volt starter motors you could barely turn the thing over on a good day.
Rrr...Rrr...Rrr....Rrr.....Rrr...
Our old 1961 Ford tractor sounded the same way.
That old Lincoln had the Oil/Air bubbler type of oil filter, too. Weird. Had more room in the back seat than most cars have in the whole car, though.
All of a sudden, a crankcase explosion occured!
The oil cap whizzed past my ear! If it had connected with my noggin, I wouldn't be tying these words right now!
The oil cap was finally located after it went across the street and broke a window in a telephone booth.
The dipstick was never found!
After that, the old Ford started and we drove it home. The next week, we replaced the oil pan gasket!
Ever see that happen, Mr. S.?
Funny as that...I heard of a guy who decided to clean out his distributor cap with starting ether (a good solvent)...he slammed the cap back on, hit the starter, and BAM...a hundred little pieces of distributor cap!
I saw a piston come up through the hood of a car at the dragstrip one time...that was dramatic.
All kinds of nifty things can happen to a car that's malfunctioning...i've seen a driveshaft bust loose from it's u-joint and drive itself up through the floor (Mercedes 280SL)...I've seen clutches explode (hence we have scattershields on high-powered cars), differential houses crack in half, rear axle shafts break on wind-up. Just remembered on an old MG, the oil feed line to the oil pressure guage breaking and spitting all over my date....last date, I might add, with that lady.
I remember it had black rubber instead of cork valve cover gaskets. They blew out from under the covers and looked like snakes.
Somehow, the pan gasket survived. What we didn't know however was the fact the explosion raised up the valley cover thus breaking the seal.
When we started the thing, we had oil EVERYWHERE!
Ah, the good old days...
Haven't seen this on any other car.
What kind of car?
lessee...Princess Grace died in a Rover
And we won't go into Di and James Dean, we all know those....
Oh, was it Mamie Van Dooren or Diana Dors that got decapitated in a Chrysler Imperial?...(I TOLD you this would be a grim topic....).
Oh, here's a hard one...the car that killed famous dancer Isadore Duncan when her long scarf got caught in the rear wheel hub.
No, Isadore Duncan was killed in an Amilcar, but Bugatti is often cited, and from what i can tell from various sources, is incorrect....Amilcar was a very sporty French car...well, they may both sports and unsporty models. Hell of a good guess, though.
And the car that killed over 80 people at Lemans in 1955?
BONUS QUESTION--and the car that probably caused the above accident?
One of the interesting sidenotes to that story was that from that day forward, Mercedes pulled out of racing. Some say to honor the dead, but more likely because they had won everything ten times over and had nothing left to prove...it was a good opportunity for a graceful exit.
Hmmm...maybe they're upset after Mazda won it.
I'd love to take a ride in one of the M-B pre WW II grand prix cars...supposedly, you could mash the gas pedal at 150 mph in 4th gear and spin rubber.
