2001 - 2006 Honda CR-Vs
1215216218220221314
  • fenris99fenris99 Member Posts: 16
    yeah, i have the Duelers.
    If it is as you say, maybe I'll just keep them through one winter (while the treads are still good) and then move on to something with a little more grip.
  • robmarchrobmarch Member Posts: 482
    are the weakest link of the package. Mine wore quickly, but the worst part was that they went from "fine" to "delaminating" in less than a week. This was at 30k miles, by the way.
    They're acceptable, but I wouldn't recommend them as replacement tires. Depending on driving style, some people might benefit from replacing brand new ones for better tires. (I'd make this suggestion on many cars, not just the CR-V)
  • tomk17tomk17 Member Posts: 135
    Being a self proclaimed tire expert I'm a big fan of snow tires. I've bought many tires from the tirerack.com and would consider the new Kumho I'ZEN snow tires for the CR-V. I've read positive comments about these tires specifically on the CR-V. You might say "never heard of Kumho" but they are a major manuf in Japan much like Summitomo. For $45 per tire they should make a significant difference in the snow / ice and I hear they ride well (and quietly)on dry surfaces. I'll have a set of 4 before Thanksgiving and will advise. For $30 less PER TIRE than the Michelin Alpins (good tires), the Kumhos are a good deal. If you are gunshy about the Kumbo's I have used the Dunlop Graspic DS1's for $56 each.
    Another vote against the Duelers. I've had a set in the past, just 28k low-grip miles out of them.
    Try to get the BF Goodrich tires instead, they're also available OE.
    -juice
  • tpannitpanni Member Posts: 9
    I bought my 02 V a month ago with 8,100 miles. Two weeks later, I changed all four tires to 205-15 Toyo Z800 which Les Schwab sells on the west coast. I had done the same with my prior car, A Toy Camry S/W. I immediately felt the difference with the lower rolling resistance of the Z800's (compared to the Michelin X radials I had on this car before, also good tires). The Z800's were quiet right from the start, even at 35psi. I track my mileage carefully, filling to about the same level each time and calculating the mileage. My Camry's mileage went up about 2 mpg with the Z800's, about 7.5%.
    While I only did about two tankfuls on my CRV with the original Bridgestone duelers, I have noticed a milage improvement of about the same (2mpg) with the Toyo's. My in-town driving, a lot of it bumper to bumper here in Seattle, went from just over 23mpg to over 25 mpg. Last weekend, I put 150 miles on a freeway trip and calculated the fillup at 302 miles as giving 26.8 mpg in what was essentially a 50% in0town/50% highway. I don't drive much over 65 and drive conservatively for the most part. I calculated that with the $50 trade-in for the original Bridgestones, the Toyo z800's current sale price and the mileage imrovement, the Toyo's were costing me $50/yr over keeping the stock Bridgestones - in my mind well worth the quieter ride and better traction (A rated) vs the B-traction for the Bridgestones. I also paid $11/tire to have them "siped" for improved wet weather traction, an important consideration in the Seattle area.
    I don't understand why people put larger tires on SUV's. They have a stability rollover issue any way and anything to keep the center of gravity low as the CRV engineers have done makes eminent sense. To compromise stability for looks is ....nuts.
    I am definitely sold on the Toyo Z 800's (Toyo tires were top ranked in the survey I read at Tire Rack), and to have A traction and the highest mileage rating, 100,000 miles with 750 treadwear rating is great. I plan to lower my tire pressure to 32-33 for the winter months at hand.
  • desertmandesertman Member Posts: 30
    The stock tire is the Bridgestone Dueler HT. However, Bridgestone also makes a Dueler HL, which is a much better tire (see the reviews on TireRack.com). And the HL is still a "light truck" highway tire, so it's good for mild off-roading. If you're going to put streetcar tires on the CR-V, you should have just bought a car instead.
    "If you're going to put streetcar tires on the CR-V, you should have just bought a car instead."
    I don't think there's a whole lot of difference between a "light truck highway tire" and a "passenger car highway tire". I went with the Yokohama Avid T4's, which are pretty much identical to the H4's and the S/T's (which are technically light truck tires). I don't see them being a problem for any light offroad duty that the OEM tires could handle.
    I went away from the Bridgestone H/L's because they were significantly more expensive than the Yokohamas, which got good reviews at tirerack. And, the delamination of the HT's wasn't a shining endorsement for Bridgestone to me, though they were different tires.
