A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
2001 - 2006 Honda CR-Vs
1192193195197198314
  • diploiddiploid Member Posts: 2,286
    If you need seating for 5, that rules out the Element.
  • robmarchrobmarch Member Posts: 482
    is a great color on the CRV, in my opinion. My family had 6ish dark red cars before the CRV, though, so it was out of consideration. The Mohave Mist or Silver are probably the easiest to hide dirt. The darker colors have the best visual impact. I like the Red better than the blue or green, and think the Black CRV is very classy looking, and almost looks like a different vehicle, since the body molding doesn't stand out as much. I ruled it out because of cleaning difficulty, though :)
  • matt479matt479 Member Posts: 26
    My $.02 - to put an end to knowing whether the CRV has switched into AWD, Honda should put an AWD indicator light on the dash. It would defiantly help while driving.
    taking a quick glance at the Element, I'd prefer still to have my CRV. Reason:
    1) The dash on the Element seems to be set up odd. The air controls are just above the shifter. Could cause some problems. The CRV shifter looks like it's in an odd place put it's really close to most other cars.
    2) Passenger space. The Element's back sets are set up for only 2 people. The CRV can easily handle 3 people in the back. It can also handle two car sets and a person in the back.
    3) Kind of minor - the fold down cup holder in the CRV. Very convenient and when folded down it provides extra storage space and foot space for the person sitting in the middle. The Element has the emergency break in the same spot. The CRV emergency break placement is pretty darn cool. When released it's out of the way and blends really well into the dash.
    4) Element body style - very questionable. The CRV is a little hard to get use to, but not as bad as the Element.
    Overall, the new CRV's are very well refined. I get a lot of complements about it.
    The cargo space in both looks to be about the same. I've been able to fit A TON of luggage and gear into my CRV. The engine specs are about the same. All time 4WD is great thing to have in the back of your mind. Reason is that with the CRV you're always guessing as to when the AWD kicks in.
    "Honda should put an AWD indicator light on the dash. It would defiantly help while driving."
    How so? Shouldn't your eyes be on the road, not the dash? =)
    Seriously, the safest way to drive is to assume that RT4WD is not working and the car is 2WD. Knowing that RT4WD is active only gives a false sense of security. If you see an indicator light lit up, what would you do differently? Would you even have time to do something before the system disengages?
  • sluglineslugline Member Posts: 391
    I could actually see some people view a RT4WD light as confusing, because most people associate dash lights as indicators of things gone wrong or needing attention, not a signal that things are working properly.
    Know what I'd like to see instead of a light? A gauge that would show the amount of torque being transferred to the rear wheels at any given time. It would be the CR-V's equivalent of the Insight's IMA gauges -- a geeky toy everyone can't help but watch when it goes into action. :)
    Did you just call yourself a geek? =)
    As I understand it, the percentage of power sent to the rear wheels is a factor of how much slippage there is within the clutch packs. The harder the packs are pushed together, the more friction there is. The more friction, the more power. Friction is a tough thing to measure.
    "Knowing that RT4WD is active only gives a false sense of security" - I disagree. An AWD indicator light would give you correct security. Not having it is like not having an Oil Light, temperature gauge, airbag gauge, etc., etc., etc. It helps you to know that the car is operating correctly. Real time AWD is a driving mode like OD. I'd like to know when it's on, rather trying to sense it while I'm concentrating on driving. Having the gauge relieves this thought in the back of your mind. It gives you confidence.
    I don't need something as technical as slugline's idea. Just let me know that car is working as designed so that I can concentrate on driving. While driving in snow, operating under "I think the AWD is working" can be distracting..
    Matt - I understand the curiosity factor, but I don't think an indicator light will do what you want it to do. Knowing how RT4WD works, such an indicator would most likely do this:
    on
    off
    on
    off
    on
    off
    The device can engage within a quarter turn of the wheels. It disengages just as fast. It also begins to engage when you take tight turns (the path of the front wheels is longer than the path of the rear wheels creating a difference in speed which activates RT4WD). So, it's possible that the light will come on even when there isn't any slippage. Would this provide more comfort or less?
    Frankly, I see this causing more anxiety to those who do not understand the system. Dealers would be getting calls from customers with AWD systems that won't stay engaged or engage too often.
