KIDDING buddy. I'm right with ya on that one.
I will be glad to "follow you" in your Mazda. Where do we meet? That would be better than internet racing, or worse, pulling arguments out of thin air.
Eventually, I will let you follow me.
Alas, individual differences may also play a part, I wouldn't want to disadvantage the Accord any further with your driving :P
I will see if I can borrow the GPS tool from work - its kind of like one of those g-analyst things you see advertised in magazines.
Bench racing aside, I have gotten the '93 to go faster around the I94 to Michigan Ave cloverleaf than the '07, and I wasn't wrestling with it as much and it definitely didn't feel like the doorhandles were dragging. My '89 Galant did that, but at the time it was probably a good thing.
My 2004 6 had a trunk release on the fob and on the lower left (of the steering wheel) dash. I don't think they changed that for '05 so I'm not sure what you were missing.
The hatchback trunk was strange.... are all Mazda sedans equipped with the lifting rear window/trunk combo?
No. Only the hatchback model. The sedan has a regular trunk opening and the wagon has, well, a wagon hatch.
I mostly agree with your assessment of the engine too. I felt the V6 was a bit underpowered when paired with the ATX. However, when paired with the MTX, which I had, you are free to access the power, that doesn't come in until about 3500 RPMs as you stated, freely and then it really comes to life. Even with the lack of low end power it was always more than adequate to putz around town in. Drag racing required some high revving lauches though.
I think perhaps the hatchback and the wagon are missing a trunk/hatch release, while the sedan has the buttons on the key fob/remote and by the steering wheel...... I'm just assuming that's the difference that occurred, or did Mazda run out of trunk release buttons at the factory in 2005? :P
The hatchback model looks just like the sedan; doesn't it? It had a big spoiler and the ground effect aerodynamic trim too. All things I'd give up for 25 more HP.
I was a bit concerned at the interior scuffing and wear and tear shown on this 2 year old 36K mile vehicle from Mazda. I don't care if it was abused, it needs to handle the abuse better. It did seem as if the dealer kept it very clean too.
Personal attack? Huh? I was referring to your obvious slant (to be mild about it) towards Korean products. I've made pro-Honda/Nissan/Japanese assertions that have attracted similar respnses and don't go round with my feelings hurt.
I guess only the kumbaya comments are expected around here.
I thought the color was called "powder white pearl."
IIRC, the 5-door unlocks ALL the doors when the unlock button is pressed on the fob, including the hatch. I don't know why they don't have an interior release though. zzzoom6 can answer this one better than I can, since he's got the 5-door.
...Or driving a manual compared to the power-sapping slushbox. Trust me, the manual pulls nicely, without the need for 25 more HP on the freeway onramps.
The dealer can clean it as much as they want to, but it's still a rental, subject to much more wear-and-tear and abuse than what anyone would do to their own car. My '04, OTOH, is free of any scratches or blemishes on the dash and center console. The carpeting and the back seats look as good as new as well, even with all the abuse they get from my job (visiting construction sites, carrying equipment, etc.)
The only thing I'm not too thrilled about is the cloth seat material on the drivers seat. With only 57K miles on it, it looks worse than many cars with 100-150K miles on them. It's worn almost down to nothing. It's a common problem with the '03-'05 models, and the '06-up material was changed with the seat redesign, with no significant complaints since.
The auto slushbox has 6 gears to work with, so it should be a good slushbox and not saap too much power. Too bad they don't have manual tranny rental/loaners.
Pretty much, yes. The hatch has a slightly longer C pillar and shorter trunk lid. The big giveaway is the rear wiper on the hatch which the sedan does not have either.
I think the acceleration of my 6 is also about the same as the manual contour...both were measured at around 9.5 sec. for 0-60, IIRC. To me, this is adequate. Of course, a manual in the 6 would be faster...depending on driver skill.
Once upon a time, I bought a manual Voyager to get 5 gears, instead of 3 and 5 mpg better gas highway mileage. Also once upon a time, I felt power of 4 cylinders was always inadequate with an automatic.
What changed your opinion?
More power, more efficient automatic trannys?
But, 5% on EPA mode is barely 1 mpg on a car getting 20 mpg, so it seems negligible. This is besides the fact that EPA mode is a bit too standardized to see the impact of power, and driving style. The latter will largely dictate real world fuel economy but can’t be standardized in any other way. However, a driver has better chance to improve fuel economy with manual transmission (beyond that 5% increased efficiency) than with automatic.
