Is this a way of getting even better FM reception by Honda?
kyfdx
The Crutchfield instructions are easy to follow but I found that the Honda instructions more useful.
The first thing I would advise anyone attemting this project is to before removeing the OEM unit make sure what works,( speakers) as after I hooked up the replacement the left front door speaker did not work.
After a about a half hour of messing around I pluged the old unit in and the same problem, found out the speaker was never pluged in, from the factory.
Following the instructions was easy, remove a screw here, pull panel down here, bla bla bla, the only thing that worrys me is how hard to pull.
I would never do a install again, its worth $30-$50 to have it done, if you can find a good shop that won't break anything,( knows what they are doing) and put it back together with out leaveing anything out.
If your not particular, and don't mind a loose panel here a screw missing or striped here, give it a try.
Mine went back together fine, I just don't need the aggravation, as I am very picky about my vehicle.
My .02 cents.
Tom
1) Has anyone had the dealer add keyless entry to the LX and how much did it cost? We do not need the EX with the moonroof and AWD.
2) How much is the Honda Care Warranty? I believe I read a post that stated between $800 and $1,000 for 7 year or 100,000 miles.
3) How does the 2wd/fwd perform in minor snow/slush?
Also, any comments about the three models would be appreciated.
-juice
is noisier and rides rougher plus the overall feel is poor quality.The Santa Fe is slow taking off but is quiet and smooth.It was a close second.
I have owned a Subaru and it was rattling at 40k
miles so I passed on that.The Highlander was looked at but did not offer all the CRV has unless
you spent $5k more.If they all cost the same I would have gotten the Highlander Limited Edition.The only thing about it, is it's for chicks.The only negative about the CRV is at 80mph
it downshifts on hills meaning it either needs more power or I need to drive slower.
Buy an american model and add aftermarket leather for about $900. Catskins is better than most OE leather. With heat it's about $1300.
You can get the armrest extension with any Forester, plus factory leather. Then again, you can install the armrest yourself on a CR-V, as long as its position doesn't interfere with shifting. Or have the upholstery shop install it for you.
As for Subies rattling, well, the Forester and CR-V are tied on top for CR's reliability rating in this class. Noone's perfect, but these two are as good as it gets (with a few exceptions for both, of course).
-juice
We've driven the CR-V on several long trips, the last one was from Western NY to Key West Florida and back this past Christmas, so we've had it on just about every type of road surface. Some roads are noisier than others, but all are bearable. It's definitely noisier than a passenger sedan. Good luck.
If it seems loud, ask them to check the tire pressure, too. They usually ship them overinflated to prevent flat-spotting the tires.
-juice
http://www.honda.co.uk/newcars/accord300k.html
It's the euro Accord wagon. Acura TSX here, but not in wagon format unfortunately. Acura has lots of room below the MDX for a two-box something or other, if not a CR-V or Element clone, maybe this?
Very neat, it hints at the quality of design and engineering.
-juice
-juice
The 2001 was ENTIRELY different, similarly the even older ones had even LESS powerful engines.
BTW don't go by the the Edmunds "TMV" used prices for CR-Vs, I don't where they come up with such OUTRAGEOUSLY LOW prices! Further the GOOFY 'customized appraisal'tool doesn;t have ANY of the DIO options and those are HUGELY popular with CR-V buyers, whether NEW or USED ...
For a reality check, ask for a second opinion over in Real-World Trade-In Values.
Still doing comparisons of CRV & Subaru Forester. Does anyone know if TMV price is good leverage when purchasing CRV's (seems like due to popularity/supply of Honda's). Dealer I've been working with seems quasi-haggle free. TMV quoting me price of $21,173 (MSRP $22,060) for 5 speed EX. Seems like when I've checked previously that TMV was closer to MSRP. Kinda leaning towards CRV, since I don't anticipate any off-roading and past excellent experience with Honda's. But I do love that Forester moon-roof and AWD. Thanks for any info.
If you'd like to ask about the Forester, hop over to the Forester thread under SUVs, we have lots to share about it.
-juice
I rode in my Father-in-laws' '03 a few days ago and was struck by how much quieter it is compared to my '99. He only has 6k miles on his, compared to my 50k. Makes me want a new one...but I don't need it.
-juice
All comments are appreciated.
Is loudest in winter (cold)
Only occurs when just starting to move or just about to stop.
I have a clutch, but no noise from it
Can rock vehicle pushing on it front/back or sideways while parked but no squeak.......only just when starting to move....can't detect when already moving or shifting
Sounds like it is coming from under vehicle.
Can rock back and forth in my seat and no noise
When it occurs its like the frame is flexing because it sounds like a metal rubbing squeak noise
Mechanic took a look and could not find it.
Who has some ideas for me to check on?
Component Description:
27. SUSPENSION:INDEPENDENT FRONT NHTSA Number: 629541
Bulletin Number: 5905
Bulletin Date: FEB 2002
Vehicle: 1999 Honda CR-V
Summary:
CUSTOMERS MAY COMPLAIN OF A TWANG NOISE FROM THE FRONT SUSPENSION THAT SOUNDS LIKE A SPRING CONTACT.
There's another one about clunking going over bumps too, but that didn't sound like your symptoms. There are messages about suspension noises here and in CR-V Owners: Problems & Solutions that you can find with a discussion search.
-juice
Some body told me that we can not adjust the driver seat in CRV , is that true?
Approximately how many inches we can move forward/backward the driver seat.
Rajum - I think your best bet is to try it at the dealership. There is plenty of adjustment to the seat, but some tall folks have complained that it doesn't go back far enough. Opinions on the matter vary greatly.
raju: check out the seat track. A Subaru owner was able to rig the power seat on his Outback to go back an extra inch or two, maybe you could do the same with the CR-V.
Honda could make it go 6" farther back and the rear seats would still be useful!
-juice
Greetings from sunny Miami.
-juice
I personally carry around either an Ody key with a house key or an Accord key with a house key along with a set of work keys, Each vehicle has a key ring with all those annoying customer loyalty tags for whoever is going to the grocery store.
There is so much leg room in the back seat that I don't know why the front seats don't adjust back further. Other than that, we love the car.
It was about $80 plus shipping.I made an extension so my bike rack would clear the spare tire when mounted on the hitch receiver.The wiring
harness was another $25 which I have not installed yet.It is more involved.I sometimes wish
I had a 5 speed for the fun factor but the auto is mighty convenient and it's resale value is helped.
-juice
Could be a safety "thing". Positioning the front seat occupants behind the B pillar may have a negative effect on crash safety. Just a guess on my part.
I'd also love to see pics of that seat modification. Thanks.
-- Wife and I live in southern NJ, and have a lease on a honda civic (2000) - 3 months left. We were looking at the cr-v for the next car - but the dealer has been a bit odd with us. I asked the dealer regarding ending the lease early to buy the cr-v now, and he said that we would have to pay off the lease first (same dealership). If we went with the honda, we would be a THREEPEAT customer at the dealership, so I was very surprised. I know that other car companies agree to end leases early when there is a sale involved... is the dealer just messing with us?
-- I test drove the 4wd LX, and it seemed pretty nice. Is there much of a difference between the 2wd and the 4wd (automatic) overall other than the obvious?
-- Price I got for the 4wd LX was $20,500. Good? bad?
www.ilovecrv.com
It's amazing that body colored bumpers on the V improve the looks 100% It also seems like the headlights and front nose look much cleaner also.
Anyone else see a difference?
One question...the cd player doesn't seem to play discs that I burned on my computer. Is that the case with all of you? No big deal, I can access most of the same songs on my iPod in the CRV, but I thought I'd ask.