    If your fear is that the system is broken, all I can say is this. Other than the squeal that happens when the diff fluid needs changing, I can recall only one vehicle that has had a problem with RT4WD (a leaky unit). The system is completely mechanical and relatively uncomplicated. It is quite possibly the most reliable device on the vehicle.
    Idiot lights, OTOH, malfunction all the time.
  • denise31denise31 Member Posts: 21
    Thanks, matt479 for giving me something to think about. You are right the Element's body style is questionable- and that missing B-pillar really concerns me.
    Also, the Element will not have side airbags available until June 2003.
    Overall, I think the CR-V is a very good choice.
  • andriesandries Member Posts: 37
    I agree with you. The other day I was in town, after we had that rain and snow. The V worked awsome,and I never wondered if the AWD was working or not. I guess thats because I have driven 4 wheel drives for so long,that when you know its slipperey, and your not spinning out like the car beside you is, then its obvious that all systems are a go!!
  • moonkatmoonkat Member Posts: 265
    B-pillar is not missing. It is part of the rear door as well as the structural reinforcement.
    Actually, that O/D light isn't there to tell you exactly when overdrive is engaged. It only comes on to tell you when overdrive (aka fourth gear on automatic transmission) has been prevented from engaging. There's a difference, and I hope the owners manuals are getting clearer on this topic. Then again . . . gear indicator lights for auto trannies would be interesting idea . . . we may as well get those along with the RT4WD light!
    Seriously, if I may pick up on your analogy to other warning lights: No one needs a light to tell us when we're braking for a stoplight, or when our airbags are deploying. Generally, we want those lights to show up only when something needs attention. Quite bluntly, RT4WD is a dumb, but effective system; it's all hydraulically activated with no "brains" behind it. So maybe I might not mind a light that tells you when the fluid is low or needs changing, but that's about it.
    Varmine: It's Christmas Eve Eve, and I'm posting about RT4WD on a web board. 'Nuff said. :)
  • christic3christic3 Member Posts: 2
    I need to buy a car since my 1993 Honda Accord finally died. I've been looking at the 2003 Accord and the 2003 4WD CR-V LX. I was wondering how expensive it is to maintain a CR-V? I can kind of can gauge from my '93 how expensive the Accord will be but I've never owned a 4WD anything before and can't really judge. Has anyone made the transition from Accord to CR-V? Did it take a long time to get used to it?
  • qguqgu Member Posts: 93
    A 4WD indicator can at least tell me the road condition especially thin ice which you cannot really see. It might be flashing as long as it does not distract the driver I am all for it. 4WD indicator is more important than the cruise control indicator IMO. BTW, Honda can make it green just like the cruise indicator so people know that it does not indicate anything wrong with the vehicle rather poor road condition.
  • crv139crv139 Member Posts: 41
    you are talking about two different types of vehicle. If you want a smooth ride and do not need alot of space go with the accord.
    if you want a vehicle that has a good ride and not as smooth as the accord and more cargo space I would I would go with the crv.
    I love my CRV it is just a fun vehicle to drive, it handles great in the snow. Both the accord and CRV have the same 2.4 liter engine but you can get the 240hp v-6 in the accord.
    So its up to you what you want. I have had awd vehicles in the past they do not cost that much more as long as you do the proper maintence.
  • tomsrtomsr Member Posts: 325
    Versatiliy is what the V is about.The Accord is just transportation but the V can be anything you want.If you have the money for a car and a truck
    then have both but us po folks have to compromise.
    You can haul furniture,plants,anything,or go camping.If I get thrown out of my house I can sleep in it.It is not as fast or quiet as the Accord but it is ready when you drive by that
    garage sale and you find that bargain doodad.
  • demichidemichi Member Posts: 9
    Does anyone know any dealers,who is selling Honda CRV in the Michigan,Metro Detroit area at MSRP or below?.
    Thank you for your help.
    Versatility was the major reason I was considering the CR-V. I like the idea that I can carry people and yet still be able to haul lots of stuff. (Unfortunately, I can't afford both a car and a truck and must choose only one vehicle. If I ever win the lottery, that may change...but not anytime soon.)
    I'm glad to know it does well in the snow--since that's the other main reason I'm considering it. Has it been a good reliable vehicle? Would you recommend it?
  • stragerstrager Member Posts: 308
    A friend has the 2002 CR-V and so far it has been flawless. I think it will probably be rated as the most reliable compact SUV by Consumer Reports (just like the previous generation).