    I also don't agree with the statement that the CRV is only useful to those who take it offroad. There are a lot of people who use it for it's tall, large cargo area, and appreciate it's AWD, even if they only use it in winter weather and not doing all of the hardcore mudbogging the CRV is obviously capable of.
    Slugline, who is also know as CR-Vince in a parallel universe, has the Dueler HLs. He has had nothing but happy thoughts on them. I have to say, the bold white lettering on them really stands out (if you like that sort of thing).
  • aggie1995aggie1995 Member Posts: 318
    2002 CR-V
    OEM Duelers replaced at 30k due to some delaminating at the edges.
    Replaced with Yoko Avid S/T $60/tire installed including tax.
    Avid ride much much better. Handling is a nonfactor since my wife drives the CR-V 95% of the time with our child in the car with her. But the few times i have driven the new tires, I could not find anything objetionable. with a 60k treadlife warranty I won't have to worry about new tires for quite a while....hopefully.
    Oh the entire Avid line is rated very highly. I picked the S/T because it looked more trucky than the T4 ot S4.
  • kyfdxkyfdx Moderator Posts: 276,093
    1) All 205/70-15 tires are passenger car tires.. Whether they market them as such or not. The truck sizes in the same tire have a much different tread design... this includes the Duelers.
    2) If you plus-one size your tires (215/60-16), then you haven't raised your center of gravity at all, since they have the same overall diameter as the stock tires. I realize some go farther than that, and try to fill up the wheel wells, and I agree that I wouldn't want to compromise my handling that way.
    regards,
    kyfdx
    interesting that you saw delamination at the same mileage I did. Mine happened instantly...they were fine one day and delaminating the next, well before the wear bars or sidewalls were significantly worn.
    what would the truck sizes be in the yokohama line?
    The ones that start with LT...light truck P... denotes passenger
  • bayoubengalbayoubengal Member Posts: 3
    I know I'm re-hashing an old thread but . . .
    Just purchased a new CRV (see above). I got it at invoice (plus some accessories), but when we got to the financing phase, they offered the 7/10K warranty for ~$1,700 and dropped my APR to 3.25% (4-years).
    I could have gotten a 7/10K warranty from my credit union (3.99% APR pre-approved) for $1,100, but it wouldn't have been from Honda.
    Questions:
    1. Was the Honda warranty a good deal? (I'm thinking "no". I've seen some cheaper ones in previous postings.)
    2. Can I purchase a warranty on-line, directly from Honda? (I'm thinking "yes") If so, where?
    3. If I cancel the warranty I signed at the dealership, how will that affect my APR (I'm thinking it won't, but I don't know)
    My dilemma is this: I'd like to get a new warranty (read: "cheaper") 7/10K directly from Honda, but I have to cancel my current one. Am I being too greedy and should I just be happy with the deal I got, or should I try to look for a better price on the warranty?
    Any advice/comments would be greatly appreciated!
  • tomsrtomsr Member Posts: 325
    In Southern California CRVs are everywhere because they are practical.Most are never offroad so car tires are practical.There is not another vehicle out there that that compares for the price. If someone was making a tall station wagon with the carrying capacity of the V then it would be selling.I don't need AWD but to get all the goodies that's the way it comes.I opted to put Michelin Harmony tires on my V at 27k miles because my experience with Michelin has been good. Someone will probably say ,what about the Saturn VUE? Compare fit and finish to the V then decide.
    I'd cancel it and wait a year or two before buying.
    I was just researching the Texas auto lobby and found this link (Consumer's Union).
    (You did ask for advice, lol)
    You can't buy the warranty directly from Honda, but other Honda dealers sell it online. As long as you buy it before 2 years/24K miles, the price doesn't change significantly. I checked recently on my '02 CRV, and as long as I buy before 24K miles, the price for 7 yr/100K is still under $1000.
    I would cancel ASAP if you paid $1700. And I believe its illegal to tie the APR of your financing to whether you buy a warranty. I would also stay away from the third party warranty sold by your credit union. Your credit union will not back it up, if the warranty company refuses to pay, or goes out of business. Its just a profit center for the credit union also.
    regards,
    kyfdx
    Steve & kyfdx
     - Thanks for the info. That was an interesting article about the Texas regs.