Some newer automatics are closing the gap, however. For example, by getting rid of torque converter as in Antonov design, efficiency is improved, and as a result, fuel economy (Honda Civic’s i-Shift 6-speed automatic in Europe is designed around this premise).
Yep.
Perhaps, but there is also a chance that instead one will drive in a way that gets worse mileage. I know that is likely the case with me, I can't see the point in a manual if I'm gonna baby the trottle and shift at 2000 rpm.
In addition, these days the top gear in a 5 (or more) speed automatic usually has a higher ratio than the manual...which should mean the auto should be more efficient when in locked up mode. That was another reason for my switch...I believe Mazda6 manual runs at about 25% higher rpm than the auto in top gear.
When I had a manual, I sure was never driving around at 1500-2000 rpm, like the auto is at steady lower speeds.
They don't necessarily show their advantage on EPA cycle (which goes largely by set acceleration pace for ALL cars and regardless of gearbox type).
That is usually the case with most cars. But the reason generally is that MTs are typically designed with performance in mind, and have shorter low gears. And with limited gear span, they end up having shorter top gear too. OTOH, check out BMW's SMG. It has 7-speeds, and one of the shortest geared transmission you can find in the market with a top gear overall drive ratio of ~3.00:1 (and that, while being mated to a V10).
The 2009 Sonata will be available around March for Sale.
Some of the highlights include.
*Azera lookin front end
*Horsepower increase for both 4cyl and V6
*Improved fuel economy for both engines
*5 speed auto trans for 4cyl
*Blue background dashboard lights
*Improved handling and ride
*Specific sport handling for SE model
*Redone interior featuring, more storage,better finish,less plastic looking
*USB port and i-pod jack
*Exhaust tuned for performance sound
I have a 2005 Mazda6 i 5-door manual, and I got 30.5 mpg's going 80mph. I just had a trip to upstate NY, and got 470 miles on 15.4 gallons of gas. A/C was on for the majority too. I'm quite happy, I must say, considering the sticker said 31 mpg's.
* Nice side profile. The big grille doesn't look so bad on a black car, but I still haven't warmed up to it. Alloys are a little elaborate for my taste, but are not bad looking.
* Very comfortable driver's seat, nice fat leather steering wheel, Civic-like spoke design. Gauges light up on entry--looks OK (even with plain white backlighting), but I'm wondering... why?
* Center stack is a maze of small dark buttons, set close together, and one big dial. Not my preference for controls, but maybe other folks love all the buttons. The buttons have a solid feel--not sure why others have reported they feel cheap.
* Fat leather-covered armrest, slides fore and aft.
* The silver-colored plastic trim doesn't look worthy of a $31,000 car. Looks more like something I'd expect in a Chevy or Dodge. At least it breaks up the otherwise all-black interior. I know some people like black interiors, but it seemed too tomb-like to me.
* The back seat didn't seem any roomier than the 2007 model, but I wasn't able to take advantage of the extra width. Knee room is fine (I'm 5'10"), but there's a big problem in the back: toe room is very tight under the front seats, to the point where I couldn't stretch out my legs to take advantage of the knee space and thus my thighs were not well supported. That makes the back seat OK only for kids and short adults. There's a center armrest in the back, with a cheap-looking one-piece plastic cupholder--no lid, no grippers, just two holes.
* Overall the interior quality seems pretty good, except for sharp flashing on the tops of the door bins. Also, the black leather is stiff; it seemed more "buttery" on older Accords. Maybe it will wear well.
* The trunk is fairly small for the class and is hampered by hinges that take up trunk space (odd that there aren't struts on a $31k car) and a floor that isn't flat--it bulges up around the wheel housings. It's nicely lined, though.
Just based on sitting in the car, I was not impressed. For a car that list for over $30k, I expected more. Maybe it was the black interior; perhaps the tan leather would look richer. I also expected better rear-seat accomodations given the size of the car, and its price.
So other than great mileage, how did you like the car?
ahh, the power of advertising - while it is true that Mazdas 'feel' (and to some look) sportier than the other cars in this group, they are very behind, FE and power wise. Part of being 'Fordified' I guess because the leaders in the 'green' dept come from elsewhere as well. IMO, Mazda would and could build a more competitive car without Dearborn bringing them down.
