Visitor Agreement.
The manual is controlled by the driver, whatever gear he/she selects. If you down shift to 2nd instead of 4th, I don't think it's going to stop you (please correct me if I'm wrong, folks).
1st gear does has a mechanism to block down shifts to prevent over-revving, but I think that's the only one that does.
-juice
regards,
kyfdx
(still under 3500 RPM)
Some 6 speeds have very close gates, though. I'm sure missed shifts are more common.
Still, redline in 2nd is probably around 60mph or so, I think just above, so you'd have to be going pretty fast to do any harm.
-juice
I have my oil changed every 5k miles. I just put new tires.. upgrading to 16". Of all the vehicles I have owned... this is the best trouble free vehicle.
I bought my wife a 2004 Pilot on 12/24.. and is also a good choice. I have not driven it much, but plan to go to Phoenix next week.
regards,
kyfdx
As an afterthought, I checked the air cleaner last week and it was very dirty especially where it was exposed to the air inlet. I replaced the air filter and immediately noticed a smoother idle it was okay before but now its smoooooth. I will also keep track of my milage to see if the new filter helps.
Honda CR-V
Recently I changed my air filter too( @ 16K for the first time). Yes, it was dirty where it was exposed to the air inlet. I replaced the air filter but I did NOT notice a smoother idle or ride.
I used a purolater air cleaner as a replacement. What did you use? I noticed the OEM from Honda was built like a brick outhouse and had the spray gunk like K&N Filters. I did not price the honda air cleaner but I bet its expensive and I am going with the Purolator because I will change every 10K. Das Vedania .
must be something wrong with mine for sure!
Did not see Purolator - got no chance to compare.
And how could I compare anyway? We need, like, Consumer Report for that.
I believe 15K is a good time to change it
(manual gives us 30K ). What do you think?
How many miles have the rest of you put on your CR-Vs?
Also, since recalls are handled without a warranty, I wouldn't recommend getting the extended for those issues alone.
It is a hard decision. If you plan on keeping it for 100K, then it seems like a pretty decent value at $900-$1000. I have 26K on mine now, and due to the purchase of my wife's new car, I'm fairly certain I'll have mine until I die. I'm still mulling it over, but I think I'm going to buy the warranty before mine expires.
Does this help? I didn't think so.
regards,
kyfdx
Roadside assistance. If you get a 7 year extended warranty, you also get roadside assistance for the full 7 years. My dad renewed his, that alone costs $71 per year.
So if you had bought it up front that alone adds 7 * $71 = $497 value all by itself. Now if you get it you're only getting the 4 remaining years or $284 value. So it's harder to justify, but still might be worth it.
-juice
What about issues that may end up manifesting themselves as repairs that I have to pay for.
Truth be told, I probably won't get the warranty. I never have on previous vehicles. And I bought a Honda for the very reason that I could look forward to a long reliable service with it.
Thanks for the input.
I am happy (?) to report that my mileage increased to 25.1 MPG from 22.4 MPG the tank before. I believe this is solely due to the change in driving habits, as the miles and area driven and the weather were virtually the same as the week before. That is a 12% increase in MPG.
As noted before, I did stay under 65MPH for the entire tankful, with most of that under 60MPH. Also, I was able to stay under 3500 RPM, except for just two occasions the entire week, with almost all driving done under 3K RPM.
I know this isn't scientific, but I thought that was a pretty major increase, from just changing my own driving habits. I also run my tires at factory recommended 26 PSI, so I'm sure I could pickup a couple more MPG from going up to 32 PSI. That makes 27 MPG seem very achievable.
Just a personal observation.. From watching the gas gauge, it seems you can really get the MPG up at a steady 55MPH. If you are running errands around town, making frequent stops, etc, you really kill the mileage no matter how easy you are driving.
The only drawback to this, is now I feel guilty driving 75 MPH on the way to work. Wasting our natural resources, not to mention my financial resources. I'll try to get over it, though.. Next time I want to do this experiment, I'll trade cars with my wife for the week. She drives like Grandma, anyway.
regards,
kyfdx
Put those two together and mileage increases noticeably when you slow down a little on the highway.