    The major downside of the CR-V compared to the Accord is way too much road noise which really becomes bothersome on the freeway. Switching to quieter Yokohama tires hasn't made much difference.
    There will be people on this board who will say the road noise is not excessive, it's not a Lexus, what else do you expect for $20K etc, etc. Check out the road noise level at freeway speeds before you decide because in the city the CR-V is very quiet.
    My friend loves the CR-V otherwise(he's a long time Honda owner), but is actively looking to trade it in for a quieter SUV/"crossover" because he can't live with that road noise for the next 5 years.
  • dash10dash10 Member Posts: 2
    I test drove the 4 wheel drive SUV and noticed a small vibration in the steering wheel at about 70 MPH. Also a little howl behind the front seats at the same speed. Is this common? Any comments if this disappears with the 2 WD models.
  • sephonesephone Member Posts: 5
    That's right. My favorite car was my Miata (sold it when the kids came along). CR-V noisy? Come on!
    My other vehicle is a Harley....
    What is it with quiet vehicles? Your driving man – and ought not forget it. I think some of those people I see falling asleep at the wheel must have "quiet" cars.
  • jfigueroa1jfigueroa1 Member Posts: 209
    I had a 01 accord very nice easy to get in and out, quiet, elegant ride,good soft ride. on the other hand i gave it on trade in for the cr-v for my wife. The cr-v I feel is a more safer vehicle due to the higher seating position,in the city it is nice and quiet but in the high way it tent to be a little too loud. The interior space is great,the way you could adjust to your convenience is a thumb up. power, yes it is there step in the gas pedal and it will rev hard but, do not worry you will not feel it shift, it is that smooth.
    Greetings from sunny Miami
  • gregoryc1gregoryc1 Member Posts: 764
    My wife and I are considering a purchase of a 2003 CRV in the next month. We are looking at the LX-4WD-4dr w/Side Air Bags. This will be our 4th Honda vehicle. The other Honda vehicles have been: 2 Accords and 1 Civic. We have been VERY happy with the quality of these vehicles. Is there anyone out there who presently owns this vehicle and is willing to share both good and bad experiences. ----Have a nice day!-----Greg
  • wellresearchedwellresearched Member Posts: 63
    My 2002 AWD CRV was put to the test yesterday! The 20 mile trip back home after Christmas dinner was quite a challenge. Although not as large as a snow fall as is common in my childhood hometown (Watertown, NY).... this was a major storm for where I now live. I can't share any off road stories, as I never went off road...unlike the MANY MANY cars all over the place! This vehicle never balked!!! When I cleaned it off it was solidly in a 2 ft snow drift! No problem pulling out (albeit light snow..not heavy with water) I drove it appropriately for the conditions (between 10-20mph... with heavy snow and winds) The super highway only had one lane(which was barely passable) open.
    Neither my neighborhood or my driveway was plowed (8 inches at the lowest ..2ft highest).
    I never lost control of this vehicle...it started, slowed, stopped and mostly stayed ON the road!!!! It handled flawlessly.
    I can not imagine ever demanding more from it (winter driving). It is unlikely I would choose to drive at all in weather any worse than yesterday.
    Similarly, I arrived at work this morning on time. The roads were not at all well plowed with lots of drifts. Again, my CRV didn't hesitate.
    What a GREAT vehicle in the snow!
  • gatorgreggatorgreg Member Posts: 91
    Christic3, the CR-V's 4WD system is one of the, if not the, easiest/cheapest 4WD system's to maintain. All you need to do is change the rear diffy fluid once in a while, although in practice many people have found that the interval specified in the owner's manual is too infrequent. However, you should be able to go several years before changing it.
    Accord is a great car, but I'd take the V cuz you never know when the cargo capacity and RealTime 4WD of the CR-V will come in handy :)
  • dave_cldave_cl Member Posts: 54
    We bought our 2002 CR-V in December, 2001, and it now has 25000km on the odometer.
    My wife just returned from the Boxing Day sales (why do women do this???) and she told me that the Ontario Provincial Policeman who was directing traffic at the mall, showed up in a CR-V, with the "Police" painting on the side, and all the lights on top!
    The OPP used to buy Ford Explorers around here (50 miles north of Toronto, and in the snow belt), but I'm impressed if they are going with the CR-V.