    I'm reading the fine print on the warranty to see if I can purchase a new (cheaper) warranty after I cancel the old one. I don't see why not, but there's a line in the warranty that says:
    "V. Cancellation of contract.
     - A refund shall terminate this contract. If canceled, coverages cannot be reinstated".
    Technically, I won't be "reinstating". I'll be getting a new one.
    I've sent e-mails to the other Honda dealers in town requesting a price quote on the warranty. I'll let you know what I find out.
  • maryclovermaryclover Member Posts: 9
    I'm picking up my new 04 CRV next Friday in Chicago. I have to drive it back to New York. What's the deal with breaking in an engine. Do I need to stay below 55 mph for the first 1000 miles?
    Please help.
  • tigerinroctigerinroc Member Posts: 18
    I have been told that Honda adds additives into oil within new cars which eliminates the concern of breaking in an engine nowadays. Therefore, feel free to drive at 70MPH when you are on the thruway and do not change oil before 5000 miles or 6 months to utilize the additives.
    Have been driving up to 70 MPH with my 2004 civic which I bought 2 weeks ago.
    I forgot two more things. Within the first 500 miles, do not accelerate your speed too fast within a very short period of time and do not step on the break too harsh.
    Hope this helps.
    Someone actually read a contract - that may be a first around here :-)
    Sounds like an "anti-shopping around" clause you found. I bet the ext. warranty is in a computer somewhere indexed by VIN and that you won't be able to get another Honda one if you cancel.
    For $1700, I'd put that money in the bank for the next three years, then use it as a maintenance and repair fund.. With most Hondas, you'll be far ahead at 100K miles.
    steve.. I bet you are right.. that would suck
    regards,
    kyfdx
    I plan to purchase a cargo liner for my new CRV. Checking Autoanything.com, I see a Huskey liner for $68 and free shipping vs the Weathertech liner for $99 delivered. The only diff looks like a 2" lip on the Huskey vs 3" on the weathertech model. Any experiences would be appreciated but for $30 less the Huskey one looks fine.
    Sorry, I don't own one myself. That said, I think it depends on what you're going to haul.
    I rotate my tires twice a year, midyear (June) and end of year (December) are easy to remember and make sure the tire dealer does a "computer spin" balance each time. Conseuently. I only buy tires from a dealer that does the spin balance for free, in addition to road hazard and flat repair service. The two in my area I have used are Costco and Les Scwab (there may be others), that also have competitive tire prices and a resonable selection. The after-purchase service can really impact the long term cost of the tires.
    Tpanni
    I got info back from a dealer:
    _____
    "Yes, you can cancel your warranty and purchase another one. The clause in the contract refers to those situations where Honda Care cancels the contract, not if you cancel the contract.
    Please be aware that if Honda Care was included in the loan agreement with the bank, the refund will go to the lienholder and not to you."
    _____
    I'll keep searching for better prices, but I'll probably wait until 24/24K before I purchase another warranty. Since I financed it, my monthly payments should drop . . . but I'll check w/ my lending institution to see how that works (I'll just apply the overpayment towards the principal on the vehicle).
    Thanks for all the help! (and I'll post prices when I find them). So far, the best price I found on the internet was a little over $1,000 for 7/100.
    Does anyone know if Mobil 1 5W30 is OK to use in 02-03 CRV still under warranty (less than 10K miles)? One dealer service department reminded me that Honda recommends 5W20 and another said 5W30 was OK but to let the car break in to 10-12k miles before putting in synthetic oil.
    tpanni
    Just saw an announcemnt by Exxon Mobile of release of 0W20 synthetic with Supersyn, usable where 5W20 is specified. Honda CRV 02 and up was specifically mentioned. Seems like a really thin oil. Any words of wisdom?
    Did the dealer explain why they recommend waiting until after break in?
    I can't think of anyone who would know better than the folks who design, build, and read warranty reports on these engines. So, if Honda recommends using a thin oil, use the thin oil.
    RE: Recommending driving 10-12K miles before using synthetic oil.
    The service person's stated reason was that the new engine needed to wear a little before using synthetic oil which causes very little wear. The owners manual says synthetic is OK and says nothing about a "wear-in" period.
    The current theory is that modern cars are made to closer tolerances and don't need to wear in - no need for ring scuffing or whatever.
