Can you say if the fires were related to that recall that we suspected earlier?
-juice
"All I am trying to do is have honda admit it was a defect." - Sabrina
Can you tell us what the defect is?
This is a kind of 'logical doldrums' /Catch-22 situation, which lawyers know how to handle:
First look for a party with a deepest pocket and then find a 'defect'.
Also, I don't have access to Honda's files on their investigations (they still haven't even given me mine). If they know the cause they ain't telling me
Is there a "defect" or enough of a suspicion of a defect someone can absolutely point to? That is for the judge to decide. I'm not NASA. The car is a melted wreck and the o/c was not out of the ordinary.
In 2002, 2001 CRV's, the NHTSA website has no fire complaints. For the 2003's there are two (one is mine)which are very similar. That seems like a big increase, no? No matter what the problem, seems like Honda should spend some time on this - perhaps asking me what happened might be a good start.
Is it possible Honda isn't looking hard enough? They got the engineers and the technicians.
I really am sorry I can't say more. I have nothing against Honda. I would not even have gone this far if they just gave me the new vehicle under warranty. I have never asked for anything more than to be whole.
This is not to say that there wasn't a defect in your particular CR-V. I'm not taking a position on your case - it sure sounds like someone is at fault. But Honda is wise to ensure that it was their defect and not the dealer's (or someone else's) fault before electing to provide a new vehicle under warranty.
encountered.
- quote from autos.yahoo.com
http://autos.yahoo.com/newcars/d/honda03crv/lx2wd4spdat/trim_spec- s.html?content=specs&refsrc=autos/trim_overview
(2) Is the CR-V engine interference-type (valves can hit pistons if timing belt/chain breaks) or noninterference-type?
For the 2002 calendar year, Honda sold 146,266 units.
For 2003 (so far), Honda has sold 132,575 units.
I don't mean to assume, but if you are asking for the purpose of comparing sales figures to fire incidents, it comes out to about .00000717254%.
I believe that most Honda engines use interference valves. I know that the old model does. The new CR-V uses a timing chain, btw.
Both my car and the other one came from UK plant
Both were EX's
Both were subject to the same recall.
Both had identical or near identical issues. (the other car had less mileage than mine).
I know this because I received the full report from the NHTSA
By way of comparison, Honda just recently recalled 652,000 cars for an ignition switch. Know how many crashes there were? Try 28. There were about 150 complaints, but don't forget this recall involved a wear issue that spanned many model years (therefore older models may skew the results). I wonder how many complaints/crashes came from 02's? - probably not alot, but they were still recalled because they had potential problems. That is not much different, satistically speaking than the number you mentioned, especially if you take it down by plant (which probably produced only 65,000 or about half).
Also, is it me, or did you misplace a decimal. I think it is .0014%, but I could be wrong. PLUS not everyone reports to the NHTSA (in fact I would never have if the car was replaced under warranty). If we just assumed the UK plant made half, now we are up to 0.0028%. That may not be a lot if you are talking about broken door latches or mirrors falling off or something, but considering we are talking about spontaneous combustion (and I do mean spontaneous), I would think 2 is not a little number and is well within the percentages for taking the problem seriously, not fluffing it off. I would think the first few cars that went out of park probably had a few doubters too.
Again, I hold no grudge. But the way this was handled was atrocious.
I imagine that if they find a major problem in manufacture or design that causes a fire, they would issue the recall immediately.
That said, I hope your situation comes out in your favor. Please let us know when the culprit is identified.
But that doesn't let Honda off the hook. Certainly it is a more difficult investigation and it may take a different type of "investigation" then they traditionally do - more than just taking some pictures. No investigator ever interviewd me and they came to their "conclusion" extremely quick given the circumstances.
Brand new car (and someone elses) erupts into flames with absolutely no warning and they start reading the fine print. Doesn't sit well with me, sorry. Not after being a 20 year customer. Including the Hindenburg, I have owned 5 new Hondas, with my family owning severl more. And I have been responsible for at least 3 people buying Hondas in the 6 months before the fire. If they won't take care of a loyal customer like me who should they take care of?
Should they recall every 03 CRV. Of course not, but I still say something's up. This is real small dollars for them and it just doesn't make sense.
