Search for real world and pose your question with specifics
Year, make, model, color, engine, tranny, service history, real condition wrt dents-dings-scratches, mileage, and of course city and state.
Honda CR-V Owners: Accessories & Modifications
I believe there are some posts there that would help.
Extended warranties: Sorry I missed the live chat last September. What was the consensus? I have an 04 LX, and got the 5yr/100K warranty ($0 deductible) for $950. If I act within 30 days, I can cancel it.
(now 21 days...)
The chances of needing the extended warranty are pretty small. Even you do need out of warranty repairs, $950 will probably cover it.
It's just 5 years, but still, that was $355 last time I checked (my dad renewed his after his warranty expired).
If that is something that you want, you're really only paying $595 for the warranty. Odds are one single repair and you'll break even.
Finally, let's say you sell it in 4.5 years and with 95k miles, you still have some warranty left. That gives the buyer peice of mind, surely it'll be a lot easier to re-sell, and might even add value.
So is it worth it? Only you can answer that.
-juice
(I already have roadside assistance with my car insurance. And it's financed sorta separate... it's tacked on to the end of my loan period. So if I cancel, my payment doesn't go down, but it's 3 months fewer payments)
Thanks again!
The plug "blew out" ??
O.K...assume the dealership mechanic failed to tighten it properly. This happens in the best of shops. In a perfect world, this would never, ever happen but it does.
I don't understand.
Toyota builds great cars and trucks. I think they are excellent and on a par with Honda.
They have recalls too. Not the end of the world.
And, they can leave drain plugs loose too.
Hopefully, all of your "problems" will be solved and you will be happy with your new ride!
I'm considering (but not likely) a CR-V because the price and value, but I don't want those problems.
Recommend driving the vehicle that you are going to purchase - take an extended drive if you have to to ensure the noise isn't present.
The whistle complaints are most likely due to faulty installation of a roof rack, which I don't have on my CR-V.
Rattles and squeeks seem to be on a vehicle by vehicle basis. Some have them. Others do not. Which is no different than any other car.
Whats the concensus on the board? Is everybody following the Honda recs and if so how long are the OEM Bridgestones lasting?
We don't offroad or tow, and have the vehicle as an economical,4wd to deal with around town in upstate NY.
Inputs appreciated.
I have test driven 3 cars from private parties (with 20K to 46K miles). On two of the vehicles the brake pedal feels like it is grinding and there is an audible noise. I like Honda very much, however this concerns me, especially after reading other CRV owners experiences listed here online.
Is it possible that the brakes are a weak spot or under engineered?
Thanks for your comments!
buyer
Pulsing means the rotors are warped.
Spongy pedal means the brake fluid is spent.
But grinding? That sounds bad. Could be something stuck in the brakes, a seized piston, or a broken hand brake, maybe?
-juice
I'm not saying that is what is happening on the used CRVs you are looking at, but it is possible. Do you notice the noise going away after the first few stops?
regards,
kyfdx
Just a thought.
-juice
Also, perhaps the threshold for ABS kicking in is lower than for RT4WD?
Either way, I wouldn't buy a car with brakes that were grinding. The mere fact that the owner ignored what could be a critical safety flaw tells you a lot about how it was taken care of.
-juice
But I agree... I wouldn't want a vehicle that had been neglected.
Kept the tire press at 30+,(well above the laughable 25 rec'd), but the 4 miles up and down our paved mtn road combined with several "brisk speed" long trips have done them in. Shopping hard on the TireRack and may go w/a set of ASA JS1s, 16x7,in place of the wheelbarrow wheels, and a set of 215/60-16s tires.
For a few bucks more they could of shod this thing w/16s up front,imo. NEway, that's my 2Cts. BR,md
My wife has a BMW 325i, and I was lurking on a BMW forum, and the posters were discussing upgrading from 17" to 18" or even 19" wheels. Even though they were keeping the same overall diameter (as you would be with 215/60-16), they kept saying how they needed to lower their cars. I asked why. With the thinner sidewall, it gives the appearance that there is a bigger gap between the top of the tire and the fender, even though it isn't. So, everyone that went with bigger wheels also lowered the suspension.
As I'm sure you are aware, that is probably what most people dislike about the looks of the CRV already. It seems to have too much space between the tires and the fenders. Even though your upgrade won't actually create any more space, it will appear to. That is what turned me off of doing it.
College Hills Honda recommends using 235/60-16 tires with the upgrade, mostly for looks. This will throw off your odometer and speedometer readings slightly, however.
regards,
kyfdx
Hopefully I could beat 35K expectancy of stock tires.
This is the first vehicle of mine that isn't an American made sedan...a totally different vehicle...and I think it is just terrific! My cousin bought one after driving mine!
Those Bridgestone Duelers are lousy tires, I've owned a set myself. I bet the BFGs are better. Is that what you have, kizhe?
kyfdx: Element fills up the wheel wells a little better, with 16"s and bigger tires. Those would look good on a CR-V, if they'd fit. It would be a little more than a Plus One.
-juice
regards,
kyfdx
I ended up doing a Plus One, but 10mm wider to a 225/60R16 tire. You get better tire selection in that size, IMHO.
I have 60k miles now, so the new tires already have more mileage than the original ones, and they have plenty of tread life remaining.
-juice
Even old dogs....
kyfdx
regards,
kyfdx
Most get about 30K out of the Bridgestones. The BFGs tend to last 40-60K. I got about 55K from my BFGs. The AquaTred IIIs I have on my CR-V now have another 40K on them and they look pretty good.
regards,
kyfdx
http://www.mlive.com/prnewswire/prnauto.ssf?/cgi-bin/stories.pl?A- CCT=mlive2.story&STORY=/www/story/04-01-2004/0002139222&E- DATE=
Has anyone had experience with this?
http://www.mlive.com/prnewswire/prnauto.ssf?/cgi-bin/stories.pl?A- CCT=mlive2.story&STORY=/www/story/03-30-2004/0002137007&E- DATE=