    My (my wife's, actually, but don't tell) CR-V is FANTASTIC in the snow conditions we experience here. I didn't use my brand new, 10HP snowblower at all last winter. Instead, every time it snowed, I drove the CR-V around and around and around my semi-circular driveway, so that the snow was packed down, and not removed. If we get 3 feet of snow in one storm this winter, I'm going to see how she fares!
    I'll report here.
    And, of course, if I get stuck, I'll just pull out the snowblower.
    BTW, I've got the Duelers.
  • civicwcivicw Member Posts: 135
    I'm assuming those pictures are taken with a digital camera. What brand/model camera and resolution is it? For that size, the pictures look quite sharp.
    I tend to fall asleep behind the wheel so I need noise!I had a VW beetle and that would really keep me awake.Quiet is nice for short drives
    but after a few hours on the road too comfortable
    could put you to sleep forever.I envy truck
    drivers who can drive all day across vast stretches of desert and plains and not get sleepy.
    Here is a question: What is the range after the low fuel lite comes if doing 50mph?My lite came on at 275 miles and I was sweating it cause I could not find a gas station open.I finally found one at 297 miles.
    As suggested earlier, a test drive is the best way to determine if the noise levels are too much for you. However, I think you'll find that the CR-V is no louder than the majority of other vehicles in this class. With the CR-V, you get low wind noise, little engine noise, but quite a bit of road noise from the tires. With an Escape, you get more engine and wind noise. In a VUE, you get road and engine noise. In a RAV4, you get engine noise. The Forester is probably the least noisey of the group. However, all of them will be relatively noisey when compared to something like the Accord.
    The CR-V tends to do well in deep snow. The narrow tires cut through the deep stuff and the 8.1" of ground clearance keep you above the drifts. Car & Driver found that it did well navigating snow ruts, though they don't specify exactly why. The stock tires are okay by all-season standards, however, if you want/need real traction, get a set of snow tires.
    Left on Tuesday morning to go to the inlaws for Christmas. Filled the CR-V to the brim when we left home. It was -16 C when we left,and the wind was fairly calm. We set the cruise on 100 Kilometers, and left her there. When we got to the town closest to her home, I stopped and filled it to the brim again.
    We put on 457 kilometers or 283 miles. Put in 41.237 litres or 9.07 Imperial gallons. Works out to be around 31 mpg, or for our American friends, thats about 25.8 mpg. For winter driving I thought that was fairly decent, and the CR-V had only 900 kilometers when we left for our short trip.
    The mud pic is actually a still image pulled off of a hi-8mm Sony camcorder, although I can't remember if I was using a hi-8mm tape that day or just a regular 8mm tape. Not sure the model number but I got it about 5 years ago. Freeze framing video is still the best way of capturing flying mud IMO :):):) The grass pic was taken with a couple year old Sony digital camera, Mavica model MVC FD73, the kind that uses floppies (very convenient for low tech people like me). My wife just got a fancy new Olympus digicam which takes incredible pics, but so far she won't let me use it to take pics of the CR-V :):):)
  • luv2motorluv2motor Member Posts: 25
    I have logged on 19,450 miles on my '02 CRV and I've had it less than a year! It has been a great car so far (knock on wood). I was wondering though, should the Maintenance Required light flash ten times upon start up and then go out? I can't remember if this has always been the case.
    Also, has anyone experienced a "warm" rubber smell coming from the rear of the car? Smells a little like warm tires or maybe brakes???
    ...don't take this personally but read the manual re: maint rqd light.
    Standard maint schedule is every 10K so the lights flashes at you starting around 500-600 miles before the interval.
  • thistle3304thistle3304 Member Posts: 1
    Hi all. I'm in the process of deciding on a new vehicle. I've got three Civics; I'm obviously a happy Honda owner. I've had very bad luck with the US builders. I'm currently evaluating the Subaru WRX wagon, Honda CRV, and Toyota RAV4. They each have their special attractions. I'm interested in anyone's personal evaluations between these vehicles.
    I'm also interested in preferences between the European built CRV or the Japanese built CRV. Any suggestions one way or the other?
    Dan
    This should be an easy one :)
    If you want a sports car with decent cargo room, go for the WRX wagon. It's a great car.
    If you want a great value in a higher seating position and lots of passenger and cargo room without going to a full size SUV, the CRV is a great choice. It handles well, but certainly not on par with the WRX.