To the best of my knowledge, there were no overt changes to the engine between 2002 and 2003. That's why I used the total sales for a sample population. That said. There could have been running changes. These are made whenever they find an issue, change from one supplier to another, or even alter the assembly process to speed things up. These types of changes might be made two or three times a calendar year and have nothing to do with the model year. So... we really don't have any clue what the total number of vehicles affected might be.
In fact, not only do we not know how many vehicles are affected, we also don't know what the defect is. We don't know if there is a defect, or if this was dealer error. We don't know if the vehicle was damaged or vandalized (unknown to you). We don't know if there are other reports that simply have not been reported to the NHTSA. We don't know what if this has happened in Europe, Australia, the Philipines, Singapore, Japan, China, or any of the other markets where the CR-V is sold.
Honestly. We don't know jack.
All we really know is that you had an upsetting ordeal. I think we're all very sad to be reading about it. It's certainly something that we'll keep an eye on.
Think about it this way. If a manufacturer denies a problem and the NHTSA issues a recall. The manufacturer can no longer sell that particular vehicle in the USA. Not until the problem is fixed. Trust me. That would be bad. The NHTSA does not design fixes. So, working with the NHTSA on the issue, and learning as much as possible, is the best way for the manufacturer to develop a fix for the issue BEOFRE a recall is issued.
If you think that Honda is slow to react to a problem, ask the owners of early 2002 models. They may have had their cars towed from their driveways or places of work as Honda addressed the seatbelt recall tht was issued in the first few months of sales.
Maybe I'm wrong, but they definitely have a different feel to the after sale service than other brands I have owned in the past...
"Sue the party who has the report and will not release it!" - Andreaplume
Sue them for what?!?!
This was a small Toyota and cause of the fire was electrical (owner just started the engine in the cold weather).
Fire truck came within 5 minutes (!) and stopped the fire.
How many vehicles were involved in that recall? I think that really narrows it down a lot.
-juice
Sorry, personal beef there, since I went to Edmunds Live in 2000 and that "stop sale" also meant I could not even test drive one at that event.
-juice
As long as we're talking about the Escape... The NHTSA seems to have a pretty firm definition of what constitutes a "safety-related" defect as well. It was well documented that several models of the Escape and Tribute would stall without warning. Many thought that this should be addressed with a recall, but all the fixes that were issued were done as TSBs.
The PR machine is working over time. My wife is in PR so I'm allowed to say that. I remember a recall where an automaker had an accelerator that could stick in the full open position. Their spin was that it could "increase stopping distances". LOL
That's why NHTSA is around, as a reality check. They'd say something like it could cause the driver to lose control and crash the vehicle.
-juice
Kizhe: You mean to tell me a fire happened this MORNING and it was already suspected electrical. Need those people to work for Honda. In two months I can't even get them to admit they sell CRV's (what type of cars we sell is proprietarty, sorry).LOL.
Kidding aside, can someone explain to me how an electrical problem actually causes a fire in a car. I understand in a house, but are we talking about bascally an overheated wire that burns through its insulation, then the spark ignites something else. Since most of the engine area is metal, what exactly fuels the fire? I understand how a house wire overheats, but assuming no changes by the owner, how does a car wire overheat, especially, in the case Kizhe saw, the car had just been started? Are we talking radio wires, defroster wires, that type of thing.
That's why the theory that the dealer's mechanic made a mistake with the oil change makes the most sense to me.
I would not be surprised if we later see a TSB with special instructions for that recall, to at least clean/inspect a certain area for potential fires.
-juice
There are too many lawyers in this world. Ya gotta figure Honda would be more forthcoming if they didn't have to CTA. Is the vehicle still around? Could you go to the local fire department and slide one of their inspectors a little cabbage to look it over?
And I thought my Maytag Neptune was a nightmare.
I'm trying to come up with an example. Subaru issued one for installing new wheel bearings on Foresters because dealers were overtorqueing them, and they'd fail a 2nd time.
TSBs are issued for things as simple as additions to the owner's manual, even.
-juice
1) Buyer purchases NEW CRV thru Honda,
2) Buyer purchases warranty thru Honda,
3) Buyers car catches fire,
4) Honda Dealer takes possesion of buyers car,
5) Buyer says warranty should cover repair or replacement of CRV,
6) Dealer/Honda refute warranty claim stating cause of fire is not covered under warranty,
7) Dealer/Honda will not release cause of fire,
8) Dealer indirectly works for Honda Corp,
8) I say sue Honda
Honda must determine if whatever caused the fire was covered under the warranty...afterall it is their warranty. However, the buyer should not be expected to simply take Honda Corps word...'Well we won't tell you what caused the fire but rest assured it's not covered under your warranty'....who in their right mind would accept that!