  • theracoontheracoon Member Posts: 666
    It should have a section on Break-In that suggests avoiding the following: full-throttle starts and rapid acceleration (for the first 600 miles), hard braking (200 miles), and don't change the oil before the first recommended oil change listed in the maintenance schedule (5,000/10,000 miles for newer Hondas).
    The owners site also mentions that a special oil is used from the factory, which helps break in the engine. So the first oil change should be delayed as long as possible (within schedule guidelines). There is no mention of any impact on the break in procedures listed in the owners manual.
    I plan to take mine in around 7K for the first oil change.
  • got_vtecgot_vtec Member Posts: 22
    I can't remember how many miles we got on them, but it was more than 30K (mentioned earlier) on the stock tires of our '99. Not a lot more than that, though!
    We replaced them with new car tires -- we don't take the 'V offroading, unless you are talking about dirt roads & driveways. They are much more quiet, and seem to have decent wet handling.
    Gary
  • carmineycarminey Member Posts: 1
    I am interested in buying a 2004 Honda CR-V LX AWD. Since the dealer did not have 2004 available, I test drove the 2003 LX AWD. It was a smooth ride and everything was going well, until...I tried to increase the speed from 25 mph to 40mph. While doing so, I had to press the gas pedal almost half way down and the rpm went to 4000 before the engine started to kick in and went up to 40mph. I came from a Honda family (we've owned an Odyssey, a Civic and an Accord), but I have never noticed that the gas pedal would have to be pressed half-way down in order to get to 40mph. Also, the pick-up power wasn't that great-not good for merging into highway traffic. Does anyone has similar experience, or did I happen to test drive a 'worn-out' demo unit. Thanks.
    I don't have problems merging from on-ramps, but you have to keep the engine at 3500 or higher RPM. At higher RPMs the engine will really move.
    My experience is that if you get the engine in the range of about 2500 RPM, it can require that you floor the accelerator before the engine will downshift and start moving. I find it most noticeable on the freeway at about 60 MPH when I want to pass.
    I also notice that when on cruise control, the engine will allow a loss of 2 MPH before kicking into a lower gear.
  • kentkmokkentkmok Member Posts: 27
    The acceleration of my 2003 CRV LX wasn't that impressive either, although I don't have problem merging to the freeway.
    There is one thing I don't understand though. The weight and drag ratio of 2003 CRV (3201 lb)is about the same as the new Accord (3113 lb), and they have the same engine. But the CRV doesn't nearly have as much pick up as the Accord (my girlfriend has one and I drive it occasionally)... any thought?
  • banddexpressbanddexpress Member Posts: 63
    Just got a 03 crv black sure it will get dirty but it sure looks sharp. I was just wondering it said I should of got a card with the radio code on it for anti theft I never got one that I know of. Could someone please tell me where is the card located at? I might have it but amongst all the paper work I could just be overlooking it. Thanks Brent
  • gary_williamgary_william Member Posts: 52
    check in the coin holder to the left side of the dash board. Mine was there. If not, look in the user's manual in the back.
    It was in the coin holder. Alot of different little storage areas to get used to. Also I was wondering the dealership recomends you change the oil every 3k but the warranty book says 5k or 6 months I was just wondering as long as you do what the book tells you to I'm sure you won't void the warranty but again I would like the crv to get 150-200k miles on it I was just wondering what everyone thinks about changing your oil.
    Brent
    I just traded in a 98 Odyssey with the 2.3L engine. I always used the synthetic oil after the first oil change and will do the same on a new CRV. I typically ran the oil 8-9K miles. Since I changed it myself, I figure I have to crawl under the car 1/2 the number of times. At 115K miles, that engine was perfect. In summary, to me synthetic oil simply cuts the # of changes in half and therefore costs the same as conventional oil.
    Carminey - Take a few more test drives. As you get more accustomed to the CR-V's combination of gearing and engine output, you'll learn how it make it move without much fuss.
    Kentmonk - The CR-V and Accord do, in fact, have different engines. The power curve for the Accord (and Element) is stronger through the lowest rpms. At around 2,700 rpms, the CR-V takes the lead, providing more oomph through the mid-range. Combine that with different transmission ratios and you get the reason for what you've felt.
  • gringo1gringo1 Member Posts: 72
    We live in a high crime area for stolen vehicles and have learned it is best to have a kill switch installed on most vehicles.