Ford has consistently been the leader in emissions thanks to Bill Ford. Ford has more PZEV vehicles in California than any other mfr. There are different definitions for being "green" - it's not just FE.
Accord and Civic have very different spoke design on the steering wheel, unless you're comparing coupe to coupe (even they are different).
It was odd for me to see hinges (as opposed to struts) in some luxury cars, and I gave it some thought. I can see two reasons:
- Hinges last forever (struts can go bad)
- Hinges are easier to operate (struts make the trunk lid operation stiffer), and perhaps also a reason I saw its use in some luxury cars with power trunk option.
Let me guess... you were expecting a boat load of wood trim. :P
One reason you didn't mention is that a couple of pieces of metal (hinges) are cheaper to make than two hydraulic struts (decontenting). I can't imagine any part "going bad" on an Accord, can you?
Actually I think the wood trim on the new Accord is overdone, i.e. too much on the doors. But IMO tan leather and some color variation in a cabin can look richer than all-black.
Me too. In fact, the shift-knob and the steering-wheel instantly reminded me of my dad's 2007 Civic Sedan.
Ha, wouldn't they have to have the content (struts) in the first place in order to DEcontent?
Exactly. Not only did Ford ignore FE to focus on emissions (pun intended) - they never advertised their emissions leadership. I think old Billy just did it to make himself feel good. At one time a 4.0L Explorer had lower emissions than a Prius. But nobody outside of a few Ford enthusiasts know about it.
That's all changed now as evidenced with the Taurus. I expect similar gains as the new engines are rolled out across the board and tuned.
You were claiming the spoke design was similar. Now I guess it is about use of silver trim which probably serves a purpose against the "stark" black trimmings something you complained about earlier. But if you want to talk about silvery trim, Civic wasn't the first to have it. In fact, Accord sedan's steering wheel (design and trimming) resembles this more...
And that is from 2003 Pilot. So, when should we expect the Civic-like silvery trim to make it into Sonata?
As for hinges versus struts, the idea is to minimize "breaking points". Keeping it simple works better, at least in my opinion. If you haven't figured it out, don't worry, it ain't the end of the world.
I love the car. It handles better then most mid-sized sedans. Reliability has been great, no repairs of any kind. I currently have 35K on it.
I do think Mazda's could be more fuel effeciant, although, I will not complain about the gas mileage. The reason why the 2.3L Mazda6 is only rated at 31 highway is because of the way it is geared. At 70mph, the engine is turning about 3,200 RPM's, and at 80mph, it is turning 3,500 RPM's. I suspect with a higher top end gear ratio, the highway fuel economy would be better. However, Mazda chose a lower gearing because even in top gear, the engine is right in the power band, and can easily gain speed. That is the Zoom-Zoom way. Mazda engineers their vehicles to perform. They do not advertise fuel economy as their main attraction, like Honda does. Mazda promotes how much fun their vehicles are to drive. I would disagree that Mazda's are more econo/green then Zoom-Zoom.
My Mazda6 is also a PZEV. Totally green? No, but darn close. Mazda's are not bad for the environment.
Ford is not holding Mazda down in terms of what they are building. Take a look at what they offer, and then take a look at what Ford offers. No comparison.
Is the Mazda6 more fuel efficant then Accord or Camry? No. Do Accord and Camry have driving dynamics like the Mazda6. No. I chose fun over a few MPG's. Bottom line, I love my Mazda6.
Yeah, that usually happens when a car that's essentially been out for SIX years is compared to models re-designed and re-engineered since then.
If it wasn't for Ford buying the 33.4% share in Mazda, I doubt Mazda would EXIST (let alone thrive) in 2007. Mazda has set personal sales records with both the 3 and 6 since being "Fordified", and there wouldn't be ANY V6 for the NA-market 6 without Ford.
Mazda may not be selling in CamCord territory, but they are quite possibly the ONLY division making $$$ for Ford.
And in terms of them being "competitive", that essentially means "dumbing-down" their product in order to appeal to the mass-market, and not the sporty crowd. I believe this move was tried in the mid-late '90s with the deceased 626, and that's what led them to a lack of sales (and Ford eventually bailing them out) in the first place.
Thanks for explaining Honda's strategy re minimizing breaking points, simple is better etc. That would explain why they made the 2-piece folding rear seat one piece for 2008. Also I guess it would explain why they went to a 5-speed automatic for 2003 rather than the 4-speed, because the 5-speed would be less likely to br... oh. Never mind.