Sabrina alludes to the fact that if the fire was 'covered' she would be entitled to a 'repair' or 'replacement' What that replacement would be can be argued later.
It is unfair for Honda NOT to release their report and thus the buyer suffers a depreciation and increased insurance premium loss.
Until proven otherwise, I say that Sabrina should sue to get whatever the value is of:
what her warranty stated would be covered +
whatever increased insurance premiums she pays until the issue is resolved less whatever the insurance has already paid her.
The ball is in Hondas court. If her fire was 'covered' she is out (monetarily) only the aggravation and emotional distress of the event. To prove the 'fire' was or was not covered she needs the report that is being withheld.
By the way, if Honda would show that the start of the fire was not due to a defect but rather to dealer service then I'd say move the lawsuit to the dealer.
Sorry but it sounds like Honda is covering either themselves or their dealer. I thought these games were only played with the domestics.
To be honest I like the CRV, as soon as the price comes down a bit (still selling at list where I am) I'd like to get one. I just keep hoping I see signs of Honda doing the right thing and resolving this issue....and if it turns out it's the dealers fault, Sabrinas fault or a freak accident....well at least we'd then ALL know and not be so suspicious!
used to say: "Two things you don't want to watch being made: sausages and laws".
I would add to this: "You don't want to watch when they service/fix your car"... :-)
That's why I always try to do it myself if I can.
And nobody watch me! :-)
'Honda must determine if whatever caused the fire was covered under the warranty..."
They did. No defect was found.
"However, the buyer should not be expected to simply take Honda Corps word."
If the buyer is not going to take Honda's word for it, what good is the report? You want to read, "no defect found", rather than hear it spoken? If they are going to lie about the results, why not lie on the report? If anything, the report is just going to make Honda's position look more official.
If the buyer chooses not to accept the manufacturer's investigation, the buyer can get a second opinion. The ball was in Sabrina's court. She dropped it. Or rather, she took the insurance company's money and passed the ball to them.
MODERATOR /ADMINISTRATOR
Review your vehicle
-juice
So did Honda determine the cause of the fire or not? Did perhaps Honda determined the dealer was at fault but rather than mention that fact they just said it was not a defect? The whole thing just sounds fishy...sorry but I think if they can not determine what caused the problem, they should say so. If they determined what caused the problem, they should say so. That is all..
I looked at a Pilot tonight....much nicer than I thought.
Let's say, COMPLETELY HYPOTHETICALLY (since it was raised), if the dealer did the o/c according to Honda training/specs, etc (or any other fix), and the fire or similar type catastropic problem happened. Do you think then it would be a Warranty claim or not? What if Honda then issues some TSB modifying the procedure as someone suggested? Would that change the answer.
Just wondering what people think. Again, this is hypothetical (at least at this time)
Bottom line, in situations like this, sabrina9 loses (as we know what she's going thru), the ins. companies lose because they will pay something, Honda loses 'cuz they're getting a black eye in this as well as the dealer is too.
So who makes out?........Lawyers.
Have you looked at the new 2004 RAV4 when you bought your CR-V? Any "features" that turned you off?
I've had great luck with both Toyota's and Honda's so I consider myself impartial. One main factor from me was the extra interior space the CRV offered. Check out KBB.com, then "Decision
Guide" on the left menu, then select "Side-by-Side Comparison". This lets you select and compare many detailed specs, dimensions, and features between up to 4 vehicle. You'll see some significant differences in rear seat leg room (like 5") and some front seat dimensions as well. The safety "Stars" rating is a bit better for the CRV also for what thats worth. Toyota options seem to realy add up costwise also these days as compared to the LX / EX packages Honda offers. Good Luck
How that would be settled could vary. The dealer may have to make reparations with you. Then go after Honda for reimbursement. Or it might just come down directly from Honda.
Tcpip1 - Depends. What are you going to use it for?
With all the lowering of MPG by Toyota, I suppose they NEED the high mileage of the Prius, otherwise their corporate fuel economy ratings would be in the toilet.