    We just bought a new 03 EX CRV and were told by the dealer that the ignition keys have sensors/chips inside them that an engine module reads and verifies before it will allow the engine to start.
    My question: is a kill switch still a good idea or is it superfluous?
  • richardwsrichardws Member Posts: 1
    tpanni
    If you look in your manual it will recommend 7500 mile oil changes. It will say synthetic is OK
    1st--
    Honda engine break in period is not really a factor. Of course the engine sets itself in as it is used. But dont be afraid of going 80 mph on the freeway when it has 2 miles on the car. The only break-in period is to not have your first oil change before 4K miles due to an agent in the factory oil that should be kept in the engine just a little bit longer.
    Honda is basically my life right now. I am dedicating all of my efforts and all of my desires and determinations into the product that I sell, so I spend a great deal of time in my shop, with my mechanics, and my cars.
    NOW--
    The way that I see it, Honda & Toyota are constantly battling over "bragging rights" for which vehicle has the best maintenance schedule, and that sometimes both are a little over zealous
    The fact is however that the cars that they make nowadays can get by with 10K oil changes, but I know that would minimize the cars life by many years and many miles
    (I get the feeling that I wish that you had a better salesman.)
    My point is that aside from your first oil change (which should be done @ around the 4K mark) you should religiously change your oil @ 3000 to 3500 mile intervals. Ask any mechanic: the oil is much cleaner at 3000 than at 6K or 10K mile oil changes
    As for synthetic, it is not recommended. The reason for that is...
    Hondas are built specifically for regular oil (and you can always view the appropriate weight on you oil cap). Also you should not use a higher grade of gasoline - use the regular grade 87 octane. That is what they are specifically built for. If you do not like that recommendation, it is your car and you can do as you please with your investment. But I recommend that you trade in your Honda for an Acura or better yet a BMW. The only reason that you should use a higher octane with a current model Honda is if you are towing something (or if you own a S2000).
    The point is just the point: Hondas have a lower cost of ownership. Keep the costs as low as possible, and take advantage of your investment. In my opinion, the CR-V is the best deal that we have available, for all that you get for what you spend, and the cost of ownership (which is what you should really be looking at no matter what you consider buying) is so much less than anything else that is close to it
    My best wishes
    Respectfully,
    RS
    The normal service interval is now 10,000 miles.. thats from the owners manual.. If you follow the severe service schedule, its 5000 miles. I used to change the oil every 3750 to stay on the 7500 interval, but now that I have the '02 CRV, I change every 5000, so I can stay on the 10K interval. I could probably go with every 10K on the oil changes, but I was brought up on every 3000 miles, and its all I can do to move to 5K.
    regards,
    kyfdx
  • bamacarbamacar Member Posts: 749
    I too change my oil in our Hondas at 5000 intervals. Hard to convince myself to push it out further. As Honda has designed their engines to go further, and we should be keeping the ownership costs down changing oil at 3000 is just overkill and wasteful. I would love to see a study of engines changed at 3000 and 5000 intervals; I don't believe there would be any difference in engine life. Probably true at 7500, but I am not convinced yet. Also appearance of oil, though fun to look at, means very little. If it is doing its lubrication job it is fine- ugly or not.
    My girlfriend just bought an 03 CRV and is now back in Mexico where car theft is common.
    From my msg above, what do you think about the necessity of putting in a kill switch?
    Or is the ignition key security accomplishing the same thing?
    "But I recommend that you trade in your Honda for an Acura or better yet a BMW."
    so it's ok to put synthetic in an Acura, but not a Honda? Honda designed the engine to operate with conventional oil as the baseline. That doesn't mean the engine wouldn't last longer or provide better gas mileage with synthetic oil.
    There are advantages to synthetic oil, and there is the disadvantage that it costs more. If you do the math, it doesn't cost much more, though. I think it's well worth the money, though I agree with you to use 87 octane in the CRV.
    My 96 Altima has been using Mobil 1 since 20k miles and it has 145k on it now. The CRV has ~30k, and I'll switch it over next change.
  • gerry100gerry100 Member Posts: 100
    As background my wife and I just bought a CRV for it's utility and low cost per mile.
    I generally drive company cars supplied by a lease company thet handles large numbers of a wide variety of vehicles. For them the rule is 5k miles when they pay for the changes.
    Obviously they've determined that following the 7500mile recommendations costs them in the long run and that the 3000 miles costs in the short run and is overkill.