-juice
A 12% increase in mpg at your controlled tire pressure of 26psi is quite good. And as you report, it indicates to me also, that the milage per gallon some people report is not bogus. Once again thanx and I know how you must have felt to try not to break the egg on the pedal
I really felt guilty when I hit 75 MPH this morning... Maybe the wife will let me drive her car this week...HMMMMM
regards,
kyfdx
My theory is that I am attempting to keep the VTEC from engaging by keeping lower RPMs. I'll start recording at my next fill up.
I'm not dissatisfied with my current 21 MPG in town, but it is the challenge of it all that inspires me. How high can we go?
Highest mpg: 31.2
Max range: 401 miles
And my averge MPG numbers match lsattle (although my highway numbers are slightly better), which is not surprizing since I live in Indiana and have similar weather cycles.
The EPA testing methodology has the driver shifting at a specific speed, rather than rpm. During their testing sticks that are geared low, may be revved higher than a driver would in the real world. Most drivers shift at a specific rpm (usually by the sound of the engine).
So... it looks like there is good reason to suspect that the EPA under-rated the 5 speed CR-V. Based on their own internal testing, Honda's original estimates for the G2 had both the 5 speed and auto getting the same mpg.
With that in mind, I've been keeping an eye on threads related to MPG (in several boards). It takes a while to see consistencies because 5 speeds are not common. So far, the impression I'm getting is that the 5 speeds match the automatics, but unlike the G1 models they do not exceed them.
We both purchased our CR-Vs in April of 1999, so we've both had them the same length of time.
I've driven about 91,000 miles over that period. You've driven less than me.
Speed is calculated by by using distance travelled over time. Since I've gone farther over the same amount of time, I must be going faster!
There you have it. Scientific proof that Silver CR-Vs are faster.
That might offset any losses from the torque converter.
-juice
Some V6 competitors have 2.9:1 gearing, it's how some V6s can manage 26mpg on the highway.
-juice
Automatic: 4.36
Manual: 4.562
Gen2
Automatic: 4.438
Manual: 4.765
True. I've just shy of 62,000 miles on my CR-V.
At least you got the formula correct. But let's talk about the numbers...
I really can only add this...
Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital. ~Aaron Levenstein
Torture numbers, and they'll confess to anything. ~Gregg Easterbrook
Unfortunately, mine also stopped very quickly.. with some outside help..
Hence, the reason I am now driving an '02.
regards,
kyfdx
-juice
When price of gas will reach 5 bucks per gallon
I bet all of us would like to have a smaller car with LESS powerful engine.
-juice
Sometimes a larger engine allows the computer to use higher torque in the lower RPM bands, resulting in higher MPG than a smaller engine in the same application.
Kizhe - Ditto. I need enough power to get the job done. I do not need to race from stop light to stop light at 60 mph, or be able to pass Bimmers on winding roads. The quest for ever-increasing power is one of my pet peeves. Especially when it cuts into something useful like fuel economy.
That said, I like the way some companies are doing things. A bump in power plus a bump in fuel economy is a win-win situation.
The 3.3L that Juice mentioned above is a great example. It gets terrific mpg and moves vehicles like the RX330 with plenty of oomph. On top of that, they are incorporating their hybrid system.
Honda is adding IMA to the V6 Accord later this year. They are also adding VCM (the engine shuts down 3 cylinders when cruising) to the same engine. More power and better fuel economy. Even without these advanced systems, each of Honda's most recent models has received boosts in both power and fuel economy over the model it replaces.
I'd love to see more, perhaps an MDX-H?
-juice
How many folks out there have opted for the re-usable K&N air filter for the CRV? This re-usable filter drops in the original housing and seems cost effective since even through mail order, the stock Honda air filter is $19. The 100,000 K&N filter (with cleaning)is only about $45. By the way, how do you clean those things anyway? Looks like a cleaning kit is needed?