    The RAV4 got expensive quickly, when I priced it. But, it is somewhat in between the two, trading some cargo room for slightly sportier handling.
    I think test driving all 3 should make their personalities known very quickly.
    Good luck with your choice!
    I had a burning smell from the rear of my 2002 CR-V, at 16 000 kilometres. The dealer machined the rotors and replaced the brake pads. No charge.
    Check out my messages #8848 and #8881 on this forum for more details about burning brakes.
  • bob346bob346 Member Posts: 12
    can the speed of the wiper sweeps be adjusted in any way , i find the factory setting is 6 sec. would like a 3 sec. if possible. by the way i have 8888 miles & still think its about the best out there!!!! thanks Bob346
  • jtn46jtn46 Member Posts: 13
    My CR-V finally arrived yesterday after about 6 weeks, and we started the paperwork on it today. It should be in my driveway tomorrow or Friday! One good thing about the long wait is that assuming I qualify (which the business manager told me I almost definitely will) I'll be able to get the 3.49% financing rate Honda's offering until tomorrow.
  • tapgypsytapgypsy Member Posts: 11
    Sorry if this has been talked about previously, but I just made an appointment to have the 30,000 service done on my 2000 CRV. The service is being done at the dealership where I purchased. Quoted price is $450??!! This is my first Honda and perhaps this isn't unusual, but it certainly seems excessive...or is it?
  • theracoontheracoon Member Posts: 666
    $450 is excessive. For my 1999 CR-V it was less than $200 and that included having the rear differential fluid changed, something that isn't required for the 30,000 mile service but is a good idea. The dealership also provided a free loaner car while the service was being done.
    JM2C
    ...are they doing the Honda recommended maintenance as per the manual and Honda Ownerlink or their own list of items?
    I remember that my selling dealer did their own list which skipped a number of the Honda items (ie AC Filter) but they added their own items like valve adjustment and vacuum oil change every 7500 miles.
    My current dealer has preprinted Honda forms that match up directly to Honda's recommendation.
    Got some more snow driving in my '02 CRV this past weekend. Was in Mammoth, CA. while it snowed another 3'. CRV handled beautifully in the snow. During most of the nights the roads were covered in about of 1' of snow. One night was a complete white out. Duelers handled great. Only problem is on ice. Every car is going to have this problem even with chains. First night of the storm pulled into a parking lot that was solid ice underneath the fresh snow. Slid out pretty bad, but the Anti-lock brakes kicked in really good and stop me before hitting any other vehicles. Probably slid about 10' before coming to a stop. Didn't get complete side ways.
    Another great performance in my CRV in these conditions was the defrost. Would melt the snow on my windshield so fast.
    Got to revisit my idea of a AWD indicator light - would be great to have because during most of the snow driving I don't believe the AWD is active. You can definitely feel it at slow speeds going through thick sections of snow. Coming out of a parking space filled with snow you can feel the AWD working. But when driving down a street at 20mph on snow, I'd guess it's in FWD and you're dependent on the tire traction.
    Adding windshield fluid this morning, saw road salt everywhere in the engine compartment. There are two big openings from engine compartment to front tires. The compartment looked dirty. I do not know what to say to HONDA. I am not happy to see that. I have never owned a vehicle which let road salt to get into engine compartment so freely. CR-V definitely superised me.
    I have posted this earlier. I also made comment about fine gravel on top, and where you pull the dipstick. I know I will be giving mine a shot of air before pulling the dipstick.
    Ggu - I have a 99 CR-V with no openings in the wheelwells. I also have road debris in the engine compartment. Fully enclosed wheelwells do not stop it. I have over 70K miles on my CR-V and this is my fourth Winter with it. I've cleaned the engine compartment only once. So far no troubles.
    If it helps you sleep at night, there is a diagram demonstrating how to construct a "baffle" of sorts. The link is posted somewhere in the past few months. There are several other pickup trucks and SUVs with similar designs, so I'm not worried about it.
    The Edmunds Maintenance Guide will tell you what we think the 30,000 service should cost. Some people like to do more than the "minimum" though.
  • rockycowrockycow Member Posts: 114
    Steve the guide is not up-to-date. 30K maint guide show plug replacement. the 2002 CRV has long life 110K plugs. I didn't bother checking any further.
